Tried resetting steering angle sensor.
VincenzaV
C?ID=245917
I have a new to me 04' TDI Jetta Wagon. My parents gave it to me (I'm not a kid, however). I bought the KII vagcom. They said they brought it to their trusted mechanic due to a diagnosis light that came one. The mechanic said the steering angle sensor/clock spring went (162K miles). I decided to try and clean the connectors on the clock spring/angle sensor with Deoxit just to see if that MIGHT help, as well as reset the sensor. It did not work (expectedly). I found a used OEM ESP (the one I need) equipped one on Ebay from a seller that has a 14 day return policy. Since it was so easy to get to it, I figured it was worth the try on a used one.
I am trying to attach pics (photo bucket links) of what the screen said when trying to recalibrate it. It seems to not of let me do it because the sensor failed?
http://i178.photobucket.com/albums/w268/oshanac/photo 3-12_zpsqhcqiwhb.jpg
http://i178.photobucket.com/albums/w268/oshanac/photo 2-18_zpskjskgsjb.jpg
http://i178.photobucket.com/albums/w268/oshanac/photo 1-17_zpsyceyd9wl.jpg
Your pictures are so fuzzy I'm not 100% certain which ABS you have. It's really easy to make screen shots in Windows. Alt + PrintScreen grabs a bitmap of the currently active window and stuffs it into the Windows Clipboard, from where you can paste it into numerous apps, or even directly into a browser window pointed at Imgur.com.
Assuming you have what I think you have, take a look in the ABS, MBV 004, field one. Turn the wheel from side to side. What happens?
DrPeter
16.4905° S, 151.7375° W
... The mechanic said the steering angle sensor/clock spring went (162K miles). I decided to try and clean the connectors on the clock spring/angle sensor with Deoxit just to see if that MIGHT help, as well as reset the sensor. It did not work (expectedly)...
- Did you happen follow the procedure that we have in the Ross-Tech wiki pages?
Basic Setting - Sensor for Steering Angle (G85)
If you could also please post a complete Auto-Scan, this may shed some light on your concerns,
Thank you,
drpeter
VincenzaV
C?ID=245917
Hi, yes I used the ross-wiki instructions. I', not sure if I can do a screen shot. I have a Winbook TW800 tablet with window 8.1 (I think, 8 or 8.1???). When I am outside in the car, I have no wifi. So can you do a screen shot and then come inside to the wifi zone and post it?
I can take better pictures.
One confusing thing for me in the instructions was when it says "activate the basic setting" option. Activate it how, where? By means of selecting the "Adjustment of Steering Sensor" in drop down? If so, I tried and then hit the dead end as posted above.
I'll try the complete auto scan. How do I do that? Sorry. newbie here.
Sure you can. Alt + PrintScreen, then Paste into the application of your choice. I like Irfanview, but MS Paint (comes with Windows) will do. In either case, save the file in .PNG format (it's the best format for screen-shots), then upload at your leisure when you have Internet access.
Please see this thread.
VincenzaV
C?ID=245917
Hi Uwe, where is the print screen button? I have a tablet remember. I have a virtual keyboard, but don't remember seeing a "print screen" button.
DrPeter
- You may need to attach a USB keyboard to 'PrtScn' (Print Screen)
- The [On/Off/Next] button on the Basic Settings screen, you press it, will 'Activate the Basic Settings'.
- Sorry about that, forgot to add that 'How-to' link ;)
- and I intended to add this link too... Basic Setting - Sensor for Steering Angle (G85)
From the Screen pic, I see [1C0-907-37x-ESP-F.lbl] - That is the MK60, so the above wiki page should apply.
drpeter
VincenzaV
C?ID=245917
Wow, I COMPLETELY missed that button drpeter. I'll have to try it again now that I know I screwed up the process.
Oh, missed the fact that this is a tablet. If the virtual, on-screen keyboard your hardware vendor installed as the default doesn't support PrintScreen, launch Microsoft's own-- OSK.exe -- I just did that on a Dell Venue 8 Pro running Windows 8.1 and that keyboard has a PrtScn "key".
Keithuk
Stoke on Trent, England
C?ID=122432
Laptops are a bit strange from desktop computers. My Samsung you have to press Fn+Alt+Insert/Prt Sc then open Paint up and paste it in Ctrl+V. On my desktop you press Prt Sc and paste it straight in Paint.
VincenzaV
C?ID=245917
Uwe-that computer talk is above my pay grade. The standard virtual keyboard it has does not look like the full one you have there. I'm not sure how to get that one (OSK.exe)?
It comes with Windows. Every version of Windows since XP (at least) has has OSK.exe.
VincenzaV
C?ID=245917
I just have now idea how to use it.
Here is my autoscan.
Sidebar-What does the brake light switch code mean? When this was my dad's car, he had problems with the brake slight going out, seems the cheap designed rear lights had this circuit board like pattern that would come off the plastic base and lose contact. Maybe that's what that code is for?
VCDS Version: Release 14.10.2
Data version: 20150311
Thursday,14,May,2015,19:13:08:22955
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
          76
VIN: WVWRR61J64W189053   Mileage: 271040km-168416miles
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 038 997 016 L    HW: 028 101 114 6
   Component: R4 1,9L EDC G000AG  3791
   Revision: 12345678    Serial number: VWZ7Z0D9680709
   Coding: 0150034
   Shop #: WSC 08088 444 84770
   VCID: 2753F45695B4BF190F5-515A
Address 02: Auto Trans        Labels: 09A-927-750.lbl
   Part No: 09A 927 750 AM
   Component: AG5 Getriebe 09A   0251
   VCID: 76EDE912529E9691443-5178
            28-10 - Short to Plus - Intermittent
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019458
   Shop #: WSC 01266 785 00200
   VCID: 3469131A5462C481BA7-5178
            014 - Defective
   Part No: 1C0 909 605 F
   Component: 17 AIRBAG VW61 0108 0003
   Coding: 12599
   Shop #: WSC 01266
   VCID: 2753F456C5B4BF190F5-513C
   Part No: 1J5 920 906 R
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 15234
   VCID: 3C793B3A2C320CC1727-513C
   WVWRR61J64W189053     VWZ7Z0D9680709
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 01266
   VCID: 70E1DF0A30FAB8A19EF-515A
   Part No: 1C0 959 799 C
   Component: 8A Komfortgerát HLO 0004
   Coding: 00259
   Shop #: WSC 01266
   VCID: 3773241615142F999F5-4B18
   Component: 8A Tõrsteuer.FS KLO 0202
   Component: 8A Tõrsteuer.BF KLO 0202
   Component: 8A Tõrsteuer.HL KLO 0202
   Component: 8A Tõrsteuer.HR KLO 0202
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180 F
   Component:    Radio PM6        0016
   Coding: 00401
   Shop #: WSC 01266
   VCID: 234BE046B18C533953D-515A
End-------------------------(Elapsed Time: 04:26)--------------------------
Sent from Windows Mail
