Results 11 to 20 of 38
Thread: How to read wiring diagrams - the videos (final version)
    Feb 2016
    Thanks!
    Great Videos! Thanks for posting. Now if I can keep my German colors straight . . .
  2. #12
    Mar 2016
    Quote Originally Posted by senna1 View Post
    HI jeff.
    I have Elsawin, which i have slowly learnt, The only part that i cant understand is for some earth circuits it says for example 410. Earth connection 1 in main wiring harness, do you know how to find this earth location,, Where as you know most regular earths on the diagrams such as 605 tells you where it is located,, on top of end of steering column.
    but where is the earth when for example it says earth connection 1.
    If you are able to isolate the wiring from the battery supply/ECM's to allow a safe check of the wiring, then use the ECT 2000, Google it and watch a video demo of it in use, when you get used to using it you will find electrical testing much quicker.
  3. #13
    Nov 2014
    New Zealand
    Interesting, the talk about the 410 connection, and the sender earth from the instument cluster:
    When I put the Gold R32 cluster, into the Touran, the outside temp sensor, fuel sender earths and coolant level sensor etc had NO earth - however, does the diagram above, mean that pins 19 AND 31 should be earthed? The Touran ONLY has an earth on pin 19, Does the Golf cluster require one on pin 31 too, and that would provide the earth to these sensors?
    I currently have the sender earth connected to a chassis earth, to get these sensors working.
    This is the ONLY time, I have seen this on a diagram... though I have found a couple of mistakes in the diagrams I'm using fo the R32 Touran conversion.
    I must say, I've worked a LOT with Subaru diagrams too, and they make MUCH more sense to me!
    Last edited by NZDubNurd; 09-13-2016 at 02:46 AM. Reason: Apparently my S key is a bit dodgy! and the control of my fingers!
  4. #14
    Sep 2016
    Riga, Latvia
    Here pin 19 is number of pin. "31" is "label" or "meaning" what is this pin for.
    Japanese diagrams are build using different principles.
    Try to work with french car wiring diagrams and You will see complete neverending nightmare
  5. Likes Uwe, Jack@European_Parts, ExcelAutos liked this post
  6. #15
    Nov 2014
    New Zealand
    Quote Originally Posted by MartinsX View Post
    I thought that too, like the can-l can-h etc. Weirdly, it goes from pin 19, to earth connection 367, and to the earth point at the top of the steering column. Just seems weird to have a label!
    Thanks.
  7. #16
    May 2014
    Quote Originally Posted by NZDubNurd View Post
    NZDubNurd: I agree that VW's nomenclature on WD is arcane and certainly not intuitive, but your circled pin does make sense if you make reference to DIN 72552 (which is itself an arcane document, but one that is widely used in European vehicles in general and German cars in particular).
    The mysterious "31" in your circled part of the wiring diagram means "Terminal 31" - which is defined in the "Battery" part of the DIN standard and it means "return to battery- or direct to ground"
    So, the good Burghers at VW have been kind-enough to indicated on the WD the purpose of PIN #19 (i.e. ground) in the same way that the pins for CAN high/low are indicated
    Google DIN 72552 to find the full list of DIN numbers
    PS: A "nice" example in the DIN standard is the the relationship between Terminal 30 (which is a hard 12 volt pin) and Terminal 15 (which is a switched 12 v pin) - it's nice that the switched number is half the full volt number (I think, at least)
  8. Likes ExcelAutos, NZDubNurd liked this post
  9. #17
    Nov 2014
    New Zealand
    Aha! Makes sense...
    ...except I haven't seen it ANYWHERE else in these diagrams, and I've probably spent 300 hours processing them... some of them are memorized!
    Nah.. DubNurd!
  10. Likes DV52, Jack@European_Parts liked this post
  11. #18
    May 2014
    I've probably spent 300 hours processing them [WD s]... some of them are memorized!
    Nah.. DubNurd!
    NZDubNurd: 300 hours??? Just remember that contrary to popular belief, the human brain DOES have a finite limit - I can attest to this having reached an advanced level of mental decrepitude, my self. From bitter experience, I can say with certainty that when the brain's memory capacity is reached, it's a LIFO process (Last-In-First-Out)
    I only wish that someone had told me this fact when I was young, so I could make-sure that the "lower" memory address locations were filled with important information - as it was, my early interests were focused on useless stuff like girls and fast cars!
    So my advice to you (pending the veracity of my assumption of you being "disgustingly young") is don't make the same mistake that I made - Fill those important lower memory address locations in your brain with data that will be useful when you reach my advanced years (hint: WD info isn't a contender)!
  12. Likes Jack@European_Parts liked this post
  13. #19
    Nov 2014
    New Zealand
    I have no life.
    Edit: I'm 37 :-)
  14. Likes Jack@European_Parts liked this post
  15. #20
    May 2016
    Must be why Einstein stated, don't bother memorizing what you can look up, just know where to look it up.
    Larimore.
