Results 1 to 6 of 6
Thread: Tiguan changed Byte 18
    Lithuania
    I have VW Tiguan (2012) with Bi-Xenon lights.
    Using Ross-Tech VCDS I've changed Central electric 9 Byte 18 from "00
    Lighting: Standard/Parameter Settings (EEPROM)" to "30 Lighting: VW
    Tiguan (5N1/VW316) Rest of World (RoW)", but now LED lights doesn't work
    and changing back to "00 Lighting" doesn't help.
    Is it possible to restore old settings?
    A car crash is the reason so many errors it is.
    VCDS Version: Release 12.12.2
    Data version: 20140212
    Friday,04,April,2014,17:30:52:13054
    Chassis Type: 5N (7N0)
    Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 2E 37 42 44 46 4C 52
              53 55 56 62 69 72 77
    VIN: WVGZZZ5NZCW062630
    22-AWD -- Status: Cannot be reached 1100
    55-Xenon Range -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Cannot be reached 1100
    72-Door, Rear Right -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 LG    HW: 03L 907 309 AD
       Component: R4 2,0l EDC   H24 2075
       Revision: 42H24---    Serial number: 00000000000000
       Coding: 00250012043600080000
       Shop #: WSC 01324 020 00200
       ASAM Dataset: EV_ECM20TDI01103L906018LG 003006
       ROD: EV_ECM20TDI01103L906018LG.rod
       VCID: 7AFB0626FDEDA7CED53-802F
    14627 - Fuel Pump Control Module
              P025A 00 [167] - Electrical Fault
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
    Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
       Part No SW: 0BH 300 011 K    HW: 0BH 927 711 C
       Component: DSG DQ500-7A  H05 1706
       Revision: 00H05V01
       ROD: EV_TCMDQ500021_SE36.rod
       VCID: 2A5BF6664DCDD74EE53-807F
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 AP    HW: 5N0 614 109 AP
       Component: J104   C6 450M VD8B 0005
       Revision: --H07---    Serial number: 00000005210972
       Coding: 0005441
       VCID: 79F9192A30EBACD6DC9-802C
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 11.75 V
                        Bin. Bits: 00011111
                        Count: 2
                        Hex Value: 0x0000
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
                        Hex Value: 0x0000
                        Voltage: 11.75 V
                        Bin. Bits: 00011111
                        Count: 3
                        Hex Value: 0x0000
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:49
                        Hex Value: 0x0000
                        Voltage: 11.75 V
                        Bin. Bits: 00011111
                        Count: 256
                        Hex Value: 0x0000
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:58
                        Hex Value: 0x0000
                        Voltage: 11.25 V
                        Bin. Bits: 00011111
                        Count: 191
                        Hex Value: 0x0000
       Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
       Revision: 00001004
       Coding: 0000004002
       ROD: EV_ClimaAutoBasis_SE36.rod
       VCID: 800FF4CE1B317D1E1B7-80D5
    13701520 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
    13701536 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
       Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
       Component: BCM PQ35 M    021 0064
       Revision: BC021001
       Coding: 40180A3BA0251AC0400800C0340009E44B552F08736D8560E48400000040
       VCID: 3E73CA36A9454BEEA9B-806B
       Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS 120112 03  32  0010
       Coding: 009795
       Component: RLS 050112 05  54  0403
       Coding: 02304D
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:49
                        Voltage: 12.00 V
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:49
                        Voltage: 12.00 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:53
                        Voltage: 12.00 V
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:53
                        Voltage: 12.00 V
    Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
       Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0025
       Revision: --------    Serial number: 56261202000687
       Coding: 158103
       ASAM Dataset: EV_EPHVA2C000000000 002008
       ROD: EV_EPHVA2C000000000_VW36.rod
       VCID: 4487B8DECFA9213EFFF-8011
    13637396 - Databus
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
    13637397 - Databus
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
    Address 14: Susp. Elect. (J250)       Labels: None
       Revision: 00000000    Serial number: 02011200480002
       Coding: 010180
       VCID: 275D0F5256DFEA26FAD-8072
    03263 - Functional Restriction
                000 - - - MIL ON
                        Fault Status: 11100000
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:47
                        Error Code: 7
                        Bin. Bits: 00000000
    03262 - Comfort Restriction
                        Reset counter: 179
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:47
                        Error Code: 2
                        Bin. Bits: 00000000
    00141 - Rear Body Acceleration Sensor (G343)
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:47
    00774 - Level Control System Sensor; Rear Left (G76)
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:47
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__206 VW10 HI   1918
       Revision: 23016000    Serial number: 003K0P0JBD49
       Coding: 0012342
       VCID: 4C9790FE2FF9E97E37F-8019
       Subsystem 1 - Serial number: 6332MTS657403501
       Subsystem 2 - Serial number: 6342MTS642123501
       Subsystem 3 - Serial number: 6351HTS6U17AV9KJ
       Subsystem 4 - Serial number: 6361HTS6JBFM0AKJ
    6 Faults Found:
    01589 - Igniter for Head-Airbag; Passenger Side (N252)
                        Fault Status: 11100001
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:49
    01588 - Igniter for Head-Airbag; Drivers Side (N251)
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:49
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:49
    01217 - Side Airbag Igniter; Driver Side (N199)
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:49
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:49
    00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:49
       Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
       Revision: FF010040    Serial number: 20120120201837
       Coding: 198A140000
       VCID: 7CF7003EF7D999FEC7F-8029
       Coding: 820000
       Part No SW: 5N0 920 882 C    HW: 5N0 920 882 C
       Component: KOMBI         H04 0417
       Coding: 111F01
       ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
       VCID: 3365EB029A079686565-8066
    9453074 - Fuel Level Sensor 1
              B103E 1B [009] - Resistance Too High
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
    9459739 - Fuel Level Sensor 2
              B1058 1B [009] - Resistance Too High
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
       Revision:   H42       Serial number: 030112F1000862
       Coding: 356002
       VCID: 3A7BC626B56D67CE953-806F
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:49
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:49
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:49
       Component: IMMO          H04 0417
       ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
       VCID: EADBB6660D4D974EA53-80BF
    Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 1T0 035 680 H    HW: 1T0 035 680 H
       Component: RNS-MID       H64 4120
       Revision: AB001001    Serial number: VWZ6Z7M8212073
       Coding: 0400040204000080000C
       Shop #: WSC 00862 461 85084
       VCID: 3365EB0292079686565-8066
    6 Faults Found:
                        Reset counter: 139
                        Mileage: 45184 km
                        Reset counter: 139
                        Mileage: 45184 km
                        Reset counter: 139
                        Mileage: 45184 km
                        Reset counter: 139
                        Mileage: 45184 km
    01523 - Microphone for Telephone (R38)
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:57
    03138 - Input AUX IN
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:04:52
       Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0503
       Revision: 13110009    Serial number: 0004045133
       Coding: 0000B4
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 387FDC2E836175DE637-806D
    65538 - Local Data Bus
              U10BA 00 [009] - No Communication
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
       Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.287 1002
       Revision: 1AH03836    Serial number: 00113570257101
       Coding: 0000258
       VCID: 3C77C03E7F5959FE87F-8069
                        Fault Status: 11101101
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
                        (no units): 4.0
                        Voltage: 12.00 V
       Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0503
       Revision: 15110009    Serial number: 0004037751
       Coding: 0000B4
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 3979D92AB86B6CD69C9-806C
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
       Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
       Component: J540 EPB4  VW-64783 0009
       Revision:   H19       Serial number: 00000000584975
       Coding: 0026157
       VCID: 3561D51A5C7388B6781-8060
                        Fault Status: 01101101
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
                        Voltage: 12.00 V
                        Count: 104
                        Hex Value: 0x1260
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    02432 - Supply Voltage for Left Parking Brake Motor (V282)
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
                        Voltage: 12.00 V
                        Count: 29
                        Hex Value: 0x1270
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    02433 - Supply Voltage for Right Parking Brake Motor (V283)
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
                        Voltage: 12.00 V
                        Count: 30
                        Hex Value: 0x1270
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    Address 55: Xenon Range (J745)       Labels: 5M0-907-357-V3.clb
       Component: AFS-ECU       H04 0111
       Coding: 043A00000B000200
       ROD: EV_HeadlRegulVWAFSPt.rod
       VCID: 377DDF128E7F7AA66AD-8062
       Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329
       Component: LeiMo links  H02 0008
       Coding: 140000
       Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329
       Component: LeiMo rechts  H02 0008
       Coding: 140000
    13705985 - Databus
              U1123 00 [137] - Received Error Message
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
    13705987 - Databus
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
    13705991 - Databus
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:48
    Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
    6 Faults Found:
                        Reset counter: 139
                        Mileage: 45184 km
                        Reset counter: 139
                        Mileage: 45184 km
                        Reset counter: 139
                        Mileage: 45184 km
                        Reset counter: 139
                        Mileage: 45184 km
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:01:57
                        Reset counter: 139
                        Mileage: 45191 km
                        Date: 2024.14.29
                        Time: 00:04:52
    Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
       Revision: 3A001001    Serial number: 00008030012249
       Coding: 410D000100000000
       VCID: 306FE40E6311AD9E2B7-8065
    Thank You
    Last edited by Uwe; 04-10-2014 at 07:43 AM. Reason: Wrapped CODE tags around Auto-Scan
    00 is not the original setting. When you see 00 in Byte 18, it is there to "mask" or "hide" the real setting. It should be possible to restore the original setting if it is known. Hopefully somebody will know it (I don't).
    Mackay Qld Australia
    Here are all of the Tiguan values for Byte 18:
    2F | VW Tiguan (VW316) | Halogen/Xenon | RoW | TFL_0
    30 | VW Tiguan (VW316) | Halogen/Xenon | RoW | TFL_S
    50 | VW Tiguan (VW316) | Halogen/Xenon | NAR | TFL_1
    51 | VW Tiguan (VW316) | Halogen/Xenon | NAR | TFL_S
    8A | VW Tiguan (VW316/416) | Halogen/Xenon | RoW/Ska | TFL_1_Ska
    TFL_0: TFL mit NSL u. RFL (daytime running lights and rear fog light, reversing light)
    TFL_1: mit TFL TFL-Outputs (daytime running lights with daytime running light outputs)
    TFL_S: TFL Skandinavien Abblendlicht m (daytime running lights via Scandinavia low beam lights)
    Lithuania
    "bambazonke" I got one of them to write instead of the 00 value xenon and LED should light?
    Quote Originally Posted by Tomasitas69 View Post
    Sorry Tomas I don't quite understand your response. The Tiguan depending on what country it is sold in, can have any of the 5 codes listed above. If it was me, it would be either the first, second or the last option. That is 2F, 30 or 8A. Try all three and see what happens and then choose one that is applicable for your current rear lights setup. I seriously doubt you car would have been set up for the North American (NAR) market judging by your autoscan you posted (VIN number and workshop codes) and seeing your current BCM configuration in longcoder helper.
  6. Likes Uwe liked this post
    United States
    I don't think this controller was coded to Hex 30 from the factory but replied to this thread with some suggestions: http://forums.ross-tech.com/showthre...ull=1#post1962
