The other day I've tried to replace the original gateway in my 2011 Polo 6R 1,6 TDI with start/stop system.
Originally it has the following gateway:
I tried to replace it with 7N0907530D. It was just one that I've had in my garage. Don't know where it came from.
Why? Because I wanted to have the possibility to code it for [20-High Beam Assist]. My 6R GW does not support that.
It turned out that everything is working except the ABS unit. There were no connection to the ABS unit. I've looked in ElsaWin and the connections are the same for the 2 gateways, but VCDS can't connect.
Does the Polo ABS have a special version of can-bus since it can't connect?
There we no problems connecting to engine, cluster, radio ect. The car also started perfect - but with some lights on because the of ABS..
In know that 7N0 are not designed for the Polo. It should just be fun having another gateway. Later on I would replace it with a 7N0...BC gateway in order to code it for 5F-Infotainment...
Any ideas?
Address 19: CAN Gateway Labels: 6R0-907-530-V1.clb
Part No SW: 6R0 907 530 B HW: 1K0 907 951
Component: J533 Gateway H28 0020
Revision: H28 Serial number: 240910F1002717
Coding: 7D021D00080000000002
Shop #: WSC 00788 648 00255
VCID: 32613AF2AD920F8E5D9-8067
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0001
Revision: --------
Coding: 210228E3416E00BA842D14E282D500521300
VCID: 86093622359AC32E211-80D3
Any ideas?
