How to... PR Codes.
victor35ma
Los Angeles CA.
C?ID=242342
Hello again, talking about "PR codes"? please help understand how to decode/understand this ones. of course in terms of how they are useful when it comes to insert (using VCDS) for isntance the engine/ABS coding. Any component...
All following pictures and auto scan came from the same vehicle.
Picture 1
the alpha-numbers in the red circle. how this can help me to decode any vehicle system coding ? it is only categorized as: Option.
Picture 2.
found it in the same car. is this a PR code sticker too?
Picture 3
from the valve cover.
Tuesday,24,March,2015,14:56:00:33623
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: 3VWGG71KX7M032686   License Plate: 5WFD887
Mileage: 88470mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWGG71KX7M032686   Mileage: 142380km-88470miles
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 Q    HW: 07K 906 032 Q
   Component: 2.5l R5/4V      G   9650
   Revision: --H01---    Serial number: VWZ7Z0F4483712
   Coding: 0000003
   VCID: 377D176B46CED3999F5-8062
001089 - EVAP Emission Control Sys
               P0441 - 001 - Incorrect Flow - MIL ON
                    Fault Status: 11100001
                    Fault Frequency: 71
                    Mileage: 129329 km
                    Time: 00:20:45
                    RPM: 690 /min
                    Load: 18.0 %
                    Temperature: 81.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.970 V
006481 - Radiator Fan 2 (V177)
               P1951 - 002 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 44
                    Mileage: 137202 km
                    Time: 02:54:08
                    RPM: 636 /min
                    Load: 24.3 %
                    Speed: 3.0 km/h
                    Temperature: 83.0°C
                    Temperature: 48.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.335 V
001152 - Coolant Fan Control Circuit 1
               P0480 - 004 - Electrical Malfunction - Intermittent
                    Fault Frequency: 19
                    Mileage: 141031 km
                    Time: 05:33:12
                    RPM: 1662 /min
                    Load: 18.4 %
                    Speed: 82.0 km/h
                    Temperature: 82.0°C
                    Temperature: 47.0°C
                    Voltage: 13.843 V
   Part No SW: 09G 927 750 FL    HW: 09G 927 750 FL
   Component: AQ 250 6F           0920
   Revision: 00H25000    Serial number:
   Coding: 0000072
   VCID: 000FBCB7538054216EF-8055
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8D7F4B6EFEEBD9575-806A
   Part No: 1K0 820 047 FP
   Component: Climatic PQ35   120 0606
   VCID: 77FDD76B064E13995F5-8022
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 P    HW: 3C0 937 049 P
   Revision: 00H46000    Serial number: 00000000425560
   Coding: 14050E234004150007140000001400000008730B5C0000
   VCID: 36631A6F41C42A91843-8063
   Component: Wischer 180806 020  0501
   Coding: 00038805
   Shop #: WSC 00066
   Revision: 05034000    Serial number: 003B6D05JEE%
   Coding: 0013889
   VCID: 6CD7F8074F08A041A27-8039
   Subsystem 2 - Serial number: 6332MSME10073638%
   Subsystem 3 - Serial number: 6342MSME11235842+
   Subsystem 4 - Serial number: 6351HSME0A200E171
   Subsystem 5 - Serial number: 6361HSME0A3B204FD
   Subsystem 6 - Serial number: 63727SME097F1430%
   Subsystem 7 - Serial number: 63827SME0A031C02W
02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
   Part No SW: 1K0 953 549 AR    HW: 1K0 953 549 AR
   Component: J0527           035 0070
   Coding: 0010021
   VCID: 020BB6BF5D8C463178B-8057
   Part No SW: 1K0 920 953 H    HW: 1K0 920 953 H
   Component: KOMBIINSTRUMENT 3HL 1610
   Revision: V0003000    Serial number: VWZ7Z0F4483712
   Coding: 0023203
   Shop #: WSC 22161 067 57207
   VCID: 306F2C77A3A004A1DEF-8065
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001066260210
   Coding: 3FBF034007001002
   VCID: 2C5738078F886041E27-8079
   Component: IMMO            3HL 1610
   Shop #: WSC 22161 444 84538
   Component: J386  TUER-SG FT    1125
   Revision: 12006001    Serial number: 00000022968802
   Coding: 0001205
   VCID: 3B750B5B7AE6F7F97BD-806E
                    Fault Status: 00101100
                    Reset counter: 226
                    Fault Status: 00111000
                    Reset counter: 226
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   VCID: 3467206757B83881BA7-8061
   Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
   Component:    KSG PQ35 RDK 051 0215
   Revision: 00051000    Serial number: 00000000000000
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   VCID: 74E7E067173878817A7-8021
            000 -  -  - Intermittent
                    Reset counter: 219
                    Mileage: 142013 km
                    Time: 08:53:30
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1125
   Revision: 12006001    Serial number: 00000520368723
   Coding: 0001204
   VCID: 3C7708477FE8F0C1727-8069
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 B    HW: 1K0 035 161 B
   Component: Radio DE2       014 0016
   Revision: 00014000    Serial number: VWZ4Z7F6156601
   Coding: 0040401
   VCID: 1E33E2CFC93482D17C3-804B
   Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
   Component: J388   TUER-SG HL   1115
   Revision: 12005001    Serial number: 00000000374665
   Coding: 0001168
   VCID: 3E73024F69F4E2D15C3-806B
                    Fault Frequency: 88
                    Reset counter: 226
                    Mileage: 140034 km
                    Fault Frequency: 54
                    Reset counter: 186
   Component:    RDK              0420
   Coding: 0100101
   Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
   Component: J389   TUER-SG HR   1115
   Revision: 12004001    Serial number: 00000000302676
   Coding: 0001168
                    Reset counter: 199
                    Mileage: 141194 km
                    Reset counter: 199
End-------------------------(Elapsed Time: 01:48)--------------------------
They are very helpful when there's a documented correspondence between PR codes and a Coding. This is common on some ABS systems (where, without knowing the PR codes for the brakes, you have to guess) as well as a few other systems here and there. But there's by no means a universal correspondence between PR codes and codings.
victor35ma
Los Angeles CA.
C?ID=242342
are those in the highlighted in the red circle the actual PR Codes?
victor35ma
Los Angeles CA.
C?ID=242342
You can decode them if you type them into VW/Audi/Seat/Škoda Option Codes Decoder
wow... really, is it that simple. let me understand it a little bit more and I 'll go back to you with even more questions, since in conjunction with VCDS it is the bible for VW coding. thank you so much. hope this web site stay always up and running all the time.
Hmm, I consider those transmission type codes, you can typically find them somewhere in either in the part number or component field of the TCU when you scan it, but I'm not sure if they match up with any PR codes directly.
-Uwe=
victor35ma
Los Angeles CA.
C?ID=242342
thank you Mr Uwe. Now I am VW cooking...
