Page 1 of 19 12311 ... LastLast
Results 1 to 10 of 185
Thread: HVAC IN HELL please save me from heat :-) 2010 B8
    May 2015
    Question HVAC IN HELL please save me from heat :-) 2010 B8
    Hey fellas-
    Im new to the forum but not the car world, I am extremely excited to have my VAGCOM finally but NEED HELP PLEASE!
    Ac is not working AT ALL.
    replaced the g395 pressure sensor (but wondering if they sent me a generic sensor and not a true oem, hence still getting the Implausible signal)
    When i ran the individual component checks, THE AC DID BLOW COLD WHEN THE N280 VALVE SAW CURRENT.
    Please please can anyone help?
    I know there is a TSB on this issue, which is what originally led me to change the pressure sensor.
    Also I did have the system pumped(not flushed just dumped) and refilled with the computerized machine to Audi specs.
    VCDS Version: Release 14.10.2 (x64)
    Data version: 20150311
    Saturday,30,May,2015,19:16:56:07369
    Chassis Type: FL (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
              72
    VIN: WAUEFAFL0AN047123   Mileage: 87960km-54655miles
    55-Headlight Range -- Status: Cannot be reached 1100
    Address 01: Engine (DL0MA-CAEB)       Labels: 06H-907-115-CAB.clb
       Component: 2.0l R4/4V TF H16 0001
       Revision: E1H16---
       Coding: 0104010A02070160
       Shop #: WSC 05136 444 12160
       VCID: 79F9A4A8F8C59BE9291-802C
    Readiness: 1110 0101
    Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
       Part No SW: 8K1 927 155 J    HW: 0AW 927 156 H
       Component: 0AW 20TAVSUSA H04 0003
       Revision: --H04---    Serial number: 0000000118
       Shop #: WSC 02145 785 00200
       ASAM Dataset: EV_TCMVL381 A02017
       ROD: EV_TCMVL381_AU48.rod
       VCID: 3B757EA0B27969F97BD-806E
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
       Part No SW: 8K0 907 379 BT    HW: 8K0 907 379 BT
       Component: ESP8 front    H04 0010
       Coding: 080D18
       Shop #: WSC 02391 823 56573
       VCID: 0C17ED7CAF579E41027-8059
                        Reset counter: 92
                        Mileage: 87961 km
                        Date: 2015.05.30
                        Time: 17:30:26
                        Hex Value: 0x0000
                        Hex Value: 0x0782
                        Hex Value: 0x0035
                        Hex Value: 0x4097
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
       Component: BCM2 1.1      H02 0327
       Coding: 090100
       Shop #: WSC 02399 823 56573
       VCID: 78FFA1ACCBCF82E156F-802D
       Subsystem 1 - Part No SW: 8T0 959 754 G    HW: 8T0 959 754 G
       Component: FBSAUDIB8 IDG  H61 0072
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0171
       Revision: C1000000    Serial number: 01150120101817
       Coding: 64102000
       VCID: 000FC94C931FCA216EF-8055
    00256 - A/C Pressure/Temperature Sensor (G395)
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 92
                        Mileage: 87962 km
                        Date: 2015.05.30
                        Time: 19:09:54
                        Temperature: 31.0°C
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 92
                        Mileage: 87962 km
                        Date: 2015.05.30
                        Time: 19:09:54
    00797 - Sunlight Photo Sensor (G107)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 92
                        Mileage: 87962 km
                        Date: 2015.05.30
                        Time: 19:09:55
                        Temperature: 33.0°C
                        Temperature: 31.0°C
                        Output: 300 W
                        Output: 300 W
    Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000559680
       Coding: 26001091063CAF010000080300003D0D0F1C520800010161000000
       VCID: 3C777DBCBF776EC1727-8069
       Component: WWS 140110  H06 0070
       Coding: 00FD11
       Component: RLS  H04 0003
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
                        Reset counter: 92
                        Mileage: 87960 km
                        Date: 2015.05.30
                        Time: 17:11:00
    02258 - Door Opener Transmitter
                        Reset counter: 92
                        Mileage: 87960 km
                        Date: 2015.05.30
                        Time: 17:11:00
    Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
       Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0070
       Revision: 11001001    Serial number: 51291001503758
       Coding: 200103
       VCID: 479D1250F6B13D19EF5-8012
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
       Component: AirbagVW-AU10 H39 0560
       Serial number: 003EGD05F4F%
       Shop #: WSC 02135 785 00200
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 428B0344D593183138B-8017
       Serial number: 5810000R0900005WDS
       Serial number: 6334MSME4E420E15H
       Serial number: 6344MSME4F32416CL
       Serial number: 6352QSME624C5322D
       Serial number: 6362QSME734B3A28Q
       Serial number: 63732SME5B4A0F067
       Serial number: 63832SME1B4A040E1
    Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
       Component: Lenks.Modul   H16 0014
       Revision: --------    Serial number: 90304JAI000DU
       Coding: 000036
       VCID: 3D7170B8A46D67C9459-8068
       Component: E221 - MFL  H02 0010
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 980 M    HW: 8K0 920 980 M
       Component: KOMBIINSTR.   H20 0255
       Revision: 00100000    Serial number: CIX33131A
       Coding: 8B1609000300D705020000
    Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
       Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0105
       Revision: EB800053    Serial number: 5300E101128020
       Coding: 00C303
       VCID: 52AB33040DF388B188B-8007
       Component: J367-BDM  H07 0170
                        Reset counter: 92
                        Mileage: 87962 km
                        Date: 2015.05.30
                        Time: 19:13:14
                        Bin. Bits:    10111
                        Voltage: 11.80 V
                        Count: 6
                        Bin. Bits:    10011
                        Time: 25.40 s
    Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000009905426
       Coding: 011C03204000410001
       VCID: 45811858CCBD2F091D9-8010
    Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0125749502
       Coding: 0106023A007A440400B0013200000000
       Component: GTO BF  H06 0050
       Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS045  H07 0041
    Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000009932986
       VCID: 4487055CC78716010A7-8011
       Revision: 00000003    Serial number: 00000000540912
       VCID: 3467559C9727A681BA7-8061
    Address 55: Headlight Range
       Part No SW: 4F0 035 082 A    HW: 4F0 035 082
       Component: Radio U SIRIU H45 0021
       Revision: AB001007    Serial number: 335AU0A7547550
       Coding: 020000020100000001
       VCID: 1D31903804AD07C9659-8048
    02246 - Loudspeaker; Center
                        Fault Status: 01101011
                        Reset counter: 92
                        Mileage: 87960 km
                        Date: 2015.05.30
                        Time: 17:07:44
                        Voltage: 11.80 V
    Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
       Part No SW: 8T1 035 664 B    HW: 8T1 035 664 B
       Component: H-BN-NA       H47 0042
       Revision: --------    Serial number: 490AW0A7543554
       Coding: 010200000006A1EF01000B0E000000030000
       VCID: 377D629086514D999F5-8062
       Subsystem 1 - Part No: 8R0 060 884 F
       Component: NAR 2009/2010  5304
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
       Component: E0380 Bedient  H08 0100
       Subsystem 4 - Part No: 8R0 906 961 A
       Component: CD-Database  1293
    Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000102685070
       Coding: 010C03204000210001
       VCID: 428B0344DD93183138B-8017
       Revision: --H03---    Serial number: 525PA8-J9Z90PW
       Coding: 1000006
       VCID: 387F61AC4B4F42E196F-806D
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000102685067
    End-------------------------(Elapsed Time: 03:11)--------------------------
  2. Likes Pinpointdiag liked this post
  3. #2
    Please post a complete Auto-Scan so people can see these issues in context.
    May 2015
    when i ran the individual component output tests, this is the one that would turn the Compressor on briefly and blow cold air for the 1st time since i have owned the car !
    as you can see, the current to it was going from 0 up to .7 and back to 0 constantly back and forward(not sure if that is how the output test works by sending signal then stopping then sending)
    [IMG][/IMG]
    [IMG][/IMG]
    Sounds to me like a weak battery is in history here....
    You have a COM error between the monitoring of the J519 watching the load circuit....... with load management override.
    Correct the voltages and communications and it should be okay.
    Check with meter or wiggle tests of the twisted pair between........ to gateway......verify via WD and with AID of VCDS advanced measuring blocks while logging!
  6. Likes B82010 liked this post
    May 2015
    thanks for the reply!
    I have NO idea what a lot of that means unfortunately, I just got my VAGCOM today, barely even know how to use it, certainly dont know yet how to do measuring blocks.
    What twisted pair are you speaking of?
    I tested the three wires from the Pressure sensor G395 to J519 and they read voltage, but multiple Audi techs told me a LIN based system is pointless to use a Multimeter on.
    So I am still stumped at this point as what I personally can do or try
    May 2015
    Others that threw these same codes, just changed their pressure sensors and fixed the issue. The TSB I followed said that is the number 1 reason for these codes and the no Compressor kicking on/no cold air.
    and/or the TSB mentions the LIN cable from G395 press sensor being cut and causing that, but I put a temporary jump wire from the Sensor to 1inch away from the j519 unit, and no luck (although i did not have vagcom then so maybe I had to erase the faults once the Jump wire was in?)
    You must get the repair manual ......
    Twisted pair means CAN/HIGH/LOW Network cable.
    You need to review WD in repair manual and observe the TSB, as well as general testing procedures.
    or seek a professionals aid and open wallet.
    The tool is not a substitute for not having the repair manual.........and jumping stuff out isn't advised because you are gonna have a bad time.
  10. Likes B82010 liked this post
  11. #8
    May 2015
    ty again for the fast reply man.
    Ross_tech said if no one could help me figure it out through these forums By Monday that I can call in and they will go over it with me to try and diagnose it. I will wait till then before I spend any more money on anything.
    I Bought a Genuine Audi manual, and all it shows is how to remove or replace things, does not have any wiring diagrams or testing procedures whatsoever which certainly pissed me off. That is how I learned about the TSB and the sensor and LIN wire issue.
    If there was a way that I could Use the VAGCOM to see if the Sensor was sending signal to the J519 unit, then I could cross off the sensor itself AND the LIN wire being an issue.
    I still have a strong feeling that it is the Sensor, I got it off Ebay and they said it was "Original Equipment" but when I showed it to the Audi tech he said it is just a generic company sensor...
  12. #9
    Oh boy FOD here we go..............
  13. #10
    Võru, Estonia
    Hey in this thread.
    Jack why are you suggesting checking can wires? Fault code just suggest to go to 0x09 and check 02.
    (For those who didn't understand: http://forums.ross-tech.com/showthre...ut-0x01-08-000 )
    Only weird issue is why isnt 55 - headlights range accessible.
    Output test window.
    One window shows specified amperage and second shows the actual amperage.
    The world is my oyster...
  14. Likes B82010 liked this post
