Hey guys,
I have the above vehicle. We had to replace the mechatronic unit as usual on this model. the part was supplied by Audi Germany(the owner supplied it himself when he travelled there) and the component protection was also released by a technician from Audi using the VasPC. also the Mechatronic was installed as per instructions from ELSA.
for some reason there is no drive to the wheels even though the gear lever moves through the entire range from P to S.
Have I missed something?
Monday,04,May,2015,16:37:00:40454
VCDS Version: 15.3.0.0
Data version: 20150314
VIN: WAUZZZ8R9AA103351 License Plate: UAQ 550H
Mileage: 43980km-27327mi Repair Order: Kenneth Q5
Chassis Type: 8R (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2E 42 46 47 52 53 56 62 72
77
VIN: WAUZZZ8R9AA103351 Mileage: 43980km-27327miles
Address 01: Engine (CL0MA-CDNC) Labels: 06H-907-115-CAB.clb
Part No SW: 8R0 907 115 A HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H16 0006
Revision: E1H16---
Coding: 0121000C240F0060
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_ECM20TFS8R0907115A A02007
ROD: EV_ECM20TFS0118K2907115AJ.rod
VCID: 326DA2D365B167A801-8067
2937 - Please Check Fault Codes in Transmission Control Module
U1026 00 [044] - -
Mileage: 43984 km
Date: 2015.05.04
Time: 15:49:09
Readiness: 1110 0001
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8R0 927 156 AB HW: 0B5 927 156 E
Component: 0B5 20TFSIRdW H04 0006
Revision: --H04--- Serial number: 0000001658
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 7BF34FF7F27B66E092-802E
8938 - Base Measurements
P17CA 00 [109] - Implausible Data
Reset counter: 40
Mileage: 43984 km
Time: 00:00:00
Address 03: ABS Brakes (J104) Labels: 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 L HW: 8R0 907 379 L
Component: ESP8 quattro H07 0010
Coding: 021540
VCID: 499FE53FE027047050-801C
Fault Status: 00101101
Reset counter: 152
Mileage: 43984 km
Date: 2015.05.04
Time: 15:49:08
Hex Value: 0x00C0
Hex Value: 0x0782
Hex Value: 0x000A
Hex Value: 0x238F
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0328
Coding: 011500
VCID: 010F3D1F98970C30C8-FFFF
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8T2 820 043 AD HW: 8T2 820 043 AD
Component: KLIMA 1 ZONE H08 0171
Revision: B0000000 Serial number: 01140420100576
Coding: 64050000
VCID: 74E164CBD7252998D3-8021
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 L HW: 8K0 907 063 L
Component: BCM1 1.0 H29 0380
Revision: 07029001 Serial number: 00000000516731
Coding: 690040B10034A7010001000000005F5F001D460802000101000000
VCID: 387990FB8BCD8DF83F-806D
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 100309 H10 0041
Coding: 01DD13
Component: RLS H04 0003
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 Q HW: 8K0 919 475
Component: PARKHILFE 4K H06 0070
Revision: 11001001 Serial number: 51241010915250
Coding: 000105
VCID: 479BE307F633F20046-8012
Address 15: Airbags
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304JDE0009F
Coding: 000013
VCID: 3D7781EFA4EFA8D0EC-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 980 J HW: 8R0 920 980 J
Component: KOMBIINSTR. H11 0255
Revision: 00200000 Serial number: CJJ73UL3A
Coding: 2F06220002002600010000
VCID: 4089F81BD31DC53887-8015
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G104118016
Coding: 00CB03
VCID: 010F3D1F98970C30C8-8054
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0140
Reset counter: 192
Mileage: 43984 km
Date: 2015.05.04
Time: 14:19:22
Bin. Bits: 10111
Voltage: 11.40 V
Count: 6
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020202
VCID: 397F95FFB0C794F0C0-806C
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000010501164
Coding: 011002205001440004
VCID: 4587E90FCC3FE010B4-8010
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0128845987
Coding: 013B0622203900940430053280000000
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H01 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H01 0220
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8R0 035 223 F HW: 8R0 035 223 E
Component: DSP STD H11 0440
Revision: 00000000 Serial number: 00000000000001
Coding: 0203010102
VCID: 2F6BABA77E834A406E-807A
02247 - Subwoofer (R148/R157)
Fault Status: 01101011
Reset counter: 152
Voltage: 12.40 V
Temperature: 27.0°C
Bin. Bits: 00000100
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000010501729
VCID: 4481F40BC705D918A3-8011
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000488065
VCID: 3461A4CB97A5699813-8061
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 P HW: 8T2 035 186 P
Component: Concert3 H06 0350
Revision: 00000010 Serial number: AUZ5Z6J1388706
Coding: 0402008201058D00015B070800
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000103462486
Coding: 010002204001240004
VCID: 428DF213DD11D72891-8017
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000103462483
Part No SW: 8T0 862 335 D HW: 8T0 862 335 D
Component: FSE_256x BT H39 0600
Revision: 00000000 Serial number: 00000005182439
Coding: 0010320
VCID: 3B738FF77AFBA6E0D2-806E
End-------------------------(Elapsed Time: 07:32)--------------------------
