Results 21 to 30 of 31
Thread: How to read wiring diagrams - the videos (final version)
  1. #21
    Aug 2016
    The Hague, NL
    no wonder today's youth is so stupid. they rely on google wikipedia and urban dictionary.
  2. Likes PetrolDave liked this post
  3. #22
    May 2014
    ^^^Michel: with respect - I can't agree.
    I never cease to be amazed by today's youth - of course it's a gross exaggeration to generalize, but the youth that I speak-to tend to think differently to my generation and invariably their thought processes are far more efficient and much more incisive (IMO).
    I guess it's because the value and the quantum of information has changed dramatically over the years and because the mechanisms to access data has exploded exponentially!!
    I think it's called "evolution".
    PS: However, I do agree that youth is wasted on the young - but this was also true when I was young (soooooo many years ago, now)
  4. #23
    Aug 2016
    The Hague, NL
    on that I can agree!
  5. #24
    Maybe not stupid but careless - go to any subject on wikipedia that you have personal knowledge of and spot the glaring errors which when you correct them invariably get put wrong again!
    Wikipedia is NOT reliable is the bottom line, you have to cross reference it against other sources.
  6. #25
    Aug 2016
    The Hague, NL
    small life pro tip, wikipedia itself isn't great but in the natural sciences and history it's not too bad. but if you want to go in-depth, check out the citations at the bottom section on wikipedia. that usually refers to good and elaborative sources.
  7. Likes Uwe liked this post
  8. #26
    Sep 2015
    I've watched both videos and done some additional reading of the self study materials but I haven't found a description of what a "Plus Connection" is. I see it listed in the WD I have on eBahn for my Touareg.
    Also on page 15 of the PDF that goes with the two videos it shows an A15 in a circle. I'm wondering how this connection with the letter designation differs from the other connections (no letters) described as "weld connections"
    Can someone enlighten me?
  9. #27
    The A15 in a circle should be described in the legend on that page of the diagram.
  10. #28
    Sep 2015
    It is on the legend, but it says
    "Plus Connection 13 (15a) (in main wiring harness)"
    another says
    " Plus Connection 2 (15a) (in main wiring harness)"
    I'm wondering what a plus connection is
  11. #29
    HQ
    Short answer, it is a weld point, several wires joined together:
    A very generic example of a weld point, wires joined together.
    The "15a" should be a circuit that has battery positive voltage with the ignition turned on. Where these weld points are located in the vehicle? Not documented.
    Jef
  12. Likes jyoung8607, Uwe liked this post
  13. #30
    Jun 2014
    Newcastle, England
    Quote Originally Posted by DicknNancy View Post
    Battery positive; i.e. '+' hence 'plus'. With reference to ground.
    Jef excellently illustrates how it is physically constructed, they're then insulated and buried deep in the wiring harness.
  14. Likes Uwe liked this post
