I've just installed an RNS 315 and MDI into my 2015 caddy.
All is working fine, but when I've done autoscan after it has a few faults.
I have 03138 on the 2E MDI and I have fault codes for rear speakers on 57 Navigation.
Obviously being a van I have no rear speakers.
I understand that I need to turn off the functions using long coding? Does anyone know how to solve the problem?
VCDS Version: Release 14.10.2 (x64)
Data version: 20150311
Saturday,09,May,2015,10:46:42:43045
Chassis Type: 2K (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 61 77
VIN: WV1ZZZ2KZFX065725 Mileage: 3020km-1876miles
Address 01: Engine (J623-CAYD) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 PD HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 6930
Revision: --H43--- Serial number: 00000000000000
Coding: 00114034032501080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023PD 003009
ROD: EV_ECM16TDI02103L906023FL.rod
VCID: 77D31B47CE6561995F5-8022
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: 433C400D092803FFC21202E6901EC091A1000020
Shop #: WSC 35110 377 00141
VCID: 04297C8B87B33A014A7-8051
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 DA HW: 7N0 907 426 DA
Component: AC Manuell H20 0707
Revision: 00001002
Coding: 0010004003
ROD: EV_ACManueBHBVW36X_SE36.rod
VCID: 76CD1643C96F1891443-8023
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 S HW: 5K0 937 086 S
Component: BCM PQ35 M+ 122 0174
Revision: BD122001
Coding: 491A583E8025F16A088800809000816403010C8842008060648087000041
VCID: 44A9BC8BC733FA010A7-8011
Subsystem 1 - Part No: 1T2 955 119 A
Component: Wischer 02101 26 0512
Coding: 009795
Subsystem 2 - Part No: 7N0 951 171 A
Component: DWA-Sensor 00 002 0206
Address 10: Park/Steer Assist (J446) Labels: 1Q0-919-475.clb
Part No SW: 2K0 919 475 HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0004
Revision: -------- Serial number: 32901428000341
Coding: 108001
ASAM Dataset: EV_EPHVA14VN3370000 001006
ROD: EV_EPHVA14VN3370000_VN35.rod
VCID: 70C1205BAB0B36A19EF-8025
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag01V H07 0013
Revision: -------- Serial number: 003HN00K059Y
Coding: 000000000000000000000000000000003156
ROD: EV_AirbaVW10BPAVN750_SK12.rod
VCID: 334BEF579A9D4DB9A3D-8066
Serial number: 3495RRB405732020F8BE
Serial number: 3505RRB401052Q32IGO7
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 BM HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20141021300486
Coding: 0082160000
ROD: EV_SMLSNGVOLWS.rod
VCID: 79D71D7FF87177E9291-802C
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Coding: 820000
Part No SW: 2K0 920 976 E HW: 2K0 920 976 E
Component: KOMBI H03 0905
Coding: 480A00
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AQ HW: 7N0 907 530 AL
Component: J533 Gateway H58 1653
Revision: H58 Serial number: 191014F1001128
Coding: 357401
VCID: 7F23F367EE5559D9175-802A
Component: IMMO H03 0905
VCID: 6AF532338DD7CC71D0B-803F
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Revision: A1001003 Serial number: 7666850364
Coding: 010100
VCID: 2B7BF7374AAD1579EBD-807E
03138 - Input AUX IN
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 144
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 2K0 035 279 A HW: 2K0 035 279 A
Component: RNS315-EU H85 0501
Serial number: VWZAZ2P0580298
Coding: 040004310400090000008000
ROD: EV_RNS315EUV2UDS.rod
VCID: 2871083B535B3E6106F-807D
Component: EUR_W_V7 0066
1048595 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
Reset counter: 144
Mileage: 3027 km
Date: 2015.05.09
Time: 10:11:59
1048596 - Rear Right Bass Speaker
B1067 13 [009] - Open Circuit
Reset counter: 144
Mileage: 3027 km
Date: 2015.05.09
Time: 10:11:59
1048599 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
Reset counter: 144
Mileage: 3027 km
Date: 2015.05.09
Time: 10:12:01
1048600 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
Reset counter: 144
Mileage: 3027 km
Date: 2015.05.09
Time: 10:12:01
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0131632
VCID: 48B1A8BB3B1BDE61E6F-801D
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
VCID: 3957DD7F70F1B7E9691-806C
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0131632
VCID: 47B3AB873605D119EF5-8012
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1653
Coding: 030F1859
VCID: 71C7255FA8013FA9911-8024
Component: J367-BDM H07 0180
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007666733865
Coding: 0A01010000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3C59C46BB7C382C1727-8069
End-------------------------(Elapsed Time: 02:04)--------------------------
