Took a scan of the loaner I have while my car is getting the campaigns done. I also did a controller map of some of the modules. I just have to figure out where to put those.
Thursday,07,May,2015,21:15:29:49008
VCDS Version: 15.3.0.0 (x64)
Data version: 20150314
VIN: 3VWD07AJXFM301430 License Plate: 2015 JETTA 1.8SE
Mileage: 120km-74mi Repair Order:
Chassis Type: AJ (6N0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 44 56 75 77 0B
VIN: 3VWD07AJXFM301430 Mileage: 120km-74miles
Address 01: Engine (J623-CPKA) Labels: None
Part No SW: 06K 906 071 B HW: 06K 907 425 C
Component: Simos18.2 H13 8099
Revision: --H13---
Coding: 001A0012242400165000
Shop #: WSC 00066 790 00015
ASAM Dataset: EV_ECM18TFS02006K906071B 001004
ROD: EV_ECM18TFS02006K906071B.rod
VCID: 2A5B320A4D405968B9-807F
Address 02: Auto Trans (J217) Labels: 09G-927-749.clb
Part No SW: 09G 927 749 A HW: 09G 927 749 A
Component: AISIN AG6 G3 129 2856
Coding: 000348
ASAM Dataset: EV_TCMAQ250031 001004
ROD: EV_TCMAQ250031.rod
VCID: 377D1B7E8EF2F48036-8062
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C492200FB850F02E792190041A1100012
VCID: 0407BCB287A46F18E3-8051
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Revision: 00092000 Serial number: 0355269114
Coding: 000F0F
Shop #: WSC 00066 000 00089
ROD: EV_KESSYPQ35G_AU21.rod
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 CG HW: 5C0 820 047 CG
Component: J301 Klimaanlage 0208
Revision: 2001001S Serial number: 00000002556283
VCID: 67DD8B3E56D2A40066-8032
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 E HW: 7H0 937 090 A
Component: BCM PQ25 Max3 H78 0725
Revision: B8078001 Serial number: 78003028150467
Coding: 7B994B9A082B0F0008382080240884C50FC6702E60000050B0A050022844
Shop #: WSC 44022 001 1048576
VCID: 306F2062639C23B877-8065
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Coding: 820000
Subsystem 3 - Part No: 5K0 959 591 A
Component: J245 PS41.402 H02 0003
Coding: 180000
Subsystem 4 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A
Component: E221__MFL-TAT H04 0019
Coding: 280000
Subsystem 5 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Coding: 800000
02660 - Radio Remote Control not Matched/Adapted
Reset counter: 46
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD055455
Coding: 00004B32
VCID: 72EBEA6AA51051A8C1-8027
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J1500029QUA0J
Coding: 303146
Serial number: 3572MSME016C7D49ZZZ2
Serial number: 3582MSME57697D49ZZZB
Serial number: 3516KSME43441533ZZZG
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME4B112333ZZZI
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME53460532ZZZM
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME47100632ZZZI
Part No SW: 5C6 920 954 B HW: 5C6 920 954 B
Component: KOMBI H04 0806
Coding: 270A01
Shop #: WSC 00066 000 00121
VCID: 2D5139167CAE4E505C-8078
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090 A
Component: GW-K-CAN TP20 H78 0725
Revision: B8078001
Coding: 102200
VCID: 70EFE062A31C63B837-8025
Component: IMMO H04 0806
Coding: 000007
VCID: 6ADBF20A8DC0996879-803F
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 15000003351004
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 306F20626B9C23B877-8065
Address 2E: Media Player 3
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 306 3501
Revision: 00H22000
VCID: 39791D4670E6E2F0C0-806C
Address 56: Radio (J503) Labels: None
Part No SW: 1K0 035 188 H HW: 1K0 035 188 H
Component: Radio Prem-8 H07 0009
Revision: -----12S Serial number: VWZ4Z7R3662764
Coding: 01000440020006
VCID: 2D51391674AE4E505C-8078
Address 75: Telematics (J949) Labels: None
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0156
Serial number: 000003554140533
Coding: 02630102C21632107F1606000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_OCULow 002009
ROD: EV_OCULow_SE12.rod
VCID: 14278CF2FFC4FF9873-8041
Address 77: Telephone (J412) Labels: 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666925290
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 326B2A6A659011A801-8067
End-------------------------(Elapsed Time: 03:30)--------------------------
