Results 1 to 8 of 8
Thread: Deep down the byte 18 rabbit hole after installing OEM US LED tails on 12 GLI...
    Apr 2015
    I have a 2012 Jetta GLI non nav halogens. I installed a set of US-spec (from hybrid I guess?) LED tails and I'm having a worse and worse time trying to code them, with now non-lighting coding errors coming up.
    First of all I was getting rear fog warning light after install. This set does not have rear fog nor is the car wired for it as far as I know. I don't care about rear fog - would be nice but not worth effort, though I do have auto headlight switch with rear fog capability. The car has no additional modifications beyond what I just mentioned.
    Anyway, now I'm getting a bunch of errors in autoscan beyond just those related to the lighting setup, not to mention that none of the byte 18 variations (including those done w/out long code) have fixed the issue. Car was at dealer today for DSG flush and I asked them to reset to factory via their system that connects to Germany. My coding changes were indeed reset (and it fixed a weird issue I had with trunk) but the LED DRLs won't come on at all still and there are still warnings for about every possible exterior light upon startup. This was not the case when I first started on this. I also had previously followed some instructions on letting BCM reset and try recoding to original settings but that didn't work either. Dealer reset also did not resolve DRLs or autoscan ABS/TPS monitoring error plus several other autoscan errors. There are no dash lights or anything beyond lights out bulb. The LED tails work except that the dimming parameters seem to be off as the turn signals are extremely bright while brakes and night lamps extra dim.
    I have no idea WTF is going on at this point so any suggestions are tremendously appreciated! As per the norm, a seemingly semi-simple mod has gone way over my head !
    Here is my latest, post-dealer VCDS autoscan:
    Thursday,23,April,2015,18:11:01:48450
    VCDS Version: 14.10.2.0
    Data version: 20150311
    VIN: 3VW4A7AJ3CM048038 License Plate:
    Mileage: 83190km-51691mi Repair Order:
    Chassis Type: AJ (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 47 4F 52 56 62
    72 77
    VIN: 3VW4A7AJ3CM048038 Mileage: 83190km-51691miles
    Address 01: Engine (CBF) Labels: 06J-907-115-CBF.clb
    Part No SW: 06J 906 027 K HW: 06J 907 309 B
    Component: MED17.5.2 TFSI 2 03 2908
    Revision: PAH04--- Serial number:
    Coding: 040301081C070160
    Shop #: WSC 09417 444 100808
    VCID: 334BF61652882AB9A3D-8066
    Address 02: Auto Trans Labels: 02E-927-770.lbl
    Part No SW: 02E 300 057 B HW: 02E 927 770 AL
    Component: GSG DSG AG6 511 2730
    Revision: 05351113 Serial number: 00001103201160
    Shop #: WSC 00066 000 00000
    VCID: 181121BA2B2EE9E1B6F-804D
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: A14B600C49260002850B06E792210041A70800
    VCID: 7BDB1E36FA5822F93BD-802E
    Reset counter: 81
    Mileage: 83195 km
    Date: 2015.04.23
    Time: 00:04:55
    Count: 2
    Count: 12
    Count: 29184
    Count: 16390
    Count: 49664
    Count: 254
    Address 08: Auto HVAC
    Part No SW: 5K0 937 086 L HW: 5K0 937 086 L
    Component: BCM PQ35 M 011 0048
    Revision: BJ011001
    Coding: 2F200A1A902F06C400080080000005640100008840808D625C 8000000040
    Shop #: WSC 64979 001 1048576
    VCID: 3D5FD02EA4CCECC9459-8068
    Fault Status: 00101010
    Reset counter: 80
    Mileage: 83195 km
    Date: 2015.04.23
    Time: 13:38:57
    Term 15 On
    Voltage: 12.55 V
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
    Fault Status: 01101010
    Reset counter: 40
    Mileage: 83195 km
    Date: 2015.04.23
    Time: 13:38:59
    Term 15 On
    Voltage: 12.50 V
    Address 15: Airbags
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
    Revision: FF010040 Serial number: 20110614300276
    Coding: 089A140000
    Shop #: WSC 00066 000 00187
    ROD: EV_SMLSNGVOLWS.rod
    VCID: 76CD0F02C97A7F91443-8023
    Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H06 0010
    Coding: 830000
    Part No SW: 5C6 920 971 B HW: 5C6 920 971 B
    Component: KOMBI H04 0617
    Coding: 271E01
    Shop #: WSC 00066 000 00118
    VCID: 2C79ED6A47B67541E27-8079
    Part No SW: 7N0 907 530 K HW: 1K0 907 951
    Component: J533 Gateway H40 1620
    Revision: H40 Serial number: 06091101290627
    Coding: 351002
    VCID: 3851C13A8BEEC9E196F-806D
    Part No SW: 561 919 965 HW: 561 919 965
    Component: Kompass 001 0001
    Revision: 00001000 Serial number: 1829227R046005
    VCID: 63EB4656A2E8FA3913D-8036
    Component: IMMO H04 0617
    VCID: 6AF52B728DC2AB71D0B-803F
    Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
    Revision: A1001003 Serial number: 7660408300
    VCID: 2977147E40446069191-807C
    Part No SW: 561 959 701 HW: 3C0 959 793 B
    Component: TUER-SG FT 002 0515
    Revision: 13110009 Serial number: 0003310845
    Coding: 0004B5
    Shop #: WSC 01383 790 50316
    ROD: EV_TSGFPQ35BRFVW46X.rod
    VCID: 5B9B7EB65298C2F95BD-800E
    Slave Driver:
    Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
    Component: J388__TSG-HL 006 1508
    Serial number: 00000005996724
    Coding: 000490
    B11EC 54 [008] - Missing Calibration / Basic Setting
    Reset counter: 80
    B11EE 54 [008] - Missing Calibration / Basic Setting
    Reset counter: 80
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 70 3201
    Revision: 00H20000
    Shop #: WSC 02069 000 90108
    VCID: 3449F50A57862D81BA7-8061
    Address 47: Sound System
    Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
    Part No SW: 7N0 907 532 HW: 1K0 907 951
    Component: EZE_2 H40 1620
    Coding: 01030100
    VCID: 6FC33A66BE204E59875-803A
    Subsystem 1 - Part No SW: 5K0 959 591 HW: 5K0 959 591
    Component: J245 PS41.019 H08 0006
    Coding: 180000
    Address 52: Door Elect, Pass.
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 1K0 035 180 AD HW: 1K0 035 180 AD
    Component: Radio Prem-8 H04 0018
    Revision: -----17S Serial number: VWZ4Z7L3192332
    Coding: 0102000001
    VCID: 62E543527DF2F33118B-8037
    Reset counter: 40
    Mileage: 77651 km
    Date: 2014.05.28
    Time: 11:36:20
    Address 77: Telephone
    End-------------------------(Elapsed Time: 02:08)--------------------------
    Tartu, Estonia
    First...What options have you tried for byte 18?
    I have many tables for that byte...
    All of them found from www , haven't tried out any of them myself as i don't have such car.
    ===LED TAIL LIGHTS===
    04; ROW; halogen(GTI); DRLs=LED(+Parking Lights); Tail Lights=LED; Rear Fog-Yes
    15; ROW; halogen(GTI); DRLs=Incandescent; Tail Lights=LED; Rear Fog-Yes
    41; ROW; Xenon; DRLs=No (LED Parking Lights); Tail Lights=LED; Rear Fog-Yes
    44; ROW; Xenon DRLs=No; Tail Lights=LED; Rear Fog-Yes
    22; ROW/Japan;halogen; DRLs=No; Tail Lights=LED; Rear Fog-Yes
    3F; Ska; Xenon; DRLs=perm Low Beams; Tail Lights=LED; Rear Fog-Yes
    43; Ska; halogen; DRLs=perm Low Beams; Tail Lights=LED; Rear Fog-Yes
    1F; NAR; halogen; DRLs=Incandescent; Tail lights=LED; Rear Fog=No
    21; NAR; halogen; DRLs=LED(+Parking Lights); Tail lights=LED; Rear Fog=No
    ===INCANDESCENT TAIL LIGHTS w/ REAR FOG===
    02; ROW; halogen; DRLs=Incandescent; Tail lights=Incandescent; Rear Fog=Yes
    3C; ROW; Xenon; DRLs=perm Low Beams; Tail lights=Incandescent; Rear Fog=Yes
    40; ROW; halogen; DRLs=No; Tail lights=Incandescent; Rear Fog=Yes
    42; Ska; Xenon; DRLs=LED(+Parking Lights); Tail lights=Incandescent; Rear Fog=Yes
    Hex;Primary Vehicle;Secondary Vehicle;Lighting;Region;Details
    05;VW Jetta (VW351); ;Halogen;RoW;TFL_0
    4A;VW Jetta (VW351); ;Xenon;RoW;PO_LED
    4B;VW Jetta (VW351); ;Xenon;RoW;TFL _LED
    7E;Audi Q3 (AU316);VW Jetta (VW351);Halogen/Xenon;Südk.;TFL_0
    7F;Audi Q3 (AU316);VW Jetta (VW351);Halogen/Xenon;Südk.;TFL_S
    86;VW Jetta (VW351); ;Halogen/Xenon;RoW/Ska;TFL_0_Ska
    8C;VW Jetta (VW361); ;Halogen/Xenon;RoW;TFL_1
    TFL_0: TFL mit NSL u. RFL (daytime running lights and rear fog light, reversing light)
    TFL_1: mit TFL TFL-Outputs (daytime running lights with daytime running light outputs)
    TFL_S: TFL Skandinavien Abblendlicht m (daytime running lights via Scandinavia low beam lights)
    TFL_LED: LED-Modul mit und Doppelfunktion PO TFL (LED module with dual function parking lights and daytime running lights)
    TFL_0_S: Sonderlösung Skand., Vorhalt (special Scandinavia derivative solution)
    PO_LED: LED-Modul, nur für PO genutzt (led module used only for parking lights)
    The world is my oyster...
    Apr 2015
    Thanks for the quick response. I tried so many combos from the various lists I found and suggestions on forums. 21 seems like it should be the correct code but again it doesn't seem to work :-/ thus my confusion. I almost feel like whatever new code I put in isn't being accepted at all actually. I did follow one post the forum about resetting by coding to default number (looks like 21 should be it in my case), getting out, locking car, waiting 2 mins for BCM to "fall asleep" and then recoding once more to 00. That didn't do anything either...
    Apr 2015
    Also, here is my autoscan from prior to changing anything regarding lighting and prior to dealer reset. With this coding I had enabled a few things like windows down via key. Trying to code back to this exact setup did not return things to normal. As a note, the error in this autoscan regarding the left brake light is correct - there was some problem with the assembly in that lamp where it would cut out sometimes and trigger bulb out warning. This is one of the reasons I replaced with this LED set.
    Saturday,18,April,2015,20:52:39:48450
    VIN: 3VW4A7AJ3CM048038 License Plate: ZEDO
    Mileage: 83150km-51667mi Repair Order:
    72 77
    VIN: 3VW4A7AJ3CM048038 Mileage: 83150km-51667miles
    Revision: 00H31001
    Revision: BJ011001
    Coding: 2F230A3A902F06C400080080250085640720008841808D62DC 8000000040
    Shop #: WSC 00066 123 12345
    00984 - Left Tail Light (M4)
    Fault Frequency: 67
    Reset counter: 72
    Mileage: 77059 km
    Date: 2014.05.04
    Time: 20:46:49
    Term 15 On
    Voltage: 14.10 V
    Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
    Component: AirbagVW10G 013 0807
    Serial number: 003GTM01SU44
    Coding: 00003937
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
    ROD: EV_AirbaVW10SMEVW360_SK35.rod
    VCID: 3449F50A9F862D81BA7-8061
    Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
    Component: BF-Gewichtss. H10 0027
    Serial number: 6940000Y1100007C8F0B
    Coding: 303245
    Serial number: 3572MSME192B1262ZZZR
    Serial number: 3582MSME772C7161ZZZ.
    Serial number: 3516KSME291F5012ZZZO
    Serial number: 3526KSME39265312ZZZL
    Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
    Serial number: 3556LSME09211712ZZZH
    Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
    Serial number: 3566LSME6F5A3212ZZZ$
    Coding: 271E01
    Coding: 351002
    Revision: 00H20000
    Part No SW: 3T0 035 456 B HW: 3T0 035 456 B
    Component: KonzernAmp10K 0362
    Revision: -------- Serial number: BP225319948226
    VCID: 3041F91A6B9E11A1DEF-8065
    Coding: 01030100
    Coding: 180000
    Part No SW: 561 959 702 HW: 3C0 959 792 B
    Component: TUER-SG BT 002 0515
    Revision: 15110009 Serial number: 0003299509
    Coding: 0004B4
    ROD: EV_TSGBPQ35BRFVW46X.rod
    VCID: 5C997DAA5796C5C1527-8009
    Slave Passenger:
    Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
    Component: J389__TSG-HR 006 1508
    Serial number: 00000006033705
    Coding: 000490
    Coding: 0102000001
    Reset counter: 20
    Mileage: 77651 km
    Date: 2014.05.28
    Time: 11:36:20
    End-------------------------(Elapsed Time: 02:16)--------------------------
    Apr 2015
    Just one final note. I also tried to enable/disable the DRLs per the manual and those procedures did not work either. The DRLs would not come on. Additionally, changing coding to enable/disable DRL via menus, or enabling other functions such as coming home on/off via menu, did not work. Setting fogs to operate at DRL did indeed work but turning that off again results in no DRLs at all. No new settings appear to take effect, unlike before when enabling/disabling such things was immediately visible on the MFI.
  6. #6
    Apr 2015
    Just in case I hadn't screwed things up enough already, last night I tried a few more codes and finally one resulted in the car going crazy. Every single light/piece of electronics flickered, the DRLs came on flashing when hitting break pedal, etc etc and VCDS would no longer access module 9 so I couldn't even try to recode back to original. I hope I didn't brick the module
    Any suggestions at all for this??? Seemed like it should have been relatively simple, as it was for some others with GLIs who did same.
  7. #7
    HQ
    As noted... so the J519 isn't talking... so lets try the following:
    • Operate power locks with door switch several times, leave in the unlock position when done
    • See about arming the alarm for 30 minutes
    • Disconnect battery cables and touch them together, 10 secs good, 10 minutes great. 10 years... dedication
    • Unplug J519 and leave overnight.
    See if any of those tips helps get the J519 up and talking again.
    Side foot note for everyone, while we don't know what all is going on here.... when doing something outside the normal scanning of a car, lets make sure a battery charger is hooked up. Low voltage can cause problems.
    Jef
  8. Likes Uwe, NZDubNurd liked this post
  9. #8
    Apr 2015
    Tried all these stops, with the exception of holding the battery cables together for 10 years - started to get cold standing there after 14 hours so I gave up. Unfortunately nothing has worked. Autoscan freezes on module 9 and can't access it manually either still. ESP fault popped up after I disconnected battery but it's my understanding that it should hopefully reset after a few miles of driving (correct?). Here is the autoscan I just did (I had to click "done" when it got to module 9 since it just froze there):
    Wednesday,29,April,2015,12:10:27:48450
    VIN: 3VW4A7AJ3CM048038   License Plate: SCREWED
    Mileage: 83210km-51704mi   Repair Order:
              72 77
    VIN: 3VW4A7AJ3CM048038   Mileage: 83210km-51704miles
    09-Cent. Elect. -- Status: Sporadic communication error 1000
    1C-Position Sensing -- Status: Malfunction 0010
    2E-Media Player 3 -- Status: Malfunction 0010
    46-Central Conv. -- Status: Sporadic communication error 1000
    000604 - Fuel Pump Control Module
                   P025C - 000 - Short to Ground - Intermittent
                        Load: 0.0 %
                        Temperature: -40.0°C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 12.573 V
    Readiness: 0110 0101
       Revision: 00H31001
                        Reset counter: 44
                        Mileage: 83219 km
                        Date: 2015.04.29
                        Time: 00:01:09
                        Count: 2
                        Count: 12
                        Count: 12800
                        Count: 16390
                        Count: 49664
                        Count: 65280
    Address 09: Cent. Elect.        Labels: None
       VCID: 558F688EBCBC14896D9-8000
    Address 15: Airbags
       Coding: 271E01
    12664832 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 84
                        Mileage: 83215 km
                        Date: 2015.04.29
                        Time: 02:15:45
    13631488 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 84
                        Mileage: 83215 km
                        Date: 2015.04.29
                        Time: 02:15:46
       Coding: 351002
       Shop #: WSC 00000 960 117126
                        Reset counter: 84
                        Mileage: 83215 km
                        Date: 2015.04.29
                        Time: 02:15:47
                        Reset counter: 84
                        Mileage: 83215 km
                        Date: 2015.04.29
                        Time: 02:15:47
                        Reset counter: 84
                        Mileage: 83219 km
                        Date: 2015.04.29
                        Time: 17:01:54
                        Reset counter: 84
                        Mileage: 83219 km
                        Date: 2015.04.29
                        Time: 17:01:53
       Revision: 00H20000
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 83219 km
                        Date: 2015.04.29
                        Time: 00:00:58
                        Battery Volts: 12.6 V
                            PD
                        Temperature: 31.0°C
                        Count: 2
                        Steering Angle: 0.00°
                        Count: 1
                            SteerAng n.Init
    Address 46: Central Conv.
       Coding: 01030100
       Coding: 180000
       Coding: 0102000001
                000 -  -
                        Reset counter: 44
                        Mileage: 83215 km
                        Date: 2015.04.29
                        Time: 01:08:59
    Address 62: Door, Rear Left
    Address 72: Door, Rear Right
    End-------------------------(Elapsed Time: 03:23)--------------------------
