Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: MQB Instrument Cluster Lighting - Help needed
    ^^^ Wow - this is a very old thread indeed. It's a good thing that I haven't aged in the interim (don't tell anyone, but I have a self portrait in my attic that most assuredly isn't ageing gracefully - I do hope that you have read the classic novel by that most brilliant of Irish playwrights of the late 19C).
    In answer to your question - I did indeed pursue PanEuropean's sage observations with mixed success and with my own very dubious conclusions - all of which remain entirely unsubstantiated and are likely the product of a seriously diminished intellect (the result of which I attribute to too much alcohol and too many years on this fragile blue planet).
    It all culminated in a set of tweak instructions that you can find HERE - version 1.
    In the course of my discussions on these lighting adjustment curve -channels (in another place), I was contacted by a rather bright (pun intended) forum colleague, "ZEAL8080" (you may not remember the mighty intel chip "eighty-eighty") who had also developed his own theories about how these channels operated. Anyhow, based on ZEAL's work (or rather, based on my understanding of his Japanese writings on the matter), I wrote-up another set of instructions which you can read HERE-version 2
    The difference between the two instruction-sets is that in version 1 I target the response characteristics of the photo-transistor that sits in the instrument panel and in version 2, changes to the lighting curves happen only in the 2 x clock dials.
    So, version 1 results in a more holistic change to the cabin lighting in that there are many functions in the car (like the instrument cluster and the MIB screen) that are affected by the photo-transistor response. Your will read a postscript in my link where I've had to readjust other parts of the dash illumination as a consequence of photo-transistor curve changes. It seems from feedback responses that I have received for others that version 1 lends itself more readily where folk have tinted the cabin windows and as a result the general cabin illumination is inherently changed.
    Again from user feedback, version 2 seems to be used by those that are seeking a simpler (and more targeted) change.
    I'm not sure what your motivation is for changing these curves, so I can't comment on which of these versions (if any) are suitable
    Edit: If PanEuropean still visits this forum - Hello Michael
  2. Likes Uwe liked this post
  3. #12
    It looks like he hasn't been here since early in 2017.
  4. Likes DV52 liked this post
  5. #13
    Aug 2018
    Norway
    Based on this research, is there any way to change adaptions so that the ambient light sensor works normally in "AUTO" but keeps all the interior and instrument lighting ON when the switch is at "0" or "DRL" -as some call it?
    Admap from a similar car.
    	SW:5Q0-937-084-CP   HW:5Q0-937-084-CF ---  Cent. Elect. --- SA: 31347
    	Component:BCM MQBAB M+  H36 0253, Coding:000000000000000000000000000000000000000000000000000000000000
    	EV_BCMMQB,018001,EV_BCMBOSCH_018.rod
    	Wednesday,29,May,2019,11:29:27:53544
    	VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
    	VCID: 08499AE662BE29C7D6D-805C
    IDE01550-Service position,170.494336 °,2
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,10
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,10
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,10
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,10
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active ,10
    IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,200 ms,10
    IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,200 ms,10
    IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,200 ms,10
    IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
    IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
    IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.3 °,16
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,16
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,16
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
    IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,11
    IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,11
    IDE04927-ENG141962-Window heater-Waschduesenheizung,installed ,11
    IDE04927-ENG154810-Window heater-window heating front activation time pause,240 s,11
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
    IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,not active ,8
    IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
    IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,8
    IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,not installed ,8
    IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
    IDE04928-ENG142249-Anti-theft device-OBD Alarm,not_active ,8
    IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,not_active ,8
    IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
    IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
    IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
    IDE05144-Read parameter address,00 00 00 ,3
    IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,224
    IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,30
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,30
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,30
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,30
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,30
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,30
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,30
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,30
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,51.50 °C,30
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,50.50 °C,30
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,51.50 °C,30
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,50.50 °C,30
    IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
    IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO,Keine_Spannungsanforderung ,30
    IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.0 V,30
    IDE06507-MAS13132-Button in center console-Function of button 3,NOT-DEFINED ,8
    IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed ,8
    IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
    IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
    IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
    IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
    IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
    IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
    IDE07356-Position during interval mode,31.494474 °,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,not active ,6
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,255 min,6
    IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,9
    IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,LIN_REGEN_LICHT_SENSOR ,9
    IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
    IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
    IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
    IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
    IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,19
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
    IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,19
    IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
    IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,not active ,19
    IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,19
    IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
    IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active ,19
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
    IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,19
    IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
    IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,5
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,5
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed ,5
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17
    IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,not installed ,17
    IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,not installed ,17
    IDE10298-Alternating park position 1,7.494498 °,2
    IDE10299-Alternating park position 2,29.494476 °,2
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.00 ,256
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000  ,256
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,256
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000  ,256
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000  ,256
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000  ,256
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,0 %,256
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,0 %,256
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,0 %,256
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,0 %,256
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0 %,256
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,0 %,256
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,0 %,256
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,0 %,256
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,0 %,256
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,0 %,256
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,0 %,256
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,0 %,256
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,0 %,256
    IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.0 s,256
    IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
    IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
    IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
    IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
    IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
    IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
    IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
    IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,0 ,30
    IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
    IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,0 ,30
    IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
    IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
    IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
    IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
    IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,0 ,30
    IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
    IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
    IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
    IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
    IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
    IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
    IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
    IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
    IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
    IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
    IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
    IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
    IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,0 ,30
    IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
    IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,0 ,30
    IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,not installed ,3
    IDE11944-ENG141948-Keyless access and start authorization-Kessy,not installed ,3
    IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3
    IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,3
    IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
    IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,0 ,30
    IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,0 ,30
    IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
    IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
    IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
    IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
    IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,0 ,30
    IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,0 ,30
    IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,0 ,30
    IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,0 ,30
    IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,0 ,30
    IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
    IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
    IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
    IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
    IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
    IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
    IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
    IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,0 ,30
    IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
    IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,0 ,30
    IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
    IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,0 ,30
    IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
    IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
    IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
    IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,0 ,30
    IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
    IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,0 ,30
    MAS05055-lower turn position,31.494474 °,2
    MAS05056-upper turn position,170.494336 °,2
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
    MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
    ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status,not active ,9
    ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC,00 00 00 ,9
    ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,First_dtc ,9
    ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
    ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
    ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,0 ,60
    ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,0 ,60
    ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,0 ,60
    ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,0 ,60
    ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,0 ,60
    ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,0 ,60
    ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,0 ,60
    ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,0 ,60
    ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,0 ,60
    ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,0 ,60
    ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,0 ,60
    ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,0 ,60
    ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,0 ,60
    ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,0 ,60
    ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,0 ,60
    ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,0 ,60
    ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,0 ,60
    ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,0 ,60
    ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,0 ,60
    ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,0 ,60
    ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,0 ,60
    ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,0 ,60
    ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,0 ,60
    ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,0 ,60
    ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,0 ,60
    ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,0 ,60
    ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,0 ,60
    ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,0 ,60
    ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,0 ,60
    ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,0 ,60
    ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,0 ,60
    ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,0 ,60
    ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,0 ,60
    ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,0 ,60
    ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25,0 ,60
    ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26,0 ,60
    ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27,0 ,60
    ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,0 ,60
    ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,0 ,60
    ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,0 ,60
    ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,0 ,60
    ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12,0 ,60
    ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13,0 ,60
    ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,0 ,60
    ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15,0 ,60
    ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16,0 ,60
    ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17,0 ,60
    ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18,0 ,60
    ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19,0 ,60
    ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,0 ,60
    ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,0 ,60
    ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,0 ,60
    ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,0 ,60
    ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,0 ,60
    ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,0 ,60
    ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,0 ,60
    ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,0 ,60
    ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,0 ,60
    ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,0 ,60
    ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,0 ,60
    ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,0 ,60
    ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,0 ,60
    ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,0 ,60
    ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,0 ,60
    ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,0 ,60
    ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,0 ,60
    ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,0 ,60
    ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,0 ,60
    ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,0 ,60
    ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,0 ,60
    ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,0 ,60
    ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,0 ,60
    ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,0 ,60
    ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,0 ,60
    ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,0 ,60
    ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,0 ,60
    ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,0 ,60
    ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,0 ,60
    ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,0 ,60
    ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,0 ,60
    ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,0 ,60
    ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,0 ,60
    ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,0 ,60
    ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,0 ,60
    ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,0 ,60
    ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,0 ,60
    ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,0 ,60
    ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,0 ,60
    ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,0 ,60
    ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,0 ,60
    ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,0 ,60
    ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,0 ,60
    ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,0 ,60
    ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,0 ,60
    ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,0 ,60
    ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,0 ,60
    ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,0 ,60
    ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,0 ,60
    ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,0 ,60
    ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,0 ,60
    ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,0 ,60
    ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,0 ,60
    ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,0 ,60
    ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,0 ,60
    ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,0 ,60
    ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,0 ,60
    ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,0 ,60
    ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,0 ,60
    ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,0 ,60
    ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,0 ,60
    ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,0 ,60
    ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,0 ,60
    ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,0 ,60
    ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,0 ,60
    ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,0 ,60
    ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,0 ,60
    ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,0 ,60
    ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,0 ,60
    ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,0 ,60
    ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,0 ,60
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
    ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
    ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0,1 ,23
    ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
    ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
    ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11,1 ,23
    ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12,1 ,23
    ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13,1 ,23
    ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14,1 ,23
    ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15,1 ,23
    ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,1 ,23
    ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
    ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
    ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
    ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,1 ,23
    ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7,1 ,23
    ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,1 ,23
    ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9,1 ,23
    ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,10
    ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,active ,10
    ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,active ,10
    ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10,active ,10
    ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Wechselblinken_Warnblinken ,10
    ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,active ,10
    ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS,PreCrash_passiv ,10
    ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
    ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
    ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,active ,10
    ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,active ,10
    ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,active ,10
    ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,active ,10
    ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,active ,10
    ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
    ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
    ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,active ,10
    ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,active ,10
    ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
    ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
    ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
    ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9
    ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
    ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9
    ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9
    ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,not installed ,9
    ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
    ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,9
    ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,9
    ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
    ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
    ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,9
    ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,No ,5
    ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
    ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,active ,5
    ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
    ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,18
    ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,18
    ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
    ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,manual ,18
    ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
    ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,18
    ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
    ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
    ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
    ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
    ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,false ,18
    ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,Yes ,18
    ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,No ,18
    ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),discrete ,18
    ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,installed ,18
    ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
    ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
    ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
    ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,One-sided ,18
    ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,active ,18
    ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,24 s,18
    ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Sollspannungsanforderung 13.5 ,18
    ENG122934-erase_error_table,55 00 00 ,3
    ENG122933-error_mask,0 bit,2
    ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht (GLW:MDF) ,6
    ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,active ,6
    ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
    ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6
    ENG141685-Front_wash_function,10 ,2
    ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,active ,6
    ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6
    ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,active ,6
    ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Keine_Spannungsanforderung ,6
    ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,0 ms,6
    ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Deactivating ,6
    ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
    ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,not active ,6
    ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
    ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6
    ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6
    ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
    ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,installed ,8
    ENG141645-MAS00214-HW_Verbau-Brake pad wear,installed ,8
    ENG141645-ENG142026-HW_Verbau-Druckklappe,not installed ,8
    ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,not installed ,8
    ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,active ,8
    ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,not active ,8
    ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
    ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
    ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
    ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
    ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
    ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
    ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
    ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
    ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
    ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
    ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,58.5 %,30
    ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,58.5 %,30
    ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,58.5 %,30
    ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,58.5 %,30
    ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,54.5 %,30
    ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,49.5 %,30
    ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,46.5 %,30
    ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,35.5 %,30
    ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,31.5 %,30
    ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,20.0 %,30
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,0 ,16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,00 ,16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,00 ,16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,not active ,16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,not active ,16
    ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
    ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
    ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Unknown (76),16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,0 ,16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,00 ,16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,00 ,16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,not active ,16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,not active ,16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,0 ,16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,00 ,16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,00 ,16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,not active ,16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,not active ,16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,127 ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,36 ,16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,only_if_closed ,16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parking light right ,16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,35 ,16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,only_if_closed ,16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0 ,16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00 ,16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,00 ,16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active ,16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,not active ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09 ,16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,43 - allgemeine LED ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,43 - allgemeine LED ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127 ,16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
    ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,25 - allgemeine Glühlampe Innen- oder Außenlicht ,16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,43 - allgemeine LED ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,43 - allgemeine LED ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,00 ,16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00 ,16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,00 ,16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00 ,16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,00 ,16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,00 ,16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active ,16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,00 ,16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,00 ,16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active ,16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,127 ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4B ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,5 - LED Abblendlicht ,16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Versorgungsbedarf der LCM Module ,16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parking light right ,16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,127 ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,5 - LED Abblendlicht ,16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Versorgungsbedarf der LCM Module ,16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 2B 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 2B 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 19 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 1B 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 FF 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 00 00 00 00 00 00 00 00 00 ,192
    ENG141662-Leuchtenkonfiguration_Sonstiges,2B 00 00 36 08 0A FF 00 00 00 00 00 00 00 00 00 2B 00 00 35 08 09 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
    ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
    ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,not active ,62
    ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
    ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
    ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
    ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
    ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
    ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
    ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
    ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
    ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
    ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_1 ,62
    ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
    ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
    ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
    ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62
    ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,0 mm,62
    ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,0 mm,62
    ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,0 mm,62
    ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,0 mm,62
    ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
    ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
    ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
    ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
    ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
    ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62
    ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
    ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
    ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
    ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,not active ,62
    ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
    ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
    ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,not installed ,62
    ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,0.00 s,62
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
    ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
    ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
    ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
    ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
    ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
    ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
    ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
    ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
    ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
    ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
    ENG122979-ENG141954-Networking-A/C electronics,installed ,8
    ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,not installed ,8
    ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8
    ENG122979-ENG141953-Networking-Getriebesteuergeraet,installed ,8
    ENG122979-ENG99457-Networking-Head area heater,not installed ,8
    ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8
    ENG122979-ENG141969-Networking-UGDO,not installed ,8
    ENG124714-ENG142044-OCU-DWA_push,active ,8
    ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
    ENG124714-OCU-,not installed ,8
    ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,8
    ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,8
    ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,8
    ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,8
    ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via ZV-Absicherung Light ,8
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
    ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
    ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
    ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
    ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
    ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
    ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,not active ,16
    ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
    ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,5
    ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5
    ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,5
    ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
    ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,5
    ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5
    ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5
    ENG122927-RLS_close_glazing,2.0 s,1
    ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s,3
    ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s,3
    ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h,3
    ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h,3
    ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx,2
    ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 ,2
    ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6 ,2
    ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s,2
    ENG122929-RLS_LIN_Communication,4 s,1
    ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
    ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
    ENG122930-RLS_tunel_gateway_recognize,5 s,1
    ENG122935-RLS_Washer_Front,15 s,1
    ENG122926-RLS_wiper_position_parking,15 s,1
    ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
    ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,installed ,10
    ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
    ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
    ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,400 ms,10
    ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms,10
    ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms,10
    ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,400 ms,10
    ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Keine_Spannungsanforderung ,10
    ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
    ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
    ENG141684-SFT271875-Slave_systems_identification-Light switch,Not available ,6
    ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module,Not available ,6
    ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
    ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
    ENG141684-SFT271896-Slave_systems_identification-Alarm horn,Not available ,6
    ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Not available ,6
    ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
    ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Not available ,6
    ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
    ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
    ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
    ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
    ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
    ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
    ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
    ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,SMLS ,4
    ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
    ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,5
    ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,not active ,5
    ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,active ,5
    ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
    ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
    ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,active ,5
    ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
    ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
    ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt,250 ,10
    ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel,10 km/h,10
    ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
    ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,10.0 min,10
    ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen,40 ms,10
    ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
    ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
    ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
    ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
    ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
    ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
    ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
    ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
    ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
    ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
    ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
    ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
    ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
    ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
    ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
    ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
    ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
    ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
    ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
    ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
    ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
    ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
    ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
    ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI ,21
    ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
    ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
    ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active ,21
    ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
    ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
    ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,100 %,21
    ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.100 ,21
    ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 %,21
    ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
    ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
    ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
    ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
    ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
    ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
    ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
    ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
    ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
    ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
    ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
    ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
    ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
    ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
    ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
    ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
    ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
    ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
    ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
    ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
    ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
    ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
    ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,510 lx,8
    ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
    ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
    ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
    ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
    ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
    ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
    ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
    ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
    ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
    ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
    ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
    ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
    ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
    ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
    ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,not active ,4
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
    ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4
    ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,not installed ,4
    ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,not installed ,4
    ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,LIN ,4
    ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,9
    ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,9
    ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,not installed ,9
    ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,9
    ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,9
    ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,9
    ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,9
    ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,9
    ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,Always ,9
    ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,Always ,9
    ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,not installed ,9
    ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,9
    ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,9
    ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,9
    ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,active ,9
    ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,9
    ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,9
    ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,not active ,9
    ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
    ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,not installed ,9
    ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
    ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
    ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
    ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,active ,7
    ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7
    ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7
    ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,7
    ENG141651-ENG141957-ZV allgemein-Radio freq.,434.42MHz ,7
    ENG141651-ENG141958-ZV allgemein-Tankschloss,Bidirectional ,7
    ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale Entriegelung ,7
    ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
    ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
    ENG141654-ENG116706-ZV Autolock-Autounlock NAR,not active ,3
    ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3
    ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,adjustable ,3
    ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
    ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,not active ,4
    ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,active ,7
    ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,not installed ,7
    ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7
    ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,not active ,7
    ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7
    ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Contact control ,7
    ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
    ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,7
    ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
    ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,active ,8
    ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
    ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,active ,8
    ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,active ,8
    ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
    ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
    ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,2-Motorenschloesser ,5
    ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,5
    Elapsed Time: 01:52
    Works at a VAG dealer - drives a BMW built in Britain with American parts.
    MY03 R53 MINI Cooper S
    MY09 B8 Audi A4 1.8Tq with 6spd millenial anti theft device
    It is better to back up your coding two times than bricking your ECU one time.
  6. #14
    ^^^Akkipen: Allow me to preface my response by apologizing for an apparent confusion which is evident in your question and which I have failed to make clear on this thread (entirely my omission)
    The subject matter of this thread has nothing to do with the "ambient light sensor" which normally works in AUTO. On MQB platform vehicles, this sensor hangs off the center of the windscreen and it points outward to measure the AMBIENT lighting levels exterior to the car (The sensor is euphemistically and technically called RLS, or if the sensor also includes a humidity sensor, RLHS, or RLFS).
    The sensor for the dimming_characteristic_curve_adjustment channels that are the subject of this thread is different: it looks inward, into the car's cabin and it's not the RLS/RLHS/RLFS.
    The latter sensor lives on the tachometer clock dial between "7" and "8" - see below
    So changing the values in version-1, or version-2 shouldn't affect the switch ON/OFF lighting dynamic that the RLS/RLHS/RLFS imposes on the AUTO position.
    Why not try it - what's the worst that can happen ?- if you don't like the lighting effect, simply revert the setting back, or change them to something else.
    Perhaps version-2 is simpler. If you like to live-on-the-edge , try the values below which should maximize the illumination of the clocks during daylight while still providing the driver a visual prompt to turn-on the headlights at dusk (for those times when the LDS isn't on AUTO position):
    ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1 > 2
    ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2 > 2
    ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3 > 64
    ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4 > 64
    ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5 > 64
    ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6 > 64
    PS: Interesting aside regarding your question - I've noticed the following two channels from your BCM admap:
    Back when I was a young student trying to learn this stuff, we used 500 lux as a nominal value for dusk. Clearly the design of the RLS has an embedded hysteresis in it's operation to stop the headlights from "hunting" (continuously switching on/off) at the cusp of dawn/dusk - I guess. I wonder if these values can be changed?
  7. Likes Uwe liked this post
