Results 1 to 4 of 4
Thread: 2010 Q5 0B5 2.0FSI DSG No drive
    Oct 2014
    Kenya
    Hey guys,
    I have the above vehicle. We had to replace the mechatronic unit as usual on this model. the part was supplied by Audi Germany(the owner supplied it himself when he travelled there) and the component protection was also released by a technician from Audi using the VasPC. also the Mechatronic was installed as per instructions from ELSA.
    for some reason there is no drive to the wheels even though the gear lever moves through the entire range from P to S.
    Have I missed something?
    Monday,04,May,2015,16:37:00:40454
    VCDS Version: 15.3.0.0
    Data version: 20150314
    VIN: WAUZZZ8R9AA103351   License Plate: UAQ 550H
    Mileage: 43980km-27327mi   Repair Order: Kenneth Q5
    Chassis Type: 8R (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 2E 42 46 47 52 53 56 62 72
              77
    VIN: WAUZZZ8R9AA103351   Mileage: 43980km-27327miles
    Address 01: Engine (CL0MA-CDNC)       Labels: 06H-907-115-CAB.clb
       Part No SW: 8R0 907 115 A    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H16 0006
       Revision: E1H16---
       Coding: 0121000C240F0060
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_ECM20TFS8R0907115A A02007
       ROD: EV_ECM20TFS0118K2907115AJ.rod
       VCID: 326DA2D365B167A801-8067
    2937 - Please Check Fault Codes in Transmission Control Module
              U1026 00 [044] - -
                        Mileage: 43984 km
                        Date: 2015.05.04
                        Time: 15:49:09
    Readiness: 1110 0001
    Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
       Part No SW: 8R0 927 156 AB    HW: 0B5 927 156 E
       Component: 0B5 20TFSIRdW H04 0006
       Revision: --H04---    Serial number: 0000001658
       Coding: 000001
       Shop #: WSC 04940 001 00001
       ROD: EV_TCMDL501.rod
       VCID: 7BF34FF7F27B66E092-802E
    8938 - Base Measurements
              P17CA 00 [109] - Implausible Data
                        Reset counter: 40
                        Mileage: 43984 km
                        Time: 00:00:00
    Address 03: ABS Brakes (J104)       Labels: 8R0-907-379-V1.clb
       Part No SW: 8R0 907 379 L    HW: 8R0 907 379 L
       Component: ESP8 quattro  H07 0010
       Coding: 021540
       VCID: 499FE53FE027047050-801C
                        Fault Status: 00101101
                        Reset counter: 152
                        Mileage: 43984 km
                        Date: 2015.05.04
                        Time: 15:49:08
                        Hex Value: 0x00C0
                        Hex Value: 0x0782
                        Hex Value: 0x000A
                        Hex Value: 0x238F
                        Hex Value: 0x00FF
    Address 05: Acc/Start Auth.        Labels: 8K0-907-064-05.clb
       Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
       Component: BCM2 1.1      H02 0328
       Coding: 011500
       VCID: 010F3D1F98970C30C8-FFFF
       Part No SW: 8T2 820 043 AD    HW: 8T2 820 043 AD
       Component: KLIMA 1 ZONE  H08 0171
       Revision: B0000000    Serial number: 01140420100576
       Coding: 64050000
       VCID: 74E164CBD7252998D3-8021
       Part No SW: 8K0 907 063 L    HW: 8K0 907 063 L
       Component: BCM1 1.0      H29 0380
       Revision: 07029001    Serial number: 00000000516731
       Coding: 690040B10034A7010001000000005F5F001D460802000101000000
       VCID: 387990FB8BCD8DF83F-806D
       Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 100309  H10 0041
       Coding: 01DD13
       Component: RLS  H04 0003
       Coding: 024D25
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
    Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
       Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0070
       Revision: 11001001    Serial number: 51241010915250
       Coding: 000105
       VCID: 479BE307F633F20046-8012
    Address 15: Airbags
       Revision: --------    Serial number: 90304JDE0009F
       Coding: 000013
       VCID: 3D7781EFA4EFA8D0EC-8068
       Component: E221 - MFL  H02 0010
    Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 980 J    HW: 8R0 920 980 J
       Component: KOMBIINSTR.   H11 0255
       Revision: 00200000    Serial number: CJJ73UL3A
       Coding: 2F06220002002600010000
       VCID: 4089F81BD31DC53887-8015
       Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0117
       Revision: GB800053    Serial number: 5300G104118016
       Coding: 00CB03
       VCID: 010F3D1F98970C30C8-8054
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0140
                000 -  -  - Intermittent
                        Reset counter: 192
                        Mileage: 43984 km
                        Date: 2015.05.04
                        Time: 14:19:22
                        Bin. Bits:    10111
                        Voltage: 11.40 V
                        Count: 6
    Address 2E: Media Player 3 (R199)       Labels: 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0290
       Revision: 00000000
       Coding: 020202
       VCID: 397F95FFB0C794F0C0-806C
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000010501164
       Coding: 011002205001440004
       VCID: 4587E90FCC3FE010B4-8010
       Revision: 00002001    Serial number: 0128845987
       Coding: 013B0622203900940430053280000000
       Component: J245EE20SKB13  H01 0220
       Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J394EE20SKB13  H01 0220
    Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
       Part No SW: 8R0 035 223 F    HW: 8R0 035 223 E
       Component: DSP STD       H11 0440
       Revision: 00000000    Serial number: 00000000000001
       Coding: 0203010102
       VCID: 2F6BABA77E834A406E-807A
    02247 - Subwoofer (R148/R157)
                        Reset counter: 152
                        Voltage: 12.40 V
                        Temperature: 27.0°C
                        Bin. Bits: 00000100
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000010501729
       VCID: 4481F40BC705D918A3-8011
       Revision: 00000003    Serial number: 10000000488065
       VCID: 3461A4CB97A5699813-8061
    Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
       Part No SW: 8T2 035 186 P    HW: 8T2 035 186 P
       Component: Concert3      H06 0350
       Revision: 00000010    Serial number: AUZ5Z6J1388706
       Coding: 0402008201058D00015B070800
       Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
       Component: Display
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000103462486
       Coding: 010002204001240004
       VCID: 428DF213DD11D72891-8017
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000103462483
       Part No SW: 8T0 862 335 D    HW: 8T0 862 335 D
       Component: FSE_256x BT     H39 0600
       Revision: 00000000    Serial number: 00000005182439
       Coding: 0010320
       VCID: 3B738FF77AFBA6E0D2-806E
    End-------------------------(Elapsed Time: 07:32)--------------------------
    United States
    If you haven't done so already please try this Basic Settings procedure:
    http://forums.ross-tech.com/showthre...ll=1#post23158
  3. Likes Uwe, dubTECH, jyoung8607 liked this post
    Northern ireland
    As Dana has already pointed out, you need to run the basic settings to set the travel paths for the selectors or it won't drive. This should have been stated in Elsa.
  5. Likes jyoung8607, Uwe liked this post
  6. #4
    Oct 2014
    Kenya
    Results
    Results:
    [Basic Settings - 04]
    - From the pull down list select one of the following at a time, press
    [Go] and when it has completed press [Stop].
    [Erase counter for start and stop processes]-error request out of range
    [Clutch valve calibration]- Aborted safety reasons
    [Distance sensor calibration]- finished sucessfully.
    car now has drive and no faults logged in the memory.
    thank you people
  7. Likes jyoung8607, Uwe liked this post
