Results 1 to 10 of 16
Thread: 2012-2014 NAR Passat(A32) TDI/CKRA – AdBlue Level Reset Procedure
    16.4905° S, 151.7375° W
    The following procedure is intended for all NAR spec Passat TDI (A32) vehicles from 2012 to 2014 with the CKRA - 103kW-140HP 2.0L TDI engine.
    Please provide feed back on this as this is currently untested, thank you.
    Prerequisites:
    - Engine fully warmed up (above 80’C) and idling
    - Transmission in Park/Neutral
    - Emergency brake = On
    - Doors and hood are closed
    - Do not depress any pedals during this procedure, until instructed to do so.
    To Reset the AdBlue Level:
    - Clear all fault codes(yes, even if there are none present)
    - Select 01-Engine]
    - Select [Basic Settings-04]
    - From the pull down menu choose:
    - - - [Resetting of learned values of average quantity adaptation], press [Go!]
    - - - - After completion, Press [Stop]
    - - - Then [Reset learned values quant. meter. unit and press. contr. Valve], press [Go!]
    - Select [Check of SCR efficiency], press [Go!]
    - Depress Brake pedal, then depress accelerator pedal, the ECM should take control of the Engine speed.
    - This test may take up to 30+ minutes to complete!
    - Upon completion, you should see ‘System Okay’, the AdBlue light and the warning message about ‘miles to no start’ will be reset. Verify there are no fault codes.
    Done, end…
    Edit - The following additional steps may need to be performed:
    • Basic Settings IDE04567 Resetting of SCR tank level detection
    • Basic Settings IDE04730 Reset SCR lock
    • Test drive vehicle
    drpeter
    Apr 2015
    Spain
    Hi Dr Peter,
    Do you know if this procedure is valid for a VW Sharan CFGB Engine??? Do you know where can I get a procedure for a CFGB engine???
    I do not, you may try it on any vehicle/engine configuration you like, I can dig into and see if I can find anything for the CFGB.
    - If you could please start a new post/thread in Car Repair Support asking this question and please post a complete vehicle Auto-Scan.
    I would like it if the posts here could be feedback on this procedure,
    Thank you,
    drpeter
  4. Likes piok, AlvisMartin liked this post
    United States
    This is just an internal note but that self test resolved ST?ID=71990
    Summary for the public:
    2012 NAR market TDI Passat with a BUNCH of new parts: Engine, Turbo, DPF, etc major mechanical repairs 10K ago. New NOx CAT, NOx sensor, 2.5 Gallons of AdBlue etc.. currently.
    > Address 01: Engine (J623-CKRA) Labels: 03L-906-012-CKR.clb
    > Part No SW: 03L 906 012 BP HW: 03L 907 309 S
    > Component: R4 2,0L EDC H21 7445
    > Revision: 71H21--- Serial number:
    > Coding: 001D0012042400008000
    > Shop #: WSC 28044 001 1048576
    > ASAM Dataset: EV_ECM20TDI01103L906012BP 004009
    > ROD: EV_ECM20TDI01103L906012BP.rod
    > VCID: 73E456EFDA1061DAB1-8026
    > No fault code found.
    > Readiness: 0 0 0 0 1
    It was threatening 15 miles until it wouldn't restart so she couldn't drive for 40-50 miles to let things happen naturally. The normal Reset SCR lock (finished correctly) followed by Resetting of SCR tank level detection (finished correctly) steps were not working and a couple mile test drive didn't help either. Peter's Check of SCR efficiency Finished Correctly within 5 min and then Resetting of SCR tank level detection finally worked! She needs to drive and see at this point.
    The NOx sensor 1 test didn't complete after 13 min of holding the brake and gas.. but it would have been ideal to see it report Finished Correctly.
  6. Likes Andy, Boki Ar, DrPeter liked this post
    Sep 2016
    Riga, Latvia
    Hi!
    Do anyone know, will procedure in post #1 work for European market VW Sharan with 2,0 TDI engine CFFA?
    Ad Blue warning is on, no fault codes, "Resetting of SCR tank level" didn't help. Ad Blue tank is filled.
    The car will come back tomorrow, I'll try to dig deeper into this.
    Second question - is the remaining times to start engine warning a real thing? I.e. engine will not start after counter will reach 0?
    Wednesday,28,December,2016,18:07:39:32442
    VCDS Version: 16.8.3.1
    VIN: WVWZZZ7NZBV040245   License Plate:
    Chassis Type: 7N (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 61 62 72
    VIN: WVWZZZ7NZBV040245   Mileage: 203400km-126386miles
    Address 01: Engine (J623-CFFA)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 H    HW: 03L 907 309 Q
       Component: R4 2,0L EDC   H24 8254
       Revision: 44H24---    Serial number:
       Coding: 00190012040401080000
       Shop #: WSC 00020 999 00000
       ASAM Dataset: EV_ECM20TDI01103L906018H 003006
       ROD: EV_ECM20TDI01103L906018H.rod
       VCID: 2F6D79837663F63A15-807A
    Address 03: ABS Brakes        Labels: 7N0-614-109.clb
       Part No SW: 7N0 614 109 M    HW: 7N0 614 109 M
       Component: J104   C3 450M VD90 0009
       Revision: --H07---    Serial number: 00000004159246
       Coding: 0018967
       Shop #: WSC 00020 790 00000
       VCID: 377D41E346333EFA4D-8062
       Part No SW: 7N0 907 426 K    HW: 7N0 907 426 K
       Component: AC Manuell    H17 0202
       Revision: 00001012
       Coding: 0000000003
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 3C775ECFB7151DA2A0-8068
    9477489 - Motor for Air Distribution Flap
              B109D 71 [008] - Actuator stuck
                        Fault Frequency: 12
                        Reset counter: 183
                        Mileage: 203368 km
                        Date: 2016.12.28
                        Time: 10:23:10
       Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
       Component: BCM PQ35 B    011 0048
       Revision: BA011001
       Coding: 40180A3B81251AC0400800C0100000E443011308424D01626480872000C1
       VCID: 35614BEB9C3FCCEA5F-8060
       Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS    110406  31  0032
       Serial number:         110426211537
       Coding: 004DBD
       Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
       Component: VW10Airbag01L H07 0013
       Serial number: 003GFP8AP2DV
       Coding: 00314C
       ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
       ROD: EV_AirbaVW10TS6VW428.rod
       VCID: 3E7354C7A1090FB28E-806A
       Subsystem 1 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.V  --- ---
       Serial number: 3493ETS60956007149DL
       Subsystem 2 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.V  --- ---
       Serial number: 3503ETS60782A0B14DDS
       Subsystem 3 - Part No SW: ---            HW: ---
       Component: S.Sens.Fah  --- ---
       Serial number: 3513ETS6020480B14DDG
       Subsystem 4 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.H  --- ---
       Serial number: 3523ETS60CE38F813DD8
       Subsystem 5 - Part No SW: ---            HW: ---
       Component: F.Sens.Fahr  --- ---
       Serial number: 35540TS60FE8EE6139D5
       Part No SW: 5K0 953 501 BG    HW: 5K0 953 569 K
       Revision: FF010040    Serial number: 20110415200198
       Coding: 1182040000
       VCID: 70EFBAFFABDDA9C24C-8024
       Coding: E20000
       Part No SW: 7N0 920 870 A    HW: 7N0 920 870 A
       Component: KOMBI         H20 0420
       Coding: 140F00
       VCID: 306F7AFF6B5DE9C20C-8064
       Part No SW: 7N0 907 530 D    HW: 1K0 907 951
       Component: J533  Gateway H35 0614
       Revision:   H35       Serial number: 010511F2001495
       Coding: 468002
       VCID: 31697FFB6857E0CA03-8064
       Component: IMMO          H20 0420
       VCID: 6ADBA8978D01531202-803E
       Part No SW: 3C0 035 279     HW: 3C0 035 279
       Component: RNS315        H05 0010
       Serial number: VWZAZ2L3336528
       Coding: 000004110400000000021000
       ASAM Dataset: EV_RNS315VWEUV1UDS A01005
       ROD: EV_RNS315VWEUV1UDS.rod
       VCID: 60CFCABF7B3D1942DC-8034
    Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
       Part No SW: 7N0 959 793 D    HW: 7N0 959 793
       Component: TSG FA        H04 0400
       Revision:             Serial number: 0000114814038
       Coding: 011006208000411011
       VCID: 43852533C2EB625AE1-8016
    01705 - Selection Switch for Mirror-Adjust (E48)
                        Reset counter: 142
                        Mileage: 203356 km
                        Date: 2011.05.20
                        Time: 21:17:05
       Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.323 0802
       Revision: 1AH03729    Serial number: 00111110295901
       Coding: 0000258
       VCID: 3B755DD37A1B1A9AA9-806E
    Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
       Part No SW: 7N0 959 792 D    HW: 7N0 959 792
       Component: TSG BF        H04 0400
       Revision:             Serial number: 0000115072360
       VCID: 428B2037DDF16B52EA-8016
       Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
       Component: J540 EPB4  VW-55183 0007
       Revision:   H18       Serial number: 00000000326565
       Coding: 0024066
       VCID: 336575F3524BD2DA71-8066
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Component: Batt.regelung H35 0614
       Coding: 030B185A
       VCID: 71E9BFFBA8D7A0CA43-8024
       Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370410649
    Address 62: Door, Rear Left
    Address 72: Door, Rear Right (J389)       Labels: 7N0-959-794.clb
       Part No SW: 7N0 959 794 E    HW: 7N0 959 795 A
       Component: TSG HR        H03 0400
       Revision:             Serial number: 0000115373584
       Coding: 010004200000411001
       VCID: 45813B2BCCDF5C6ACF-8010
    02131 - Child Safety Lock Motor
                        Reset counter: 184
                        Mileage: 203403 km
                        Date: 2011.05.21
                        Time: 17:52:47
    End-------------------------(Elapsed Time: 02:49)--------------------------
    Sep 2016
    Riga, Latvia
    Procedure at post #1 did not work for this car. Nor similar procedures found in other topics here and in other sources of information. I was able to reset SCR level and SCR lock, but SCR efficiency test was refused by control module with message "Error. Request out of range". ECU software update at dealer from V.8254 to some newer version solved this out. TPI 2024801/4.
    I can answer my second question, too - yes, when AdBlue system malfunction related countdown reaches 0, it is not possible to start engine.
  9. Likes Eric, Uwe liked this post
  10. #7
    Nov 2017
    Hungary
    Confirmed
    This method is confirmed on a 2011 VW Sharan 2.0. I forgot the enginecode sorry, but works for us.
    We fought with the start because the conditions wasnt ready, but when its started and the procedure runs thru the result was great.
    Thanks.
  11. Likes DrPeter liked this post
  12. #8
    Jul 2014
    I tried this reset procedure on my 2013 Passat TDI. During the check of SCR efficiency, the ECM never takes control of the engine speed. I gave up pressing the accelerator with my foot after 7 minutes. Is it normal in some cases to not have the ECM take over engine speed during that test? Should I just prop the pedal down with a push-rod and let it run longer?
    Or, am I mistaken in thinking that I can remove my foot from the pedal after a few moments and the ECM will keep the RPMs around 1500?
  13. #9
    Quote Originally Posted by roni024 View Post
    Did you have your other foot firmly on the brake pedal?
  14. #10
    Jul 2014
    Yes, even when removing my foot from the accelerator to see if the RPMs would hold.
    Edit: I should also mention, the glow plug indicator flashes during the procedure. I'm not sure if that's normal.
