hi all
Here is my first post
can you help me to coding abs caddy 2014
thanks...
Thursday,07,May,2015,17:52:32:26370
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WV2ZZZ2KZBX249831 License Plate:
Address 01: Engine
Control Module Part Number: 03L 906 023 FL
Component and/or Version: 1,6l R4 CR td H43 9971
Software Coding: 00114034032401080000
Work Shop Code: WSC 35110
VCID: 75E5B45CD4A634B6B81-8020
Advanced Identification/FAZIT
Identification: SJ8-FST
Revision: --H43---
Date: 16.12.10
Manufacturer number: 0008
Test stand number: 0185
Flash Status
Programming Attempts(application): 1/1/1
Successful Attempts(application): 1/1/1
Programming Status: 00000000
Flash Date: 13.10.30
Misc.
Hardware number: 03L 907 425 C
Workshop System Name: J623
ASAM Dataset: EV_ECM16TDI02103L906023FL
ASAM Dataset Revision: 003008
Car Info
Chassis Number: WV2ZZZ2KZBX249831
Engine code: CAYD
VCDS Info:
Labels: 03L-906-023-CAY.CLB
Readiness: No script available
ROD: EV_ECM16TDI02103L906023FL.rod
Sunday,10,May,2015,12:36:08:26370
Chassis Type: 2K (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 61
Address 01: Engine (J623-CAYD) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 FL HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 9971
Revision: --H43--- Serial number: 00000000000000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023FL 003008
7196 - Function Restriction due to Faults in Other Modules
U1113 00 [101] - -
Fault Frequency: 129
Mileage: 24266 km
Date: 2049.14.13
Time: 08:37:51
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 423C200D09260003421304E7901A0042000010
Shop #: WSC 35110 377 08192
VCID: 76E7B350C1A03FAEB1B-8023
6 Faults Found:
03306 - Coding Not Valid
Reset counter: 102
Mileage: 24563 km
Date: 2049.14.17
Time: 13:17:47
Count: 3
Count: 2
Count: 12800
Count: 4161
Count: 45824
Count: 8448
03841 - RPM Sensor Rear Left: Incorrect Signal
Reset counter: 100
Mileage: 24531 km
Date: 2049.14.16
Time: 13:40:39
Count: 3
Count: 2
Count: 20992
Count: 71
Count: 43776
Count: 59648
Fault Status: 01100101
Reset counter: 100
Mileage: 24531 km
Date: 2049.14.16
Time: 13:40:39
Count: 3
Count: 2
Count: 20992
Count: 212
Count: 43776
Count: 59648
Reset counter: 100
Mileage: 24531 km
Date: 2049.14.16
Time: 13:40:39
Count: 3
Count: 2
Count: 20992
Count: 8192
Count: 43776
Count: 59648
02186 - Engine <-> ADR Interface
Reset counter: 100
Mileage: 24531 km
Date: 2049.14.16
Time: 13:40:39
Count: 3
Count: 2
Count: 20992
Count: 8206
Count: 43776
Count: 59648
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 101
Mileage: 24531 km
Date: 2049.14.16
Time: 13:50:04
Count: 3
Count: 2
Count: 20992
Count: 128
Count: 43264
Count: 59648
Address 08: Auto HVAC (J301) Labels: 7N0-907-426.clb
Part No SW: 7N0 907 426 K HW: 7N0 907 426 K
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000000003
ROD: EV_ClimaBasis_VN35.rod
VCID: 3C736178B70CA5FE87F-8069
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 2K5 937 086 B HW: 2K5 937 086 B
Component: BCM PQ35 M+ 011 1044
Revision: BD011001
Coding: 461A0A3A80251A6B088000829000016443017288424F8160648087000041
VCID: 3565745C9C2674B6781-8060
Subsystem 1 - Part No: 1T1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 01121 26 0512
Coding: 009795
Address 10: Park/Steer Assist (J446) Labels: 1K0-919-475.clb
Part No SW: 1K0 919 475 L HW: 1K0 919 475 L
Component: PARKHILFE 005 1806
Revision: 00005000 Serial number: 0 263 004 450
Coding: 108001
Shop #: WSC 35110 377 00162
VCID: 3B716264BA02A2C68E5-806E
01548 - Sensor for Parking Aid; Rear Right (G206)
Reset counter: 114
Mileage: 21775 km
Date: 2047.14.02
Time: 18:19:47
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 92
Mileage: 21759 km
Date: 2047.14.02
Time: 17:25:35
Fault Status: 00100110
Reset counter: 132
Mileage: 21733 km
Date: 2047.14.02
Time: 15:19:17
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag013 H06 0013
Revision: -------- Serial number: 003HN001MJFE
Coding: 000000000000000000000000000000003133
ROD: EV_AirbaVW10BPAVN750_SE12.rod
VCID: 33614A449A526A86565-8066
Serial number: 3495RRB405P05BDSGGSM
Serial number: 3505RRB405707S8S6PJ0
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AT HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440JL9000QV
Coding: 1080160000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 820F5F801568930E0D3-80D7
Part No SW: 2K0 920 865 A HW: 2K0 920 865 A
Component: KOMBI H04 0404
Coding: 180200
ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
VCID: 2C535138476C357E17F-8079
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 071210F1000438
Coding: 357400
VCID: 316D404C684E5896249-8064
Reset counter: 134
Mileage: 22668 km
Date: 2049.14.07
Time: 13:16:05
00469 - Infotainment Databus in Single Wire Operation
Fault Status: 00101011
Reset counter: 117
Mileage: 22032 km
Date: 2047.14.16
Time: 01:40:24
Component: IMMO H04 0404
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EADF17200D186B4EA53-80BF
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2109
Coding: 0131120
VCID: 489B0DA83BD4F95E137-801D
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 140 3201
Revision: 00H20000
VCID: 34634958575C6DBE4FF-8061
013 - Check DTC Memory
Fault Status: 01101101
Fault Frequency: 9
Reset counter: 102
Mileage: 24563 km
Date: 2049.14.17
Time: 13:31:31
Voltage: 12.88 V
DU
Temperature: 48.0°C
RPM: 778 /min
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0131120
VCID: 47990E9436CAF6261AD-8012
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: RCD310 EU H11 5007
Revision: -----01S Serial number: VWZ4Z2K1107343
Coding: 05010000010000
Shop #: WSC 27928 141 90632
VCID: 65C5E41C6C06C436081-8030
Reset counter: 134
Date: 2064.00.00
Time: 00:00:00
00856 - Radio Antenna
Reset counter: 134
Date: 2064.00.00
Time: 00:00:00
Reset counter: 134
Date: 2064.00.00
Time: 00:00:00
00468 - CD-ROM Drive (R92)
Fault Status: 00101110
Reset counter: 40
Date: 2064.00.00
Time: 00:00:00
Fault Status: 00100111
Reset counter: 136
Mileage: 24156 km
Date: 2049.14.12
Time: 11:08:35
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H35 0614
Coding: 030B185A
VCID: F1ED004C28CE9896E49-80A4
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
End ---------------------------------------------------------------------
