Results 1 to 10 of 12
Thread: Post up your scans please!
    If you have a HEX-NET and a Windows PC, we'd greatly appreciate it if you'd run two Auto-Scans and post 'em both, one with VCDS connected to the HEX-NET via USB and another with it connected via WiFi with the HEX-NET in Access Point mode. Of course, please make sure you're using the latest versions
    Don't post 'em here, start a new thread for each car please.
    I think we've made substantial progress over the last few weeks and we need to know what (if any) issues remain when using VCDS with a HEX-NET interface.
    Thanks!
  2. Likes Gary liked this post
  3. #2
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    I should have a HEX-NET in a few days. I have access to a 2014 Beetle, a 2004 Passat GLX and a 2006 Phaeton W12.
    For comparison, is it of any value to capture a third scan with my traditional HEX-USB+CAN?
    Yes, if you have one, there certainly is value in posting it as a "reference" scan. That allows us to use a file comparison program to look for minor
    FWIW, I expect the Beetle will work well, the Passat probably too, but the Phaeton may well have issues the HEX-NET.
    Bump for more scans with the just-published Codeblock 0.4019 and VCDS Beta 14.4.1
    Jun 2014
    Are you still looking for more comparison Scans? I will do it tonight on my '08 S6 if needed.
    Scans are always good. Of course, please make sure you use current versions of all software / firmware.
    NC USA
    Speaking of which, I'm desperately late in getting an updated set. Apologies.
    Hoping to do this week - we're closing a quarter over here and it's been a wee bit of chaos lately...
    2012 A8L 4.2 Oolong/Titanium. Premium, LED, Driver assist, Rear seat comfort, Dual pane, Alcantara, Panorama
  9. #8
    Verified VCDS User hans j's Avatar
    Mar 2014
    Utah
    This one that told me some ROD files were missing:
    Wednesday,02,September,2015,15:11:08:05734
    VCDS Version: 15.7.0.2 (x64)
    Data version: 20150820
    Dealer/Shop Name: Utah Imports hj
    VIN: WVGFF9BP3BD007202   License Plate:
    Mileage: 69222km-43012mi   Repair Order:
    Chassis Type: BP (7P6)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 65
              69 6D 72
    VIN: WVGFF9BP3BD007202   Mileage: 69222km-43012miles
    Address 01: Engine (J623-CGRA)       Labels: None
       Part No SW: 03H 906 023 B    HW: 03H 907 309
       Component: 3,6 FSI ULEV2 H15 8643
       Revision: M7H15---
       Coding: 002A0012433600000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM36FSI01103H906023B 002005
       ROD: EV_ECM36FSI01103H906023B.rod
       VCID: A15AA51AB0DF0C36FA-80F4
    5582 - Oil Pressure Switch for reduced Oil Pressure
              P164D 00 [032] - Malfunction
    14690 - Loading Mode active
              P169A 00 [032] - -
    7666 - EVAP System
    Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
       Part No SW: 0C8 927 750 A    HW: 0C8 927 750 A
       Component: AL1000 AISIN  001 1870
       Coding: 001368
       ASAM Dataset: EV_TCMAL991031 001001
       ROD: N/A
       VCID: AA484236CDE9CF6EAB-80FE
    No ASAM data for: "EV_TCMAL991031" ()
    Address 03: ABS Brakes (J104)       Labels: 7P0-907-379.clb
       Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
       Component: MK25A         H36 0418
       Revision: --------    Serial number: 411910010EC010
       Coding: 5B7613C34924255ADAF6C89392D4A4407700
       ASAM Dataset: EV_MK25AXT 007001
       ROD: EV_ESPMK25A01000.rod
       VCID: C592118A44B70016A6-8090
       Slave 1:
       Part No SW: 4H0 907 064 AK    HW: 4H0 907 064 AK
       Component: BCM2 2.0      H24 0217
       Coding: 09860000000000000000
       VCID: F2F89A562DB9C7AED3-80A6
       Subsystem 1 - Part No SW: 7P6 959 754 M    HW: 7P6 959 754 M
       Component: FBSTOUAREGIDG  H04 0051
       Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Component: J764 ELV MLB  H38 0044
    Address 08: Auto HVAC (J255)       Labels: 7P6-907-040.clb
       Part No SW: 7P6 907 040 AG    HW: 7P6 907 040 AG
       Component: Klima 2 Zonen H18 0613
       Coding: 4606200880
       ROD: N/A
       VCID: F9EAAD7A78CFB4F692-80AC
    No ASAM data for: "EV_AirCondiFront" ()
    15360256 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 63
                        Mileage: 66483 km
                        Date: 2015.08.18
                        Time: 14:50:54
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
       Part No SW: 4H0 907 063 L    HW: 4H0 907 063 D
       Component: BCM1 2.0      H12 0092
       Revision: 15012002    Serial number: 00000001053618
       Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
       VCID: B17A555AE83FBCB66A-80E4
       Component: WWS    110430  31  0020
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
       Component: RLFS  H09 0011
       Coding: 035223
       Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
       Component: E1 - LDS  H04 0031
       Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0020
    Address 10: Park/Steer Assist (J446)       Labels: 7P6-919-475.clb
       Part No SW: 7P6 919 475     HW: 7P6 919 475
       Component: PARKHILFE 8K  H03 0016
       Revision: --------    Serial number: 55901112001647
       Coding: 118501
       ASAM Dataset: EV_VW526ParkiAssis2 001008
       ROD: EV_VW526ParkiAssis2.rod
       VCID: D5B2C1CAB417B096D6-8080
       Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
       Component: VW10Airbag02D H05 0023
       Revision: --------    Serial number: 003JX002K0RI
       Coding: 000000000000000000000000000000003244
       ROD: EV_AirbaVW10BPAVW526.rod
       VCID: C09C009E5B95253E95-8094
       Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
       Component: BF-Gewichtss.  003 0005
       Serial number: 5850000R10B09024B2
       Serial number: 3575LRB404R0HM78D11B
       Serial number: 3585LRB404P0HM78E0DM
       Serial number: 3515RRB40570I70G394N
       Serial number: 3525RRB40550I70G90CR
       Serial number: 3555NRB405B0GR36DGOW
       Serial number: 3565NRB405B0GR365PMW
    Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
       Part No SW: 4H0 953 568 A    HW: 7P6 953 507
       Component: Lenks.Modul   H08 0007
       Revision: --------    Serial number: 90815KE20001F
       Coding: 000015
       Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
       Component: E221__MFL-TAS  H03 0027
    Address 17: Instruments (J285)       Labels: 7P6-920-xxx-17.clb
       Part No SW: 7P6 920 980 M    HW: 7P6 920 980 M
       Component: Kombi         H13 0239
       Revision: 11240062    Serial number: 658090511593038
       Coding: 8B6732022B00CF05020004
       ASAM Dataset: EV_KombiUDSRBVW526 001013
       ROD: EV_KombiUDSRBVW526.rod
       VCID: C690168679B10B0EAF-8092
       Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
       Component: GW-CAN-L-MOST H08 5202
       Revision: --------    Serial number: 00000000145245
       Coding: 0021032600
       ASAM Dataset: EV_GatewVW526UDS 001006
       ROD: EV_GatewUDS_VW52.rod
       VCID: B86C687E03456DFE2D-80EC
       Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
       Component: Batt_Sensor  H07 0140
       Serial number: 00000000005650393878
       Part No SW: 4H0 959 793 F    HW: 4H0 959 793 F
       Component: TSG FA        H07 0162
       Revision: --------    Serial number: 0000116218451
       Coding: 011D07200000453005080000
       VCID: BC64746E3F7D41DEC9-80E8
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0149433405
       Coding: 0186123A28B9500080B00620210000000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
       Component: GTO BT  H19 0059
       Component: TSG BF        H07 0162
       Revision: --------    Serial number: 0000115964630
       VCID: BB6677723A7346E6C0-80EE
    Address 53: Parking Brake (J540-)       Labels: 7P0-907-801.clb
       Part No SW: 7P0 907 801 E    HW: 7P0 907 801 E
       Component: EPB           H51 1100
       Revision: 00000000    Serial number: A11409001BF
       Coding: 01040000
       Shop #: WSC 40306 001 1048576
       ROD: EV_ParkbA7.rod
       VCID: B572614A1457909636-80E0
       Slave 3:
    0033 - Dynamic Start Assist Function Not Available
              C10DE 00 [008] -  -
                        Reset counter: 71
                        Mileage: 67228 km
                        Date: 2015.08.26
                        Time: 14:55:11
       Coding: 010A00010F000400
       ROD: N/A
       VCID: FCE4B46E77FD81DE89-80A8
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0001
       Coding: 130000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0001
       Coding: 130000
    No ASAM data for: "EV_HeadlRegulVWAFS" ()
       Part No SW: 4G0 035 082     HW: 4G0 035 082
       Component: Radio U SIRIU H51 0052
       Revision: AB001007    Serial number: 471E 0B7577036
       Coding: 020007020100000001
       VCID: DDA2D9EAC42768D69E-8088
    Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
       Part No SW: 7P6 035 664     HW: 7P6 035 664
       Component: H-BN-NA       H43 0170
       Revision: --------    Serial number: 445EX0B7514444
       Coding: 010200050040E1ED01022B0E00000003F0080101
       VCID: F5F2A14A5CD7D096F6-80A0
       Subsystem 1 - Part No: 8R0 060 884 P
       Component: NAR 2010  0407
       Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: DU8 SV Touch  H24 0045
       Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: CD-Database  1886
       Component: TSG HL        H09 0162
       Revision: --------    Serial number: 0000116084265
       Coding: 011C07200000253005080000
       VCID: BA68727635497FEEDB-80EE
       Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
       Component: RDKBERU25     H09 0008
       Serial number: 10000000029523
       ROD: N/A
       VCID: BF9E0362266B5AC6EC-80EA
    No ASAM data for: "EV_RDKBERU25" ()
    Address 69: Trailer (J345)       Labels: None
       Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
       Component: Anhaenger     H09 0110
       Revision: 5A001001    Serial number: 00000147065897
       Coding: 020D000000000000
    Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
       Part No SW: 7P6 959 107     HW: 7P6 959 107
       Component: HDSG-Modul    H10 0611
       Revision: 22010001    Serial number: 116100021
       Coding: 0533314003
       ASAM Dataset: EV_HeckkTouar 202135
       ROD: EV_HeckkTouar.rod
       Component: TSG HR        H09 0162
       Revision: --------    Serial number: 0000116085283
    End-------------------------(Elapsed Time: 02:39)--------------------------
  10. #9
    Check the UDS_EV folder please and look at the date stamp on the Chassis.clb file.
  11. #10
    Mar 2014
    Utah
    8/12/15 6:15 am
