Module 5F
MRosth
New Member
Sweden
C?ID=240381 (NRRT)
Hi
New here in the forum and I cant access Module 5F on my Audi A6 2015.
Cant find a correct security code.
Monday,11,May,2015,09:08:21:34545
VCDS Version: Beta 15.3.0
Control Module Part Number: 4G1 035 044 B
Component and/or Version: MU-H-LN-EU 041 0073
Software Coding: 017542010000010013110002000A00102F000AE5F1700100DF
Work Shop Code: WSC 02391
VCID: 1E0B9CC9013124C8D5-804B
Advanced Identification/FAZIT
Serial number: A589B0F7507970
Identification: JTB-074
Date: 08.02.15
Manufacturer number: 1170
Test stand number: 006D
Flash Status
Programming Attempts(application): 0/0
Programming Attempts(data): 0/1/1
Successful Attempts(data): 0/1/1
Flash Date: 00.01.01
Flash Tool Code(data): 00200 785 02391
Misc.
Hardware number: 4G1 035 044
Workshop System Name: J794
Equipment/PR Code: 0000000017E92D7B
ASAM Dataset: EV_ª
ASAM Dataset Revision: 001115
Car Info
Chassis Number:
VCDS Info:
Labels: None
ROD: ERROR - EV_ª 001115 (AU57)
Clearly you can access it, since you posted data from it. ;)
What are you trying to do that you think you need a security code for?
MRosth
New Member
Sweden
C?ID=240381 (NRRT)
I can access it, but I cant change any values.
Would like to be able to operate SMS/mail when driving, its set to 0Km/h.
I know its not recommended when driving but I miss that future from my previous A6(year 2013)
MRosth
New Member
Sweden
C?ID=240381 (NRRT)
Monday,11,May,2015,09:17:42:34545
VCDS Version: 15.3.0.0
Data version: 20150314
VIN:    License Plate:
Mileage: 4930km-3063mi   Repair Order:
Chassis Type: 4G (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 34 3B 42 44 46 52 53 55
          5F 62 69 6D 72 AC
VIN: WAUZZZ4G4FN065399   Mileage: 4930km-3063miles
Address 01: Engine (J623-CRTE)       Labels: None
   Part No SW: 4G2     HW: 4G2 907 401
   Component: 3.0TDI EDC17  H33 0001
   Revision: 92H33---
   Coding: 32254012053609030000
   ASAM Dataset: EV_ECM30TDI0114G2907311C 001001
   ROD: EV_ECM30TDI0114G2907311C.rod
   VCID: 2D694B057C97CF505C-8078
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 4G0 927 166 G    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0003
   Revision: --H03---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 3151577560AFABB078-8064
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379.clb
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 27A6DE45E4657BA2BB00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 3FB5014DA6FB4DC0FE-806A
200448 - Function Restriction due to Faults in Other Modules
          U1113 00 [040] - -
                    Mileage: 1769 km
                    Date: 2015.04.03
                    Time: 12:39:18
200192 - Function Restriction due to Implausible Message(s)
          U1112 00 [032] - -
Address 05: Acc/Start Auth.        Labels: 8K0-907-064-05.clb
   Part No SW: 4H0 907 064 FP    HW: 4H0 907 064 EP
   Component: BCM2 2.0      H36 BCM2 2.0      H36 05600560
   Coding: 05A96F4E000000000000
   VCID: 7CCFB641FF6D96D89B-8029
   Subsystem 2 - Part No: 4H0 905 852 C
   Component: J764 ELV MLB
No Faults Found
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Component: KLIMA 4 ZONEN H14 0112
   Serial number: 06021500041889
   Coding: 368211B8210000
   ROD: EV_AirCondiComfoUDS.rod
   VCID: 63FDED3D6AD34920BA-8036
Address 09: Cent. Elect.        Labels: 4H0-907-063.clb
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 BCM1 2.0      H20 03110311
   Coding: 0105C01440349FE04901408300001800CF9C67082E08020100000894E100170200400024030000
   VCID: 71D19775A82FEBB038-8024
   Subsystem 1 - Part No SW: 4G1 955 119     HW: 4G8 955 119
   Component: WWS57X 150125  H37 0080
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Subsystem 4 - Part No: 4H0 907 658
   Component: AQ_Hum_Sensor
No Faults Found
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P10035M0G
   Coding: 30333130313730323735554A304C34473053
   VCID: 3B4D755DB2E351E0D2-806E
   Serial number: 3575HRB405D33RVK2GK4
   Serial number: 3585HRB405P33RVK1ORV
   Serial number: 3515JRB400I533VUCH3P
   Serial number: 3525JRB400C53590HP2P
   Serial number: 3554VRB400S52RDAAP83
   Serial number: 3564VRB406734O9UA1IV
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Revision: --------    Serial number: 90372OAS000IX
   Coding: 000435
   VCID: 38476A518BD57AF83F-806D
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G9 920 950 S    HW: 4G9 920 950 S
   Component: TDieRdw   Nv  H07 0043
   Revision: 03001036    Serial number: 658290115592054
   Coding: 83AF22081B4100080B0600
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K.rod
   VCID: 40B702B1DB05323887-8015
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Component: J533--Gateway H13 0075
   Revision: --------    Serial number: 00000001726520
   Coding: C0CD078118
   ASAM Dataset: EV_ 001024
   ROD: N/A
   VCID: 75D9A365D447C790E4-8020
   Serial number: 3796435403
No ASAM data for: "EV_" (AU57)
4224 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 100
                    Mileage: 3009 km
                    Date: 2015.04.16
                    Time: 16:12:54
5603 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 100
                    Mileage: 3009 km
                    Date: 2015.04.16
                    Time: 16:12:51
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Revision: AA001002
Address 28: HVAC, Rear (E265)       Labels: None
   Part No HW: 4G0 919 158 R
   Serial number: 04021500041014
   Coding: 20
   ROD: EV_ClimaContrUnitRearUDS.rod
   VCID: 5599C3E53487A790C4-8000
Address 34: Level Control (J197)       Labels: None
   Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H19 0783
   Coding: 008001
   ASAM Dataset: EV_AirSuspe 003025
   ROD: EV_AirSuspe_AU57.rod
   VCID: 2F55510D769BBD406E-807A
          C10C8 00 [008] -  -
                    Reset counter: 134
                    Mileage: 4562 km
                    Date: 2015.05.06
                    Time: 19:01:51
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA8208Y137
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2_AU57.rod
   VCID: 365B646989C18C882D-8063
   Coding: 011F16014000620002080002
   VCID: 47A519ADF62B050046-8012
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0017426525
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS.rod
   VCID: 335D5D7D9AB399A00A-8066
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Component: BCM2 2.0      H36 0560
   Revision: 00002001    Serial number: 0359087385
   Coding: 013A0E20A0B93001C320090420010F470000000000000000000000000000
   Coding: 011F16014C00620002080002
   VCID: 46BB14A9F1211C08BD-8013
   Revision: --------    Serial number: 00000001355109
   ROD: EV_ParkiBrake_AU48.rod
Address 55: Headlight Range (J745)       Labels: None
   Part No SW: 4H4     HW: 7P6 907 357 B
   Component: MxB-ECU       001 0081
   Coding: 04FA02102A630200
   ASAM Dataset: EV_ 005003
   ROD: N/A
   VCID: 305752716BA5A2B877-8065
   Subsystem 1 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J
   Coding: E01E00
   Subsystem 2 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J
   Coding: E01E00
   Part No SW: 4G1 ™    HW: 4G1 035 044
   Component: MU-H-LN-EU    041 0073
   VCID: 569BC4E92981AC88CD-8003
   Engine Control Module 2:
   Subsystem 1 - Part No SW: V03 959 801 ET    HW: -----------
   Component: ECE 2015  --- 0105
   Seat Adjustment Driver Side:
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0006
   Serial number: AUZ8Z9FY8012C4
   Sound System:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 ™
   Serial number: 90349OAU0017J
   Door Electronics Rear Left:
   Component: Gracenote  --- 1010
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 99
                    Mileage: 4930 km
                    Date: 2015.05.11
                    Time: 09:09:08
Address 62: Door, Rear Left        Labels: None
   Component: TSG HL        H03 TSG HL        H03 05070507
   Coding: 010F14004000620002080002
   VCID: 49A11F95E03FF37050-801C
No Faults Found
Address 69: Trailer (J345)       Labels: None
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 7B001001    Serial number: 0360256509
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella.rod
656650 - Bulb for Right Turn Signal on Trailer
          C10F6 15 [008] - Open or Short to Plus
                    Reset counter: 116
                    Mileage: 3753 km
                    Date: 2015.04.26
                    Time: 09:57:40
Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0150
   Revision: 14005001    Serial number: 026500616
   Coding: 093205C031
   Shop #: WSC 00000 768 00200
   ROD: EV_HDSGAu571.rod
0015 - Switch in Luggage Compartment for Closing the Rear Lid
          B113D 29 [008] - Signal Implausible
Address AC: Reductant Control (J880)       Labels: None
   Component: SCR
   Revision: 00000000    Serial number: 150
   ASAM Dataset: EV_RDCMA00100 008
   ROD: EV_RDCMA00100.rod
End-------------------------(Elapsed Time: 05:08)--------------------------
MRosth
New Member
Sweden
C?ID=240381 (NRRT)
Anyone that could help?
rlarsen
Copenhagen, Denmark
C?ID=78998
Did you try with the login code you can generate for the VIM ??
Sebastian
Magdeburg, Germany
HN0-nnnnnn
It appears there are several communication errors in you auto-scan, some of which seem to be the reason for your troubles. Meaning, VCDS didn't properly talk to the car. Please contact your VCDS supplier, you're using a Multiscan interface, Ross-Tech only supports KEY, KII, Micro-CAN, HEX, HEX+CAN and HEX-NET hardware.
