Label file for Audi A6 4G
Perko
C?ID=188298
Hi I just bought a used Audi A6 2012 model, from December 2011, Among some of the things, I am missing ACC display in the FIS, and thought this might be a coding problem; but starting VCDS, I find no long coding help for CAN BUS, ACC or Instrument cluster coding.
I do not dare to change anything that is not documented.
Is this something we can expect in the not too distant future?
I will attach a full scan of the car
Per
Scan:
Monday,06,April,2015,12:05:59:35772
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WAUZZZ4G2CN094248   License Plate: AU11970
Mileage: 104896km-65179mi   Repair Order:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 28 34 36 3B 42 44 46
          47 52 53 55 56 5F 62 69 6C 6D 72 85 8B 8E 8F 90
VIN: WAUZZZ4G2CN094248   Mileage: 104896km-65179miles
69-Trailer -- Status: Not registered 0011
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CLAA)       Labels: 059-907-311-CLA.clb
   Part No SW: 4G0 907 311 B    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0002
   Revision: 53H37---
   Coding: 12254012046601020000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907311B 001003
   ROD: EV_ECM30TDI0114G0907311B.rod
   VCID: 224DB0FA35444D3158B-8077
13812 - Exhaust Gas Temperature Sensor 4 Bank 1
          P246F 00 [032] - Implausible Signal
                    Mileage: 104896 km
                    Time: 00:00:00
5619 - Engine Off Timer Performance
          P150A 00 [096] - -
                    Mileage: 104112 km
                    Date: 2015.03.27
                    Time: 00:39:39
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 4G1 927 156 C    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0001
   Revision: --H10---    Serial number: 0000001352
   Coding: 000001
   ROD: EV_TCMDL501.rod
   VCID: 2D5753C67C9A8249F59-8078
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379.clb
   Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
   Coding: 07A6C701E065E380CB00
   ROD: EV_ESPPremiAU57X_AU57.rod
   VCID: 3879729283D837E196F-806D
   Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
   Coding: 01A93006000000000000
   VCID: 76E5BCAAC14C8191443-8023
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H12 0063
   Serial number: 27111100040958
   Coding: 3602007824
   ASAM Dataset: EV_AirCondiComfoUDS 002035
   ROD: EV_AirCondiComfoUDS.rod
   VCID: 275BA1EE5E66A8190F5-8072
0276 - Engine Off Timer Performance
          P150A 00 [008] - -
                    Reset counter: 136
                    Mileage: 104112 km
                    Date: 2015.03.27
                    Time: 00:00:32
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001144696
   Coding: 0907201009749FE289810087A0001800CF9CC7082E080101800108542F01
   VCID: 6ED594CAB91CB9518C3-803B
   Subsystem 1 - Part No SW: 4G1 955 119     HW: 4G8 955 119
   Component: WWS57X 111026  H35 0051
   Coding: 0045F7
   Component: RLS  H04 0003
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Coding: 110000
   Coding: 110000
   Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Coding: 020300
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0043
   Revision: 11001001    Serial number: 55901132801177
   Coding: 280B07
   ROD: EV_EPHVA18AU57X0000.rod
   VCID: 3B736D9EB2EE1CF97BD-806E
Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H17 0400
   Coding: 7D04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   ROD: EV_AdaptCruisContrAU57X.rod
   VCID: 2859A2D25378A76106F-807D
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG005PT9K
   Coding: 30323436313330303335554A304C34473053
   VCID: 36657CAA89CCC191843-8063
   Serial number: 3575HRB405B0TGJE38V0
   Serial number: 3585HRB40630Q3SK80FH
   Serial number: 3515JRB405R0V8BS7H1
   Serial number: 3525JRB40610TGJIGO8+
   Serial number: 3554VRB405J0QBGI31GX
   Serial number: 3564VRB405P0QBGIKP3P
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
   Revision: --------    Serial number: 90372KKB001ZJ
   Coding: 00003D
   VCID: 377B71AE86C638999F5-8062
   Component: E221 - MFL  H08 0009
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 931 R    HW: 4G8 920 931 R
   Component: TDieRdwAcc    H79 0416
   Revision: 25460175    Serial number: 658221111593006
   Coding: 138611001F050008000000
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K.rod
   VCID: 3D776386ACFA12C9459-8068
   Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000314585
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 346146A29FB0D381BA7-8061
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790165080
   Voltage stabilizer:
0021 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Fault Frequency: 35
                    Reset counter: 102
                    Mileage: 104112 km
                    Date: 2015.03.27
                    Time: 11:34:55
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Revision: AA001002
   Coding: 04018264747464545425363E
   VCID: 336345BE92BED4B9A3D-8066
Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0056
   Serial number: 19071100040317
   Coding: 00
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
   ROD: EV_ClimaContrUnitRearUDS.rod
   VCID: 2F6B49CE7696F059C75-807A
Address 34: Level Control (J197)       Labels: None
   Part No SW: 4G0 907 553 E    HW: 4G0 907 553
   Component: LUFE-DAEMPFER H17 0781
   Coding: 008003
   ROD: EV_AirSuspe_AU57.rod
   Revision: AA000000    Serial number: 00000018882856
   Coding: 0058130000006001000001010101102030303232203232
   VCID: 77FBB1AEC646F8995F5-8022
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA4202X04$0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA.rod
   Part No SW: 4G8 959 793 D    HW: 4G8 959 793
   Component: TSG FA        H05 0212
   Coding: 011F16204E00628002080003
   Shop #: WSC 02312 785 00200
   VCID: 418F1F76D8027629211-8014
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0015229977
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS.rod
   VCID: 326D40BA65A4DDB1A8B-8067
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0164203427
   Coding: 0100062020B93400832009842C0104000000000000000000000000000000
   Subsystem 1 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 96
                    Mileage: 104118 km
                    Date: 2015.03.27
                    Time: 13:32:30
02615 - Fuel Tank Cap; Lock
                    Reset counter: 96
                    Mileage: 104119 km
                    Date: 2015.03.27
                    Time: 13:50:29
   Revision: CJ007001    Serial number: 00000000008972
   Coding: 030000
   VCID: 1D378306043A72C9659-8048
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Coding: 011F16204E00628002080002
   Revision: --------    Serial number: 00000000193361
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 2A5D58DA4D74957110B-807F
Address 55: Headlight Range (J431)       Labels: None
   Serial number: 111123-0002-074
   Coding: 11226F601002A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C515EC247808B41E27-8079
   Part No SW: 4G1 035 053 E    HW: 4G1 035 053
   Component: Radio U Basic H41 0093
   Revision: AB001007    Serial number: 227KV0B7511143
   Coding: 010003010000000001
   VCID: 214FBFF638425629411-8074
   Part No SW: 4G0 035 670 G    HW: 4G0 035 670 A
   Component: H-BNT-EU      H47 0484
   Revision: --------    Serial number: 428KZ0B7532601
   Coding: 050100010003F9EF65308B3E00000003080001000000000000
   VCID: 275BA1EE5666A8190F5-8072
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: CD-Database  3638
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F14204000628002080002
   VCID: 44811662C71063010A7-8011
Address 69: Trailer (J345)       Labels: None
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Component: Anhaenger     H11 0100
   Revision: 5G001001    Serial number: 00008200215391
   Coding: 0100000000000000
   VCID: 71EF8FB6A822A6A9911-8024
02588 - Swiveling Trailer Hitch
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent - MIL ON
                    Fault Status: 10100101
                    Reset counter: 136
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 4H0 907 428 A    HW: 7P6 907 441 D
   Component: TopView       H05 0111
   Revision: 11001001    Serial number: 82330JF0016687
   Coding: 0202000001010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
   ROD: EV_CamerSysteTopViewAUDI.rod
   VCID: 2B535DDE428E8C79EBD-807E
Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
   Part No SW: 4G9 959 107 A    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0139
   Revision: 14003001    Serial number: 324100240
   Coding: 097205C010
   ASAM Dataset: EV_HDSGAu572 001001
   ROD: EV_HDSGAu571.rod
0004 - No Basic Setting
          B2010 00 [137] -  -
                    Reset counter: 96
                    Mileage: 104112 km
                    Date: 2015.03.27
                    Time: 12:30:40
0114 - Load Space Cover
          B12EF 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 136
                    Time: 00:00:00
   Component: TSG HR        H04 0212
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H25 0036
   Coding: EA040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 65C7EBE664EA7A09FD9-8030
Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Coding: 7D04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   ROD: EV_AdaptCruisContr2AU57X.rod
   VCID: 2645ACEA596CB111343-8073
87552 - Control Module Incorrectly Coded
          U1014 00 [008] - -
                    Reset counter: 136
                    Mileage: 104112 km
                    Date: 2015.03.27
                    Time: 11:34:56
Address 8E: Image Processing (J851)       Labels: 4G0-907-107.clb
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000051611117
   Coding: 0480AB181111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7_AU57.rod
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 00660600031F037E000308014248D2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 316F4FB660A2E6A9D11-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 06:10)--------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Based on your scan, the long coding assist should work just fine for #13 (ACC) and #17 (Instruments). As for #19 (Gateway), that is on our todo list.
Dana
Western PA, USA
It looks like you purchased VCDS from one of our distributors. Please register with us for technical support using this page: http://www.ross-tech.com/vca/hex-com-reg.php
After doing so one of the guys can change your forum status to Verified VCDS User so you aren't limited to posting in the New User sub-forum.
NEtech
C?ID=56995
Trailer retrofit is not coded.
Dana
Western PA, USA
Nice catch Niels. 1D0 = Without trailer hitch according to the VIN and that retrofit would require coding modifications to several controllers in this type of vehicle.
Please post in the Retrofits section after you are registered for support if you need assistance with that.
Perko
C?ID=188298
OK I have done the registration, on the registration page now
Verified and moving to Retrofits.
Perko
C?ID=188298
Sebastian, it is for #19, and #8B, that is indicated as "Control Module Incorrectly Coded", where I am missing the help.
Also module #69 Trailer does not have any help, I now also tried with V14.10.2, that I installed on one laptop, and with
the beta version, that I installed on another laptop. Apart from the errors I am getting, Also I gannot get the ACC display
in the FIS, which I guess is also due to a coding problem. ( I know it is there, as I saw the display shortly when another
car changed lane just in front of me, which engaded the emergency brake, and displayed in the FIS for about 1 second)
I tried looking at the "Trailer Hitch Retrofitting a6 (4F)" (there is none for 4G); but help text is missing in many of the modules.
After coding the ones where I could find help, the scan looks like this:
Thursday,09,April,2015,13:21:50:35772
VCDS Version: 15.3.0.0 (x64)
Data version: 20150314
Mileage: 104911km-65188mi   Repair Order:
VIN: WAUZZZ4G2CN094248   Mileage: 104911km-65188miles
   Revision: 53H37---
   Coding: 12254012047601020000
   VCID: 224DB0FA35444D28F1-8077
   Coding: 000001
   VCID: 2D5753C67C9A82505C-8078
   VCID: 3879729283D837F83F-806D
   VCID: 76E5BCAAC14C8188ED-8023
   Coding: 3602007824
   VCID: 275BA1EE5E66A800A6-8072
          P150A 00 [008] - -
                    Reset counter: 136
                    Mileage: 104112 km
                    Date: 2015.03.27
                    Time: 00:00:32
   VCID: 6ED594CAB91CB94825-803B
   Coding: 0045F7
   Coding: 02512B
   Coding: 110000
   Coding: 110000
   Coding: 020300
   Coding: 280B07
   VCID: 3B736D9EB2EE1CE0D2-806E
   Coding: 7D04010202
   VCID: 2859A2D25378A778AF-807D
   VCID: 36657CAA89CCC1882D-8063
   Coding: 00003D
   VCID: 377B71AE86C6388036-8062
   ROD: EV_RBD4K.rod
   VCID: 3D776386ACFA12D0EC-8068
   Coding: 00CD077D00
   VCID: 346146A29FB0D39813-8061
   Voltage stabilizer:
          U1014 00 [008] - -
                    Reset counter: 143
                    Mileage: 104911 km
                    Date: 2015.04.09
                    Time: 11:53:36
   Revision: AA001002
   VCID: 336345BE92BED4A00A-8066
   Coding: 00
   VCID: 2F6B49CE7696F0406E-807A
   Coding: 008003
   VCID: 77FBB1AEC646F880F6-8022
   ROD: EV_SARA.rod
   VCID: 418F1F76D802763088-8014
   ROD: EV_RCEPS.rod
   VCID: 326D40BA65A4DDA801-8067
                    Reset counter: 96
                    Mileage: 104118 km
                    Date: 2015.03.27
                    Time: 13:32:30
                    Reset counter: 96
                    Mileage: 104119 km
                    Date: 2015.03.27
                    Time: 13:50:29
   Coding: 030000
   VCID: 1D378306043A72D0CC-8048
   VCID: 2A5D58DA4D749568B9-807F
   VCID: 2C515EC247808B584B-8079
   VCID: 214FBFF638425630E8-8074
   VCID: 275BA1EE5666A800A6-8072
   VCID: 44811662C7106318A3-8011
   VCID: 71EF8FB6A822A6B038-8024
                    Reset counter: 136
   VCID: 2B535DDE428E8C6042-807E
   Coding: 097205C010
          B2010 00 [137] -  -
                    Reset counter: 96
                    Mileage: 104112 km
                    Date: 2015.03.27
                    Time: 12:30:40
                    Reset counter: 136
                    Time: 00:00:00
   Coding: EA040000
   VCID: 65C7EBE664EA7A1054-8030
   Coding: 7D04010202
   VCID: 2645ACEA596CB1089D-8073
          U1014 00 [008] - -
                    Reset counter: 136
                    Mileage: 104112 km
                    Date: 2015.03.27
                    Time: 11:34:56
   ROD: EV_RGS_L.rod
   VCID: 316F4FB660A2E6B078-8064
   ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 06:31)--------------------------
Dana
Western PA, USA
It looks like this car was born with ACC (PR code: 8T4 - Adaptive Cruise Control) so the missing display is likely the end result of the incomplete 69-Trailer retrofit.
That ABS module may not accept coding modifications but we are working on fine tuning a special procedure. Additional information is located in this recent A7 thread (specifically posts #4 and #16) : Audi A7 New ABS Module coding
The best way to configure the 69-Trailer retrofit would be via SVM at the Audi dealer. This is explained in some detail here: (Post #8) 2013 Q5 Trailer Hitch Retrofit
We can try to build you a list of the new coding values in forum, like Niels did for this individual, but I don't think the ABS is going to cooperate. Please let us know if you intend on sending this vehicle off for SVM configuration or not.
