2014 SEAT Ibiza 1.4 TOCA, CGGB
GaryM
Oxford, UK
C?ID=226919
I decided to take the liberty of scanning the courtesy car I am currently in possession of for use as a reference scan :)
Thursday,16,April,2015,11:31:01:55895
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: VSSZZZ6JZER124918   License Plate:
Mileage: 14250km-8854mi   Repair Order:
Chassis Type: 6J (6N0)
Scan: 01 03 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZER124918   Mileage: 14250km-8854miles
Address 01: Engine (J623-CGGB)       Labels: None
   Part No SW: 03C 906 014 FB    HW: 03C 907 445 C
   Component: CGGBMM7GVE    H01 6542
   Revision: --H01---    Serial number:
   Coding: 00110014000400000000
   Shop #: WSC 00049 770 00137
   VCID: 62CB8FD37E95E63118B-515E
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6R0 907 379 BG    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 13DD247D212500C4C81D246A845900800804
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   ROD: EV_Brake1ESP90iBOSCH.rod
   VCID: 0407A94B8FC148014A7-8051
Address 08: Auto HVAC        Labels: 6J0-820-045.clb
   Part No SW: 6J0 820 045 A    HW: 6J0 820 045 A
   Component: J301  Klimaanlage   0330
   Revision: 00 26 08    Serial number: 0000002797531-
   VCID: 2447C9CBE701A8012A7-8071
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 P    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H34 0411
   Revision: BF034001    Serial number: 0581 074141794
   Coding: 248829E888612500922008F06E4B9CC80040422F608C0000200000000000
   VCID: 4A9B4773E5655E71F0B-801F
   Subsystem 1 - Part No SW: 6R0 959 802 AN    HW: 6R0 959 802 AN  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  006 5130
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 AL    HW: 6R0 959 801 AL  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  006 5130
   Coding: 020000
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 5 - Part No: 1K8 951 171 A
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagA05 H10 0020
   Revision: --------    Serial number: 003GX023UVE3
   Coding: 003035
   Shop #: WSC 00049 770 00111
   ROD: EV_AirbaVW10BPAVW250_SE25.rod
   VCID: 4A9B4773ED655E71F0B-801F
   Serial number: 3495RRB400U50UJ8D1I%
   Serial number: 3505RRB401050UJ8AP7F
   Part No SW: 6J0 920 906 K    HW: 6J0 920 906 K
   Component: KOMBI         H31 0302
   Revision: X003115S    Serial number:
   Coding: 410A00
   ASAM Dataset: EV_KombiUDSMM9RM10 A04752
   ROD: EV_KombiUDSMM9RM10_SE12.rod
   VCID: 3561048F949B21898D9-8060
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H34 0411
   Revision: BF034001
   Coding: 422100
   VCID: 70EFF59BA37944A19EF-8025
   Part No SW: 5K0 953 234     HW: 6J0 920 906 K
   Component: IMMO          H31 0302
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_SE25.rod
   VCID: 6ADBE7F38DA5BE71D0B-803F
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 11211
   Shop #: WSC 00049
   VCID: 306F359BF7F904A1DEF-8065
Address 4B: Multifunc. Module        Labels: None
   Part No: 6J0 959 441 A
   Component: MF-Modul       0007 0001
   Shop #: WSC 77005 000 00000
   VCID: 3169309FA8F30DA9D11-8064
Address 56: Radio (J503)       Labels: None
   Part No SW: 6J0 035 156     HW: 6J0 035 156
   Component: Radio         H09 0014
   Revision: R0000000    Serial number: SEZAZ1P6562597
   Coding: 010004080201
   VCID: 64C789CB6781E801EA7-8031
End-------------------------(Elapsed Time: 02:17)--------------------------
golfi_vend
Tartu, Estonia
C?ID=195131
Why do i have a feeling something there still uses K-line?
Your feeling is correct. There's K-line (KWP2000), normal CAN (TP2.0), CAN TP1.6, and UDS, all in the same car. :D
The only thing it's missing is some Ur-VAG, KW1281. ;)
GaryM
Oxford, UK
C?ID=226919
Out of interest, how can you tell what protocol a control module is using from the details in an Auto-Scan? Or can you not?
GaryM
Oxford, UK
C?ID=226919
To confirm what Uwe put in post #3, these are the protocols used by each of the controllers...
01-Engine -------------> KWP2000
03-ABS Brakes ---------> UDS
08-Auto HVAC ----------> CAN
09-Cent. Elect. -------> CAN
15-Airbags ------------> UDS
17-Instruments --------> UDS
19-CAN Gateway --------> CAN
25-Immobilizer --------> UDS
44-Steering Assist ----> TP 1.6-1281
4B-Multifunc. Module --> CAN
56-Radio --------------> CAN
I can. But how is a trade secret, sorry. :D
GaryM
Oxford, UK
C?ID=226919
I guess that probably means an internal cross-referencing RT database of control modules / label files / rod files / protocols that you can just do a lookup on :D
"No comment". :cool:
