Upon starting my car this evening I got a warning "Gearbox malfunction, you can continue driving". The message appeared several times and then went away. I ran a full scan (see attached), but the error code appears to be 12550 - Signal Line for Gear Display on Selector Lever. Has anybody come across this before?
Tuesday,21,April,2015,20:21:13:08798
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WAU2GAFC9CN074274 License Plate:
Mileage: 92914km-57734mi Repair Order:
Chassis Type: FC (4G0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 28 36 3B 3C 42 44 46 47
52 53 55 56 5F 62 6C 6D 72 8F 90
VIN: WAU2GAFC9CN074274 Mileage: 92914km-57734miles
3B-Sensor Elect. -- Status: Malfunction 0010
Address 01: Engine (J623-CGXB) Labels: 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0007
Revision: --H07---
Coding: 1A2A0034052600060000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551A 003008
ROD: EV_ECM30TFS0214G0907551A.rod
VCID: 275DC01B5ECF4A190F5-8072
9662 - EVAP System
P0456 00 [096] - Very Small Leak Detected
Mileage: 92404 km
Date: 2015.04.08
Time: 08:35:59
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4G0 927 158 P HW: 0BK 927 156 R
Component: 0BK 30TFSIUSA H17 1006
Revision: --H17---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002018
ROD: EV_TCMAL551211_AU48.rod
VCID: 3B750C6BB247FEF97BD-806E
P1894 00 [040] - Implausible Signal
Mileage: 92907 km
Date: 2015.04.21
Time: 19:46:43
Address 03: ABS Brakes (J104) Labels: 4G0-907-379.clb
Part No SW: 4G0 907 379 F HW: 4G0 907 379 F
Component: ESP PREMIUM H09 0250
Coding: 44A70F0322E5F0C05B00
ASAM Dataset: EV_ESPPremiAU57X 004017
ROD: EV_ESPPremiAU57X_AU57.rod
VCID: 346727579F193181BA7-8061
Part No SW: 4H0 907 064 BR HW: 4H0 907 064 BR
Component: BCM2 2.0 H31 0333
Coding: 0D8A2000000000000000
VCID: 7AFBC96FF5FD07F120B-802F
Component: J764 ELV MLB H39 0046
Part No SW: 4G0 820 043 L HW: 4G0 820 043 L
Component: KLIMA 4 ZONEN H12 0062
Serial number: 25101100040777
Coding: 668320BA48
ASAM Dataset: EV_AirCondiComfoUDS 002033
ROD: EV_AirCondiComfoUDS.rod
VCID: 285FC32753D1456106F-807D
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 BG HW: 4H0 907 063
Component: BCM1 2.0 H12 0100
Revision: 11012002 Serial number: 00000001090337
Coding: 02002011163C9FE0C1008884A0003928CF9CD208A2080125800008402000
VCID: 6ED3F53FB9B55B518C3-803B
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119
Component: WWS57X 110929 H35 0051
Coding: 0045F7
Component: RLS H04 0003
Coding: 02562B
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Subsystem 5 - Part No SW: 8K0 959 772 C HW: 8K0 959 772
Component: SLR-B8 H05 0006
Coding: 853000
Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Coding: 020300
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 B HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0480
Revision: 00000007
VCID: 2C573F374F296941E27-8079
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 N HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0050
Revision: 11001001 Serial number: 55901129201942
Coding: 280104
ROD: EV_EPHVA18AU57X0000.rod
VCID: 3D710273AC53F0C9459-8068
Address 15: Airbags (J234) Labels: None
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H31 0032
Revision: -------- Serial number: 003D8001GJ1I
Coding: 303145313131303030314A55304C34473853
VCID: 3365244B9A1736B9A3D-8066
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y1100006MWN09
Serial number: 3575HRB405R0SM2MC1A-
Serial number: 3585HRB405J0SM2MAPRP
Serial number: 3515JRB404T0Q8K48O7X
Serial number: 3525JRB40650P7AO59D8
Serial number: 3554VRB404T0ODII9G8E
Serial number: 3564VRB40550ODII5HBZ
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372KJL001QG
Coding: 000414
VCID: 387F13678B71D5E196F-806D
Subsystem 1 - Part No SW: 4G0 951 528 F HW: 4G0 951 528 F
Component: E221 - MFL H09 0009
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 982 HW: 4G8 920 982
Component: TBenUsa H79 0375
Revision: 26181120 Serial number: 658191011591010
Coding: 0BE701060B03D605020100
ASAM Dataset: EV_RBD4K 004040
ROD: EV_RBD4K.rod
VCID: 71E9EE43A08B44A9911-8024
Part No SW: 4G0 907 468 E HW: 4G0 907 468 A
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000281858
Coding: 00C1033000
ROD: EV_GatewUDS_AU57.rod
VCID: 326B214F650D3FB1A8B-8067
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790597445
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 D HW: 4G0 919 158 D
Component: KLIMA FOND H07 0062
Serial number: 22101100040683
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
ROD: EV_ClimaContrUnitRearUDS.rod
VCID: 306F2B476B010DA1DEF-8065
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000016080495
Coding: C0581B008F002001000001010101102030303232203232
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4202DXW.0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA.rod
VCID: 2D5132337C336049F59-8078
2097156 - Internal Control Module Memory Check Sum Error
B2000 04 [109] - Internal System Fault
Fault Frequency: 0
2117632 - Internal Control Module Memory Check Sum Error
Fault Frequency: 0
Part No SW: 4G0 907 566 J HW: 4G0 907 566
Component: J769 SWA MasterH02 0030
Revision: 00H02000 Serial number: 6PZ 010 287-08
Coding: 0000007
VCID: 36631D5F41652391843-8063
Subsystem 1 - Part No: 4G0 907 568 J
Component: J770 SWA Slave H02 0030
Subsystem 2 - Serial number: 6PZ 010 287-28
Subsystem 3 - Serial number: 5F17.10.1100H020003CZ21409ÿ
Subsystem 4 - Serial number: Z21409ÿ
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011F57225E00628002000412
Shop #: WSC 02312 785 00200
VCID: 428B718FDDAD8F3138B-8017
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0012194994
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS.rod
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0161212636
Coding: 01260E3A20FAF48580B00A80020100000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0070
Subsystem 3 - Part No SW: 7P5 959 591 HW: 4H0 959 591
Component: J245 PS40.033 H07 0006
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H09 0027
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 3
Mileage: 90931 km
Date: 2015.03.02
Time: 12:47:02
02616 - Fuel Tank Cap; Unlock
Reset counter: 3
Mileage: 90931 km
Date: 2015.03.02
Time: 13:10:38
03128 - Switch 1 for Sunroof
Fault Status: 00101100
Reset counter: 154
Mileage: 91640 km
Date: 2015.03.13
Time: 21:53:39
00204 - Sunroof Button (E325)
Reset counter: 154
Mileage: 91640 km
Date: 2015.03.13
Time: 21:53:39
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
Reset counter: 145
Mileage: 92508 km
Date: 2015.04.12
Time: 14:12:30
Part No SW: 4G0 035 223 B HW: 4G0 035 223 A
Component: BOSE G3 C7 H07 0130
Revision: CJ007000 Serial number: 00000000031177
Coding: 030000
VCID: 1C37EFF71F8999C1927-8049
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
Coding: 011F57225E00628002000402
VCID: 41897E83D8AB9429211-8014
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000162562
ROD: EV_ParkiBrake_AU48.rod
VCID: 2A5B392F4DDD777110B-807F
Address 55: Headlight Range (J431) Labels: 4H4-907-357.clb
Part No SW: 4H4 907 357 A HW: 4H4 907 357 A
Component: ....AFS13.... H01 0012
Serial number: 111023-0004-010
Coding: 1223A633701AA400
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
H01 0031
Coding: 3A0000
H01 0031
Coding: 3A0000
Part No SW: 4G0 035 082 B HW: 4G0 035 082
Component: Radio U SIRIU H53 0076
Revision: AB001007 Serial number: 156JB0B7564887
Coding: 020007010000000001
VCID: 1F4DD8FB0E9F82D9775-804A
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 746 C HW: 4G0 035 746
Component: H-BNT-NA H48 0423
Revision: -------- Serial number: 031JT0B7517521
Coding: 090200040003E1EF55128F0E00000003100001000000000000
VCID: 275DC01B56CF4A190F5-8072
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Subsystem 3 - Part No SW: 4G1 919 610 A HW: 4G1 919 610 A
Component: E380 BDT C7 H08 0203
Component: CD-Database 3371
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F17224000628002000002
VCID: 44877797C7B981010A7-8011
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H04--- Serial number: 525 PA8J1XG18Z
Coding: 1080013
VCID: 2643CD1F91C55311343-8073
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 4G8 959 107 P HW: 4G8 959 107 G
Component: HDSG-Modul H13 0039
Revision: 12013001 Serial number: 273100346
Coding: 0A3305C102
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
VCID: 428B718FD5AD8F3138B-8017
Component: TSG HR H04 0212
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 31692E43600B04A9D11-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 05:51)--------------------------
