VCDS Version: Beta 15.3.0 (x64)
Data version: 20150314
Tuesday,21,April,2015,14:56:35:35632
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 56 62
72 77
VIN: 3VWPL7AJ4CM671059 Mileage: 86270km-53605miles
4C-Tire Pressure II -- Status: Cannot be reached 1100
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 HG HW: 03L 907 309 AA
Component: R4 2,0L EDC G000AG 3522
Revision: 12H14--- Serial number:
Coding: 0050078
VCID: 77BE22EF06467480F6-8022
P0087 - 001 - Too Low - Intermittent
Fault Status: 00100001
Mileage: 85786 km
Date: 2015.04.05
Time: 11:30:55
RPM: 4784 /min
Inj. Quantity: 70.0 mg/str
(no units): 5.0
Pressure: 1904.0 bar
Pressure: 1720.0 bar
Temperature: 21.6°C
Tank Cont.: 47.6 l
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 057 P HW: 02E 927 770 AL
Component: L DSG AG6 512 3102
Revision: 05551213 Serial number: 00001112070257
Coding: 0000024
VCID: 26003FAB916C3D089D-8073
17252 - Transmission Fluid Pressure Adaptation at Limit
P0868 - 001 - - Intermittent
Fault Frequency: 255
Reset counter: 2
Mileage: 84683 km
Date: 2015.03.26
Time: 11:56:35
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C492900FB880B06E992220042B70000
Shop #: WSC 00066 123 12345
VCID: 7DB230C7E47A5ED0AC-8028
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 55
Mileage: 78052 km
Date: 2015.01.04
Time: 04:50:34
Count: 3
Count: 12
Count: 20992
Count: 16401
Count: 49920
Count: 5632
Count: 1023
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0404
Revision: 00001016
Coding: 0000001002
Shop #: WSC 00066 000 00119
VCID: 004C49339B883338C7-8055
Address 09: Cent. Elect.
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA1622C
Coding: 00003133
VCID: 3FCE8ACFA6F68CC0FE-806A
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--000034GD00
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME78652065ZZZW
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME59203167ZZZR
Serial number: 3511HSME7757232BZZZP
Serial number: 3521HSME16460D2BZZZP
Component: F.Sens.Fahr --- ----
Serial number: 35527SME73207029ZZZ6
Component: F.Sens.Beif --- ----
Serial number: 35627SME574F6829ZZZX
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440KKE000GN
Coding: 189A140000
Shop #: WSC 00066 123 00186
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 76A02FEBC94C0D88ED-8023
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H06 0010
Serial number: 0081682
Coding: 830000
Part No SW: 5K0 920 972 C HW: 5K0 920 972 C
Component: KOMBI H03 0607
Coding: 270F00
Shop #: WSC 00066 123 00119
VCID: 302CD9F36BA863B877-8065
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 08021201291049
Coding: 352002
VCID: 3D32F0C7A4FA9ED0EC-8068
03109 - Tire Pressure Monitoring Control Module 2 (J793)
Reset counter: 148
Mileage: 83475 km
Date: 2015.03.15
Time: 11:20:52
Component: IMMO H03 0607
VCID: 6A980B9B8DF4D96879-803F
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661387368
VCID: 291A349740721270B0-807C
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 J HW: 3C0 035 684 G
Component: RNS-MID H02 4366
Revision: AB001001 Serial number: VWZ6Z7M8119001
Coding: 04010442040000A0000B
VCID: 2A18CB9B45741968B9-807F
Subsystem 1 - Part No: 7L6 919 859
Component: NAR V8 8112
01523 - Microphone for Telephone (R38)
Fault Status: 00101011
Reset counter: 238
Mileage: 72067 km
Date: 2014.10.30
Time: 18:10:50
00862 - Antenna for GPS Navigation (R50/R52)
Fault Status: 00100111
Reset counter: 238
Mileage: 70259 km
Date: 2014.10.06
Time: 11:39:45
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0004082248
Coding: 0004B5
Shop #: WSC 01383 790 50316
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 5BF65E5F52AEB0E0F2-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 007 1509
Serial number: 00000006339447
Coding: 000490
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 70 3301
Revision: 00H22000
VCID: 3522E8E75CCA469024-8060
Address 46: Central Conv.
Address 4C: Tire Pressure II
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 050B0500
VCID: 6FAE1A8FBE163C402E-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0004100308
Coding: 0004B4
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 5CF45D4357A0B7D8FB-8009
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 007 1509
Serial number: 00000006111425
Coding: 000490
66562 - Heated Exterior Mirror
B11F8 14 [009] - Open or Short to Ground
Fault Frequency: 7
Reset counter: 203
Mileage: 70355 km
Date: 2014.10.07
Time: 06:26:19
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Reset counter: 238
Mileage: 72067 km
Date: 2014.10.30
Time: 18:10:50
Reset counter: 238
Mileage: 70259 km
Date: 2014.10.06
Time: 11:39:45
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661571882
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
VCID: 271E32AF5E662400A6-8072
