Results 11 to 20 of 23
Thread: Audi A3 8V Hold assist enabling
    Quote Originally Posted by rajeevx5 View Post
    Thank you for your reply. I did try that code but it still didn't work. Hill hold assist is a different function to hold assist which im talking about. In the adaptations its called AUTO HOLD. That is what im trying to enable.
    rajeev: Thanks for the clarification. My bad- I was aware of the difference, it was just a problem getting my addled mind to sync with my fat fingers!!
    Anyhow - since our last exchange, my "deep-throat" source for these beguiling and rarely-seen numbers has again responded with yet more codes to add to my reference list.
    The additional codes for 03- ABS follow:
    • 11966
    • 37202
    • 31857
    • 28183
    • 44595
    • 24435
    • 15081
    • 18573
    I'm not sure which security codes align with which adaptation channels, but feel free to try them. Please share any of your findings with the rest of us
    Cheers
    PS:if Zloybob visits here - the information that you have provided is greatly appreciated. Many thanks for your generosity
  2. Likes rajeevx5 liked this post
  3. #12
    May 2015
    • 11966
    • 37202
    • 31857
    • 28183
    • 44595
    • 24435
    • 15081
    • 18573
    Cheers
    Thanks for all of those codes! Many people have been looking for these. Do you think if i try one after the other and trying to do the adaptation each time until it works will be safe? Is there any risks of locking my abs module by using these?
    Thank You
  4. #13
    This is gonna sound random, but do you have a battery charger?
    When trying various security access codes, one should beware of the following: Entering an unacceptable security access code will often put a control module in a state where it refuses to take any others (even a good one!) for a period of time, and the timer that counts down that period only runs when the ignition is on. So be prepared to let your car sit around with the ignition on for a good long time (an hour or more) any time you try a bad one.
  5. #14
    May 2015
    So each bad code means an hour wait? I think all these codes would be accepted its just knowing which code unlocks the adaptation that i want. Would putting good codes in successively lock the module out?
  6. #15
    I do not know how many bad codes you can enter before this particular module will penalize you with "Lock time" nor how long the lock time period will be. I'm just giving you a general warning about trying various security codes.
    I also don't know whether too many "good" (but not the one you're looking for) codes entered in succession will give you issues. My guess is trying good codes (i.e. ones that aren't outright rejected) probably won't cause issues if you cycle the ignition between codes.
  7. #16
    May 2015
    These codes are all accepted except for 44595 and 28183. But none of these codes can activate auto hold. Do you mind asking Zloybob what the code is for auto hold? Thank you
  8. #17
    Also there is an MWB in newer UDS controllers called:
    "Security Access: Number of invalid keys"
    That is increasing with the entering of a wrong secure code.
  9. Likes Uwe liked this post
  10. #18
    Verified VCDS User rlarsen's Avatar
    May 2015
    Copenhagen, Denmark
    What error do you get ??
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 20.4.1
    (HEX-V2)
  11. #19
    May 2015
    Quote Originally Posted by rlarsen View Post
    With the wrong code i get an error saying the control module refused the code. With a valid security code is says code accepted but when you go to change the auto hold functionality it come sup with an error message saying security access required.
  12. #20
    Oct 2015
    I just tried all of these codes in my 2016 A3 and had the exact same result as rajeevx5 - all but those 2 were accepted, none were the right code for AUTO HOLD adaptation. Tried them all with engine on, again with engine off.
    How do we figure this out??
