Results 11 to 20 of 33
Thread: S3 8V VCDS coding
    Frankyshiu; from the auto-scan report on your first post, it seems that your RLFS is 8U0 955 559 . This the same number as reported in a post by DJAlix who apparently owns an Audi A3 and who was able to get Auto rain-close to work on his car (albeit he had subsequent problems with his sun-roof closing). It might be of value reading this post HERE
  2. #12
    Nov 2014
    San Josť, Costa Rica
    Frankyshiu, your car has the RLFS/RLHS (Rain, Light & Humidity Sensor). m_bolc, your car has the RLS (Rain, Light Sensor).
    So we're still talking about different parts/sensors.
    Ahh, my bad.
    What does the humidity sensor portion of the part do? I pressume it is for the climate control?
  3. #13
    Apr 2015
    Hong Kong
    Thanks Sebastian, DV52 and m_bolc , let me have a look and try tonight
  4. #14
    Apr 2015
    Hong Kong
    had a tried to code to 06885D/07006C , still no any item on screen, was blank....
    how you can let the items popup ? DV52 .. i see your posted.
  5. #15
    Quote Originally Posted by Frankyshiu
    Frankyshiu: 您好 . Not certain that I entirely understand your question, but I'm assuming that you are asking how to show the options in the Long Coding Helper screen. What you need to do is to click on the "down-arrow" tab at the RHS of the screen. I have highlighted this on the picture below
    Cheers
  6. #16
    Apr 2015
    Hong Kong
    My drives is S3, and i changed the code from 00006C to either 06885D or 07006C , still not showing anything under RLS
    ie "Byte 0 - bit 0 - 5 empty ... Byte 1-2 Bit 0-15 empty as well...
  7. #17
    Apr 2015
    Hong Kong
    was blank, not as same as your attached.... Thanks again DV52
  8. #18
    Verified VCDS User DJAlix's Avatar
    Apr 2015
    London, United Kingdom
    There is currently no label file for the A3/S3 RLFS You have to enter the coding manually and tick the bit's blind for the moment. Also there seems to be no way of getting / forcing the MMI Rain Closing Menu to show as there is no way to force a factory reset on the MMI "CAR" section.
    I currently have my A3 coded, manually, as 07006C and rain closing works for all the windows but not the sunroof.
    VAG Car Coding
    Adaptation | Coding | Diagnostic | Retrofit - London, United Kingdom
    Authorised VW Group Services Provider and Independent Repairer
    @vagcarcoding
  9. #19
    Apr 2015
    Hong Kong
    Thanks guys !!
  10. #20
    Apr 2015
    Hong Kong
    any idea on "Audi emergency brake light" mate ? active when braking hard and flashing in rear lamps.
