Results 1 to 6 of 6
Thread: Please help with Golf 5 Cruise control retrofit
    May 2015
    Bulgaria
    can anybody help me with a Golf 5 cruise control retrofit information. The Golf is MY09 1.9TDI, Chassis Type: 1K, and Steering wheel: 1K0 953 549 DA. According to the Steering Wheel Control Module Versions table my module has no Steering Angle Sensor and LIN is not supported. So here are my questions:
    1. Do I need a Steering Wheel Control Module that supports LIN and which one would be suitable for my car if mine is not suitable? My assumption would be 1K0-953-549-CF (Type 2 / SW 0111 / Highline), but still I would need confirmation by someone more experienced, that this one would do the job.
    2. Do I have to do anything about the Steering Angle Sensor especially if I Use The 1K0-953-549-CF Control Module?
    3. What is the proper Cruise Control Switch/Lever - does it have a specific part No. and how would I know which one is proper for me?
    Would be very grateful if anyone could help me with answers to these questions.
    Here is part of the scan if it can help:
    Address 01: Engine Labels: 03G-906-021-BLS.clb
    Part No SW: 03G 906 021 QJ HW: 03G 906 021 AB
    Component: R4 1,9L EDC 000SG 1984
    Revision: --H11--- Serial number: VWXBZ0J5043137
    Coding: 0000071
    Shop #: WSC 76112 146 181318
    VCID: 77FD3C1D066824995FA-8022
    Part No SW: 1K0 953 549 DA HW: 1K0 953 549 DA
    Component: J0527 053 0111
    VCID: 74E70B11171E4F817A8-8021
    Part No SW: 1K0 920 854 R HW: 1K0 920 854 R
    Component: KOMBIINSTRUMENT YJU 4005
    Revision: V0010000 Serial number: VWXBZ0J5043137
    Coding: 0007103
    Shop #: WSC 01225 002 1048576
    VCID: 3A7BE52975FAF9F1604-806F
    Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
    Part No SW: 1K0 907 530 S HW: 1K0 907 951
    Component: J533 Gateway H07 0071
    Revision: H07 01 Serial number: 220409F2001437
    Coding: E9807F06000202002002
    VCID: 377DFC1D46E8E4999FA-8062
    Tartu, Estonia
    1. You need at least midline SW controller, that suports cruise. LIN is only needed when you're retrofitting Multi-Function Steering Wheel. And there you need to determine the type of LIN it uses. Older 8 button ones LIN1.3 and newer LIN2.0
    http://wiki.ross-tech.com/wiki/index...odule_Versions
    2. No. Steering angle sensor is built in 44-Steering assist(Electrical power steering)
    3. 1K0953513G
    The world is my oyster...
  3. Likes ee3Si liked this post
    May 2015
    Bulgaria
    Thank you for the prompt answer and valuable information.
    I have some more questions to make everything very clear:
    Will any midline ot highline controller (1K0-953-549 xx) be ok, should it match the existing software level and slipring? Then I believe I should look for a model without Steering Angle Sensor?
    Thank you in advance.
    Tartu, Estonia
    You need to match slipring and angle sensor. In some cases if you have AT trans. you also have to match the ability to control lock solenoid, but every other aspect is solely on your needs.
    May 2015
    Bulgaria
    Thanks again, it is all clear now. I'll post the results after I collect the parts and do the job.
    United States
    This thread is rather old but the OP provided feedback recently and we updated that Mk5/6 SWCM Wiki page. 1K0-953-549 CD in addition to a LIN 1.3 MFSW from a B6 Passat were successfully configured.
  8. Likes Uwe liked this post
