Results 1 to 9 of 9
Thread: Audi Q7 DPF regeneration
    New User
    May 2015
    I'm having some trouble regenerating my DPF on my 2008 Audi Q7 3.0L Diesel.
    I've seen a video on YouTube showing a Q5 having it's DPF regenned successfuly:
    So I thought it would work on my Q7 as the engine ID is practically the same. However, I am getting errors such as "redir labels fail" and "no documentation available".
    Is there something i'm missing, do I need to download a new labels file? My VCDS appears to be the newest available, it's official too, bought from a UK distributor.
    Here is the output from VCDS:
    Friday,29,May,2015,11:12:38:45112
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
    VIN: WAUZZZ4L88D059448   License Plate: MJ08 TYW
    Mileage: 94140km-58495mi   Repair Order:
    Chassis Type: 4L (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 34 42 46 47 4F 52 56
              61 62 6F 72 76
    VIN: WAUZZZ4L88D059448   Mileage: 94140km-58495miles
    Address 01: Engine (CAS)       Labels: Redir Fail!
       Part No SW: 4L1 910 401 D    HW: 4L0 907 401 A
       Component: 3.0TDI EDC17G100AG  0080
       Revision: --H01---    Serial number:
       Coding: 0121002C190F0168
       Shop #: WSC 00482 210 91427
       VCID: 24404D4BE76BC7012A7-8071
    009263 - Diesel Particulate Filter (Bank 1)
                   P242F - 001 - Restricted/Clogged - MIL ON
                        Fault Status: 11100001
                        Mileage: 94133 km
                        Date: 2015.05.27
                        Time: 10:50:37
                        (no units): 33.0
                        (no units): 39.5
                        Mileage: 840 km
                        (no units): 0.0
                        (no units): 24.0
    008194 - Particulate Trap Bank 1
                   P2002 - 008 - Efficiency Below Threshold
                        Mileage: 94133 km
                        Date: 2015.05.27
                        Time: 10:50:37
                        (no units): 33.0
                        (no units): 39.5
                        Mileage: 840 km
                        (no units): 0.0
                        (no units): 24.0
    001592 - Throttle Body Actuator Bank 1 (J338)
                   P0638 - 000 - Implausible Signal - MIL ON
                        Fault Status: 11100000
                        Mileage: 94133 km
                        Date: 2015.05.27
                        Time: 10:50:39
                        Lambda: 99.2 %
                        Temperature: 16.2°C
                        Temperature: 23.4°C
                        Lambda: 4.7 %
                        Voltage: 11.93 V
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
                   P2015 - 003 - Implausible Signal
                        Fault Status: 01100011
                        Mileage: 94148 km
                        Date: 2015.05.29
                        Time: 10:58:59
                        RPM: 1092 /min
                        Voltage: 11.25 V
                        Lambda: 0.0 %
                        Lambda: 0.0 %
                        Voltage: 0.540 V
                        Bin. Bits: 00000000
    Any help would be much appreciated, thanks!
    Except that the ECU in the video uses the UDS protocol for diagnostics and yours doesn't. That means procedures are completely different.
    I don't have a procedure for your engine handy, but I'm fairly confident you need to address the 001592/P0638 and 008213/P2015 codes before you will be able to run a successful regeneration in any case.
    New User
    May 2015
    is there even a way to do the regen for this particular model then?
    I've tried as per in the video and it doesn't work and i've also tried the coding II input (10016) and that didn't work either.
    Problem is even if I fix those errors you mention i'll still be stuck in limp mode.
    I'm confident there's a way to force a regen -- provided the soot loading isn't too high yet, and provided the other issues are dealt with first.
    Magdeburg, Germany
    What are your readings in MVB 104 and 107?
    New User
    May 2015
    here are the readings as requested, thanks
  7. #7
    Quote Originally Posted by winx1 View Post
    Is there even a way to do the regen for this particular model then?
    Yes there is way for regeneration on every Model.
    The problem is, as Uwe wrote, if you don't fix the error, you will not be able to do regeneration!
    The ash amount is 0.20 liter, maximum is 036 l (From the your screen shot).
    Soot amount calculated is 42.0 g and Soot amount measured is 37.0 g.
    The threshold of soot is 38.5 g (MWB 107.2) where you get:
    If you have 59.5 g in 104.2 you can buy a new filter, if you don't get below that value first!
    The procedure showed in the Video is okay, but if your button [Coding II-11] is not greyed out, you may have to use that with the login.
    Enough fuel in the tank, temperatures okay, all electrical consumers on.
    But as your ECU is not UDS, you start [Basic settings-04] and choose MWB 226 direct.
    When MWB 104.2 is above 31.5 g (in your case now, it varies in other cases) the engine will start a regeneration when conditions are correct while driving.
    PS. You have not registered the forum yet?
  8. Likes Zenerdiode liked this post
  9. #8
    New User
    May 2015
    thanks for the reply.
    So from what you are saying it is probably not the DPF that is causing the "limp mode" (power loss) but rather the Mass airflow/throttle body error?
    thanks
  10. #9
    New User
    May 2015
    I managed to start the test:
    But when I do full throttle:
    I've tried doing just the brake, brake and accelerator together all different sequences but it doesn't work
    any ideas?
    thanks
