Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: S3 8V VCDS coding
    Apr 2015
    Hong Kong
    S3 8V VCDS coding
    Audi emergency brake & RLFS both empty for S3 8V, any progress working ?
    For emergency brake (previously in 09- C.E, Long coding Byte 16 ?)
    For RLFS, i had a changed to 06885D, 06A8DD and 07E8DD ... still not working & empty under instrument.
    Many thanks
    Franky
    auto scan here
    Sunday,10,May,2015,09:21:21:35021
    VCDS Version: 15.3.0.0
    Data version: 20150314
    VIN: WAUZZZ8V2EA105185   License Plate:
    Mileage: 17661km-10974mi   Repair Order:
    Chassis Type: 8V (5Q0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 52 55 5F A9
    VIN: WAUZZZ8V2EA105185   Mileage: 17661km-10974miles
    Address 01: Engine (J623-CJXC)       Labels: 06K-907-425-V1.clb
       Part No SW: 8V0 906 259     HW: 06K 907 425 A
       Component: 2.0l R4 TFSI  H09 0006
       Revision: --H09---
       Coding: 0A1D00322406010B3004
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM20TFS0218V0906259 001008
       ROD: EV_ECM20TFS0218V0906259.rod
       VCID: 7DB23179EC79A3D0AC-8028
       Part No SW: 0D9 300 011 R    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H52 4317
       Revision: 05852204    Serial number: TFK01311050883
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 2404241D2F53321883-8071
    10657 - RPM Signal from ECU
              P0726 00 [002] - Implausible Signal
       Revision: 00000000    Serial number: 6318300000059E
       Coding: 32F193A254202A710178070841C8694CC92A5480E08296F6004100388608
       Shop #: WSC 32602 001 104857
       ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
       VCID: 7BB63F61F26DADE092-802E
    8311 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 28
                        Date: 2015.05.03
                        Time: 16:21:57
       Revision: 00021000    Serial number: 0194742840
       Coding: 030C1C
       ROD: EV_KessyHellaMQBAB_AU37.rod
       VCID: 3A38FA65BDD754E8C9-806F
    Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
       Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
       Revision: 20026000    Serial number: 00000000194665
       Coding: 03100014110000011000000000001500
       VCID: 3228D24565A7ACA801-8067
       Part No SW: 5Q0 937 085 T    HW: 5Q0 937 085 T
       Component: BCM MQBAB HNA H16 0124
       Serial number: 00011330901169
       Coding: 07151C42C24106FD01844004B31C07A80800000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 4AD8AAA5ED37C46859-801F
       Slave 1:
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119
       Component: WWS370 131104  041 0580
       Serial number:         131107081908
       Coding: 0A47F7
       Slave 2:
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
       Serial number: 21965176
       Coding: 00006C
       Slave 3:
       Subsystem 3 - Part No SW: 8V0 941 531 G    HW: 8V0 941 531 G
       Serial number: 24 07 2013  00000487
       Serial number: 000000000ZY132802UQL
       Serial number: 00000000000028273518
       Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.009  H02 0007
       Serial number:     WOO2530710Z
       Coding: 901E00
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H02 0033
       Revision: --------    Serial number: 94231332502157
       Coding: 0010050051
       ASAM Dataset: EV_EPHVA18AU3700000 002019
       ROD: EV_EPHVA18AU3700000.rod
       VCID: 3B36FF61B2ED6DE0D2-806E
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 8V0 907 376 B    HW: 8V0 907 376 B
       Component: DAEMPFUNGS-SG H08 0065
       Serial number:       071013943
       ASAM Dataset: EV_AudiMagneRide 002002
       ROD: EV_AudiMagneRide_AU37.rod
       VCID: 40CC888DDB0B0E3887-8015
       Serial number: 003M2R0417UA
       Coding: 98CCC000000000005C54000000C800000065
       VCID: 4BD6AFA1E24DDD6062-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 003 010 13
       Serial number: 35767000000BAA982E06
       Subsystem 2 - Part No SW: -----------    HW: 480 003 010 13
       Serial number: 35867000000FAA982E0B
       Subsystem 3 - Part No SW: -----------    HW: 480 401 511 13
       Serial number: 3516502A11230BC2D20-
       Subsystem 4 - Part No SW: -----------    HW: 480 401 511 13
       Serial number: 3526502A11230BC4210R
       Subsystem 5 - Part No SW: -----------    HW: 480 400 410 13
       Serial number: 3556502AB1142C851263
       Part No SW: 8V0 953 521 CF    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 11111308490454
       Coding: 8418
       ROD: EV_SMLSKLOMQB_AU37.rod
       VCID: 004C488D9B8BCE38C7-8055
       Part No SW: 8V0 920 870 P    HW: 8V0 920 870 P
       Component: KOMBI         H03 2220
       Coding: 278D081ABB8000081801AA00100000
       VCID: 48DC90ADF33B36784F-801D
    Address 19: CAN Gateway (J533)       Labels: Redir Fail!
       Revision: --------    Serial number: 0001276584
       Coding: 030100042B085A005B0002689C0B00000001000000000000000000000000
       ROD: EV_GatewLear_AU37.rod
       VCID: 3FCE8B71A6F571C0FE-806A
       Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
       Serial number: 04 11 2013  E0280787
       Serial number: 3789161803
    8531970 - Quiescent Current
              U1406 00 [008] - Too High
                        Reset counter: 74
                        Mileage: 17438 km
                        Date: 2015.05.03
                        Time: 16:33:29
    Address 22: AWD
       Revision: 00000000    Serial number: 13000251275005
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_AU37.rod
       VCID: 3424D45D9FB3A29813-8061
       Serial number: 09111304080358
       Coding: 005D1E205C01040000001002
       Coding: 8103
       ROD: EV_SteerAssisMQB.rod
       VCID: 3522E95994C9BB9024-8060
       Serial number: 13111302090721
       Coding: 005D16205E01040000001002
       Part No SW: 7P6 907 357 B    HW: 7P6 907 357 B
       Component: AFS-ECU       H01 0040
       Coding: 01A600002B200200
       ASAM Dataset: EV_HeadlRegulLEDAFSMQB 001001
       ROD: EV_HeadlRegulLEDAFSMQB.rod
       VCID: 3E30F675A1FF78C8F5-806B
       Subsystem 1 - Part No SW: 7PP 941 472 E    HW: 7PP 941 472 E
       Component: LED LeiMo li.  H06 7520
       Coding: E00100
       Subsystem 2 - Part No SW: 7PP 941 472 E    HW: 7PP 941 472 E
       Component: LED LeiMo re.  H06 7520
       Coding: E00100
       Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
       Component: LeiMo links  H01 7000
       Coding: E00100
       Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
       Component: LeiMo rechts  H01 7000
       Coding: E00100
       Part No SW: 8V0 035 850 B    HW: 8V0 035 850 B
       Component: MU-S--CN      040 0931
       Serial number: A3603010130619
       Coding: 017303000000000021150002000A00002F0002660100010000
       ROD: EV_MUStd4CPASE_AU37.rod
       Seat Adjustment Driver Side:
       Subsystem 1 - Part No SW: 8V0 919 603 B    HW: 8V0 919 603 B
       Component: DU Std  H48 0013
       Serial number: AUZ8Z9DM700KVY
       Sound System:
       Subsystem 2 - Part No SW: 8V0 919 614 C    HW: 8V0 919 614 C
       Component: ControlUnit_B  H33 0037
       Serial number: C1000006091300010106
    6669 - Optical Data Bus for Digital Sound System
              U10CC 00 [008] - Intermittent Disruption
                        Reset counter: 69
                        Mileage: 17438 km
                        Date: 2015.05.07
                        Time: 21:09:06
       Part No SW: 8V0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0008
       Serial number: 131029200095
    End-------------------------(Elapsed Time: 02:55)--------------------------
    Apr 2015
    Hong Kong
    anyone can help for this .... ?
    Verified VCDS User lala30's Avatar
    Mar 2015
    Croatia
    in Audi you can not do it!
    only skoda , vw and seat
    in audi is different rain sensor...
    Magdeburg, Germany
    Correct, the installed Rain/Light Sensor doesn't support rain closing as far as we know. There's gonna be an updated Beta 15.5 soon, please try that and post a fresh Auto-Scan.
  5. Likes fzanicotti liked this post
    Apr 2015
    Hong Kong
    Hi Sebastain, seem works for S3 8V for rain closing..... can you check ?
    http://www.audi-sport.net/xf/threads...206515/page-22
    Magdeburg, Germany
    Love the "seem" part. I see one statement that "some" module did accept the coding, no indication which part numbers and software levels we're talking about. In other words, not much to work with.
  8. Likes Uwe liked this post
    Verified VCDS User DJAlix's Avatar
    Apr 2015
    London, United Kingdom
    I have managed to get Automatic Rain Closing for Windows only working on the 8V. All my information is in the forum post linked above, on page 23.
    Currently there seems to be no obvious way of getting the Rain Closing feature to include a sunroof if you have one fitted.
    Coding for the RFLS = 07006C:
    Byte 0 = The Sum of all activated features and adjustments
    Bit 0 = Highway Light Function
    Bit 1 = Rain Light Function
    Bit 2 = Rain Closing
    Bits 3 to 5 = Light Activation Threshold earlier (+20% to +80%)
    So 07 = Bits 0, 1 and 2 are Active.
    Byte's 1 and 2 (combined) = Vehicle Model
    XX9597 = A Seat Alhambra
    XX805D = A Skoda Octavia
    XXA8DD = A VW Golf (mk7)
    XX006C = A Audi A3
    *These are the only known Vehicle codes I have found so far.
    There is also an issue with getting the MMI Menu Option for Rain Closing to display. I have not managed to do this yet
    Sebastian, I am more than willing to supply any information that would assist in getting this working. Just need to know what you guys need.
    VAG Car Coding
    Adaptation | Coding | Diagnostic | Retrofit - London, United Kingdom
    Authorised VW Group Services Provider and Independent Repairer
    @vagcarcoding
  10. #8
    Nov 2014
    San José, Costa Rica
    Quote Originally Posted by lala30 View Post
    I can confirm that automatic rain closing is possible with the 8V. I have an A3, but I do not think that Audi would fit a different sensor on the S3.
    My coding is 06885D. Here is an autoscan from my car:
    Wednesday,18,March,2015,18:16:45:29892
    VCDS Version: 14.10.0.0 (x64)
    Data version: 20141022
    VIN: WAUZZZ8V2FA000583   License Plate: TRB043
    Mileage: 16769km-10419mi   Repair Order:
    Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
    VIN: WAUZZZ8V2FA000583   Mileage: 16769km-10419miles
    Address 01: Engine (J623-CJZA)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 016 B    HW: 04E 907 309 A
       Component: 1.2l R4 TSI   H08 6387
       Revision: WAH08---
       Coding: 02110012230400082000
       ASAM Dataset: EV_ECM12TFS01104E906016B 001008
       ROD: EV_ECM12TFS01104E906016B.rod
       VCID: 2149CBAF30BD2E29405-8074
       Revision: 00000000    Serial number: 606040000015FD
       Coding: 10F16AA224200A6C017C060841C62508562450806082A4B2002100388608
       VCID: 7BF5D9C7F291A4F93A9-802E
    16401 - Tire Pressure Warning
              C102D 00 [008] -  -
                        Reset counter: 25
                        Mileage: 16480 km
                        Date: 2015.03.11
                        Time: 17:35:57
    Address 08: Auto HVAC (E87)       Labels: 8V0-820-047.clb
       Part No SW: 8V0 820 047 D    HW: 8V0 820 047 D
       Component: AC Manuell el H11 0052
       Revision: 20021000    Serial number: 00000000054640
       Coding: 00000004100000000000000000000100
       ASAM Dataset: EV_AirCondiFrontManAU37X 008018
       ROD: EV_AirCondiFrontManAU37X.rod
       VCID: 377D05F78E3940999E1-8062
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
       Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
       Component: BCM MQBAB M   H16 0124
       Serial number: 00011406500433
       Coding: 04040842C001027D07044004F30407000000000000000000000000000000
       VCID: 79F9C3CFF8AD96E9285-802C
       Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119
       Component: WWS370 140225  041 0580
       Serial number:         140227184035
       Coding: 0A47F7
       Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A
       Component: G397_RLS  H06 0002
       Serial number: 20143063
       Coding: 06885D
       Subsystem 3 - Part No SW: 8V0 941 531 Q    HW: 8V0 941 531 Q
       Serial number: 29 11 2013  00001158
       Serial number: 000000000ZY140231TB1
       Serial number: 00000000000058976888
       Serial number: 003M2R05LNY8
       Coding: 98CCC000000000005C540000004800000065
       VCID: 4B954907E2B1D479CA9-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 001 702 14
       Serial number: 35767000000685500F0O
       Subsystem 2 - Part No SW: -----------    HW: 480 001 702 14
       Serial number: 35867000000885500F0R
       Subsystem 3 - Part No SW: -----------    HW: 480 400 703 14
       Serial number: 35165029F14D3E72E40M
       Subsystem 4 - Part No SW: -----------    HW: 480 402 802 14
       Serial number: 3526502C112F6291710.
       Subsystem 5 - Part No SW: -----------    HW: 480 400 702 14
       Serial number: 3556502C513013F3D10/
       Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 07031404220752
       Coding: 0608
       VCID: 0603B833B953E911557-8053
    227387 - Windshield Wiper/Washer Switch
              B1149 13 [009] - Open Circuit
                        Reset counter: 239
                        Mileage: 16474 km
                        Date: 2015.03.11
                        Time: 16:26:36
       Part No SW: 8V0 920 860 E    HW: 8V0 920 860 E
       Component: KOMBI         H02 2220
       Coding: 07850200238000080500BA00100000
       VCID: 3C771ADBB71F63C1733-8069
       Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 E
       Component: GW MQB Mid    124 1164
       Revision: --------    Serial number: 0001674704
       Coding: 01010008200864005B000208000B00000001000000000000000000000000
       ROD: EV_GatewLear.rod
       VCID: 3E7310D3A10371D15D7-806B
       Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
       Serial number: 20 02 2014  B1311502
       Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
       Serial number: 22021403110883
       Coding: 00100E20CD00040100001002
       Coding: 0902
       ROD: EV_SteerAssisMQB_AU37.rod
       VCID: 41896B2FD0FD0E29205-8014
       Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
       Serial number: 04031403110700
       Coding: 00100620CD00040100001002
       VCID: 3D7117DFAC056AC944D-8068
       Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
       Component: MU-S--ER      040 0420
       Serial number: A3E00403140672
       Coding: 01730000FF0A000021220001001A00002F0001440100010002
       ASAM Dataset: EV_MUStd6C3PASE 002020
       ROD: EV_MUStd6C3PASE.rod
       VCID: 346732FB9F4FAB81BB3-8061
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0013
       Serial number: AUZ8Z9DY301DHC
       Sound System:
       Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
       Serial number: C1000019021400010341
    End-------------------------(Elapsed Time: 02:51)--------------------------
  11. Likes Uwe liked this post
  12. #9
    Apr 2015
    Hong Kong
    great to hearing this...
  13. #10
    Magdeburg, Germany
    Frankyshiu, your car has the RLFS/RLHS (Rain, Light & Humidity Sensor). m_bolc, your car has the RLS (Rain, Light Sensor).
    So we're still talking about different parts/sensors.
  14. Likes m_bolc liked this post
