I posted over at Vortex also. Used my new VagCom today and found codes that point to a bad ignition switch. No issues except doors locking and unlocking, MFD blinking every once in awhile. No problems starting or anything like that. Windshield wipers will "bump" up a notch when I turn the car off.
Car is new to me, has 29K original miles, no aftermarket parts what so ever. Prob. the reason why original owner passed it off to me...
I don't have to do anything but I'm worried about electrical fire or creating a bigger issue...
If it truly is the electrical part of the switch does anyone know if I have to pull the wheel or can I get at it with small screwdrivers if I get the cover off the bottom of the column?
I'm wanting to get a Bentley manual but...the car is an 09 with the TSI motor and the manual for the 09 only has the FSI motor. Should I get a 2010+ manual?
Here is the basic readout on the codes that would not clear. I had codes in other areas and am driving it today hoping they clear up..
Control Module Part Number: 1K0 953 549 BG HW: 1K0 953 549 BG
Component and/or Version: J0527 051 0101
Software Coding: 0012122
Work Shop Code: WSC 01357 011 00200
Additional Info: XXXXXXXXXXX E0221 002 0010
Additional Info: Geraet 00200
VCID: 78D118E10BBC3CE156F-802D
00576 - Terminal 15
00576 - Terminal 15
