Autoscan needed for Beetle
BeetleTDI
C?ID=234807
I need to see a scan of a 2012-2014 Beetle with 6spd manual and factory backup camera. I figure it will also have navigation. A TDI would be great but not necessary. I've added aftermarket Nav and RVC with Idatalink Maestro RR to my 2013 Beetle TDI with manual transmission, and am experiencing some strange behavior. I've seen DSG trans beetles that work but no manual. I would like to compare my coding to another manual transmission beetle with rear view camera installed.
I certainly don't want to discourage anyone from posting scans, but I'm skeptical that codings appropriate for factory Nav and RVC will shed much of any light one what's necessary to to make your aftermarket stuff work.
I also notice that idatalink.com doesn't seem to consider your Beetle supported. ;)
BeetleTDI
C?ID=234807
Not sure what you mean. Idatalink shows that the Maestro RR fully supports all trim levels and years of The Beetle. The module actually works for the most part. It's just not exchanging navigation data with the MFD. The Audio data, and steering wheel controls work perfectly. The module also doesn't recognize the reverse signal on the can bus. The CECM is wired differently on the manual trans vs DSG, but I would think the bus signals would have been the same. I was just curious if there was some coding difference that enables the data exchange. I know on some models, this won't work until you disconnect the compass module, but I can't find any evidence I have one of those in the Beetle.
Sorry, I must have missed something on my first pass through their site, so I retract the statement above that idatalink.com doesn't to consider your Beetle supported
BeetleTDI
C?ID=234807
Beetle aftermarket Nav display in MFD with Idatalink Maestro RR
After more searching, I think the main issue I'm dealing with isn't related to the CECM. If I code nav into the installation list, I get the nav display on the MFD, but the instrument cluster is frozen in whatever state it was in when the nav connected to it. The last time I tried it, the instruments were stuck with most of the warning lights on, including the parking brake. The car starts, and runs fine, the tach, speedo, and fuel gauge are working, but the lights stay on. The MFD is also stuck on whatever screen was up when the nav connected, and does not update. The steering wheel controls for the mfd do nothing also. I tested the controls with vcds, and the switches are seen by the controller, but the mfd doesn't respond. Once it's in this state, the only way out of it is to remove nav from the installation list, and disconnect the battery for a few seconds. Turning the car off does nothing. Even after many minutes of power off, and doors closed/locked, the MFD is still lit, and stuck on the last screen. The warning lights also stay on. Once the nav is removed from the installation list, and the battery disconnected for a few minutes then re-connected, everything goes back to normal. It's as if selecting nav freezes the communication to the instrument cluster at least partially with only the tach, speedo, and fuel gauge working. I see nothing in the scan that explains this, but here is the scan anyway. I know the radio, and nav don't show up as connected, but that's how it worked on my Golf with no issues, and idatalink says it should work. I'm going to update the Nav firmware tomorrow, and see if anything changes.
Any ideas are welcome.
Monday,04,May,2015,20:17:30:49008
VCDS Version: 15.3.0.0 (x64)
Data version: 20150314
VIN: 3VWRL7ATXDM656173   License Plate: BEETLE
Mileage: 55200km-34299mi   Repair Order:
Chassis Type: AT (6N0)
Scan: 01 03 05 08 09 15 17 19 25 2B 2E 37 44 56 77
VIN: 3VWRL7ATXDM656173   Mileage: 55200km-34299miles
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 906 019 AN    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000SG  4815
   Revision: 12H15---    Serial number:
   Coding: 0050072
   Shop #: WSC 00066 000 00000
   VCID: 77FDDB7E06723480F6-8022
000897 - Glow Plug/Heater Indicator Circuit
               P0381 - 000 - Implausible Signal
                    Mileage: 55204 km
                    Temperature: 25.2°C
                    Voltage: 12.39 V
                    Bin. Bits: 01000000
                    Torque: 219.0 Nm
                    Temperature: 46.8°C
Readiness: 0 0 0 1 0
   Part No SW: 5C0 907 379 C    HW: 5C0 907 379 C
   Component: ESP MK60EC1   H31 0156
   Revision: 00H31001
   Coding: E14B401649270000870C02EB921C0042A71000
   VCID: 2E533E1A79A8354865-807B
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 086 1101
   Revision: 00086000    Serial number: 0189241823
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02715
   ROD: EV_KESSYPQ35G_AU21.rod
   VCID: 34672C729F841F9813-8061
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 BC    HW: 5C0 820 047 BC
   Component: J301  Klimaanlage   0204
   Revision: 2001111S    Serial number: 00000001328242
   VCID: 62CB9A2ABDF0C128B1-8037
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 5C0 937 086 E    HW: 5C0 937 086 A
   Component: BCM25 JLB M3  H67 0256
   Revision: B0067001    Serial number: 04351355120050
   Coding: 3BBC29B8080B080000A82800260D84C50082402F60000000B2E004000000
   Shop #: WSC 00066 123 12345
   Subsystem 1 - Part No SW: 5C5 959 801 M    HW: 5C5 959 801 M
   Component: J386__TSG_FT  011 1032
   Coding: 800000
   Subsystem 2 - Part No SW: 5C5 959 802 P    HW: 5C5 959 802 P
   Component: J387__TSG_BT  011 1032
   Coding: 800000
   Subsystem 3 - Part No SW: 5C0 959 442     HW: 5C0 959 442
   Component: E221__MFL-YVJ  H02 0103
   Coding: E20000
   Part No SW: 5C0 959 655 Q    HW: 5C0 959 655 Q
   Component: AirbagVW10G   013 0851
   Serial number: 003LKM02SBS6
   Coding: 00004E45
   ROD: EV_AirbaVW10SMEVW360_SK35.rod
   VCID: 408F70A2DB3CB33887-8015
   Serial number: 6940000Y120000MHVX0U
   Coding: 30304C
   Serial number: 3572MSME2E022273ZZZP
   Serial number: 3582MSME59012273ZZZN
   Subsystem 4 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Serial number: 3556LSME28180920ZZZO
   Subsystem 5 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Serial number: 3566LSME7E0F0920ZZZ%
   Part No SW: 5C5 920 970 G    HW: 5C5 920 970 G
   Component: KOMBI         H23 0103
   Revision: X0023005    Serial number:
   Coding: 250E01
   Shop #: WSC 00066 123 00125
   ASAM Dataset: EV_KombiUDSMM9RM10 A04712
   ROD: EV_KombiUDSMM9RM10_VW01.rod
   VCID: 2F6D231E76A23C406E-807A
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 5C0 937 086 A
   Component: GW-K-CAN TP20 H67 0256
   Revision: B0067001
   Coding: 402000
   VCID: 70EFE062A31C63B837-8025
                    Reset counter: 196
                    Mileage: 55204 km
                    Date: 2015.05.04
                    Time: 20:10:17
   Part No SW: 5K0 953 234     HW: 5C5 920 970 G
   Component: IMMO          H23 0103
   Coding: 000007
   Shop #: WSC 00066 000 00125
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_SE25.rod
   VCID: 6ADBF20A8DC0996879-803F
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 12000268220003
   Coding: 4100000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7663908493
   Coding: 010100
   VCID: 2A5B320A45405968B9-807F
00464 - Control Module with Display for Radio and Navigation (J503)
                    Reset counter: 196
Address 37: Navigation
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 377D1B7E46F2F48036-8062
00750 - Warning Lamp
                    Fault Status: 11101101
                    Reset counter: 196
                    Mileage: 55204 km
                    Date: 2015.05.04
                    Time: 20:07:57
                    Voltage: 12.88 V
                        DD
                    Temperature: 31.0°C
Address 56: Radio
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007663952008
   Coding: 0A10040000010110
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3A7B024ABDE0E9E8C9-806F
9457427 - Left audio channel for speech/telephone
          B104F 13 [009] - Short to GND
                    Reset counter: 196
                    Mileage: 55204 km
                    Date: 2015.05.04
                    Time: 20:12:38
9457171 - Right audio channel for speech/telephone
          B104E 13 [009] - Short to GND
                    Reset counter: 196
                    Mileage: 55204 km
                    Date: 2015.05.04
                    Time: 20:12:38
End-------------------------(Elapsed Time: 02:37)--------------------------
BeetleTDI
C?ID=234807
I updated the Nav firmware, and OS for the Kenwood. The result was the same as before. ADS is working on finding a manual transmission Beetle TDI to test since they only tested a DSG, and assumed the manual would be the same. There is definitely something different, and I hope to have an explanation soon. I had hoped to see a scan from a manual transmission Beetle TDI with Nav to see if there are any obvious differences in coding other than Nav in the installation list. It would appear this is a rare combination.
BeetleTDI
C?ID=234807
I've found several scans of other Beetle TDI's and notice one difference between them, and mine. They all have B9 Aux display in the list of installed modules. I have the gauges on the dash, and they work fine, but no B9 module in the installation list ( which I'm told is the aux. Instruments on the dash ). The B9 is not available to add in the installation list either. I would appreciate any information on this.
NEtech
C?ID=56995
They have all: 6R0 907 530.. for [19-CAN Gateway] and 6R0 937 088.. for [09-Cent.Elect.]
BeetleTDI
C?ID=234807
I thought this might be the case, but I recently received a scan from another Beetle TDI 6 spd manual that has the same modules I have, but also has the B9. I don't mind upgrading the 09-Cent.Elect. if that will add functions I want, but I would like to make sure it will work, then I need to get the details on how to do it. I've seen one other Beetle that was upgraded, but can't get the details. If the last scan I found is any indication, it would appear I don't need to upgrade. The only difference between that Beetle and mine is the software version on the 09 module, and the fact it has B9, and Telematics. I would post that scan, but I only have it in PDF, and can't get it to post as code and keep the format correct.
