2012-2014 NAR Passat(A32) TDI/CKRA – AdBlue Level Reset Procedure
DrPeter
16.4905° S, 151.7375° W
The following procedure is intended for all NAR spec Passat TDI (A32) vehicles from 2012 to 2014 with the CKRA - 103kW-140HP 2.0L TDI engine.
Please provide feed back on this as this is currently untested, thank you.
Prerequisites:
- Engine fully warmed up (above 80’C) and idling
- Transmission in Park/Neutral
- Emergency brake = On
- Doors and hood are closed
- Driver's seat belt latched. (some cars)
- Do not depress any pedals during this procedure, until instructed to do so.
To Reset the AdBlue Level:
- Clear all fault codes(yes, even if there are none present)
- Select 01-Engine]
- Select [Basic Settings-04]
- From the pull down menu choose:
- - - [Resetting of learned values of average quantity adaptation], press [Go!]
- - - - After completion, Press [Stop]
- - - Then [Reset learned values quant. meter. unit and press. contr. Valve], press [Go!]
- Select [Check of SCR efficiency], press [Go!]
- Depress Brake pedal, then depress accelerator pedal, the ECM should take control of the Engine speed.
- This test may take up to 30+ minutes to complete!
- Upon completion, you should see ‘System Okay’, the AdBlue light and the warning message about ‘miles to no start’ will be reset. Verify there are no fault codes.
Done, end…
Edit - The following additional steps may need to be performed:
  • Basic Settings IDE04567 Resetting of SCR tank level detection
  • Basic Settings IDE04730 Reset SCR lock
  • Test drive vehicle
drpeter
kantusjack
Spain
C?ID=69091
Hi Dr Peter,
Do you know if this procedure is valid for a VW Sharan CFGB Engine??? Do you know where can I get a procedure for a CFGB engine???
DrPeter
I do not, you may try it on any vehicle/engine configuration you like, I can dig into and see if I can find anything for the CFGB.
- If you could please start a new post/thread in Car Repair Support asking this question and please post a complete vehicle Auto-Scan.
I would like it if the posts here could be feedback on this procedure,
Thank you,
drpeter
Dana
Western PA, USA
This is just an internal note but that self test resolved ST?ID=71990
Summary for the public:
2012 NAR market TDI Passat with a BUNCH of new parts: Engine, Turbo, DPF, etc major mechanical repairs 10K ago. New NOx CAT, NOx sensor, 2.5 Gallons of AdBlue etc.. currently.
> Address 01: Engine (J623-CKRA) Labels: 03L-906-012-CKR.clb
> Part No SW: 03L 906 012 BP HW: 03L 907 309 S
> Component: R4 2,0L EDC H21 7445
> Revision: 71H21--- Serial number:
> Coding: 001D0012042400008000
> Shop #: WSC 28044 001 1048576
> ASAM Dataset: EV_ECM20TDI01103L906012BP 004009
> ROD: EV_ECM20TDI01103L906012BP.rod
> VCID: 73E456EFDA1061DAB1-8026
> No fault code found.
> Readiness: 0 0 0 0 1
It was threatening 15 miles until it wouldn't restart so she couldn't drive for 40-50 miles to let things happen naturally. The normal Reset SCR lock (finished correctly) followed by Resetting of SCR tank level detection (finished correctly) steps were not working and a couple mile test drive didn't help either. Peter's Check of SCR efficiency Finished Correctly within 5 min and then Resetting of SCR tank level detection finally worked! She needs to drive and see at this point.
The NOx sensor 1 test didn't complete after 13 min of holding the brake and gas.. but it would have been ideal to see it report Finished Correctly.
MartinsX
Riga, Latvia
C?ID=268515
Hi!
Do anyone know, will procedure in post #1 work for European market VW Sharan with 2,0 TDI engine CFFA?
Ad Blue warning is on, no fault codes, "Resetting of SCR tank level" didn't help. Ad Blue tank is filled.
The car will come back tomorrow, I'll try to dig deeper into this.
Second question - is the remaining times to start engine warning a real thing? I.e. engine will not start after counter will reach 0?
Wednesday,28,December,2016,18:07:39:32442
VCDS Version: 16.8.3.1
VIN: WVWZZZ7NZBV040245   License Plate:
Chassis Type: 7N (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 61 62 72
VIN: WVWZZZ7NZBV040245   Mileage: 203400km-126386miles
Address 01: Engine (J623-CFFA)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 H    HW: 03L 907 309 Q
   Component: R4 2,0L EDC   H24 8254
   Revision: 44H24---    Serial number:
   Coding: 00190012040401080000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM20TDI01103L906018H 003006
   ROD: EV_ECM20TDI01103L906018H.rod
   VCID: 2F6D79837663F63A15-807A
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 M    HW: 7N0 614 109 M
   Component: J104   C3 450M VD90 0009
   Revision: --H07---    Serial number: 00000004159246
   Coding: 0018967
   Shop #: WSC 00020 790 00000
   VCID: 377D41E346333EFA4D-8062
   Part No SW: 7N0 907 426 K    HW: 7N0 907 426 K
   Component: AC Manuell    H17 0202
   Revision: 00001012
   Coding: 0000000003
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 3C775ECFB7151DA2A0-8068
9477489 - Motor for Air Distribution Flap
          B109D 71 [008] - Actuator stuck
                    Fault Frequency: 12
                    Reset counter: 183
                    Mileage: 203368 km
                    Date: 2016.12.28
                    Time: 10:23:10
   Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
   Component: BCM PQ35 B    011 0048
   Revision: BA011001
   Coding: 40180A3B81251AC0400800C0100000E443011308424D01626480872000C1
   VCID: 35614BEB9C3FCCEA5F-8060
   Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110406  31  0032
   Serial number:         110426211537
   Coding: 004DBD
   Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
   Component: VW10Airbag01L H07 0013
   Serial number: 003GFP8AP2DV
   Coding: 00314C
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3E7354C7A1090FB28E-806A
   Subsystem 1 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.V  --- ---
   Serial number: 3493ETS60956007149DL
   Subsystem 2 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.V  --- ---
   Serial number: 3503ETS60782A0B14DDS
   Subsystem 3 - Part No SW: ---            HW: ---
   Component: S.Sens.Fah  --- ---
   Serial number: 3513ETS6020480B14DDG
   Subsystem 4 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.H  --- ---
   Serial number: 3523ETS60CE38F813DD8
   Subsystem 5 - Part No SW: ---            HW: ---
   Component: F.Sens.Fahr  --- ---
   Serial number: 35540TS60FE8EE6139D5
   Part No SW: 5K0 953 501 BG    HW: 5K0 953 569 K
   Revision: FF010040    Serial number: 20110415200198
   Coding: 1182040000
   VCID: 70EFBAFFABDDA9C24C-8024
   Coding: E20000
   Part No SW: 7N0 920 870 A    HW: 7N0 920 870 A
   Component: KOMBI         H20 0420
   Coding: 140F00
   VCID: 306F7AFF6B5DE9C20C-8064
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 010511F2001495
   Coding: 468002
   VCID: 31697FFB6857E0CA03-8064
   Component: IMMO          H20 0420
   VCID: 6ADBA8978D01531202-803E
   Part No SW: 3C0 035 279     HW: 3C0 035 279
   Component: RNS315        H05 0010
   Serial number: VWZAZ2L3336528
   Coding: 000004110400000000021000
   ASAM Dataset: EV_RNS315VWEUV1UDS A01005
   ROD: EV_RNS315VWEUV1UDS.rod
   VCID: 60CFCABF7B3D1942DC-8034
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
   Part No SW: 7N0 959 793 D    HW: 7N0 959 793
   Component: TSG FA        H04 0400
   Revision:             Serial number: 0000114814038
   Coding: 011006208000411011
   VCID: 43852533C2EB625AE1-8016
01705 - Selection Switch for Mirror-Adjust (E48)
                    Reset counter: 142
                    Mileage: 203356 km
                    Date: 2011.05.20
                    Time: 21:17:05
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.323 0802
   Revision: 1AH03729    Serial number: 00111110295901
   Coding: 0000258
   VCID: 3B755DD37A1B1A9AA9-806E
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
   Part No SW: 7N0 959 792 D    HW: 7N0 959 792
   Component: TSG BF        H04 0400
   Revision:             Serial number: 0000115072360
   VCID: 428B2037DDF16B52EA-8016
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000326565
   Coding: 0024066
   VCID: 336575F3524BD2DA71-8066
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Component: Batt.regelung H35 0614
   Coding: 030B185A
   VCID: 71E9BFFBA8D7A0CA43-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370410649
Address 62: Door, Rear Left
Address 72: Door, Rear Right (J389)       Labels: 7N0-959-794.clb
   Part No SW: 7N0 959 794 E    HW: 7N0 959 795 A
   Component: TSG HR        H03 0400
   Revision:             Serial number: 0000115373584
   Coding: 010004200000411001
   VCID: 45813B2BCCDF5C6ACF-8010
02131 - Child Safety Lock Motor
                    Reset counter: 184
                    Mileage: 203403 km
                    Date: 2011.05.21
                    Time: 17:52:47
End-------------------------(Elapsed Time: 02:49)--------------------------
MartinsX
Riga, Latvia
C?ID=268515
Procedure at post #1 did not work for this car. Nor similar procedures found in other topics here and in other sources of information. I was able to reset SCR level and SCR lock, but SCR efficiency test was refused by control module with message "Error. Request out of range". ECU software update at dealer from V.8254 to some newer version solved this out. TPI 2024801/4.
I can answer my second question, too - yes, when AdBlue system malfunction related countdown reaches 0, it is not possible to start engine.
Galagonya
Hungary
C?ID=279185
Confirmed
This method is confirmed on a 2011 VW Sharan 2.0. I forgot the enginecode sorry, but works for us.
We fought with the start because the conditions wasnt ready, but when its started and the procedure runs thru the result was great. :)
Thanks.
roni024
C?ID=221779
I tried this reset procedure on my 2013 Passat TDI. During the check of SCR efficiency, the ECM never takes control of the engine speed. I gave up pressing the accelerator with my foot after 7 minutes. Is it normal in some cases to not have the ECM take over engine speed during that test? Should I just prop the pedal down with a push-rod and let it run longer?
Or, am I mistaken in thinking that I can remove my foot from the pedal after a few moments and the ECM will keep the RPMs around 1500?
Did you have your other foot firmly on the brake pedal?
roni024
C?ID=221779
Yes, even when removing my foot from the accelerator to see if the RPMs would hold.
Edit: I should also mention, the glow plug indicator flashes during the procedure. I'm not sure if that's normal.
So you're saying left foot on the brake, and accelerator pedal pressed to the floor, the ECU does not limit the engine speed to something reasonable?
ETA: Does your ECU have "Dieselgate Fix" software in it already?
roni024
C?ID=221779
ECU limits RPM to around 1500 RPM. I'm asking, is the ECU supposed to maintain that RPM when I remove my right foot from the accelerator and leave my left foot on the brake?
Edit: Dieselgate fix NOT installed
OK, that sounds correct.
No, I don't think so. Basic Settings that require an elevated RPM (where the ECU controls the RPM) have been always been: One foot firmly on the brake, the other foot holding the loud pedal to the floor for as long as it takes.
roni024
C?ID=221779
Thank you for the explanation. After replacing the AdBlue heater assembly and pump (broke nipple when reinstalling tank), the AdBlue countdown would not go away. I tried a couple different reset procedures (the one outlined previously, and also Reset SCR fluid level - then Reset SCR lock) but the countdown remained. A couple of ignition cycles later and it went away. Maybe it took a little time for air to bleed from the reductant line. All is well.
golfi_vend
Tartu, Estonia
C?ID=195131
This process helped me on imported NMS, that had range counting down with no faults.
After the process aborted it at least gave some faults.
I did update ECU software, cause on sharan the ECU software plays a huge role resetting adblue level. But no joy.
Seems like new sensor is needed(600 Euros)
Tuesday,10,April,2018,20:12:49:36026
VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4421.4
VIN: 1VWBN7A35EC   License Plate: PASSAT USA2
Mileage: 78870km-49007mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72
          75 77
VIN: 1VWBN7A35EC   Mileage: 78870km-49007miles
Address 01: Engine (J623-CKRA)       Labels:. 03L-906-012-CKR.clb
   Part No SW: 03L 906 012 DE    HW: 03L 907 309 S
   Component: R4 2,0L EDC   H24 6073
   Revision: 71H24---    Serial number:
   Coding: 001D0012042400000000
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_ECM20TDI01103L906012DE 004004
   ROD: EV_ECM20TDI01103L906012DE.rod
   VCID: 6A9809E48DF35314A6-803E
18643 - NOx Sensor 1 Bank 1
          P2200 00 [039] - Electrical Malfunction
                    Mileage: 78875 km
                    Date: 2018.04.10
                    Time: 20:09:43
                    Engine speed: 1497.50 /min
                    Normed load value: 16.9 %
                    Coolant temperature: 96 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 14.060 V
                    Outside air temperature: 16.5 °C
                    Status of electrical malfunction of NOx sensor 1-Bits 0-7: 234
                    Exh.gas temp.sen 4: 448.6 °C
                    Mean injection quantity: 7.17 mg/stroke
                    Limitation: torque: 270.0 Nm
18644 - NOx Sensor 1 Bank 1
                    Mileage: 78875 km
                    Date: 2018.04.10
                    Time: 20:09:43
                    Air mass: actual value (mg/stroke): 667.7 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                    NOx emission NOx sensor 1: 0 ppm
                    Air mass for release of NOx sensor 1 offset test: 0.0 g
                    Calculated efficiency of NOx conversion: 0.648
Readiness: 0 0 0 1 1
   Part No SW: 02E 300 062 B    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4020
   Revision: 05652104    Serial number: 00001310100063
   VCID: 1464771C37F735E4AC-8040
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: C54BC0F5492800FBA30D03E7921A0042A1100012
   VCID: 7EB035B4E97BCFB46A-802A
                    Reset counter: 194
                    Mileage: 78819 km
                    Date: 2018.04.09
                    Time: 00:00:35
                    Count: 2
                    Count: 12
                    Count: 20480
                    Count: 16390
                    Count: 45312
                    Count: 511
   Part No SW: 561 907 426 E    HW: 561 907 426 E
   Component: AC Manuell    H02 0303
   Revision: 00001K02
   Coding: 0010001002
   ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1D7212380C3D74AC13-8048
   Part No SW: 5K0 937 085 AB    HW: 5K0 937 085 AB
   Component: BCM PQ35 B+   122 0173
   Revision: BH122001
   Coding: EF200E1B902B08D4098800010600044800F1A08640801520648060000C70
   VCID: 73A61480D23992DC15-8026
   Part No SW: 5C0 959 655 AE    HW: 5C0 959 655 AE
   Component: AirbagVW10G   014 0851
   Serial number: 003MWM03S9TJ
   Coding: 00005033
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75A22A98D44D8CEC3B-8020
   Serial number: 6940000Y1300010ENC0L
   Coding: 303044
   Serial number: 3572MSME4916617DZZZ/
   Serial number: 3582MSME5B00017EZZZW
   Serial number: 3516KSME3A5B4228ZZZY
   Serial number: 3526KSME6C154F28ZZZ0
   Serial number: 3556LSME2372042AZZZO
   Serial number: 3566LSME3A0A6F29ZZZ7
   Part No SW: 1K5 953 521 BM    HW: 5K0 953 569 AE
   Revision: FF010042    Serial number: 20131111100818
   Coding: 088A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79BA26A8F855E88C5F-802C
   Component: E221__MFL-YVJ  H07 0022
   Coding: E20000
Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
   Part No SW: 561 920 970 G    HW: 561 920 970 G
   Component: KOMBI         H04 0811
   Coding: 231E01
   VCID: 1E701534013B6FB40A-804A
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 25111303000645
   Coding: 461000
   VCID: 7BB63CA0FA69DA9C4D-802E
Address 1C: Position Sensing
   Component: IMMO          H04 0811
Address 2E: Media Player 3
   Component: TUER-SG FT    002 0525
   Revision: 13110009    Serial number: 0007645681
   Coding: 0404F5
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BF65C2052A93A9C2D-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630131126102409
   Coding: 800000
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 194
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 153
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 290    3501
   Revision: 00H22000
   VCID: 393AE6A870D5288C1F-806C
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
   Component: EZE_2         H55 1642
   Coding: 01030108
   VCID: 6FAE18F0BE11B63CF1-803A
   Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
   Component: J245 P05 FFD7  H07 0004
   Serial number: 53388786011325702777
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0005
   Component: TUER-SG BT    002 0525
   Revision: 15110009    Serial number: 0007589267
   Coding: 0404F4
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CF45F3C57A73DA424-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14202631131126134433
   Coding: 800000
                    Reset counter: 153
   Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
   Component: Radio Prem-8  H05 0008
   Revision: -----09S    Serial number: VWZ4Z7N3522745
   Coding: 0100044004000B
   VCID: 2B16CCE04A898A1C9D-807E
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0086
   Serial number: 000003554140510
   Coding: 02140102C2163A007F1606C00000
   ROD: EV_OCULow_001.rod
   VCID: 53E6B4003A79F2DCF5-8006
12670464 - Databus
          [CAN TO brake]
                    Fault Frequency: 178
                    Reset counter: 183
                    Mileage: 50048 km
                    Date: 2016.10.03
                    Time: 18:35:02
0035 - Databus
          [CAN TO Airbag]
                    Fault Frequency: 176
                    Reset counter: 183
                    Mileage: 50048 km
                    Date: 2016.10.03
                    Time: 18:35:02
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 0
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007665382819
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 2E10C5F4719BFF34BA-807A
End----------(Elapsed Time: 01:05, VBatt start/end: 14.0V/14.1V)-----------
Jef
HQ
ST?ID=81728
E?ID=447351
Component: R4 2,0L EDC H24 8401
Did the steps outlined by Peter, still has nag message, 45 miles to death by adblue.
Battery charger hooked up, ignition on 10 minutes, no change.
Did Basic Settings:
  • IDE04567 Resetting of SCR tank level detection
  • IDE04730 Reset SCR lock
Still has death in 45 miles Adblue message. Test drove car and within 10 miles the Adblue nag message was gone.
Joey736
C?ID=385610
Just tried this on a 2016 touareg v6 tdi with adblue countdown message on display.
Scr lock reset
Scr tank level reset
Scr efficiency test ~ 15mins
Test confirmed to be completed successfully, warning light and countdown message removed from display.
Hopefully this will help others with similar issues.
Joey.
Norrisnick1
Ohio, USA
C?ID=523629
2014 passat ckra, tried the reset exactly explained and it didnt work, tried several times.
Anyone else have the same issue that was able to figure it out?
  • Informative
Reactions: JMR
@DRI@N
Romania
C?ID=317777
Hy,
I have a fault on AdBlue system, on my European Passat B8 2.0 BiTDI 2015 :
Monday,26,September,2022,16:26:31:62612
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
VIN: WVWZZZ3CZFE400297
Mileage:    Repair Order: 26.09.2022
                Address 01: Engine       Labels: 03N-906-026-CUA.clb
Control Module Part Number: 03N 906 026     HW: 03N 907 309
  Component and/or Version: R4 2,0L EDC   X22 0948
           Software Coding: 0125003A047605083000
            Work Shop Code: WSC 08601 003 104857
              ASAM Dataset: EV_ECM20BTD01103N906026 001008 (VW48)
                       ROD: EV_ECM20BTD01103N906026.rod
                      VCID: 688AB06D52FC920B4F3-803C
22585 - Reductant Level Sensor
          P203B 00 [237] - Implausible Signal
                    Mileage: 74700 km
                    Date: 2022.09.18
                    Time: 17:17:20
                    Engine RPM: 2189.00 /min
                    Normed load value: 34.9 %
                    Vehicle speed: 43 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 100 °C
                    Voltage terminal 30: 12.540 V
                    Outside temperature sensor 1: B1: raw value: 22.0 °C
                    Reducing agent pump module relative press.: calculated: 7175 hPa
                    Reducing agent fill level sensor: act. value: 0.0 mm
                    Sensor for reducing agent tank temperature: temperature: 22.1 °C
                    Reducing agent system pressurization release conditions-Bits 0-7: 0
                    Reducing agent system: current status: COSCR_PRESSURECTL
                    Reducing agent system: current status-Test_Program_SCR Con State 01 UBYTE: 4
Readiness: 1 1 0 0 0
Is possible to tell me where is this sensor, and if the first posting procedure solve my problem, because my AdBlue tank is Full ?
Thanks .
