I installed the Traction Control Retrofit Kit from ECS Tuning (http://www.ecstuning.com/Search/SiteSearch/ES2660879/ES2660879/) in my wife's 2014 VW Jetta SE (1.8T, Tiptronic, Keyless Start, NAR) with a manufacture date of January 2014. It is supposed to work "out of the box" (i.e., no coding required), but it does not. It appears that VWoA may have changed something recently (others have posted on VWVortex that the kit works on NAR 2014 Jetta's with the 1.8T).
So I pulled out the connection from "Pin 8" of the ABS module, tightened the pin (it appeared to be spread slightly), and re-installed -- same results (i.e., 12.5-13V at "Pin 8" in the ABS connector when switch depressed, 0 volts when released, and no indication in the instrument cluster once the harness in reconnected). Next I tried a test drive on a sandy dirt road, which verified 1000%, no doubt that the switch did NOT disable the traction control.
Now, for something a little more interesting that proves that the switch is wired properly, and the voltage is being sensed by the ABS module. I connected the VACDS, and navigated as follows:
The Advanced Measuring Values are selected as follows:
When the ASR/ESP Button is NOT depressed, the value shows "Not Oper." -- the ABS and ASR/ESR values fluctuate as the lights flash (i.e., because the ABS controller module is open by VAG-COM):
When the ASR/ESP Button is depressed, the vaule changes to "Activated", proving that the ABS module correctly detects sufficient voltage on "Pin 8":
This leads me to believe that there is now coding that must be done in order to enable the functionality in my vehicle . Unfortunately (but understandably), the long coding helper does not provide a lot of help for the ABS module.
The ABS module, ESP component, and coding info for my vehicle is as follows:
My full coding info for the 2014 Jetta is as follows:
NOTE: My 2012 JSW TDI has the same ABS module and ESP component by P/Ns, but with different hardware and software revs. The coding is completely different -- the traction control button came factory installed:
Any thoughts? Thanks in advance...
- Choose Select (Control Module);
- Choose 03-ABS Brakes;
- Choose Adv. Meas. Values (under Basic Functions); and
- Check ABS, ASR/ESR, and ASR/ESP Button.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: A14B400C49220002851202E5921A0041A1100012
Revision: 00H46001
Monday,07,April,2014,19:30:15:00370
VCDS Version: 14.2.3.0
Data version: 20140320
Chassis Type: AJ (6N0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 44 56 75 77
Address 01: Engine (J623-CPRA) Labels: None
Part No SW: 06K 906 070 F HW: 06K 907 425
Component: Simos12.2 H09 6865
Revision: --H09--- Serial number: 00000000000000
Coding: 001A0012242400171000
Shop #: WSC 00066 790 00201
ASAM Dataset: EV_ECM18TFS02006K906070F 001010
ROD: EV_ECM18TFS02006K906070F.rod
VCID: 2D5A83EF7C104C5C0E-8078
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels: None
Part No SW: 09G 927 749 A HW: 09G 927 749 A
Component: AISIN AG6 G3 101 2659
Coding: 000348
ASAM Dataset: EV_TCMAQ250031 001004
ROD: EV_TCMAQ250031_VW26.rod
VCID: 3776A1878E4CF68C64-8062
Revision: 00H46001
VCID: 7EF874A3E9F607C4E7-802B
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0194438836
Coding: 030C0C
ROD: EV_KESSYPQ35G.rod
VCID: 346C968B9F3A1D9441-8061
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BN HW: 5C0 820 047 BN
Component: J301 Klimaanlage 0204
Revision: 2001001S Serial number: 00000001967762
Shop #: WSC 10636 001 1048576
VCID: 6DDA43EF74908C5C4E-8038
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 J HW: 5C0 937 087 A
Component: BCM25 JLB H3 H34 0411
Revision: B2034001 Serial number: 08013010140845
Coding: 7A994BBF08AB0B0008382000340894C500C2502E6000400030A050002000
Shop #: WSC 00066 123 12345
VCID: 346C968B973A1D9441-8061
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0037
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Coding: 800000
Part No SW: 5C0 959 655 AD HW: 5C0 959 655 AD
Component: AirbagVW10 102 0912
Serial number: 003MVD02UJXO
Coding: 00004138
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 74EC568BDFBA5D9481-8021
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y13000114W60F
Coding: 303036
Serial number: 3572MSME57706D40ZZZZ
Serial number: 3582MSME73062A40ZZZQ
Serial number: 3516KSME22565229ZZZM
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME010C5B29ZZZU
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME1E73052AZZZ-
Crash sensor for front airbag; passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME0D16052AZZZW
Part No SW: 5C6 920 953 B HW: 5C6 920 953 B
Component: KOMBI H04 0809
Coding: 270A01
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 2C5C8EEB470A455419-8079
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H34 0411
Revision: B2034001
Coding: 102200
VCID: F0E4DA9B23A2E1B4E5-80A5
Component: IMMO H04 0809
Coding: 000007
Shop #: WSC 00066 000 00122
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EAD0C8F30D7E1B64AB-80BF
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000276354004
Coding: 4900000000000000
Shop #: WSC 00066 790 50316
ROD: EV_ELVMarquMPVW36X.rod
VCID: 30649A9B6B2221B425-8065
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 69 3501
Revision: 00H22000
VCID: 3972A7BF7058E0FC92-806C
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AF HW: 1K0 035 180 AF
Component: Radio Prem-8 H05 0008
Revision: -----09S Serial number: VWZ4Z7P3526864
Coding: 01000400020006
VCID: 64CC26CB675ACD1411-8031
Address 75: Telematics (J949) Labels: None
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0086
Serial number: 000003554140510
Coding: 02630102C2163A107F1606000000
Shop #: WSC 01383 790 50316
ROD: EV_OCULow.rod
VCID: D3AE7517BAF4BAACF8-8086
2103041 - Control Module Blocked
B2017 00 [009] - -
Fault Priority: 8
Reset counter: 31
Mileage: 614 km
Date: 2014.04.07
Time: 19:15:47
Address 77: Telephone (J412) Labels: None
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007665447678
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 2E5884E37116374437-807B
End ---------------------------------------------------------------------
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 114B600C492600FC881406ED92190042B70000
Revision: 00H31001
