Thursday,21,May,2015,18:30:05:49923
VCDS Version: 15.5.0.0 (x64)
Data version: 20150510
Workshop Code: 123 12345 000001
VIN: WAUZZZ8K6EA017620   License Plate:
Chassis Type: 8K (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72
VIN: WAUZZZ8K6EA017620   Mileage: 52020km-32323miles
Address 01: Engine (J623-CJCD)       Labels: 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 SJ    HW: 03L 906 018 JL
   Component: R4 2,0L EDC   H25 5104
   Revision: 45H25---
   Coding: 12194012232401080000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TDI01103L906018SJ 003002
   ROD: EV_ECM20TDI01103L906018JK.rod
   VCID: 040DE56C8FD81C1FAB-8051
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.CLB
   Part No SW: 8K0 907 379 CE    HW: 8K0 907 379 CE
   Component: ESP8 front    H09 0050
   Coding: 161DCC01
   Shop #: WSC 06325 000 00000
   VCID: 7EF99784E93476CFFD-802B
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.CLB
   Part No SW: 8K0 907 064 GD    HW: 8K0 907 064 FD
   Component: BCM2 2.0      H12 0633
   Coding: 03A24040000000000000
   VCID: 78F5819CCB1048FFB7-802D
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
Address 08: Auto HVAC (J255)       Labels: NONE
   Part No SW: 8K1 820 043 AJ    HW: 8K1 820 043 AJ
   Revision: C1000000    Serial number: 01170620131859
   Coding: 342002E000
   VCID: 70E5B9BCA36010BF7F-8025
Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.CLB
   Revision: 08016001    Serial number: 00000628090301
   Coding: 260000108034AFC00081400300001D0D0F1C070826090201000008004400020100000024000000
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B
   Component: MITSUBA060613  H18 0461
   Coding: 004577
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Coding: 02005D
   Component: E1 - LDS  H03 0031
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003KFDB0BENO
   Coding: 30524435363030303030554A304C384B3053
   Shop #: WSC 49019 001 1048576
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 4895315CF370F87F07-801D
   Serial number: 6334MSME7B355530C
   Serial number: 6344MSME7934517BL
   Serial number: 6352QSME48341E72K
   Serial number: 6362QSME4333256CG
   Serial number: 63732SME0E32196E5
   Serial number: 63832SME0E321948+
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.CLB
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20130618001246
   Coding: 000017
   VCID: 4FA71A401E1E2F4746-801A
Address 17: Instruments (J285)       Labels: 8T0-920-XXX-17.CLB
   Part No SW: 8K0 920 932     HW: 8K0 920 932
   Component: KOMBIINSTR.   H35 0563
   Revision: 00500000    Serial number: WWD616D6E
   Coding: 13A4100003010008000000
   VCID: 6CDDADCC8F48F45F43-8039
Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.CLB
   Component: GW-BEM 4CAN-M H11 0056
   Revision: 1Y070028    Serial number: 2841Y1360401DB
   Coding: 80CF07FF00
   VCID: 4A910B54E57C0A6F11-801F
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.CLB
   Component: TSG FA        H02 0508
   Revision:             Serial number: 0000065008450
   Coding: 011C02204000410001
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Revision: 00001000    Serial number: 0012579151
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ROD: EV_RCEPSAU48X.rod
   VCID: 346D75AC9FF86C9F5B-8061
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.CLB
   Revision: 00002001    Serial number: 0308671092
   Coding: 0100062820B900408120023680000047
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.CLB
   Component: TSG BF        H02 0508
   Revision:             Serial number: 0000064604906
   VCID: 4E9907441914264F4D-801B
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 30000000067023
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 39734498B89A91F788-806C
Address 56: Radio (R)       Labels: REDIR FAIL!
   Part No SW: 4G0 035 056 J    HW: 4G0 035 056
   Component: Radio U STD   H60 0133
   Revision: AB001007    Serial number: 230FV0D2812828
   Coding: 010003020100000001
   VCID: 285591DC5B30187FE7-807D
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6XX-5F.CLB
   Part No SW: 8R1 035 670 F    HW: 8R1 035 670 C
   Component: H-BNT-EU      H46 0739
   Revision: --------    Serial number: 207F-0D7552373
   Coding: 0F0100010006A1ED01808B5E00000403040000000000000000
   VCID: 36694FA481847E8F65-8063
   Subsystem 1 - Part No: 8R0 060 884 BC
   Component: EUR 2013/2014  1603
   Component: DU7 High  H42 0104
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Component: CD-Database  5298
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.CLB
   Revision:             Serial number: 0000064525199
   Coding: 010C02204000210001
   VCID: 46893F64F164EE0FF5-8013
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.CLB
   Revision:             Serial number: 0000064525200
End---------------------(Elapsed Time: 11:50, Deb=2)-----------------------
