Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 2012-2014 NAR Passat(A32) TDI/CKRA – AdBlue Level Reset Procedure
    So you're saying left foot on the brake, and accelerator pedal pressed to the floor, the ECU does not limit the engine speed to something reasonable?
    ETA: Does your ECU have "Dieselgate Fix" software in it already?
  2. #12
    Jul 2014
    ECU limits RPM to around 1500 RPM. I'm asking, is the ECU supposed to maintain that RPM when I remove my right foot from the accelerator and leave my left foot on the brake?
    Edit: Dieselgate fix NOT installed
  3. #13
    Quote Originally Posted by roni024 View Post
    OK, that sounds correct.
    No, I don't think so. Basic Settings that require an elevated RPM (where the ECU controls the RPM) have been always been: One foot firmly on the brake, the other foot holding the loud pedal to the floor for as long as it takes.
  4. Likes roni024 liked this post
  5. #14
    Jul 2014
    Thank you for the explanation. After replacing the AdBlue heater assembly and pump (broke nipple when reinstalling tank), the AdBlue countdown would not go away. I tried a couple different reset procedures (the one outlined previously, and also Reset SCR fluid level - then Reset SCR lock) but the countdown remained. A couple of ignition cycles later and it went away. Maybe it took a little time for air to bleed from the reductant line. All is well.
  6. Likes Uwe liked this post
  7. #15
    Tartu, Estonia
    This process helped me on imported NMS, that had range counting down with no faults.
    After the process aborted it at least gave some faults.
    I did update ECU software, cause on sharan the ECU software plays a huge role resetting adblue level. But no joy.
    Seems like new sensor is needed(600 Euros)
    Tuesday,10,April,2018,20:12:49:36026
    VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4421.4
    VIN: 1VWBN7A35EC   License Plate: PASSAT USA2
    Mileage: 78870km-49007mi   Repair Order:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72
              75 77
    VIN: 1VWBN7A35EC   Mileage: 78870km-49007miles
    Address 01: Engine (J623-CKRA)       Labels:. 03L-906-012-CKR.clb
       Part No SW: 03L 906 012 DE    HW: 03L 907 309 S
       Component: R4 2,0L EDC   H24 6073
       Revision: 71H24---    Serial number:
       Coding: 001D0012042400000000
       Shop #: WSC 09003 957 00200
       ASAM Dataset: EV_ECM20TDI01103L906012DE 004004
       ROD: EV_ECM20TDI01103L906012DE.rod
       VCID: 6A9809E48DF35314A6-803E
    18643 - NOx Sensor 1 Bank 1
              P2200 00 [039] - Electrical Malfunction
                        Mileage: 78875 km
                        Date: 2018.04.10
                        Time: 20:09:43
                        Engine speed: 1497.50 /min
                        Normed load value: 16.9 %
                        Coolant temperature: 96 °C
                        Intake air temperature: 33 °C
                        Voltage terminal 30: 14.060 V
                        Outside air temperature: 16.5 °C
                        Status of electrical malfunction of NOx sensor 1-Bits 0-7: 234
                        Exh.gas temp.sen 4: 448.6 °C
                        Mean injection quantity: 7.17 mg/stroke
                        Limitation: torque: 270.0 Nm
    18644 - NOx Sensor 1 Bank 1
                        Mileage: 78875 km
                        Date: 2018.04.10
                        Time: 20:09:43
                        Air mass: actual value (mg/stroke): 667.7 mg/stroke
                        EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                        NOx emission NOx sensor 1: 0 ppm
                        Air mass for release of NOx sensor 1 offset test: 0.0 g
                        Calculated efficiency of NOx conversion: 0.648
    Readiness: 0 0 0 1 1
       Part No SW: 02E 300 062 B    HW: 02E 927 770 AL
       Component: GSG DSG AG6     521 4020
       Revision: 05652104    Serial number: 00001310100063
       VCID: 1464771C37F735E4AC-8040
       Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
       Component: ESP MK60EC1   H46 0164
       Revision: 00H46001
       Coding: C54BC0F5492800FBA30D03E7921A0042A1100012
       VCID: 7EB035B4E97BCFB46A-802A
                        Reset counter: 194
                        Mileage: 78819 km
                        Date: 2018.04.09
                        Time: 00:00:35
                        Count: 2
                        Count: 12
                        Count: 20480
                        Count: 16390
                        Count: 45312
                        Count: 511
       Part No SW: 561 907 426 E    HW: 561 907 426 E
       Component: AC Manuell    H02 0303
       Revision: 00001K02
       Coding: 0010001002
       ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
       ROD: EV_ACManuaElectGen2BHTC_VW36.rod
       VCID: 1D7212380C3D74AC13-8048
       Part No SW: 5K0 937 085 AB    HW: 5K0 937 085 AB
       Component: BCM PQ35 B+   122 0173
       Revision: BH122001
       Coding: EF200E1B902B08D4098800010600044800F1A08640801520648060000C70
       VCID: 73A61480D23992DC15-8026
       Part No SW: 5C0 959 655 AE    HW: 5C0 959 655 AE
       Component: AirbagVW10G   014 0851
       Serial number: 003MWM03S9TJ
       Coding: 00005033
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 75A22A98D44D8CEC3B-8020
       Serial number: 6940000Y1300010ENC0L
       Coding: 303044
       Serial number: 3572MSME4916617DZZZ/
       Serial number: 3582MSME5B00017EZZZW
       Serial number: 3516KSME3A5B4228ZZZY
       Serial number: 3526KSME6C154F28ZZZ0
       Serial number: 3556LSME2372042AZZZO
       Serial number: 3566LSME3A0A6F29ZZZ7
       Part No SW: 1K5 953 521 BM    HW: 5K0 953 569 AE
       Revision: FF010042    Serial number: 20131111100818
       Coding: 088A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 79BA26A8F855E88C5F-802C
       Component: E221__MFL-YVJ  H07 0022
       Coding: E20000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 970 G    HW: 561 920 970 G
       Component: KOMBI         H04 0811
       Coding: 231E01
       VCID: 1E701534013B6FB40A-804A
       Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1642
       Revision:   H55       Serial number: 25111303000645
       Coding: 461000
       VCID: 7BB63CA0FA69DA9C4D-802E
    Address 1C: Position Sensing
       Component: IMMO          H04 0811
    Address 2E: Media Player 3
       Part No SW: 561 959 701     HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0525
       Revision: 13110009    Serial number: 0007645681
       Coding: 0404F5
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 5BF65C2052A93A9C2D-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  006 5470
       Serial number: 14102630131126102409
       Coding: 800000
              B11EC 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 194
              B11EE 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 153
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 290    3501
       Revision: 00H22000
       VCID: 393AE6A870D5288C1F-806C
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1642
       Coding: 01030108
       VCID: 6FAE18F0BE11B63CF1-803A
       Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
       Component: J245 P05 FFD7  H07 0004
       Serial number: 53388786011325702777
       Coding: 181100
       Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0005
       Part No SW: 561 959 702     HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0525
       Revision: 15110009    Serial number: 0007589267
       Coding: 0404F4
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 5CF45F3C57A73DA424-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  006 5470
       Serial number: 14202631131126134433
       Coding: 800000
                        Reset counter: 153
       Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
       Component: Radio Prem-8  H05 0008
       Revision: -----09S    Serial number: VWZ4Z7N3522745
       Coding: 0100044004000B
       VCID: 2B16CCE04A898A1C9D-807E
       Component: OCULowUSA     014 0086
       Serial number: 000003554140510
       Coding: 02140102C2163A007F1606C00000
       ROD: EV_OCULow_001.rod
       VCID: 53E6B4003A79F2DCF5-8006
    12670464 - Databus
              [CAN TO brake]
                        Fault Frequency: 178
                        Reset counter: 183
                        Mileage: 50048 km
                        Date: 2016.10.03
                        Time: 18:35:02
    0035 - Databus
              [CAN TO Airbag]
                        Fault Frequency: 176
                        Reset counter: 183
                        Mileage: 50048 km
                        Date: 2016.10.03
                        Time: 18:35:02
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 0
       Revision: 1B001001    Serial number: 00007665382819
       Coding: 0A10030080010110
       ROD: EV_UHVUMI.rod
       VCID: 2E10C5F4719BFF34BA-807A
    End----------(Elapsed Time: 01:05, VBatt start/end: 14.0V/14.1V)-----------
    The world is my oyster...
  8. #16
    HQ
    ST?ID=81728
    E?ID=447351
    Component: R4 2,0L EDC H24 8401
    Did the steps outlined by Peter, still has nag message, 45 miles to death by adblue.
    Battery charger hooked up, ignition on 10 minutes, no change.
    Did Basic Settings:
    • IDE04567 Resetting of SCR tank level detection
    • IDE04730 Reset SCR lock
    Still has death in 45 miles Adblue message. Test drove car and within 10 miles the Adblue nag message was gone.
    Jef
  9. Likes Uwe liked this post
