Page 8 of 8 FirstFirst ... 678
Results 71 to 80 of 80
Thread: 2004 Audi A8 Energy Management problems?? Please help
  1. #71
    Mar 2015
    Rhode Island
    Quote Originally Posted by BostonSlaya View Post
    A nice update that's AWESOME!!! The car is fixed!!! The battery drain from the start was a software update. The main reason why there was still a battery drain after the software update was because the sound system was in component protection so the module wouldn't turn off. It's been sitting all day and the Amps are still strong!! We will see of course how the battery indicator is after and leave that as an update. I have read before even if there is no battery drain sometimes the battery regulator still records it as low. I'm a little nervous qbout this because of the battery coding being rejected. Yeah thanks for the help everyone and I hope this thread helps others.
    After overnight the battery is still up good but the battery indicator is showing 10%? so of corse I'm getting a DTC on the battery regulator on vcds. Any ideas? Thanks
  2. #72
    Probably due to incorrect code inserted of the battery in BDM.
    Ultimately you may require a new battery with a correct code inserted.
  3. #73
    Mar 2015
    Rhode Island
    Thanks for the response jake.
    I try to code the battery and still gives me a reject coding. I even tried other BEM numbers and serials and still won't take it in VCDS but it does save the info. Also I'm still getting the Nav not turning off sometimes to make the car fall asleep unless I pull the Nav fuse. Could this be a Nav issue? Thanks
  4. #74
    Getting the correct Battery + coded and all the firmware updated is the start of correcting.
  5. #75
    Mar 2015
    Rhode Island
    I have the correct varta battery installed only 4 months old directly from Audi so it should take the BEM and serial number but it doesn't. One time ago it finally accepted it but that was before the Mmi update. Also what firmware? The battery regulator firmware?? Thanks
  6. #76
    I think you should take your car to the Audi dealer/qualified repair station.
    You are grasping at straws, rationalizing becoming argumentative. and not reading repair information or TSB's.
    "Core Control is aware of the problem......no more information is available at this time"
    Please refrain from speculation and do actual tests or present testing data that is related to VCDS with questions if not understood.
    I think this thread is done for me.
    Take care and do self test........see if NAV is being powered from back feed by tracing WD.
    http://wiki.ross-tech.com/wiki/index...4E)_Navigation
  7. #77
    Mar 2015
    Rhode Island
    I have been very busy and haven't been able to get this fixed yet. I purchased a loop and pluged it into every module in the sound system and car still doesn't go night night lol...
    I let the car sit and let the battery drain down and did a rescan, here it is below...
    Sunday,24,January,2016,22:41:51:14758
    VCDS Version: 15.7.3.0 (x64)
    Data version: 20151216
    VIN: WAUML44E74N017518   License Plate:
    Mileage: 90420km-56184mi   Repair Order:
    Chassis Type: 4E (4E0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 25 28 34 36 37 38 42 46
              47 4F 52 53 56 61 62 72
    VIN: WAUML44E74N017518   Mileage: 90420km-56184miles
    0E-Media Player 1 -- Status: Malfunction 0010
    Address 01: Engine        Labels: 077-910-560-BFM.lbl
       Part No SW: 4E0 910 560 A    HW: 4E0 907 560
       Component: 4.2L V8/5V      G   0070
       Revision: 00000000    Serial number: AUX3Z0CD531019
       Coding: 0007773
       Shop #: WSC 02313 785 00200
       VCID: 1F4DDD45CE847AC668-804A
    Readiness: 0010 1101
       Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
       Component: AG6 09E 4,2L5V USA  0110
       Revision: 00000001    Serial number:        0027237
       VCID: 2447D2A9E7E2591E35-8070
    Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
       Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
       Component: ESP 5.7 allrad  H46 0510
       Coding: 0007597
       Shop #: WSC 23435 000 00000
       VCID: 224BD4B1FDF6572E47-8076
    Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
       Part No SW: 4E0 910 131     HW: 4E0 909 131 A
       Component:     FBS AUDID3  H03 0140
       Revision: 01403903    Serial number: AUX3Z0CD531019
       Coding: 0263168
       Shop #: WSC 02311 785 00200
       VCID: 58BFB659EB2ACDFE69-800C
                        Reset counter: 25
                        Mileage: 90416 km
                        Date: 2016.01.24
                        Time: 19:40:48
    Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
       Part No SW: 4E0 910 732 S    HW: 4E0 035 729
       Component: Interfacebox    H43 4610
       Revision: 00000000    Serial number: 346IP047514325
       Coding: 0000103
       VCID: 326B24F1AD16C7AEB7-8066
       Subsystem 1 - Part No: 4E0 910 611
       Component: E0380 BedienteilH01 0050
       Subsystem 2 - Serial number: 00000000097794
       Subsystem 3 - Serial number: 0113.11.130000000100010015˙
       Subsystem 4 - Serial number: 010015˙
                        Reset counter: 25
                        Time Indication: 15
       Part No SW: 4E0 910 043     HW: 4E0 820 043 B
       Component: KLIMAAUTOMAT    016 0240
       Revision: 00000022    Serial number: 00000000033347
       Coding: 1151313
       VCID: 5ABBAC519526DFEE5F-800E
       Subsystem 1 - Part No: 4E0 910 772 A
       Component: Sitzluefter  FS H02  010
       Subsystem 2 - Part No: 4E0 910 772 A
       Component: Sitzluefter BFS H02  010
       Subsystem 3 - Serial number: 898053000
       Subsystem 4 - Serial number: HO15122003065A000000000168˙†89
       Subsystem 5 - Serial number: 000168˙†898053000      000-SHO
       Subsystem 6 - Serial number:     000-SHO18122003065A00000000
       Subsystem 7 - Serial number: 65A000000000072˙
    00066 - Rear Right Footwell Heater (Z43)
                        Reset counter: 240
                        Mileage: 90404 km
                        Date: 2016.01.24
                        Time: 15:19:05
                        Voltage: 13.70 V
    Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
       Part No SW: 4E0 910 279 E    HW: 4E0 907 279 E
       Component: ILM Fahrer      H11 0100
       Coding: 0111113
       VCID: 2A5B3C9185C68F6E0F-807E
       Subsystem 1 - Part No: 4E1 910 113
       Component: Wischer WWS D3  H30 0320
       Coding: 00000030
       Shop #: WSC 02313
    00532 - Supply Voltage B+
                        Reset counter: 25
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 20:37:40
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111
       Component: CD-Changer      H43 0470
       Serial number: AUZ5ZBC1016260
       VCID: 1C37EA49DF9261DE8D-8048
                        Reset counter: 25
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 20:36:26
    Address 15: Airbags        Labels: 4E0-910-655-84.lbl
       Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
       Component: Airbag 8.4E+    H10 0920
       Coding: 0530707
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549     HW: 4E0 953 549 A
       Coding: 0012241
       VCID: 65C18FADAC586016E2-8030
       Component: Lenkradmodul    H04 0080
                        Reset counter: 24
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 20:36:48
                        Reset counter: 24
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 20:39:25
    Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
       Part No SW: 4E0 910 900     HW: 4E0 920 950 B
       Component: KOMBIINSTR. VDO H44 0090
       Revision: D15         Serial number: AUDID3CD006664
       Coding: 0000202
       Shop #: WSC 65537 000 00032
       VCID: 5CB7AA499F1221DE4D-8008
                        Reset counter: 25
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 20:14:23
    Address 19: CAN Gateway        Labels: 4E0-910-468.lbl
       Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
       Component: Gateway         H07 0030
       Revision: 07          Serial number: 0200503C0111AE
       Coding: 7CFE5FCC1B2104
       Shop #: WSC 07228 444 53694
       VCID: 2643C8A191DEAB0E2B-8072
                        Reset counter: 24
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 20:40:02
    00384 - Optical Databus
                        Fault Status: 00101011
                        Reset counter: 24
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 22:31:06
    Address 25: Immobilizer        Labels: 4E0-910-131.lbl
       Coding: 0263168
       XXXXXXXXXXX ELV                 XXXX
                        Reset counter: 25
                        Mileage: 90416 km
                        Date: 2016.01.24
                        Time: 19:40:48
       Part No SW: 4E0 910 158     HW: 4E0 919 158 A
       Component: KLIMA-STG. FOND 015 0210
       Revision: 00000014    Serial number: 00000000013996
       Coding: 0000000
       VCID: 61C99BBDB8700C361E-8034
    Address 34: Level Control        Labels: 4E0-910-553.lbl
       Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
       Component: LUFTFDR.-CDC    H05 4290
       Coding: 0015510
       Shop #: WSC 22145 444 54027
       VCID: 2541CFADECD8A01622-8070
                        Reset counter: 24
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 22:36:19
       VCID: 55A1BF6DBC38F09672-FFFE
    No Faults Found
       Part No SW: 4E0 910 887 K    HW: 4E0 919 887 C
       Component: MNS US          H42 0570
       Revision: 00000000    Serial number: 355LS037511437
       VCID: 35611FED5C78D09692-8060
                        Reset counter: 25
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 20:31:20
    Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
       Part No SW: 4E0 910 135 A    HW: 4E0 907 135
       Component: Dachknoten D3   H01 0090
       Serial number: 00000332500063
       Coding: 0004021
       VCID: 1D31E74DC48868D67A-8048
                        Reset counter: 24
                        Mileage: 90424 km
                        Date: 2016.01.24
                        Time: 22:27:00
    02138 - Control Circuit for Front Right Interior Lights
                        Reset counter: 240
                        Mileage: 90424 km
                        Date: 2016.01.24
                        Time: 22:33:00
    00211 - Control Circuit for Rear Illumination Lights
                        Reset counter: 240
                        Mileage: 90424 km
                        Date: 2016.01.24
                        Time: 22:33:00
    Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
       Part No SW: 4E1 910 802     HW: 4E1 959 801
       Component: Türsteuer.FS BRM005 0110
       Coding: 0000540
       VCID: 5EB3A041890E33CE23-800A
    02111 - Motor for Window Regulator
                        Reset counter: 25
                        Mileage: 90416 km
                        Date: 2016.01.24
                        Time: 22:18:32
                        Reset counter: 25
                        Mileage: 90416 km
                        Date: 2016.01.24
                        Time: 22:18:32
    Address 46: Central Conv.        Labels: 4E0-910-289.lbl
       Part No SW: 4E0 910 289 A    HW: 4E0 907 289
       Component: Komfortgeraet   H03 0030
       Revision: 00300003    Serial number:  W040312110112
       Coding: 0065278
       VCID: 275DC5A596D4B20610-8072
       Component: Heckdeckel      H06 0060
       Component: Neigungssensor  H02 0020
                        Reset counter: 24
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 21:00:04
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 240
                        Mileage: 193858 km
                        Date: 2011.08.15
                        Time: 01:50:33
    Address 47: Sound System        Labels: None
       Part No SW: 4E0 910 224 C    HW: 4E0 035 223 B
       Component: DSP-High D3/AUX H13 0470
       Revision: Dev_D01     Serial number: 00000000655399
       Coding: 0000000
       VCID: 1E33E041C98E73CE63-804A
                        Reset counter: 240
    02084 - Component Protection
                        Fault Status: 01100101
                        Reset counter: 240
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 22:33:15
    Address 4F: Centr. Electr. II        Labels: None
       Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
       Component: ILM Beifahrer   H08 0020
       Revision:             Serial number: 00000000030051
       Coding: 0010111
       Subsystem 1 - Serial number: VK4978T078WE
                        Reset counter: 24
                        Mileage: 90424 km
                        Date: 2016.01.24
                        Time: 22:20:00
                        Reset counter: 24
                        Mileage: 90424 km
                        Date: 2016.01.24
                        Time: 22:27:00
                        Reset counter: 24
                        Mileage: 90424 km
                        Date: 2016.01.24
                        Time: 22:18:00
    Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
       Part No SW: 4E1 910 802     HW: 4E1 959 802
       Component: Türsteuer.BF BRM005 0110
       Coding: 0000540
                        Reset counter: 25
                        Mileage: 90416 km
                        Date: 2016.01.24
                        Time: 22:18:32
                        Reset counter: 25
                        Mileage: 90416 km
                        Date: 2016.01.24
                        Time: 22:18:32
    Address 53: Parking Brake        Labels: 4E0-910-801.clb
       Part No SW: 4E0 910 801 A    HW: 4E0 907 801
       Component: EPB  AV1C1010   H01 1010
       Revision: AV1C1010
       Coding: 0000532
       Shop #: WSC 23435 444 58960
       Part No SW: 4E0 910 541 T    HW: 4E0 035 541
       Component: TUNER EU/US/RDW H41 0630
       Revision: 00000000    Serial number: 304CE047583230
       Shop #: WSC 06802 176 59446
       VCID: 31692BFDA810FCB6CE-8064
    Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
       Part No SW: 4E0 910 181 A    HW: 4E0 915 181
       Component: ENERGIEMANAGER  H02 0230
       Revision: 00000000    Serial number: 00000004980755
       Shop #: WSC 07212 444 82777
       Subsystem 1 - Part No: 000 915 105 DL
       Component: von VA0  310314E03L
       Coding: 303030393135313035444C5641303331303331344530334C
                000 -  -  - Intermittent
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 17:19:23
    02276 - Quiescent Current Stage 5
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 17:19:33
    02274 - Quiescent Current Stage 3
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 17:19:43
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 17:19:53
                        Reset counter: 25
                        Mileage: 90426 km
                        Date: 2016.01.24
                        Time: 20:41:56
    Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
       Component: Türsteuer.HL BRM003 0100
       Coding: 0004108
                        Fault Frequency: 0
                        Reset counter: 25
                        Mileage: 90416 km
                        Date: 2016.01.24
                        Time: 22:18:32
                        Fault Frequency: 0
                        Reset counter: 25
                        Mileage: 90416 km
                        Date: 2016.01.24
                        Time: 22:18:32
    Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802     HW: 4E0 959 802 A
       Component: Türsteuer.HR BRM005 0110
       Coding: 0000012
       VCID: 5DB1A74D840828D63A-8008
                        Reset counter: 25
                        Mileage: 90416 km
                        Date: 2016.01.24
                        Time: 22:18:32
                        Reset counter: 25
                        Mileage: 90416 km
                        Date: 2016.01.24
                        Time: 22:18:32
    End-------------------------(Elapsed Time: 03:15)--------------------------
  8. #78
    Mar 2015
    Rhode Island
    I'm not sure but would this cause a car not to sleep? My driver side rear door has close assistance motor, passenger rear door does not! I'm not even sure a 2004 came with the option.
  9. #79
    Mar 2015
    Rhode Island
    Can someone help? Thanks
  10. #80
    Mar 2015
    Rhode Island
    OK, I have a update somewhat... So I have been pulling my 30amp fuse in the boot so my car goes to sleep forever now still looking for the problem. I have a quick question, can the MMI screen itself keep the car from going NIGHT NIGHT? I ask because the other day I noticed the screen much darker then normal, I pressed on it and boom it brightened right up.
    I have a extra screen sitting here but didn't want to go through the work installing the new screen if it would be a problem with the car going to sleep. To answer a head of time no the screen doesn't stay on after it folds down and car is of and no it hasn't gone dark sense. Thanks in advance I Appreciate all the help. Below is a current scan if needed...
    Saturday,28,May,2016,13:05:35:14758
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    Mileage: 100120km-62211mi   Repair Order:
    Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 28 34 36 38 42
              46 47 4F 52 53 55 56 61 62 72 76
    VIN: WAUML44E74N017518   Mileage: 100120km-62211miles
       Coding: 0007773
       VCID: 1F4DDD45CE847AC667-804A
    Readiness: 0010 1001
       VCID: 2447D2A9E7E2591E3A-8070
       Coding: 0007597
       VCID: 224BD4B1FDF6572E48-8076
       Coding: 0263168
       VCID: 58BFB659EB2ACDFE66-800C
       Subsystem 1 - Part No: 4E0 905 852 C
       Component: ELV                 1734
       Part No SW: 4E0 910 760 C    HW: 4E0 959 760
       Component: Sitzmemory BFS H07  0060
       Revision: 00000000    Serial number: 5DS 008 795-03
       Coding: 3940960
       Shop #: WSC 23435 444 82899
       VCID: 2345D1B5E2EC5E2643-8076
       Coding: 0000103
       VCID: 326B24F1AD16C7AEB8-8066
       Coding: 1151313
       VCID: 5ABBAC519526DFEE50-800E
                        Reset counter: 145
                        Mileage: 100121 km
                        Date: 2016.05.28
                        Time: 12:49:36
                        Voltage: 12.50 V
       Coding: 0111113
       VCID: 2A5B3C9185C68F6E00-807E
       Coding: 00000030
       Shop #: WSC 02313
       VCID: 1C37EA49DF9261DE82-8048
    Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
       Part No SW: 4E0 910 593 D    HW: 4E0 035 593
       Component: SDAR SIRIUS     H04 0670
       Revision: 00000000    Serial number: AUZ4Z7E2009013
       VCID: 285FC6999BCABD7E16-807C
       Coding: 0530707
       Coding: 0012241
       VCID: 65C18FADAC586016ED-8030
       Coding: 0000202
       VCID: 5CB7AA499F1221DE42-8008
    Address 19: CAN Gateway        Labels: 4E0-910-468.clb
       Coding: FCFE7FDC1B0904
       VCID: 2643C8A191DEAB0E24-8072
       Coding: 0263168
       Component: ELV                 1734
       4E0905852C  ELV                 1734
       Component: KLIMA-STG. FOND 015 0220
       Revision: 00000018    Serial number: 00000000027901
       Coding: 0000000
       VCID: 61C99BBDB8700C3611-8034
       Coding: 0015510
       VCID: 2541CFADECD8A0162D-8070
       Component: Sitzmemory FS  H07  0060
       Coding: 4071522
       Serial number: 00000331600277
       Coding: 0003989
       VCID: 1D31E74DC48868D675-8048
       Component: Türsteuer.FS BRM007 0110
       Coding: 0028196
       VCID: 5EB3A041890E33CE2C-800A
       Coding: 0065214
       VCID: 275DC5A596D4B2061F-8072
       Component: Heckdeckel   P14H06 0070
                        Reset counter: 145
                        Mileage: 193858 km
                        Date: 2011.08.15
                        Time: 01:50:33
       Coding: 0000016
       Shop #: WSC 54321 444 12345
       VCID: 1E33E041C98E73CE6C-804A
       Coding: 0010111
       Subsystem 1 - Part No: 4E0 910 511 A
       Component: UGDO HL US      H02 0030
       Subsystem 2 - Serial number: VK4978T078WE
       Coding: 0028196
       Revision: AV1C1010
       Coding: 0000532
    Address 55: Headlight Range        Labels: 4E0-910-357.lbl
       Part No SW: 4E0 910 357     HW: 4E0 907 357
       Component: Pre-AFS         H01 0030
       VCID: 62CB94B1BD76172E08-8036
       VCID: 31692BFDA810FCB6C1-8064
       Component: von VA0  310314E03G
       Coding: 303030393135313035444C56413033313033313445303347
       Part No SW: 4E0 910 802     HW: 4E0 959 801 A
       Component: Türsteuer.HL BRM007 0110
       Coding: 0032300
       VCID: 5DB1A74D840828D635-8008
       Component: Türsteuer.HR BRM007 0110
       Coding: 0032300
    Address 76: Park Assist        Labels: 4E0-910-283.lbl
       Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
       Component: Parkhilfe 8-Kan H11 0010
       Revision: --.--.--    Serial number: 00000335600021
       Coding: 0001208
       VCID: 2149DBBDF8F04C3651-8074
    End-------------------------(Elapsed Time: 02:57)--------------------------
