Results 1 to 10 of 10
Thread: 2014 Q5 Tweaks - Windows and Drive Select - Doesn't work the same as S4
    Mar 2014
    Hi there!
    There are a few tweaks I am trying to implement on the Q5 that I have on the S4. But, they don't seem to be working correctly.
    The most notable is the comfort window operation. In module 46, using the long coding helper to adjust byte 16, I enabled keyless access, remote, and left the door lock enabled for comfort operation. Yet the feature does not work and I do not see the requisite menu listed in the MMI that is used to turn on and off the various areas to be controlled by the comfort operation.
    The other large item is the setting of the default drive select mode. Any other insight to doing this with the Q5? The stock values: 63=0, 64=218, 65=0, 66=15. I changed 66 to 47 and got the efficiency program listed in the MMI. Seems kind of neat but haven't played with it much.
    Any ideas?
    United States
    Hello Jack,
    Are you sure Adaptation Channels 001, 002, 003, 004, 061 and 062 aren't available in that BCM for the comfort window operation?
    Audi A4/S4/A5/S5 (8K/8T) Tweaks
    -Dana
    Mar 2014
    Thanks Dana - Unfortunately - this did not work wither. Most of those channels are NA. The one I did see had a value of 100 and no pop up balloon. The other that came up had a tie in to the known channels bar that read turn signal dimming. (Disable the winking DRL)
    United States
    OK Jack. Type #2 PLA and PLB Control module maps from the 09 controller would be helpful at some point so we can see which Adaptation channels and/or Measuring Block values changed. Control Module Maps
    If you send the maps via email please include a scan.
    Thanks,
    Dana
    Mar 2014
    The autoscan and the PLA and PLB logs can be found here:
    http://www.filedropper.com/logs
    EDIT: FYI - Just click on the link that says download this file. The link that references a file opener is spam.
    Jack, since those files are plain text, we'd prefer people to just post 'em here, like this:
    Friday,21,March,2014,22:00:39:61963
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: WA1DMAFP4EA087493   License Plate:
    Mileage: 230km-142mi   Repair Order:
    Chassis Type: FP (8R0)
    Scan: 01 02 03 05 08 09 14 15 16 17 19 36 42 44 46 47 52 53 56 5F
              62 6C 6D 72 AC
    VIN: WA1DMAFP4EA087493   Mileage: 230km/142miles
    Address 01: Engine (J623-CPNB)       Labels: None
       Part No SW: 8K5 907 401 J    HW: 4G0 907 401 E
       Component: 3.0TDI EDC17  H14 0003
       Revision: 58H14---
       Coding: 2A2A4012052603050000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM30TDI0118K5907401J 001004
       ROD: EV_ECM30TDI0118K5907401J.rod
       VCID: 377DE9A48EBF8FA66AD-8062
    Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
       Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
       Component: 0BK 30 TDIUSA H16 1003
       Revision: --H16---
       Coding: 000001
       ROD: EV_TCMAL551211_AU48.rod
       VCID: 4B95A554E2371B463E5-801E
       Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
       Component: ESP8 quattro  H09 0020
       Coding: 231D1C03
       Shop #: WSC 06335 000 00000
       VCID: 9129F73C489BF196849-80C4
       Part No SW: 8K0 907 064 JP    HW: 8K0 907 064 JP
       Component: BCM2 2.0      H14 0650
       Coding: 0DA54040000000000000
       VCID: 871DD96436DFBF265AD-80D2
       Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
       Revision: C1000000    Serial number: 01010220140268
       Coding: 3621228080
       VCID: 3979EF9CB0AB99D69C9-806C
       Revision: 08016001    Serial number: 00000060543401
       Coding: 26000091803CAFE00901408300003D0D0F9CC708A6090221000008004000070100000034000000
       Shop #: WSC 06335 123 12345
       VCID: 78FF2A98CB2140DEA37-802D
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 140120  H11 0050
       Coding: 01DD13
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
       Coding: 02005C
       Component: E1 - LDS  H03 0031
       Component: USHL4.2  H30 0030
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 8R0 907 364 C    HW: 8K0 907 364
       Component: DAEMPFUNGS-SG H09 0054
       Revision: 00000000    Serial number: 14011400930001
       Coding: 010181
       VCID: 3A7BF090B5AD92CE953-806F
    Address 15: Airbags (J234)       Labels: 8R0-959-655.clb
       Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
       Component: AirbagVW-AU10 H47 0610
       Serial number: 003GPDB0WNF9
       Coding: 303634313432303030304A55304C38523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 479D9964FE5FFF261AD-8012
       Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
       Serial number: 5810000R140000H6U2
       Serial number: 6334MSME410D3769G
       Serial number: 6344MSME41085739B
       Serial number: 6352QSME5A3A5662O
       Serial number: 6362QSME3C3C0B42P
       Serial number: 63732SME753A307A1
       Crash sensor for front airbag; passenger side:
       Serial number: 63832SME753A1B40+
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862NB20019A
       Coding: 000037
       VCID: 489F9A58FB41F05E137-801D
    Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 982 A    HW: 8R0 920 982 A
       Component: KOMBIINSTR.   H35 0564
       Revision: 00100000    Serial number: ZD6371W1F
       Coding: 8BBF22001301D705020000
       Component: GW-BEM 4CAN-M H11 0060
       Revision: 1Y080030    Serial number: 3041Y14120053E
       Coding: 80CF07FF00
       VCID: 4A9BA050E54D024E053-801F
       Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
       Component: J367-BDMHella  H07 8043
    00384 - Optical Databus
                        Fault Status: 00101011
                        Reset counter: 43
                        Mileage: 39 km
                        Date: 2014.03.17
                        Time: 23:00:48
                        Bin. Bits:    10000
                        Voltage: 12.20 V
                        Count: 9
                        Bin. Bits:    00000
       Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
       Component: MEM-FS        H07 0076
       Revision: AA000000    Serial number: 00000088137492
       Coding: 01581B00000000000000
       VCID: 428B8870DD7DDA0ECD3-8017
       Component: TSG FA        H02 0510
       Revision:             Serial number: 0000088923873
       Coding: 011D13205E00440004
       VCID: 4FADB1441E2F276652D-801A
    Address 44: Steering Assist (J500)       Labels: None
       Part No SW: 8R0 909 144 G    HW: 8R0 909 144 B
       Component: RCEPS         H40 0508
       Revision: 00001000    Serial number: 0018228498
       Coding: 100000010001
       Shop #: WSC 06334 000 00000
       ASAM Dataset: EV_RCEPSAU48X 008015
       ROD: EV_RCEPSAU48X.rod
       VCID: 3C77F688B799ACFE87F-8069
       Revision: 00002001    Serial number: 0324985440
       Coding: 01260E3A20FA709584A0053600040047
       Shop #: WSC 06334 123 12345
       Component: GTO BF  H01 0080
       Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J245EE04SKB03  H03 0090
       Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J394EE04SKB03  H03 0090
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
       Revision: 00005001    Serial number: 94813024926404
       VCID: 2D51CBCC74E33576001-8078
       Revision:             Serial number: 0000089572031
       VCID: 4E93AC4019252E6E59B-801B
    Address 53: Parking Brake (----)       Labels: None
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H01 0005
       Revision: --------    Serial number: 30000000160843
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3A7BF090BDAD92CE953-806F
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 156A+0E7960475
       Coding: 020007010000000001
       VCID: 24472EE82729F43EDFF-8071
       Part No SW: 8R1 035 746 E    HW: 8R1 035 746 D
       Component: H-BNT-NA      H41 0756
       Revision: --------    Serial number: 204BX0E7637714
       Coding: 160200060005E1EF45828F5E00000403140000000000000000
       Subsystem 1 - Part No: 8R0 060 884 BL
       Component: NAR 2014  0902
       Component: DU7 High  H42 0104
       Component: CD-Database  5571
    02067 - Optical Databus; Unpermitted Wake-Up Request
                        Reset counter: 43
                        Mileage: 39 km
                        Date: 2014.03.17
                        Time: 22:59:52
                        Voltage: 12.40 V
                        Reset counter: 11
                        Mileage: 236 km
                        Date: 2014.03.21
                        Time: 21:21:27
                        Bin. Bits: 00000000 00000000
                        Bin. Bits: 00000000 00000100
       Component: TSG HL        H01 0510
       Revision:             Serial number: 0000088664962
       Coding: 010C13204000240004
       VCID: 46839460F155E62EE1B-8013
       Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
       Revision: --H09---    Serial number: 525PA8-J3XA5FY
       Coding: 1020010
       VCID: 3467DEA857C964BE4FF-8061
       Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
       Component: J605  Master  H53 0330
       Revision: --------    Serial number: 8R0827851D
       VCID: 3D71FB8CA483A5F6B01-8068
       Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
       Component: J756  Slave  H53 0330
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
       Component: TSG HR        H01 0510
       Revision:             Serial number: 0000088665016
    Address AC: Reductant Control (J880)       Labels: None
       Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H09 0010
       Revision: 00000000    Serial number: 140140911
       ROD: EV_RDCMA00100.rod
       VCID: 2B55C5D442F73B461E5-807E
    ;SW:8K0-907-063-DH   HW:8K0-907-063-DH ---  Cent. Elect.
    ;Component:BCM1 1.0      H16 0103, Coding:26000091803CAFE00901408300003D0D0F9CC708A6090221000008004000070100000034000000
    ;Wednesday,16,April,2014,20:11:34:61963
    ;VCDS Version: Release 12.12.2  Data version: 20140212
    ;VCID: 78FF2A98CB2140DEA37-802D
    A01,0,
    ;100
    A01,1,
    A01,2,
    A01,3,
    A01,4,
    ;02 N/A
    A03,0,
    ;64
    A03,1,
    A03,2,
    A03,3,
    A03,4,
    ;04 N/A
    ;05 N/A
    A06,0,
    ;550
    A06,1,
    ;OFF
    A06,2,
    ;N/A
    A06,3,
    ;N/A
    A06,4,
    ;N/A
    A07,0,
    ;1000
    A07,1,
    ;OFF
    A07,2,
    ;N/A
    A07,3,
    ;N/A
    A07,4,
    ;N/A
    ;08 N/A
    ;09 N/A
    ;10 N/A
    ;11 N/A
    A12,0,
    ;120
    A12,1,
    ;N/A
    A12,2,
    ;N/A
    A12,3,
    ;N/A
    A12,4,
    ;N/A
    A13,0,
    ;60
    A13,1,
    ;N/A
    A13,2,
    ;N/A
    A13,3,
    ;N/A
    A13,4,
    ;N/A
    A14,0,
    ;15
    A14,1,
    ;N/A
    A14,2,
    ;N/A
    A14,3,
    ;N/A
    A14,4,
    ;N/A
    ;15 N/A
    A16,0,
    ;3
    A16,1,
    ;N/A
    A16,2,
    ;N/A
    A16,3,
    ;N/A
    A16,4,
    ;N/A
    A17,0,
    ;15
    A17,1,
    ;N/A
    A17,2,
    ;N/A
    A17,3,
    ;N/A
    A17,4,
    ;N/A
    A18,0,
    ;255
    A18,1,
    ;N/A
    A18,2,
    ;N/A
    A18,3,
    ;N/A
    A18,4,
    ;N/A
    A19,0,
    ;1
    A19,1,
    ;N/A
    A19,2,
    ;N/A
    A19,3,
    ;N/A
    A19,4,
    ;N/A
    A20,0,
    ;0
    A20,1,
    ;N/A
    A20,2,
    ;N/A
    A20,3,
    ;N/A
    A20,4,
    ;N/A
    A21,0,
    ;1
    A21,1,
    ;N/A
    A21,2,
    ;N/A
    A21,3,
    ;N/A
    A21,4,
    ;N/A
    A22,0,
    ;1
    A22,1,
    ;N/A
    A22,2,
    ;N/A
    A22,3,
    ;N/A
    A22,4,
    ;N/A
    A23,0,
    ;1
    A23,1,
    ;N/A
    A23,2,
    ;N/A
    A23,3,
    ;N/A
    A23,4,
    ;N/A
    A24,0,
    ;1
    A24,1,
    ;N/A
    A24,2,
    ;N/A
    A24,3,
    ;N/A
    A24,4,
    ;N/A
    A25,0,
    ;8000
    A25,1,
    ;N/A
    A25,2,
    ;N/A
    A25,3,
    ;N/A
    A25,4,
    ;N/A
    A26,0,
    ;8
    A26,1,
    ;N/A
    A26,2,
    ;N/A
    A26,3,
    ;N/A
    A26,4,
    ;N/A
    ;27 N/A
    ;28 N/A
    ;29 N/A
    ;30 N/A
    ;31 N/A
    ;32 N/A
    ;33 N/A
    A34,0,
    ;60
    A34,1,
    ;N/A
    A34,2,
    ;N/A
    A34,3,
    ;N/A
    A34,4,
    ;N/A
    A35,0,
    ;0
    A35,1,
    ;N/A
    A35,2,
    ;N/A
    A35,3,
    ;N/A
    A35,4,
    ;N/A
    ;36 N/A
    A37,0,
    ;3
    A37,1,
    ;N/A
    A37,2,
    ;N/A
    A37,3,
    ;N/A
    A37,4,
    ;N/A
    A38,0,
    ;1000
    A38,1,
    ;N/A
    A38,2,
    ;N/A
    A38,3,
    ;N/A
    A38,4,
    ;N/A
    A39,0,
    ;550
    A39,1,
    ;N/A
    A39,2,
    ;N/A
    A39,3,
    ;N/A
    A39,4,
    ;N/A
    A40,0,
    ;117
    A40,1,
    ;32.5°C
    A40,2,
    ;OFF
    A40,3,
    ;N/A
    A40,4,
    ;N/A
    A41,0,
    ;1
    A41,1,
    ;N/A
    A41,2,
    ;N/A
    A41,3,
    ;N/A
    A41,4,
    ;N/A
    A42,0,
    ;1
    A42,1,
    ;N/A
    A42,2,
    ;N/A
    A42,3,
    ;N/A
    A42,4,
    ;N/A
    A43,0,
    ;20
    A43,1,
    ;N/A
    A43,2,
    ;N/A
    A43,3,
    ;N/A
    A43,4,
    ;N/A
    A44,0,
    ;1
    A44,1,
    ;N/A
    A44,2,
    ;N/A
    A44,3,
    ;N/A
    A44,4,
    ;N/A
    A45,0,
    ;0
    A45,1,
    ;N/A
    A45,2,
    ;N/A
    A45,3,
    ;N/A
    A45,4,
    ;N/A
    A46,0,
    ;1
    A46,1,
    ;N/A
    A46,2,
    ;N/A
    A46,3,
    ;N/A
    A46,4,
    ;N/A
    A47,0,
    ;1
    A47,1,
    ;N/A
    A47,2,
    ;N/A
    A47,3,
    ;N/A
    A47,4,
    ;N/A
    A48,0,
    ;120
    A48,1,
    ;N/A
    A48,2,
    ;N/A
    A48,3,
    ;N/A
    A48,4,
    ;N/A
    A49,0,
    ;120
    A49,1,
    ;N/A
    A49,2,
    ;N/A
    A49,3,
    ;N/A
    A49,4,
    ;N/A
    A50,0,
    ;120
    A50,1,
    ;N/A
    A50,2,
    ;N/A
    A50,3,
    ;N/A
    A50,4,
    ;N/A
    A51,0,
    ;120
    A51,1,
    ;N/A
    A51,2,
    ;N/A
    A51,3,
    ;N/A
    A51,4,
    ;N/A
    A52,0,
    ;120
    A52,1,
    ;N/A
    A52,2,
    ;N/A
    A52,3,
    ;N/A
    A52,4,
    ;N/A
    A53,0,
    ;0
    A53,1,
    ;N/A
    A53,2,
    ;N/A
    A53,3,
    ;N/A
    A53,4,
    ;N/A
    ;54 N/A
    A55,0,
    ;1
    A55,1,
    ;N/A
    A55,2,
    ;N/A
    A55,3,
    ;N/A
    A55,4,
    ;N/A
    A56,0,
    ;1
    A56,1,
    ;N/A
    A56,2,
    ;N/A
    A56,3,
    ;N/A
    A56,4,
    ;N/A
    A57,0,
    ;0
    A57,1,
    ;N/A
    A57,2,
    ;N/A
    A57,3,
    ;N/A
    A57,4,
    ;N/A
    A58,0,
    ;1
    A58,1,
    ;N/A
    A58,2,
    ;N/A
    A58,3,
    ;N/A
    A58,4,
    ;N/A
    A59,0,
    ;60
    A59,1,
    ;N/A
    A59,2,
    ;N/A
    A59,3,
    ;N/A
    A59,4,
    ;N/A
    A60,0,
    ;1
    A60,1,
    ;N/A
    A60,2,
    ;N/A
    A60,3,
    ;N/A
    A60,4,
    ;N/A
    ;61 N/A
    ;62 N/A
    A63,0,
    ;0
    A63,1,
    ;N/A
    A63,2,
    ;N/A
    A63,3,
    ;N/A
    A63,4,
    ;N/A
    A64,0,
    ;218
    A64,1,
    ;N/A
    A64,2,
    ;N/A
    A64,3,
    ;N/A
    A64,4,
    ;N/A
    A65,0,
    ;0
    A65,1,
    ;N/A
    A65,2,
    ;N/A
    A65,3,
    ;N/A
    A65,4,
    ;N/A
    A66,0,
    ;47
    A66,1,
    ;N/A
    A66,2,
    ;N/A
    A66,3,
    ;N/A
    A66,4,
    ;N/A
    A67,0,
    ;2
    A67,1,
    ;N/A
    A67,2,
    ;N/A
    A67,3,
    ;N/A
    A67,4,
    ;N/A
    A68,0,
    ;2
    A68,1,
    ;N/A
    A68,2,
    ;N/A
    A68,3,
    ;N/A
    A68,4,
    ;N/A
    A69,0,
    ;600
    A69,1,
    ;N/A
    A69,2,
    ;N/A
    A69,3,
    ;N/A
    A69,4,
    ;N/A
    A70,0,
    ;14
    A70,1,
    ;N/A
    A70,2,
    ;N/A
    A70,3,
    ;N/A
    A70,4,
    ;N/A
    A71,0,
    ;15015
    A71,1,
    ;N/A
    A71,2,
    ;N/A
    A71,3,
    ;N/A
    A71,4,
    ;N/A
    A72,0,
    ;3003
    A72,1,
    ;N/A
    A72,2,
    ;N/A
    A72,3,
    ;N/A
    A72,4,
    ;N/A
    A73,0,
    ;2639
    A73,1,
    ;N/A
    A73,2,
    ;N/A
    A73,3,
    ;N/A
    A73,4,
    ;N/A
    A74,0,
    ;2093
    A74,1,
    ;N/A
    A74,2,
    ;N/A
    A74,3,
    ;N/A
    A74,4,
    ;N/A
    A75,0,
    ;2548
    A75,1,
    ;N/A
    A75,2,
    ;N/A
    A75,3,
    ;N/A
    A75,4,
    ;N/A
    A76,0,
    ;8450
    A76,1,
    ;N/A
    A76,2,
    ;N/A
    A76,3,
    ;N/A
    A76,4,
    ;N/A
    A77,0,
    ;42
    A77,1,
    ;N/A
    A77,2,
    ;N/A
    A77,3,
    ;N/A
    A77,4,
    ;N/A
    A78,0,
    ;16426
    A78,1,
    ;N/A
    A78,2,
    ;N/A
    A78,3,
    ;N/A
    A78,4,
    ;N/A
    A79,0,
    ;11568
    A79,1,
    ;N/A
    A79,2,
    ;N/A
    A79,3,
    ;N/A
    A79,4,
    ;N/A
    A80,0,
    ;13368
    A80,1,
    ;N/A
    A80,2,
    ;N/A
    A80,3,
    ;N/A
    A80,4,
    ;N/A
    A81,0,
    ;15424
    A81,1,
    ;N/A
    A81,2,
    ;N/A
    A81,3,
    ;N/A
    A81,4,
    ;N/A
    ;82 N/A
    ;83 N/A
    ;84 N/A
    ;85 N/A
    ;86 N/A
    ;87 N/A
    ;88 N/A
    ;89 N/A
    ;90 N/A
    ;91 N/A
    ;92 N/A
    ;93 N/A
    ;94 N/A
    ;95 N/A
    ;96 N/A
    ;97 N/A
    ;98 N/A
    ;99 N/A
    A100,0,
    ;26
    A100,1,
    ;N/A
    A100,2,
    ;N/A
    A100,3,
    ;N/A
    A100,4,
    ;N/A
    A101,0,
    ;28
    A101,1,
    ;N/A
    A101,2,
    ;N/A
    A101,3,
    ;N/A
    A101,4,
    ;N/A
    A102,0,
    ;36
    A102,1,
    ;N/A
    A102,2,
    ;N/A
    A102,3,
    ;N/A
    A102,4,
    ;N/A
    A103,0,
    ;38
    A103,1,
    ;N/A
    A103,2,
    ;N/A
    A103,3,
    ;N/A
    A103,4,
    ;N/A
    A104,0,
    ;46
    A104,1,
    ;N/A
    A104,2,
    ;N/A
    A104,3,
    ;N/A
    A104,4,
    ;N/A
    A105,0,
    ;48
    A105,1,
    ;N/A
    A105,2,
    ;N/A
    A105,3,
    ;N/A
    A105,4,
    ;N/A
    A106,0,
    ;66
    A106,1,
    ;N/A
    A106,2,
    ;N/A
    A106,3,
    ;N/A
    A106,4,
    ;N/A
    A107,0,
    ;68
    A107,1,
    ;N/A
    A107,2,
    ;N/A
    A107,3,
    ;N/A
    A107,4,
    ;N/A
    A108,0,
    ;86
    A108,1,
    ;N/A
    A108,2,
    ;N/A
    A108,3,
    ;N/A
    A108,4,
    ;N/A
    A109,0,
    ;88
    A109,1,
    ;N/A
    A109,2,
    ;N/A
    A109,3,
    ;N/A
    A109,4,
    ;N/A
    A110,0,
    ;110
    A110,1,
    ;N/A
    A110,2,
    ;N/A
    A110,3,
    ;N/A
    A110,4,
    ;N/A
    A111,0,
    ;112
    A111,1,
    ;N/A
    A111,2,
    ;N/A
    A111,3,
    ;N/A
    A111,4,
    ;N/A
    ;112 N/A
    ;113 N/A
    ;114 N/A
    ;115 N/A
    ;116 N/A
    ;117 N/A
    ;118 N/A
    ;119 N/A
    ;120 N/A
    A121,0,
    ;10
    A121,1,
    ;N/A
    A121,2,
    ;N/A
    A121,3,
    ;N/A
    A121,4,
    ;N/A
    A122,0,
    ;13
    A122,1,
    ;N/A
    A122,2,
    ;N/A
    A122,3,
    ;N/A
    A122,4,
    ;N/A
    A123,0,
    ;6
    A123,1,
    ;N/A
    A123,2,
    ;N/A
    A123,3,
    ;N/A
    A123,4,
    ;N/A
    A124,0,
    ;20
    A124,1,
    ;N/A
    A124,2,
    ;N/A
    A124,3,
    ;N/A
    A124,4,
    ;N/A
    A125,0,
    ;0
    A125,1,
    ;N/A
    A125,2,
    ;N/A
    A125,3,
    ;N/A
    A125,4,
    ;N/A
    A126,0,
    ;200
    A126,1,
    ;N/A
    A126,2,
    ;N/A
    A126,3,
    ;N/A
    A126,4,
    ;N/A
    A127,0,
    ;0
    A127,1,
    ;N/A
    A127,2,
    ;N/A
    A127,3,
    ;N/A
    A127,4,
    ;N/A
    A128,0,
    ;30
    A128,1,
    ;N/A
    A128,2,
    ;N/A
    A128,3,
    ;N/A
    A128,4,
    ;N/A
    ;129 N/A
    ;130 N/A
    ;131 N/A
    ;132 N/A
    ;133 N/A
    ;134 N/A
    ;135 N/A
    ;136 N/A
    ;137 N/A
    ;138 N/A
    ;139 N/A
    ;140 N/A
    ;141 N/A
    ;142 N/A
    ;143 N/A
    ;144 N/A
    ;145 N/A
    ;146 N/A
    ;147 N/A
    ;148 N/A
    ;149 N/A
    ;150 N/A
    ;151 N/A
    ;152 N/A
    ;153 N/A
    ;154 N/A
    ;155 N/A
    ;156 N/A
    ;157 N/A
    ;158 N/A
    ;159 N/A
    ;160 N/A
    ;161 N/A
    ;162 N/A
    ;163 N/A
    ;164 N/A
    ;165 N/A
    ;166 N/A
    ;167 N/A
    ;168 N/A
    ;169 N/A
    ;170 N/A
    ;171 N/A
    ;172 N/A
    ;173 N/A
    ;174 N/A
    ;175 N/A
    ;176 N/A
    ;177 N/A
    ;178 N/A
    ;179 N/A
    ;180 N/A
    ;181 N/A
    ;182 N/A
    ;183 N/A
    ;184 N/A
    ;185 N/A
    ;186 N/A
    ;187 N/A
    ;188 N/A
    ;189 N/A
    A190,0,
    ;0
    A190,1,
    ;N/A
    A190,2,
    ;N/A
    A190,3,
    ;N/A
    A190,4,
    ;N/A
    A191,0,
    ;0
    A191,1,
    ;N/A
    A191,2,
    ;N/A
    A191,3,
    ;N/A
    A191,4,
    ;N/A
    A192,0,
    ;0
    A192,1,
    ;N/A
    A192,2,
    ;N/A
    A192,3,
    ;N/A
    A192,4,
    ;N/A
    A193,0,
    A193,1,
    ;ERROR:
    A193,2,
    ;Security
    A193,3,
    ;access
    A193,4,
    ;required
    A194,0,
    A194,1,
    ;ERROR:
    A194,2,
    ;Security
    A194,3,
    ;access
    A194,4,
    ;required
    A195,0,
    A195,1,
    ;ERROR:
    A195,2,
    ;Security
    A195,3,
    ;access
    A195,4,
    ;required
    A196,0,
    A196,1,
    ;ERROR:
    A196,2,
    ;Security
    A196,3,
    ;access
    A196,4,
    ;required
    A197,0,
    A197,1,
    ;ERROR:
    A197,2,
    ;Security
    A197,3,
    ;access
    A197,4,
    ;required
    A198,0,
    A198,1,
    ;ERROR:
    A198,2,
    ;Security
    A198,3,
    ;access
    A198,4,
    ;required
    A199,0,
    ;0
    A199,1,
    ;N/A
    A199,2,
    ;N/A
    A199,3,
    ;N/A
    A199,4,
    ;N/A
    ;200 N/A
    A201,0,
    A201,1,
    ;ERROR:
    A201,2,
    ;Security
    A201,3,
    ;access
    A201,4,
    ;required
    A202,0,
    A202,1,
    ;ERROR:
    A202,2,
    ;Security
    A202,3,
    ;access
    A202,4,
    ;required
    A203,0,
    A203,1,
    ;ERROR:
    A203,2,
    ;Security
    A203,3,
    ;access
    A203,4,
    ;required
    A204,0,
    A204,1,
    ;ERROR:
    A204,2,
    ;Security
    A204,3,
    ;access
    A204,4,
    ;required
    A205,0,
    ;1
    A205,1,
    ;N/A
    A205,2,
    ;N/A
    A205,3,
    ;N/A
    A205,4,
    ;N/A
    A206,0,
    ;1
    A206,1,
    ;not available
    A206,2,
    ;not available
    A206,3,
    ;N/A
    A206,4,
    ;N/A
    A207,0,
    ;0
    A207,1,
    ;N/A
    A207,2,
    ;N/A
    A207,3,
    ;N/A
    A207,4,
    ;N/A
    A208,0,
    ;1
    A208,1,
    ;N/A
    A208,2,
    ;N/A
    A208,3,
    ;N/A
    A208,4,
    ;N/A
    A209,0,
    ;1
    A209,1,
    ;N/A
    A209,2,
    ;N/A
    A209,3,
    ;N/A
    A209,4,
    ;N/A
    A210,0,
    ;1
    A210,1,
    ;not available
    A210,2,
    ;N/A
    A210,3,
    ;N/A
    A210,4,
    ;N/A
    A211,0,
    ;1
    A211,1,
    ;not available
    A211,2,
    ;N/A
    A211,3,
    ;N/A
    A211,4,
    ;N/A
    A212,0,
    ;1
    A212,1,
    ;not available
    A212,2,
    ;N/A
    A212,3,
    ;N/A
    A212,4,
    ;N/A
    A213,0,
    ;1
    A213,1,
    ;not available
    A213,2,
    ;N/A
    A213,3,
    ;N/A
    A213,4,
    ;N/A
    A214,0,
    ;1
    A214,1,
    ;not available
    A214,2,
    ;N/A
    A214,3,
    ;N/A
    A214,4,
    ;N/A
    A215,0,
    A215,1,
    ;ERROR:
    A215,2,
    ;Security
    A215,3,
    ;access
    A215,4,
    ;required
    ;216 N/A
    A217,0,
    A217,1,
    ;ERROR:
    A217,2,
    ;Security
    A217,3,
    ;access
    A217,4,
    ;required
    ;218 N/A
    A219,0,
    A219,1,
    ;ERROR:
    A219,2,
    ;Security
    A219,3,
    ;access
    A219,4,
    ;required
    A220,0,
    ;0
    A220,1,
    ;N/A
    A220,2,
    ;N/A
    A220,3,
    ;N/A
    A220,4,
    ;N/A
    A221,0,
    ;0
    A221,1,
    ;N/A
    A221,2,
    ;N/A
    A221,3,
    ;N/A
    A221,4,
    ;N/A
    A222,0,
    ;150
    A222,1,
    ;N/A
    A222,2,
    ;N/A
    A222,3,
    ;N/A
    A222,4,
    ;N/A
    A223,0,
    ;197
    A223,1,
    ;N/A
    A223,2,
    ;N/A
    A223,3,
    ;N/A
    A223,4,
    ;N/A
    A224,0,
    ;1
    A224,1,
    ;N/A
    A224,2,
    ;N/A
    A224,3,
    ;N/A
    A224,4,
    ;N/A
    A225,0,
    ;20
    A225,1,
    ;N/A
    A225,2,
    ;N/A
    A225,3,
    ;N/A
    A225,4,
    ;N/A
    A226,0,
    ;4
    A226,1,
    ;N/A
    A226,2,
    ;N/A
    A226,3,
    ;N/A
    A226,4,
    ;N/A
    A227,0,
    ;1
    A227,1,
    ;N/A
    A227,2,
    ;N/A
    A227,3,
    ;N/A
    A227,4,
    ;N/A
    A228,0,
    ;2
    A228,1,
    ;N/A
    A228,2,
    ;N/A
    A228,3,
    ;N/A
    A228,4,
    ;N/A
    A229,0,
    ;4
    A229,1,
    ;N/A
    A229,2,
    ;N/A
    A229,3,
    ;N/A
    A229,4,
    ;N/A
    A230,0,
    ;4
    A230,1,
    ;N/A
    A230,2,
    ;N/A
    A230,3,
    ;N/A
    A230,4,
    ;N/A
    A231,0,
    ;4
    A231,1,
    ;N/A
    A231,2,
    ;N/A
    A231,3,
    ;N/A
    A231,4,
    ;N/A
    A232,0,
    ;6
    A232,1,
    ;N/A
    A232,2,
    ;N/A
    A232,3,
    ;N/A
    A232,4,
    ;N/A
    A233,0,
    ;10
    A233,1,
    ;N/A
    A233,2,
    ;N/A
    A233,3,
    ;N/A
    A233,4,
    ;N/A
    A234,0,
    ;27
    A234,1,
    ;N/A
    A234,2,
    ;N/A
    A234,3,
    ;N/A
    A234,4,
    ;N/A
    A235,0,
    ;0
    A235,1,
    ;N/A
    A235,2,
    ;N/A
    A235,3,
    ;N/A
    A235,4,
    ;N/A
    A236,0,
    ;0
    A236,1,
    ;N/A
    A236,2,
    ;N/A
    A236,3,
    ;N/A
    A236,4,
    ;N/A
    A237,0,
    A237,1,
    ;ERROR:
    A237,2,
    ;Security
    A237,3,
    ;access
    A237,4,
    ;required
    A238,0,
    A238,1,
    ;ERROR:
    A238,2,
    ;Security
    A238,3,
    ;access
    A238,4,
    ;required
    A239,0,
    A239,1,
    ;ERROR:
    A239,2,
    ;Security
    A239,3,
    ;access
    A239,4,
    ;required
    A240,0,
    A240,1,
    ;ERROR:
    A240,2,
    ;Security
    A240,3,
    ;access
    A240,4,
    ;required
    A241,0,
    A241,1,
    ;ERROR:
    A241,2,
    ;Security
    A241,3,
    ;access
    A241,4,
    ;required
    A242,0,
    A242,1,
    ;ERROR:
    A242,2,
    ;Security
    A242,3,
    ;access
    A242,4,
    ;required
    A243,0,
    A243,1,
    ;ERROR:
    A243,2,
    ;Security
    A243,3,
    ;access
    A243,4,
    ;required
    ;244 N/A
    ;245 N/A
    ;246 N/A
    ;247 N/A
    ;248 N/A
    ;249 N/A
    A250,0,
    A250,1,
    ;ERROR:
    A250,2,
    ;Security
    A250,3,
    ;access
    A250,4,
    ;required
    ;251 N/A
    ;252 N/A
    ;253 N/A
    A254,0,
    A254,1,
    ;ERROR:
    A254,2,
    ;Security
    A254,3,
    ;access
    A254,4,
    ;required
    A255,0,
    A255,1,
    ;ERROR:
    A255,2,
    ;Security
    A255,3,
    ;access
    A255,4,
    ;required
    ;Wednesday,16,April,2014,20:10:39:61963
    1,0,,
    1,1,,,
    ;11.90 V,,
    1,2,,,
    ;12.00 V,,
    1,3,,,
    1,4,,,
    2,0,,
    2,1,,,
    ;12.00 V,,
    2,2,,,
    ;11.90 V,,
    2,3,,,
    ;12.00 V,,
    2,4,,,
    3,0,,
    3,1,,,
    ;Inactive,,
    3,2,,,
    ;Inactive,,
    3,3,,,
    ;Inactive,,
    3,4,,,
    ;N/A,,
    4,0,,
    4,1,,,
    ;ON,,
    4,2,,,
    ;ON,,
    4,3,,,
    ;ON,,
    4,4,,,
    ;7.20 V,,
    5,0,,
    5,1,,,
    ;100.0 %,,
    5,2,,,
    5,3,,,
    5,4,,,
    6,0,,
    6,1,,,
    ;Not Oper.,,
    6,2,,,
    ;0.0,,
    6,3,,,
    ;0.0,,
    6,4,,,
    7,0,,
    7,1,,,
    ;center,,
    7,2,,,
    ;2.0,,
    7,3,,,
    ;Not Oper.,,
    7,4,,,
    ;Not Oper.,,
    8,0,,
    8,1,,,
    ;100.0 %,,
    8,2,,,
    8,3,,,
    ;Not Oper.,,
    8,4,,,
    ;2.0,,
    9,0,,
    9,1,,,
    ;100.0 %,,
    9,2,,,
    ;100.0 %,,
    9,3,,,
    ;100.0 %,,
    9,4,,,
    ;100.0 %,,
    10,0,,
    10,1,,,
    10,2,,,
    10,3,,,
    10,4,,,
    11,0,,
    11,1,,,
    ;OFF,,
    11,2,,,
    ;OFF,,
    11,3,,,
    ;0.0 %,,
    11,4,,,
    ;0.0 %,,
    12,0,,
    12,1,,,
    ;100.0 %,,
    12,2,,,
    ;100.0 %,,
    12,3,,,
    ;157.0,,
    12,4,,,
    ;23.0,,
    13,0,,
    13,1,,,
    ;OFF,,
    13,2,,,
    ;Not Oper.,,
    13,3,,,
    ;0.0 %,,
    13,4,,,
    ;0.0 %,,
    14,0,,
    14,1,,,
    ;64.0 %,,
    14,2,,,
    ;64.0 %,,
    14,3,,,
    14,4,,,
    15,0,,
    15,1,,,
    ;OFF,,
    15,2,,,
    15,3,,,
    15,4,,,
    16,0,,
    16,1,,,
    ;100.0 %,,
    16,2,,,
    ;100.0 %,,
    16,3,,,
    ;100.0 %,,
    16,4,,,
    ;19.0 %,,
    17,0,,
    17,1,,,
    17,2,,,
    17,3,,,
    17,4,,,
    18,0,,
    18,1,,,
    ;Stage Int.,,
    18,2,,,
    ;0x0001,,
    18,3,,,
    ;0.000 A,,
    18,4,,,
    19,0,,
    19,1,,,
    ;OFF,,
    19,2,,,
    ;0.0,,
    19,3,,,
    ;Reached,,
    19,4,,,
    ;OFF,,
    20,0,,
    20,1,,,
    ;ON,,
    20,2,,,
    ;ON,,
    20,3,,,
    ;0.00 km/h,,
    20,4,,,
    ;Closed,,
    21,0,,
    21,1,,,
    ;0.0 %,,
    21,2,,,
    ;ON,,
    21,3,,,
    ;Inactive,,
    21,4,,,
    22,0,,
    22,1,,,
    ;OFF,,
    22,2,,,
    ;Inactive,,
    22,3,,,
    ;0.0,,
    22,4,,,
    ;3.0,,
    23,0,,
    23,1,,,
    ;9.85 bar,,
    23,2,,,
    23,3,,,
    ;0x0042,,
    23,4,,,
    ;0x0002,,
    24,0,,
    24,1,,,
    24,2,,,
    ;0x0005,,
    24,3,,,
    ;Not Oper.,,
    24,4,,,
    ;14.0,,
    25,0,,
    25,1,,,
    ;Not Oper.,,
    25,2,,,
    ;OFF,,
    25,3,,,
    25,4,,,
    26,0,,
    26,1,,,
    ;0.0,,
    26,2,,,
    ;Not Oper.,,
    26,3,,,
    26,4,,,
    ;Not Oper.,,
    27,0,,
    27,1,,,
    27,2,,,
    ;0x0002,,
    27,3,,,
    ;Activated,,
    27,4,,,
    ;Full,,
    28,0,,
    28,1,,,
    ;Full,,
    28,2,,,
    ;Not Oper.,,
    28,3,,,
    ;Inactive,,
    28,4,,,
    ;Inactive,,
    29,0,,
    29,1,,,
    ;32.5°C,,
    29,2,,,
    29,3,,,
    29,4,,,
    30,0,,
    30,1,,,
    ;Not Oper.,,
    30,2,,,
    ;ON,,
    30,3,,,
    30,4,,,
    31,0,,
    31,1,,,
    ;Closed,,
    31,2,,,
    31,3,,,
    31,4,,,
    32,0,,
    32,1,,,
    ;Inactive,,
    32,2,,,
    ;Inactive,,
    32,3,,,
    32,4,,,
    33,0,,
    33,1,,,
    33,2,,,
    ;0.0 %,,
    33,3,,,
    ;0.0 %,,
    33,4,,,
    34,0,,
    34,1,,,
    ;OFF,,
    34,2,,,
    ;0.0 mA,,
    34,3,,,
    ;0.0 %,,
    34,4,,,
    37,0,,
    37,1,,,
    ;OFF,,
    37,2,,,
    ;0.000 A,,
    37,3,,,
    ;0.000 A,,
    37,4,,,
    40,0,,
    40,1,,,
    40,2,,,
    40,3,,,
    40,4,,,
    41,0,,
    41,1,,,
    ;2.0,,
    41,2,,,
    ;Not Oper.,,
    41,3,,,
    ;43.0 %,,
    41,4,,,
    ;0.0 %,,
    42,0,,
    42,1,,,
    ;58h,,
    43,0,,
    43,1,,,
    ;6.0 %,,
    43,2,,,
    ;3.0 %,,
    43,3,,,
    ;43.0 %,,
    43,4,,,
    ;5.0 %,,
    44,0,,
    44,1,,,
    44,2,,,
    44,3,,,
    44,4,,,
    45,0,,
    45,1,,,
    ;0.0,,
    45,2,,,
    ;0.00 km/h,,
    45,3,,,
    ;12.5°,,
    45,4,,,
    46,0,,
    46,1,,,
    46,2,,,
    46,3,,,
    46,4,,,
    47,0,,
    47,1,,,
    47,2,,,
    47,3,,,
    47,4,,,
    48,0,,
    48,1,,,
    ;0.0,,
    48,2,,,
    ;0.0,,
    48,3,,,
    ;0.0,,
    48,4,,,
    ;0.0,,
    49,0,,
    49,1,,,
    ;0103,,
    50,0,,
    50,1,,,
    ;0.00 ms,,
    50,2,,,
    ;5.80 ms,,
    50,3,,,
    ;0.12 ms,,
    50,4,,,
    ;0.26 ms,,
    51,0,,
    51,1,,,
    ;2760.0,,
    51,2,,,
    ;0.0,,
    51,3,,,
    51,4,,,
    52,0,,
    52,1,,,
    ;58435-33782-56015-0,,
    53,0,,
    53,1,,,
    ;C7500063 0060,,
    54,0,,
    54,1,,,
    ;FBL-Version: 24031.1.7.0,,
    55,0,,
    55,1,,,
    ;0.0,,
    55,2,,,
    55,3,,,
    55,4,,,
    56,0,,
    56,1,,,
    ;0.0,,
    56,2,,,
    ;0.0,,
    56,3,,,
    ;0.0,,
    56,4,,,
    57,0,,
    57,1,,,
    ;0.0,,
    57,2,,,
    ;0.0,,
    57,3,,,
    ;21.0,,
    57,4,,,
    58,0,,
    58,1,,,
    ;0.0,,
    58,2,,,
    ;0.0,,
    58,3,,,
    58,4,,,
    59,0,,
    59,1,,,
    ;OFF,,
    59,2,,,
    ;OFF,,
    59,3,,,
    59,4,,,
    60,0,,
    60,1,,,
    ;0.0°C,,
    60,2,,,
    ;31.5°C,,
    60,3,,,
    ;0.0 A,,
    60,4,,,
    61,0,,
    61,1,,,
    ;0.0°C,,
    61,2,,,
    ;31.5°C,,
    61,3,,,
    ;0.0 A,,
    61,4,,,
    62,0,,
    62,1,,,
    ;0.0,,
    62,2,,,
    ;0x0000,,
    62,3,,,
    ;0.0,,
    62,4,,,
    ;0x0000,,
    63,0,,
    63,1,,,
    63,2,,,
    63,3,,,
    63,4,,,
    64,0,,
    64,1,,,
    64,2,,,
    64,3,,,
    64,4,,,
    65,0,,
    65,1,,,
    65,2,,,
    65,3,,,
    65,4,,,
    66,0,,
    66,1,,,
    66,2,,,
    66,3,,,
    66,4,,,
    67,0,,
    67,1,,,
    67,2,,,
    67,3,,,
    67,4,,,
    68,0,,
    68,1,,,
    68,2,,,
    68,3,,,
    68,4,,,
    69,0,,
    69,1,,,
    69,2,,,
    69,3,,,
    69,4,,,
    70,0,,
    70,1,,,
    70,2,,,
    70,3,,,
    70,4,,,
    71,0,,
    71,1,,,
    71,2,,,
    71,3,,,
    71,4,,,
    72,0,,
    72,1,,,
    72,2,,,
    72,3,,,
    72,4,,,
    73,0,,
    73,1,,,
    ;0.0,,
    73,2,,,
    ;0.0,,
    73,3,,,
    ;0.0,,
    73,4,,,
    ;0.0,,
    74,0,,
    74,1,,,
    ;0x0003,,
    74,2,,,
    ;0x0003,,
    74,3,,,
    74,4,,,
    75,0,,
    75,1,,,
    ;33.0°C,,
    75,2,,,
    ;9.0,,
    75,3,,,
    ;-3.0°C,,
    75,4,,,
    ;33.0°C,,
    76,0,,
    76,1,,,
    ;0.0,,
    76,2,,,
    76,3,,,
    76,4,,,
    77,0,,
    77,1,,,
    ;-2.1°C,,
    77,2,,,
    ;35.7°C,,
    77,3,,,
    ;6.50 %,,
    77,4,,,
    ;0.0,,
    78,0,,
    78,1,,,
    ;3.0,,
    78,2,,,
    ;3.0,,
    78,3,,,
    ;41.4°C,,
    78,4,,,
    ;Inactive,,
    79,0,,
    79,1,,,
    79,2,,,
    79,3,,,
    79,4,,,
    80,0,,
    80,1,,,
    80,2,,,
    80,3,,,
    80,4,,,
    81,0,,
    81,1,,,
    81,2,,,
    81,3,,,
    81,4,,,
    82,0,,
    82,1,,,
    82,2,,,
    82,3,,,
    82,4,,,
    83,0,,
    83,1,,,
    83,2,,,
    83,3,,,
    83,4,,,
    84,0,,
    84,1,,,
    ;0.0,,
    84,2,,,
    ;0.0,,
    84,3,,,
    ;0.0,,
    84,4,,,
    ;0.0,,
    85,0,,
    85,1,,,
    ;0.0,,
    85,2,,,
    ;0.0,,
    85,3,,,
    ;5.0,,
    85,4,,,
    ;4.0,,
    86,0,,
    86,1,,,
    ;0.0,,
    86,2,,,
    ;0.0,,
    86,3,,,
    ;0.0,,
    86,4,,,
    ;0.0,,
    87,0,,
    87,1,,,
    ;2.0,,
    87,2,,,
    ;0.0,,
    87,3,,,
    ;0.0,,
    87,4,,,
    ;0.0,,
    88,0,,
    88,1,,,
    ;0.0,,
    88,2,,,
    88,3,,,
    88,4,,,
    89,0,,
    89,1,,,
    ;0.0,,
    89,2,,,
    ;0.0,,
    89,3,,,
    ;0.0,,
    89,4,,,
    ;0.0,,
    90,0,,
    90,1,,,
    ;29,,
    90,2,,,
    ;0,,
    90,3,,,
    ;0,,
    90,4,,,
    ;0,,
    91,0,,
    91,1,,,
    ;4,,
    91,2,,,
    ;175,,
    91,3,,,
    ;0,,
    91,4,,,
    ;0,,
    92,0,,
    92,1,,,
    ;0,,
    92,2,,,
    ;0,,
    92,3,,,
    ;8,,
    92,4,,,
    ;44,,
    93,0,,
    93,1,,,
    ;0,,
    93,2,,,
    ;0,,
    93,3,,,
    ;0,,
    93,4,,,
    ;83,,
    94,0,,
    94,1,,,
    ;8,,
    94,2,,,
    ;44,,
    94,3,,,
    ;8,,
    94,4,,,
    ;44,,
    98,0,,
    98,1,,,
    ;0.70 kOhm,,
    98,2,,,
    ;0.00 kOhm,,
    98,3,,,
    ;Closed,,
    98,4,,,
    ;Closed,,
    99,0,,
    99,1,,,
    ;0x0034,,
    99,2,,,
    ;0x0103,,
    99,3,,,
    ;0.0,,
    99,4,,,
    ;0.0,,
    100,0,,
    100,1,,,
    ;not available,,
    100,2,,,
    ;not available,,
    100,3,,,
    ;Occupied,,
    100,4,,,
    ;Not Occup.,,
    101,0,,
    101,1,,,
    ;0.0 %,,
    101,2,,,
    ;0.0 %,,
    101,3,,,
    ;0.0 %,,
    101,4,,,
    ;0.0 %,,
    102,0,,
    102,1,,,
    ;Intermed pos.,,
    102,2,,,
    ;Inactive,,
    102,3,,,
    ;not available,,
    102,4,,,
    ;not available,,
    103,0,,
    103,1,,,
    103,2,,,
    103,3,,,
    103,4,,,
    104,0,,
    104,1,,,
    104,2,,,
    104,3,,,
    104,4,,,
    105,0,,
    105,1,,,
    105,2,,,
    105,3,,,
    105,4,,,
    106,0,,
    106,1,,,
    106,2,,,
    106,3,,,
    106,4,,,
    107,0,,
    107,1,,,
    ;Stage 0,,
    107,2,,,
    ;Stage 0,,
    107,3,,,
    ;32.5°C,,
    107,4,,,
    ;33.5°C,,
    108,0,,
    108,1,,,
    ;0.0,,
    108,2,,,
    108,3,,,
    ;N/A,,
    108,4,,,
    ;N/A,,
    110,0,,
    110,1,,,
    110,2,,,
    110,3,,,
    110,4,,,
    111,0,,
    111,1,,,
    111,2,,,
    111,3,,,
    111,4,,,
    112,0,,
    112,1,,,
    112,2,,,
    112,3,,,
    112,4,,,
    113,0,,
    113,1,,,
    113,2,,,
    113,3,,,
    113,4,,,
    114,0,,
    114,1,,,
    114,2,,,
    114,3,,,
    114,4,,,
    115,0,,
    115,1,,,
    115,2,,,
    115,3,,,
    115,4,,,
    116,0,,
    116,1,,,
    116,2,,,
    116,3,,,
    116,4,,,
    117,0,,
    117,1,,,
    117,2,,,
    117,3,,,
    117,4,,,
    120,0,,
    120,1,,,
    120,2,,,
    120,3,,,
    120,4,,,
    ;N/A,,
    121,0,,
    121,1,,,
    121,2,,,
    121,3,,,
    121,4,,,
    122,0,,
    122,1,,,
    122,2,,,
    122,3,,,
    122,4,,,
    125,0,,
    125,1,,,
    125,2,,,
    125,3,,,
    125,4,,,
    126,0,,
    126,1,,,
    126,2,,,
    126,3,,,
    126,4,,,
    127,0,,
    127,1,,,
    127,2,,,
    127,3,,,
    127,4,,,
    128,0,,
    128,1,,,
    128,2,,,
    128,3,,,
    128,4,,,
    129,0,,
    129,1,,,
    129,2,,,
    129,3,,,
    129,4,,,
    ;N/A,,
    132,0,,
    132,1,,,
    ;64.0 %,,
    132,2,,,
    ;63.0 %,,
    132,3,,,
    ;N/A,,
    132,4,,,
    ;N/A,,
    140,0,,
    140,1,,,
    ;0.0 V,,
    140,2,,,
    ;not available,,
    140,3,,,
    ;OFF,,
    140,4,,,
    ;not available,,
    141,0,,
    141,1,,,
    ;OFF,,
    141,2,,,
    ;-2.0 mm,,
    141,3,,,
    ;-9.0 mm,,
    141,4,,,
    ;not available,,
    142,0,,
    142,1,,,
    ;60.40 %,,
    142,2,,,
    ;50.00 %,,
    142,3,,,
    ;61.20 %,,
    142,4,,,
    ;52.40 %,,
    143,0,,
    143,1,,,
    ;-24,,
    143,2,,,
    ;-24,,
    143,3,,,
    ;0.0,,
    143,4,,,
    ;0.0,,
    144,0,,
    144,1,,,
    ;56.00 %,,
    144,2,,,
    ;-24,,
    144,3,,,
    ;56.00 %,,
    144,4,,,
    ;-24,,
    145,0,,
    145,1,,,
    ;not available,,
    145,2,,,
    ;not available,,
    145,3,,,
    ;not available,,
    145,4,,,
    ;not available,,
    146,0,,
    146,1,,,
    ;not available,,
    146,2,,,
    ;not available,,
    146,3,,,
    ;not available,,
    146,4,,,
    ;not available,,
    147,0,,
    147,1,,,
    ;101.60 %,,
    147,2,,,
    ;101.60 %,,
    147,3,,,
    ;0.0,,
    147,4,,,
    ;0.0,,
    148,0,,
    148,1,,,
    ;not available,,
    148,2,,,
    ;not available,,
    148,3,,,
    ;not available,,
    148,4,,,
    ;not available,,
    149,0,,
    149,1,,,
    ;not available,,
    149,2,,,
    ;not available,,
    149,3,,,
    ;not available,,
    149,4,,,
    ;not available,,
    150,0,,
    150,1,,,
    ;not available,,
    150,2,,,
    ;not available,,
    150,3,,,
    ;not available,,
    150,4,,,
    ;ON,,
    151,0,,
    151,1,,,
    ;14.6°,,
    151,2,,,
    ;not available,,
    151,3,,,
    ;Inactive,,
    151,4,,,
    ;Inactive,,
    152,0,,
    152,1,,,
    ;0.0 %,,
    152,2,,,
    ;Inactive,,
    152,3,,,
    ;0.0,,
    152,4,,,
    ;not available,,
    153,0,,
    153,1,,,
    ;not available,,
    153,2,,,
    ;not available,,
    153,3,,,
    ;not available,,
    153,4,,,
    ;not available,,
    154,0,,
    154,1,,,
    ;not available,,
    154,2,,,
    ;not available,,
    154,3,,,
    ;not available,,
    154,4,,,
    ;not available,,
    155,0,,
    155,1,,,
    ;not available,,
    155,2,,,
    ;not available,,
    155,3,,,
    ;not available,,
    155,4,,,
    ;not available,,
    156,0,,
    156,1,,,
    ;not available,,
    156,2,,,
    ;not available,,
    156,3,,,
    ;not available,,
    156,4,,,
    ;not available,,
    157,0,,
    157,1,,,
    ;not available,,
    157,2,,,
    ;not available,,
    157,3,,,
    ;not available,,
    157,4,,,
    ;not available,,
    158,0,,
    158,1,,,
    ;not available,,
    158,2,,,
    ;not available,,
    158,3,,,
    ;not available,,
    158,4,,,
    ;not available,,
    159,0,,
    159,1,,,
    ;Reg. Position,,
    159,2,,,
    ;Learned,,
    159,3,,,
    ;not available,,
    159,4,,,
    ;not available,,
    160,0,,
    160,1,,,
    ;255 cm,,
    160,2,,,
    ;255 cm,,
    160,3,,,
    ;not available,,
    160,4,,,
    ;not available,,
    161,0,,
    161,1,,,
    ;Reverse: No,,
    161,2,,,
    ;Not Installed,,
    161,3,,,
    ;0x0023,,
    161,4,,,
    ;not available,,
    162,0,,
    162,1,,,
    ;65535 cm,,
    162,2,,,
    ;65535 cm,,
    162,3,,,
    ;65535 cm,,
    162,4,,,
    ;65535 cm,,
    163,0,,
    163,1,,,
    ;65535 cm,,
    163,2,,,
    ;65535 cm,,
    163,3,,,
    ;65535 cm,,
    163,4,,,
    ;65535 cm,,
    164,0,,
    164,1,,,
    ;Not Installed,,
    164,2,,,
    ;Not Installed,,
    164,3,,,
    ;Not Installed,,
    164,4,,,
    ;Not Installed,,
    165,0,,
    165,1,,,
    ;0.00 ms,,
    165,2,,,
    ;0.00 ms,,
    165,3,,,
    ;0.00 ms,,
    165,4,,,
    ;0.00 ms,,
    166,0,,
    166,1,,,
    ;0.00 ms,,
    166,2,,,
    ;0.00 ms,,
    166,3,,,
    ;0.00 ms,,
    166,4,,,
    ;0.00 ms,,
    167,0,,
    167,1,,,
    ;Not Installed,,
    167,2,,,
    ;Not Installed,,
    167,3,,,
    ;Not Installed,,
    167,4,,,
    ;Not Installed,,
    168,0,,
    168,1,,,
    ;Stage 4,,
    168,2,,,
    ;Stage 4,,
    168,3,,,
    ;Stage 4,,
    168,4,,,
    ;Stage 6,,
    169,0,,
    169,1,,,
    ;OFF,,
    169,2,,,
    ;Not Oper.,,
    169,3,,,
    ;ON,,
    169,4,,,
    ;not available,,
    170,0,,
    170,1,,,
    ;Not Installed,,
    170,2,,,
    ;Not Installed,,
    170,3,,,
    ;BackUpCam,,
    170,4,,,
    ;not available,,
    171,0,,
    171,1,,,
    ;No,,
    171,2,,,
    ;not Active,,
    171,3,,,
    ;c.Switchoff,,
    171,4,,,
    ;No,,
    172,0,,
    172,1,,,
    ;Not Installed,,
    172,2,,,
    ;Not Installed,,
    172,3,,,
    ;Yes,,
    172,4,,,
    ;BackUpCam,,
    173,0,,
    173,1,,,
    ;not Active,,
    173,2,,,
    ;BackUpCam,,
    173,3,,,
    ;not available,,
    173,4,,,
    ;not available,,
    174,0,,
    174,1,,,
    ;Stage 4,,
    174,2,,,
    ;Stage 4,,
    174,3,,,
    ;Stage 4,,
    174,4,,,
    ;Stage 6,,
    175,0,,
    175,1,,,
    ;Active,,
    175,2,,,
    ;BackUpCam,,
    175,3,,,
    ;not available,,
    175,4,,,
    ;not available,,
    176,0,,
    176,1,,,
    ;Stage 4,,
    176,2,,,
    ;Stage 4,,
    176,3,,,
    ;Stage 4,,
    176,4,,,
    ;Stage 6,,
    177,0,,
    177,1,,,
    ;not Active,,
    177,2,,,
    ;BackUpCam,,
    177,3,,,
    ;not available,,
    177,4,,,
    ;not available,,
    178,0,,
    178,1,,,
    ;Stage 4,,
    178,2,,,
    ;Stage 4,,
    178,3,,,
    ;Stage 4,,
    178,4,,,
    ;Stage 6,,
    179,0,,
    179,1,,,
    ;not Active,,
    179,2,,,
    ;BackUpCam,,
    179,3,,,
    ;not available,,
    179,4,,,
    ;not available,,
    180,0,,
    180,1,,,
    ;Stage 4,,
    180,2,,,
    ;Stage 4,,
    180,3,,,
    ;Stage 4,,
    180,4,,,
    ;Stage 6,,
    181,0,,
    181,1,,,
    ;Stage 4,,
    181,2,,,
    ;Stage 4,,
    181,3,,,
    ;Stage 4,,
    181,4,,,
    ;Stage 6,,
    182,0,,
    182,1,,,
    ;Not Installed,,
    182,2,,,
    ;32.0°C,,
    182,3,,,
    ;0.0,,
    182,4,,,
    ;not available,,
    183,0,,
    183,1,,,
    ;0,,
    183,2,,,
    ;0.0,,
    183,3,,,
    ;0.0,,
    183,4,,,
    ;0:00 h,,
    184,0,,
    184,1,,,
    ;0,,
    184,2,,,
    ;0.0,,
    184,3,,,
    ;0.0,,
    184,4,,,
    ;0:00 h,,
    185,0,,
    185,1,,,
    ;0,,
    185,2,,,
    ;0.0,,
    185,3,,,
    ;0.0,,
    185,4,,,
    ;0:00 h,,
    186,0,,
    186,1,,,
    ;0,,
    186,2,,,
    ;0.0,,
    186,3,,,
    ;0.0,,
    186,4,,,
    ;0:00 h,,
    187,0,,
    187,1,,,
    ;0,,
    187,2,,,
    ;0.0,,
    187,3,,,
    ;0.0,,
    187,4,,,
    ;0:00 h,,
    188,0,,
    188,1,,,
    ;0,,
    188,2,,,
    ;0.0,,
    188,3,,,
    ;0.0,,
    188,4,,,
    ;0:00 h,,
    189,0,,
    189,1,,,
    ;0,,
    189,2,,,
    ;0.0,,
    189,3,,,
    ;0.0,,
    189,4,,,
    ;0:00 h,,
    190,0,,
    190,1,,,
    ;0,,
    190,2,,,
    ;0.0,,
    190,3,,,
    ;0.0,,
    190,4,,,
    ;0:00 h,,
    191,0,,
    191,1,,,
    ;0,,
    191,2,,,
    ;0.0,,
    191,3,,,
    ;0.0,,
    191,4,,,
    ;0:00 h,,
    192,0,,
    192,1,,,
    ;0,,
    192,2,,,
    ;0.0,,
    192,3,,,
    ;0.0,,
    192,4,,,
    ;0:00 h,,
    193,0,,
    193,1,,,
    ;1.0,,
    193,2,,,
    ;20.0,,
    193,3,,,
    ;3.0,,
    193,4,,,
    ;6:48 h,,
    194,0,,
    194,1,,,
    ;not available,,
    194,2,,,
    ;not available,,
    194,3,,,
    ;not available,,
    194,4,,,
    ;not available,,
    195,0,,
    195,1,,,
    ;not available,,
    195,2,,,
    ;not available,,
    195,3,,,
    ;not available,,
    195,4,,,
    ;not available,,
    196,0,,
    196,1,,,
    ;not available,,
    196,2,,,
    ;not available,,
    196,3,,,
    ;not available,,
    196,4,,,
    ;not available,,
    197,0,,
    197,1,,,
    ;not available,,
    197,2,,,
    ;not available,,
    197,3,,,
    ;not available,,
    197,4,,,
    ;not available,,
    198,0,,
    198,1,,,
    ;2,,
    198,2,,,
    ;Not Installed,,
    198,3,,,
    ;not available,,
    198,4,,,
    ;not available,,
    199,0,,
    199,1,,,
    ;0.0,,
    199,2,,,
    ;not Active,,
    199,3,,,
    ;Not Installed,,
    199,4,,,
    ;1.0,,
    200,0,,
    200,1,,,
    200,2,,,
    200,3,,,
    200,4,,,
    201,0,,
    201,1,,,
    201,2,,,
    201,3,,,
    201,4,,,
    202,0,,
    202,1,,,
    202,2,,,
    202,3,,,
    202,4,,,
    203,0,,
    203,1,,,
    203,2,,,
    203,3,,,
    203,4,,,
    204,0,,
    204,1,,,
    204,2,,,
    204,3,,,
    204,4,,,
    205,0,,
    205,1,,,
    205,2,,,
    205,3,,,
    205,4,,,
    206,0,,
    206,1,,,
    206,2,,,
    206,3,,,
    206,4,,,
    207,0,,
    207,1,,,
    207,2,,,
    207,3,,,
    207,4,,,
    208,0,,
    208,1,,,
    208,2,,,
    208,3,,,
    208,4,,,
    209,0,,
    209,1,,,
    209,2,,,
    209,3,,,
    209,4,,,
    210,0,,
    210,1,,,
    210,2,,,
    210,3,,,
    210,4,,,
    211,0,,
    211,1,,,
    211,2,,,
    211,3,,,
    211,4,,,
    212,0,,
    212,1,,,
    212,2,,,
    212,3,,,
    212,4,,,
    213,0,,
    213,1,,,
    213,2,,,
    213,3,,,
    213,4,,,
    214,0,,
    214,1,,,
    214,2,,,
    214,3,,,
    214,4,,,
    215,0,,
    215,1,,,
    215,2,,,
    215,3,,,
    215,4,,,
    216,0,,
    216,1,,,
    216,2,,,
    216,3,,,
    216,4,,,
    217,0,,
    217,1,,,
    217,2,,,
    217,3,,,
    217,4,,,
    218,0,,
    218,1,,,
    ;511,,
    218,2,,,
    ;511,,
    218,3,,,
    ;not available,,
    218,4,,,
    ;0,,
    251,0,,
    251,1,,,
    ;0.0,,
    251,2,,,
    ;2760.0,,
    251,3,,,
    ;0.0,,
    251,4,,,
    ;0.0,,
    252,0,,
    252,1,,,
    ;1.0,,
    252,2,,,
    ;0.0,,
    252,3,,,
    ;4096.0,,
    252,4,,,
    ;0.0,,
    253,0,,
    253,1,,,
    ;0.0,,
    253,2,,,
    ;N/A,,
    253,3,,,
    ;N/A,,
    253,4,,,
    ;N/A,,
    Mar 2014
    Thanks, Uwe. I wasn't aware that I could do that. I appreciate you dropping them in for me.
    Let me know what you and the team think about the tweaks. Really hoping I can get those both working.
    Thanks to all of those from Ross Tech who have jumped in already to help out!
  8. #8
    United States
    Thanks,
    Dana
    Sorry about that Jack, I just noticed an error in that old post. BCM2 is address 46 and the maps from that controller would be helpful for the comfort window inquiry. (The BCM1 / 09 maps are still helpful because this is one of the newer units)
    If you haven't sorted this already please post the PLA / PLB maps from 46 so we can take a look at those.
    -Dana
  9. #9
    Mar 2014
    No Problem - here are the files from module 46
    Let me know if you need anything else.
    ;SW:8K0-907-064-JP   HW:8K0-907-064-JP ---  Central Conv.
    ;Component:BCM2 2.0      H14 0650, Coding:01260E3A20FA709584A0053600040047
    ;Tuesday,29,April,2014,19:18:15:61963
    ;VCID: 871DD96436DFBF265AD-80D2
    A01,0,
    ;53344
    A01,1,
    ;N/A
    A01,2,
    ;N/A
    A01,3,
    ;N/A
    A01,4,
    ;N/A
    A02,0,
    ;53344
    A02,1,
    ;N/A
    A02,2,
    ;N/A
    A02,3,
    ;N/A
    A02,4,
    ;N/A
    A03,0,
    ;36961
    A03,1,
    ;N/A
    A03,2,
    ;N/A
    A03,3,
    ;N/A
    A03,4,
    ;N/A
    A04,0,
    ;36961
    A04,1,
    ;N/A
    A04,2,
    ;N/A
    A04,3,
    ;N/A
    A04,4,
    ;N/A
    A05,0,
    ;0
    A05,1,
    ;N/A
    A05,2,
    ;N/A
    A05,3,
    ;N/A
    A05,4,
    ;N/A
    A06,0,
    ;0
    A06,1,
    ;N/A
    A06,2,
    ;N/A
    A06,3,
    ;N/A
    A06,4,
    ;N/A
    A07,0,
    ;0
    A07,1,
    ;N/A
    A07,2,
    ;N/A
    A07,3,
    ;N/A
    A07,4,
    ;N/A
    A08,0,
    ;0
    A08,1,
    ;N/A
    A08,2,
    ;N/A
    A08,3,
    ;N/A
    A08,4,
    ;N/A
    A09,0,
    ;36961
    A09,1,
    ;N/A
    A09,2,
    ;N/A
    A09,3,
    ;N/A
    A09,4,
    ;N/A
    A10,0,
    ;0
    A10,1,
    ;N/A
    A10,2,
    ;N/A
    A10,3,
    ;N/A
    A10,4,
    ;N/A
    ;11 N/A
    ;12 N/A
    A13,0,
    ;87
    A13,1,
    ;N/A
    A13,2,
    ;N/A
    A13,3,
    ;N/A
    A13,4,
    ;N/A
    ;14 N/A
    ;15 N/A
    A16,0,
    ;5
    A16,1,
    ;N/A
    A16,2,
    ;N/A
    A16,3,
    ;N/A
    A16,4,
    ;N/A
    ;17 N/A
    ;18 N/A
    ;19 N/A
    ;20 N/A
    ;21 N/A
    ;22 N/A
    ;23 N/A
    ;24 N/A
    ;25 N/A
    ;26 N/A
    ;27 N/A
    ;28 N/A
    ;29 N/A
    ;30 N/A
    ;31 N/A
    ;32 N/A
    ;33 N/A
    ;34 N/A
    ;35 N/A
    ;36 N/A
    ;37 N/A
    ;38 N/A
    ;39 N/A
    ;40 N/A
    ;41 N/A
    ;42 N/A
    ;43 N/A
    ;44 N/A
    ;45 N/A
    ;46 N/A
    ;47 N/A
    ;48 N/A
    ;49 N/A
    ;50 N/A
    ;51 N/A
    ;52 N/A
    ;53 N/A
    ;54 N/A
    ;55 N/A
    ;56 N/A
    ;57 N/A
    ;58 N/A
    ;59 N/A
    A60,0,
    ;15
    A60,1,
    ;N/A
    A60,2,
    ;N/A
    A60,3,
    ;N/A
    A60,4,
    ;N/A
    A61,0,
    ;9947
    A61,1,
    ;N/A
    A61,2,
    ;N/A
    A61,3,
    ;N/A
    A61,4,
    ;N/A
    A62,0,
    ;48059
    A62,1,
    ;N/A
    A62,2,
    ;N/A
    A62,3,
    ;N/A
    A62,4,
    ;N/A
    A63,0,
    ;40
    A63,1,
    ;N/A
    A63,2,
    ;N/A
    A63,3,
    ;N/A
    A63,4,
    ;N/A
    A64,0,
    ;40
    A64,1,
    ;N/A
    A64,2,
    ;N/A
    A64,3,
    ;N/A
    A64,4,
    ;N/A
    A65,0,
    ;63
    A65,1,
    ;N/A
    A65,2,
    ;N/A
    A65,3,
    ;N/A
    A65,4,
    ;N/A
    A66,0,
    ;21
    A66,1,
    ;N/A
    A66,2,
    ;N/A
    A66,3,
    ;N/A
    A66,4,
    ;N/A
    A67,0,
    ;6425
    A67,1,
    ;N/A
    A67,2,
    ;N/A
    A67,3,
    ;N/A
    A67,4,
    ;N/A
    A68,0,
    A68,1,
    ;ERROR:
    A68,2,
    ;Security
    A68,3,
    ;access
    A68,4,
    ;required
    A69,0,
    ;0
    A69,1,
    ;N/A
    A69,2,
    ;N/A
    A69,3,
    ;N/A
    A69,4,
    ;N/A
    ;70 N/A
    ;71 N/A
    ;72 N/A
    ;73 N/A
    ;74 N/A
    ;75 N/A
    ;76 N/A
    ;77 N/A
    ;78 N/A
    ;79 N/A
    ;80 N/A
    ;81 N/A
    ;82 N/A
    ;83 N/A
    ;84 N/A
    ;85 N/A
    ;86 N/A
    ;87 N/A
    ;88 N/A
    ;89 N/A
    ;90 N/A
    ;91 N/A
    ;92 N/A
    ;93 N/A
    ;94 N/A
    A95,0,
    ;1
    A95,1,
    ;N/A
    A95,2,
    ;N/A
    A95,3,
    ;N/A
    A95,4,
    ;N/A
    A96,0,
    ;30
    A96,1,
    ;N/A
    A96,2,
    ;N/A
    A96,3,
    ;N/A
    A96,4,
    ;N/A
    A97,0,
    ;50
    A97,1,
    ;N/A
    A97,2,
    ;N/A
    A97,3,
    ;N/A
    A97,4,
    ;N/A
    A98,0,
    ;1
    A98,1,
    ;N/A
    A98,2,
    ;N/A
    A98,3,
    ;N/A
    A98,4,
    ;N/A
    ;99 N/A
    ;100 N/A
    ;101 N/A
    A102,0,
    A102,1,
    ;ERROR:
    A102,2,
    ;Security
    A102,3,
    ;access
    A102,4,
    ;required
    ;103 N/A
    A104,0,
    ;190
    A104,1,
    ;N/A
    A104,2,
    ;N/A
    A104,3,
    ;N/A
    A104,4,
    ;N/A
    ;105 N/A
    ;106 N/A
    ;107 N/A
    ;108 N/A
    ;109 N/A
    ;110 N/A
    ;111 N/A
    ;112 N/A
    ;113 N/A
    ;114 N/A
    ;115 N/A
    ;116 N/A
    ;117 N/A
    ;118 N/A
    ;119 N/A
    ;120 N/A
    ;121 N/A
    ;122 N/A
    ;123 N/A
    ;124 N/A
    ;125 N/A
    ;126 N/A
    ;127 N/A
    ;128 N/A
    ;129 N/A
    ;130 N/A
    ;131 N/A
    ;132 N/A
    ;133 N/A
    ;134 N/A
    ;135 N/A
    ;136 N/A
    ;137 N/A
    ;138 N/A
    ;139 N/A
    ;140 N/A
    ;141 N/A
    ;142 N/A
    ;143 N/A
    ;144 N/A
    ;145 N/A
    ;146 N/A
    ;147 N/A
    ;148 N/A
    ;149 N/A
    A150,0,
    ;0
    A150,1,
    ;N/A
    A150,2,
    ;N/A
    A150,3,
    ;N/A
    A150,4,
    ;N/A
    ;151 N/A
    ;152 N/A
    ;153 N/A
    ;154 N/A
    ;155 N/A
    ;156 N/A
    ;157 N/A
    ;158 N/A
    ;159 N/A
    ;160 N/A
    ;161 N/A
    ;162 N/A
    ;163 N/A
    ;164 N/A
    ;165 N/A
    ;166 N/A
    ;167 N/A
    ;168 N/A
    ;169 N/A
    ;170 N/A
    ;171 N/A
    ;172 N/A
    ;173 N/A
    ;174 N/A
    ;175 N/A
    ;176 N/A
    ;177 N/A
    ;178 N/A
    A179,0,
    A179,1,
    ;ERROR:
    A179,2,
    ;Security
    A179,3,
    ;access
    A179,4,
    ;required
    A180,0,
    A180,1,
    ;ERROR:
    A180,2,
    ;Security
    A180,3,
    ;access
    A180,4,
    ;required
    A181,0,
    A181,1,
    ;ERROR:
    A181,2,
    ;Security
    A181,3,
    ;access
    A181,4,
    ;required
    A182,0,
    A182,1,
    ;ERROR:
    A182,2,
    ;Security
    A182,3,
    ;access
    A182,4,
    ;required
    A183,0,
    A183,1,
    ;ERROR:
    A183,2,
    ;Security
    A183,3,
    ;access
    A183,4,
    ;required
    A184,0,
    A184,1,
    ;ERROR:
    A184,2,
    ;Security
    A184,3,
    ;access
    A184,4,
    ;required
    A185,0,
    A185,1,
    ;ERROR:
    A185,2,
    ;Security
    A185,3,
    ;access
    A185,4,
    ;required
    A186,0,
    A186,1,
    ;ERROR:
    A186,2,
    ;Security
    A186,3,
    ;access
    A186,4,
    ;required
    A187,0,
    A187,1,
    ;ERROR:
    A187,2,
    ;Security
    A187,3,
    ;access
    A187,4,
    ;required
    A188,0,
    A188,1,
    ;ERROR:
    A188,2,
    ;Security
    A188,3,
    ;access
    A188,4,
    ;required
    A189,0,
    A189,1,
    ;ERROR:
    A189,2,
    ;Security
    A189,3,
    ;access
    A189,4,
    ;required
    A190,0,
    A190,1,
    ;ERROR:
    A190,2,
    ;Security
    A190,3,
    ;access
    A190,4,
    ;required
    A191,0,
    A191,1,
    ;ERROR:
    A191,2,
    ;Security
    A191,3,
    ;access
    A191,4,
    ;required
    A192,0,
    A192,1,
    ;ERROR:
    A192,2,
    ;Security
    A192,3,
    ;access
    A192,4,
    ;required
    A193,0,
    A193,1,
    ;ERROR:
    A193,2,
    ;Security
    A193,3,
    ;access
    A193,4,
    ;required
    A194,0,
    ;7
    A194,1,
    ;N/A
    A194,2,
    ;N/A
    A194,3,
    ;N/A
    A194,4,
    ;N/A
    A195,0,
    A195,1,
    ;ERROR:
    A195,2,
    ;Security
    A195,3,
    ;access
    A195,4,
    ;required
    A196,0,
    A196,1,
    ;ERROR:
    A196,2,
    ;Security
    A196,3,
    ;access
    A196,4,
    ;required
    A197,0,
    A197,1,
    ;ERROR:
    A197,2,
    ;Security
    A197,3,
    ;access
    A197,4,
    ;required
    A198,0,
    A198,1,
    ;ERROR:
    A198,2,
    ;Security
    A198,3,
    ;access
    A198,4,
    ;required
    A199,0,
    A199,1,
    ;ERROR:
    A199,2,
    ;Security
    A199,3,
    ;access
    A199,4,
    ;required
    A200,0,
    A200,1,
    ;ERROR:
    A200,2,
    ;Security
    A200,3,
    ;access
    A200,4,
    ;required
    A201,0,
    A201,1,
    ;ERROR:
    A201,2,
    ;Security
    A201,3,
    ;access
    A201,4,
    ;required
    A202,0,
    A202,1,
    ;ERROR:
    A202,2,
    ;Security
    A202,3,
    ;access
    A202,4,
    ;required
    A203,0,
    A203,1,
    ;ERROR:
    A203,2,
    ;Security
    A203,3,
    ;access
    A203,4,
    ;required
    A204,0,
    A204,1,
    ;ERROR:
    A204,2,
    ;Security
    A204,3,
    ;access
    A204,4,
    ;required
    A205,0,
    A205,1,
    ;ERROR:
    A205,2,
    ;Security
    A205,3,
    ;access
    A205,4,
    ;required
    A206,0,
    A206,1,
    ;ERROR:
    A206,2,
    ;Security
    A206,3,
    ;access
    A206,4,
    ;required
    A207,0,
    A207,1,
    ;ERROR:
    A207,2,
    ;Security
    A207,3,
    ;access
    A207,4,
    ;required
    A208,0,
    A208,1,
    ;ERROR:
    A208,2,
    ;Security
    A208,3,
    ;access
    A208,4,
    ;required
    A209,0,
    A209,1,
    ;ERROR:
    A209,2,
    ;Security
    A209,3,
    ;access
    A209,4,
    ;required
    A210,0,
    A210,1,
    ;ERROR:
    A210,2,
    ;Security
    A210,3,
    ;access
    A210,4,
    ;required
    A211,0,
    A211,1,
    ;ERROR:
    A211,2,
    ;Security
    A211,3,
    ;access
    A211,4,
    ;required
    A212,0,
    A212,1,
    ;ERROR:
    A212,2,
    ;Security
    A212,3,
    ;access
    A212,4,
    ;required
    A213,0,
    A213,1,
    ;ERROR:
    A213,2,
    ;Security
    A213,3,
    ;access
    A213,4,
    ;required
    A214,0,
    A214,1,
    ;ERROR:
    A214,2,
    ;Security
    A214,3,
    ;access
    A214,4,
    ;required
    A215,0,
    A215,1,
    ;ERROR:
    A215,2,
    ;Security
    A215,3,
    ;access
    A215,4,
    ;required
    A216,0,
    A216,1,
    ;ERROR:
    A216,2,
    ;Security
    A216,3,
    ;access
    A216,4,
    ;required
    A217,0,
    A217,1,
    ;ERROR:
    A217,2,
    ;Security
    A217,3,
    ;access
    A217,4,
    ;required
    A218,0,
    A218,1,
    ;ERROR:
    A218,2,
    ;Security
    A218,3,
    ;access
    A218,4,
    ;required
    A219,0,
    A219,1,
    ;ERROR:
    A219,2,
    ;Security
    A219,3,
    ;access
    A219,4,
    ;required
    A220,0,
    A220,1,
    ;ERROR:
    A220,2,
    ;Security
    A220,3,
    ;access
    A220,4,
    ;required
    A221,0,
    A221,1,
    ;ERROR:
    A221,2,
    ;Security
    A221,3,
    ;access
    A221,4,
    ;required
    A222,0,
    A222,1,
    ;ERROR:
    A222,2,
    ;Security
    A222,3,
    ;access
    A222,4,
    ;required
    A223,0,
    A223,1,
    ;ERROR:
    A223,2,
    ;Security
    A223,3,
    ;access
    A223,4,
    ;required
    A224,0,
    A224,1,
    ;ERROR:
    A224,2,
    ;Security
    A224,3,
    ;access
    A224,4,
    ;required
    A225,0,
    A225,1,
    ;ERROR:
    A225,2,
    ;Security
    A225,3,
    ;access
    A225,4,
    ;required
    A226,0,
    A226,1,
    ;ERROR:
    A226,2,
    ;Security
    A226,3,
    ;access
    A226,4,
    ;required
    A227,0,
    A227,1,
    ;ERROR:
    A227,2,
    ;Security
    A227,3,
    ;access
    A227,4,
    ;required
    A228,0,
    A228,1,
    ;ERROR:
    A228,2,
    ;Security
    A228,3,
    ;access
    A228,4,
    ;required
    A229,0,
    A229,1,
    ;ERROR:
    A229,2,
    ;Security
    A229,3,
    ;access
    A229,4,
    ;required
    A230,0,
    A230,1,
    ;ERROR:
    A230,2,
    ;Security
    A230,3,
    ;access
    A230,4,
    ;required
    A231,0,
    A231,1,
    ;ERROR:
    A231,2,
    ;Security
    A231,3,
    ;access
    A231,4,
    ;required
    A232,0,
    A232,1,
    ;ERROR:
    A232,2,
    ;Security
    A232,3,
    ;access
    A232,4,
    ;required
    A233,0,
    A233,1,
    ;ERROR:
    A233,2,
    ;Security
    A233,3,
    ;access
    A233,4,
    ;required
    A234,0,
    A234,1,
    ;ERROR:
    A234,2,
    ;Security
    A234,3,
    ;access
    A234,4,
    ;required
    A235,0,
    A235,1,
    ;ERROR:
    A235,2,
    ;Security
    A235,3,
    ;access
    A235,4,
    ;required
    A236,0,
    A236,1,
    ;ERROR:
    A236,2,
    ;Security
    A236,3,
    ;access
    A236,4,
    ;required
    A237,0,
    A237,1,
    ;ERROR:
    A237,2,
    ;Security
    A237,3,
    ;access
    A237,4,
    ;required
    A238,0,
    A238,1,
    ;ERROR:
    A238,2,
    ;Security
    A238,3,
    ;access
    A238,4,
    ;required
    A239,0,
    A239,1,
    ;ERROR:
    A239,2,
    ;Security
    A239,3,
    ;access
    A239,4,
    ;required
    A240,0,
    A240,1,
    ;ERROR:
    A240,2,
    ;Security
    A240,3,
    ;access
    A240,4,
    ;required
    A241,0,
    A241,1,
    ;ERROR:
    A241,2,
    ;Security
    A241,3,
    ;access
    A241,4,
    ;required
    A242,0,
    A242,1,
    ;ERROR:
    A242,2,
    ;Security
    A242,3,
    ;access
    A242,4,
    ;required
    A243,0,
    A243,1,
    ;ERROR:
    A243,2,
    ;Security
    A243,3,
    ;access
    A243,4,
    ;required
    A244,0,
    A244,1,
    ;ERROR:
    A244,2,
    ;Security
    A244,3,
    ;access
    A244,4,
    ;required
    A245,0,
    A245,1,
    ;ERROR:
    A245,2,
    ;Security
    A245,3,
    ;access
    A245,4,
    ;required
    A246,0,
    A246,1,
    ;ERROR:
    A246,2,
    ;Security
    A246,3,
    ;access
    A246,4,
    ;required
    A247,0,
    A247,1,
    ;ERROR:
    A247,2,
    ;Security
    A247,3,
    ;access
    A247,4,
    ;required
    ;248 N/A
    ;249 N/A
    ;250 N/A
    ;251 N/A
    ;252 N/A
    ;253 N/A
    ;254 N/A
    ;255 N/A
    ;Tuesday,29,April,2014,19:16:32:61963
    1,0,,
    1,1,,,
    ;12.10 V,,
    1,2,,,
    ;12.10 V,,
    1,3,,,
    ;12.10 V,,
    1,4,,,
    ;    0000,,
    2,0,,
    2,1,,,
    ;Not Oper.,,
    2,2,,,
    ;Not Oper.,,
    2,3,,,
    ;Closed,,
    2,4,,,
    ;Closed,,
    3,0,,
    3,1,,,
    3,2,,,
    3,3,,,
    ;      00,,
    3,4,,,
    ;Not Oper.,,
    4,0,,
    4,1,,,
    4,2,,,
    4,3,,,
    4,4,,,
    ;Not Oper.,,
    5,0,,
    5,1,,,
    ;Not Installed,,
    5,2,,,
    ;Not Installed,,
    5,3,,,
    ;Not Installed,,
    5,4,,,
    ;Not Installed,,
    6,0,,
    6,1,,,
    ;Door Open,,
    6,2,,,
    ;Not Oper.,,
    6,3,,,
    ;Unlocked,,
    6,4,,,
    ;Not Safe,,
    7,0,,
    7,1,,,
    ;Door Closed,,
    7,2,,,
    ;Not Oper.,,
    7,3,,,
    ;Unlocked,,
    7,4,,,
    ;Not Safe,,
    8,0,,
    8,1,,,
    ;Door Closed,,
    8,2,,,
    ;Not Oper.,,
    8,3,,,
    ;Unlocked,,
    8,4,,,
    ;Not Installed,,
    9,0,,
    9,1,,,
    ;Door Closed,,
    9,2,,,
    ;Not Oper.,,
    9,3,,,
    ;Unlocked,,
    9,4,,,
    ;Not Installed,,
    10,0,,
    10,1,,,
    ;    1111,,
    10,2,,,
    ;    0000,,
    10,3,,,
    ;    0000,,
    10,4,,,
    12,0,,
    12,1,,,
    12,2,,,
    12,3,,,
    ;OFF,,
    12,4,,,
    ;OFF,,
    13,0,,
    13,1,,,
    ;Not Installed,,
    13,2,,,
    ;Not Installed,,
    13,3,,,
    ;0.0,,
    13,4,,,
    ;0.0,,
    14,0,,
    14,1,,,
    ;0.00 km/h,,
    14,2,,,
    ;Init. value,,
    14,3,,,
    14,4,,,
    15,0,,
    15,1,,,
    ;Not Installed,,
    15,2,,,
    ;Not Installed,,
    15,3,,,
    ;0.000 A,,
    15,4,,,
    ;33.0°C,,
    16,0,,
    16,1,,,
    ;Retracted,,
    16,2,,,
    ;Connected,,
    16,3,,,
    ;      00,,
    16,4,,,
    ;OFF,,
    17,0,,
    17,1,,,
    ;Not Installed,,
    17,2,,,
    ;Not Installed,,
    17,3,,,
    ;Not Installed,,
    17,4,,,
    ;Not Installed,,
    18,0,,
    18,1,,,
    ;0.0,,
    18,2,,,
    ;0.0,,
    18,3,,,
    ;0.0,,
    18,4,,,
    ;0.0,,
    19,0,,
    19,1,,,
    ;Not Installed,,
    19,2,,,
    ;Not Installed,,
    19,3,,,
    ;Not Installed,,
    19,4,,,
    ;Not Installed,,
    20,0,,
    20,1,,,
    ;Not Installed,,
    20,2,,,
    ;Inactive,,
    20,3,,,
    ;Not Installed,,
    20,4,,,
    ;Not Installed,,
    21,0,,
    21,1,,,
    ;255,,
    21,2,,,
    ;2127:15:31,,
    21,3,,,
    ;255:255 h,,
    21,4,,,
    22,0,,
    22,1,,,
    ;255,,
    22,2,,,
    ;2127:15:31,,
    22,3,,,
    ;255:255 h,,
    22,4,,,
    23,0,,
    23,1,,,
    ;255,,
    23,2,,,
    ;2127:15:31,,
    23,3,,,
    ;255:255 h,,
    23,4,,,
    24,0,,
    24,1,,,
    ;255,,
    24,2,,,
    ;2127:15:31,,
    24,3,,,
    ;255:255 h,,
    24,4,,,
    25,0,,
    25,1,,,
    ;     000,,
    25,2,,,
    ;      00,,
    25,3,,,
    ;OFF,,
    25,4,,,
    26,0,,
    26,1,,,
    ;Not Oper.,,
    26,2,,,
    ;Lid close,,
    26,3,,,
    ;Not Connected,,
    26,4,,,
    ;Not Oper.,,
    27,0,,
    27,1,,,
    ;No,,
    27,2,,,
    ;ON,,
    27,3,,,
    ;0,,
    27,4,,,
    ;    0000,,
    28,0,,
    28,1,,,
    ;  001000,,
    28,2,,,
    ;00000000,,
    28,3,,,
    ;11110000,,
    28,4,,,
    ;      01,,
    29,0,,
    29,1,,,
    ; 0000000,,
    29,2,,,
    ; 0000000,,
    29,3,,,
    ; 0000000,,
    29,4,,,
    30,0,,
    30,1,,,
    ;0.0,,
    30,2,,,
    ; 0000110,,
    30,3,,,
    ;      00,,
    30,4,,,
    ;10000110,,
    31,0,,
    31,1,,,
    ;Not Installed,,
    31,2,,,
    ;Not Installed,,
    31,3,,,
    ;Not Installed,,
    31,4,,,
    ;Not Installed,,
    32,0,,
    32,1,,,
    ;0.0,,
    32,2,,,
    ; 0000111,,
    32,3,,,
    ;      00,,
    32,4,,,
    ;10000110,,
    33,0,,
    33,1,,,
    ;0.0,,
    33,2,,,
    ;31.0°C,,
    33,3,,,
    ;  000001,,
    33,4,,,
    ; 0000000,,
    34,0,,
    34,1,,,
    ;    0000,,
    34,2,,,
    ;     000,,
    34,3,,,
    ;     101,,
    34,4,,,
    ;   00000,,
    35,0,,
    35,1,,,
    ;     000,,
    35,2,,,
    ;100 %,,
    35,3,,,
    ;10000110,,
    35,4,,,
    ;0.0,,
    36,0,,
    36,1,,,
    ;Not Installed,,
    36,2,,,
    ;Not Installed,,
    36,3,,,
    ;Not Installed,,
    36,4,,,
    ;Not Installed,,
    38,0,,
    38,1,,,
    38,2,,,
    ;Not Installed,,
    38,3,,,
    38,4,,,
    39,0,,
    39,1,,,
    ;00000000,,
    39,2,,,
    ;0.0,,
    39,3,,,
    ;0.0,,
    39,4,,,
    ;0.0,,
    41,0,,
    41,1,,,
    ;OFF,,
    41,2,,,
    ;OFF,,
    41,3,,,
    ;OFF,,
    41,4,,,
    ;OFF,,
    42,0,,
    42,1,,,
    ;      00,,
    42,2,,,
    ;Not Installed,,
    42,3,,,
    ;5.0,,
    42,4,,,
    ;      11,,
    43,0,,
    43,1,,,
    ;10100111,,
    43,2,,,
    ;00010000,,
    43,3,,,
    ;00000000,,
    43,4,,,
    ;      01,,
    44,0,,
    44,1,,,
    ;      00,,
    44,2,,,
    ;Not Installed,,
    44,3,,,
    ;OFF,,
    44,4,,,
    ;Not Installed,,
    45,0,,
    45,1,,,
    ;ON,,
    45,2,,,
    ;OFF,,
    45,3,,,
    ;ON,,
    45,4,,,
    46,0,,
    46,1,,,
    ;Not Installed,,
    46,2,,,
    ;Not Installed,,
    46,3,,,
    ;     000,,
    46,4,,,
    ;      00,,
    47,0,,
    47,1,,,
    ;OPEN,,
    47,2,,,
    ;Closed,,
    47,3,,,
    ;Closed,,
    47,4,,,
    48,0,,
    48,1,,,
    ;2.0,,
    48,2,,,
    ;1.0,,
    48,3,,,
    ;1.0,,
    48,4,,,
    ;0.0,,
    50,0,,
    50,1,,,
    ;6,,
    50,2,,,
    ;OPEN,,
    50,3,,,
    ;Unlock,,
    50,4,,,
    ;2,,
    51,0,,
    51,1,,,
    ;8,,
    51,2,,,
    ;Closed,,
    51,3,,,
    ;Lock,,
    51,4,,,
    ;2,,
    52,0,,
    52,1,,,
    ;19,,
    52,2,,,
    ;OPEN,,
    52,3,,,
    ;Unlock,,
    52,4,,,
    ;0,,
    53,0,,
    53,1,,,
    ;18,,
    53,2,,,
    ;Closed,,
    53,3,,,
    ;Lock,,
    53,4,,,
    ;0,,
    54,0,,
    54,1,,,
    ;19,,
    54,2,,,
    ;OPEN,,
    54,3,,,
    ;Unlock,,
    54,4,,,
    ;0,,
    55,0,,
    55,1,,,
    ;2014:04:29,,
    55,2,,,
    ;20:14 h,,
    55,3,,,
    55,4,,,
    56,0,,
    56,1,,,
    ;2014:04:29,,
    56,2,,,
    ;16:37 h,,
    56,3,,,
    56,4,,,
    57,0,,
    57,1,,,
    ;2014:04:29,,
    57,2,,,
    ;16:37 h,,
    57,3,,,
    57,4,,,
    58,0,,
    58,1,,,
    ;2014:04:29,,
    58,2,,,
    ;16:36 h,,
    58,3,,,
    58,4,,,
    59,0,,
    59,1,,,
    ;2014:04:29,,
    59,2,,,
    ;16:35 h,,
    59,3,,,
    59,4,,,
    60,0,,
    60,1,,,
    ;Not Installed,,
    60,2,,,
    ;Not Installed,,
    60,3,,,
    ;Not Installed,,
    60,4,,,
    ;Not Installed,,
    61,0,,
    61,1,,,
    ;1.0,,
    61,2,,,
    ;  000000,,
    61,3,,,
    ;Not Installed,,
    61,4,,,
    ;10000110,,
    68,0,,
    68,1,,,
    ;Not Installed,,
    68,2,,,
    68,3,,,
    68,4,,,
    73,0,,
    73,1,,,
    ;0,,
    73,2,,,
    ;00011000,,
    73,3,,,
    ;    0010,,
    73,4,,,
    ;0.0,,
    74,0,,
    74,1,,,
    ;11000111,,
    74,2,,,
    ;  000100,,
    74,3,,,
    ;      00,,
    74,4,,,
    75,0,,
    75,1,,,
    ;01000000,,
    75,2,,,
    ;00100010,,
    75,3,,,
    ;00010010,,
    75,4,,,
    ;01111100,,
    76,0,,
    76,1,,,
    ;0.0,,
    76,2,,,
    ;0.0,,
    76,3,,,
    ;0.0,,
    76,4,,,
    ;0.0,,
    77,0,,
    77,1,,,
    ;0.0,,
    77,2,,,
    ;0.0,,
    77,3,,,
    ;0.0,,
    77,4,,,
    ;55.0,,
    78,0,,
    78,1,,,
    ;120.0,,
    78,2,,,
    ;251.0,,
    78,3,,,
    ;0.0,,
    78,4,,,
    ;0.0,,
    79,0,,
    79,1,,,
    ;0.0,,
    79,2,,,
    ;15.0,,
    79,3,,,
    ;0.0,,
    79,4,,,
    ;25.0,,
    80,0,,
    80,1,,,
    ;0.0,,
    80,2,,,
    ;0.0,,
    80,3,,,
    ;0.0,,
    80,4,,,
    ;0.0,,
    81,0,,
    81,1,,,
    ;0.0,,
    81,2,,,
    81,3,,,
    81,4,,,
    85,0,,
    85,1,,,
    ;00000000,,
    85,2,,,
    ;00000000,,
    85,3,,,
    ;00000000,,
    85,4,,,
    ;00000000,,
    86,0,,
    86,1,,,
    ;0x0000,,
    86,2,,,
    ;0x0000,,
    86,3,,,
    ;0x0000,,
    86,4,,,
    ;0x0000,,
    87,0,,
    87,1,,,
    ;0x0000,,
    87,2,,,
    ;0x0000,,
    87,3,,,
    ;0x0000,,
    87,4,,,
    88,0,,
    88,1,,,
    ;0.0,,
    88,2,,,
    ;0.0,,
    88,3,,,
    ;0.0,,
    88,4,,,
    ;0.0,,
    89,0,,
    89,1,,,
    ;00000101 01111100,,
    89,2,,,
    ;10000101,,
    89,3,,,
    ;00010000,,
    89,4,,,
    ;00000000,,
    90,0,,
    90,1,,,
    ;Not Installed,,
    90,2,,,
    ;Not Installed,,
    90,3,,,
    ;Not Installed,,
    90,4,,,
    ;Not Installed,,
    91,0,,
    91,1,,,
    ;Not Installed,,
    91,2,,,
    ;Not Installed,,
    91,3,,,
    ;Not Installed,,
    91,4,,,
    ;Not Installed,,
    92,0,,
    92,1,,,
    ;Not Installed,,
    92,2,,,
    ;Not Installed,,
    92,3,,,
    ;Not Installed,,
    92,4,,,
    ;Not Installed,,
    93,0,,
    93,1,,,
    ;Not Occup.,,
    93,2,,,
    ;Not Installed,,
    93,3,,,
    ;Not Occup.,,
    93,4,,,
    ;Not Occup.,,
    98,0,,
    98,1,,,
    ;0.0,,
    98,2,,,
    ;0.0,,
    98,3,,,
    ;1583.0,,
    98,4,,,
    ;255.0,,
    99,0,,
    99,1,,,
    ;00000000 00000000,,
    99,2,,,
    99,3,,,
    99,4,,,
    100,0,,
    100,1,,,
    ;J8,,
    100,2,,,
    100,3,,,
    100,4,,,
    101,0,,
    101,1,,,
    ;0.0,,
    101,2,,,
    ;0.0,,
    101,3,,,
    ;0.0,,
    101,4,,,
    ;0.0,,
    102,0,,
    102,1,,,
    ;0.0,,
    102,2,,,
    ;0.0,,
    102,3,,,
    ;0.0,,
    102,4,,,
    ;0.0,,
    103,0,,
    103,1,,,
    ;0.0,,
    103,2,,,
    ;0.0,,
    103,3,,,
    ;0.0,,
    103,4,,,
    ;0.0,,
    104,0,,
    104,1,,,
    ;0.0,,
    104,2,,,
    ;0.0,,
    104,3,,,
    ;0.0,,
    104,4,,,
    ;0.0,,
    105,0,,
    105,1,,,
    ;0.0,,
    105,2,,,
    ;0.0,,
    105,3,,,
    ;0.0,,
    105,4,,,
    ;0.0,,
    106,0,,
    106,1,,,
    ;0.0,,
    106,2,,,
    ;0.0,,
    106,3,,,
    ;0.0,,
    106,4,,,
    ;0.0,,
    107,0,,
    107,1,,,
    ;0.0,,
    107,2,,,
    ;0.0,,
    107,3,,,
    ;0.0,,
    107,4,,,
    ;0.0,,
    108,0,,
    108,1,,,
    ;11111111,,
    108,2,,,
    ;1.0,,
    108,3,,,
    ;01011011 11100111,,
    108,4,,,
    ;124.0,,
    110,0,,
    110,1,,,
    110,2,,,
    110,3,,,
    110,4,,,
    111,0,,
    111,1,,,
    ;Not Installed,,
    111,2,,,
    ;Not Installed,,
    111,3,,,
    ;Not Installed,,
    111,4,,,
    ;Not Installed,,
    112,0,,
    112,1,,,
    112,2,,,
    112,3,,,
    112,4,,,
    113,0,,
    113,1,,,
    113,2,,,
    113,3,,,
    113,4,,,
    120,0,,
    120,1,,,
    ;Not Installed,,
    120,2,,,
    ;Not Installed,,
    120,3,,,
    ;Not Installed,,
    120,4,,,
    ;Not Installed,,
    160,0,,
    160,1,,,
    ;Not Installed,,
    160,2,,,
    ;Not Installed,,
    160,3,,,
    ;Not Installed,,
    160,4,,,
    ;Not Installed,,
    161,0,,
    161,1,,,
    ;Not Installed,,
    161,2,,,
    ;Not Installed,,
    161,3,,,
    ;Not Installed,,
    161,4,,,
    ;Not Installed,,
    162,0,,
    162,1,,,
    ;Not Installed,,
    162,2,,,
    ;Not Installed,,
    162,3,,,
    ;Not Installed,,
    162,4,,,
    ;Not Installed,,
    163,0,,
    163,1,,,
    ;Not Installed,,
    163,2,,,
    ;Not Installed,,
    163,3,,,
    ;Not Installed,,
    163,4,,,
    ;Not Installed,,
    164,0,,
    164,1,,,
    ;Not Installed,,
    164,2,,,
    ;Not Installed,,
    164,3,,,
    ;Not Installed,,
    164,4,,,
    ;Not Installed,,
    165,0,,
    165,1,,,
    ;Not Installed,,
    165,2,,,
    ;Not Installed,,
    165,3,,,
    ;Not Installed,,
    165,4,,,
    ;Not Installed,,
    166,0,,
    166,1,,,
    ;Not Installed,,
    166,2,,,
    ;Not Installed,,
    166,3,,,
    ;Not Installed,,
    166,4,,,
    ;Not Installed,,
    167,0,,
    167,1,,,
    ;Not Installed,,
    167,2,,,
    ;Not Installed,,
    167,3,,,
    ;Not Installed,,
    167,4,,,
    ;Not Installed,,
    168,0,,
    168,1,,,
    ;Not Installed,,
    168,2,,,
    ;Not Installed,,
    168,3,,,
    ;Not Installed,,
    168,4,,,
    ;Not Installed,,
    169,0,,
    169,1,,,
    ;Not Installed,,
    169,2,,,
    ;Not Installed,,
    169,3,,,
    ;Not Installed,,
    169,4,,,
    ;Not Installed,,
    200,0,,
    200,1,,,
    ;     111,,
    200,2,,,
    ;0.0,,
    200,3,,,
    ;0.0,,
    200,4,,,
    ;0.0,,
    201,0,,
    201,1,,,
    ;     000,,
    201,2,,,
    ;2.0,,
    201,3,,,
    ;00000010,,
    201,4,,,
    ;499.0,,
    235,0,,
    235,1,,,
    ;10010101,,
    235,2,,,
    ;10101000,,
    235,3,,,
    ;00011011,,
    235,4,,,
    ;01010110,,
    236,0,,
    236,1,,,
    ;00000101,,
    236,2,,,
    ;0,,
    236,3,,,
    ;0,,
    236,4,,,
    ;01010000,,
    237,0,,
    237,1,,,
    ;10010101,,
    237,2,,,
    ;00001000,,
    237,3,,,
    ;00001111,,
    237,4,,,
    ;00000000,,
    238,0,,
    238,1,,,
    ;00010011,,
    238,2,,,
    ;0,,
    238,3,,,
    ;0,,
    238,4,,,
    ;00110101,,
    239,0,,
    239,1,,,
    ;0.0,,
    239,2,,,
    ;50.0,,
    239,3,,,
    ;0.0,,
    239,4,,,
    ;300,,
    240,0,,
    240,1,,,
    ;10101100 11110101,,
    240,2,,,
    ;10101000 11110101,,
    240,3,,,
    ;0.0,,
    240,4,,,
    ;0.0,,
    241,0,,
    241,1,,,
    ;00001010 00100010,,
    241,2,,,
    ;00100010 00110011,,
    241,3,,,
    ;00001010 00001010,,
    241,4,,,
    242,0,,
    242,1,,,
    ;11110011 11111111,,
    242,2,,,
    ;00000100 00000000,,
    242,3,,,
    242,4,,,
    ;01001010 00000000,,
    243,0,,
    243,1,,,
    ;01011010 10100101,,
    243,2,,,
    ;10100101 01011010,,
    243,3,,,
    ;511.0,,
    243,4,,,
    ;53.0,,
    244,0,,
    244,1,,,
    ;0.0,,
    244,2,,,
    ;0.0,,
    244,3,,,
    ;0.0,,
    244,4,,,
    ;0.0,,
    245,0,,
    245,1,,,
    ;0.0,,
    245,2,,,
    ;0.0,,
    245,3,,,
    ;0.0,,
    245,4,,,
    ;0.0,,
    246,0,,
    246,1,,,
    ;0.0,,
    246,2,,,
    ;0.0,,
    246,3,,,
    ;0.0,,
    246,4,,,
    ;0.0,,
  10. Likes Uwe, Dana liked this post
  11. #10
    United States
    OK, I believe the old B8 window tweak applies but these cars use 2 BCMs so Address 46 is the window man :-) I shortened the 46 map so the stored values from channels 001, 002, 003, 004, 061 and 062 are included:
    A01
    ;53344
    A02
    ;53344
    A03
    ;36961
    A04
    ;36961
    A61,0,
    ;9947
    A62,0,
    ;48059
    I don't think these cars came with any more than 2 remote keys so adapt channels 003/004 really don't apply.
    1. Channels 001 and 002 (Personalization (Key 1 and Key 2) break down to:
      53344
      +32 = Auto-Lock (Locking at 15 kph/10 mph)
      +64 = Auto-Unlock (Unlocking with Key Removal)
      +4096 = Anti-Theft-System Confirmation (Horn/Siren)
      +16384 = Folding Mirrors installed/active
      +32768 = Highway/Comfort Turn Signals
      ... but comfort opening functions are NOT enabled:
      +00128 = Comfort Opening Driver Door Window
      +00256 = Comfort Opening Passenger Door Window
      +00512 = Comfort Opening Rear Left Window
      +01024 = Comfort Opening Rear Right Window
      Please add 1920 to 53344 for a new sum of 55264 and Test/Save that into channels 001 and 002.
    2. 061 (Comfort Operation: Opening) looks slightly odd but if that was the factory configuration I wouldn't mess with it:
      09947
      +1 = Power Windows via Remote Control
      +2 = Power Windows via Door Locks
      +8 = Front Sliding Roof via Remote Control
      +16 = Front Sliding Roof via Door Locks
      +64 = Rear Sliding Roof via Remote Control
      +128 = Rear Sliding Roof via Door Locks
      +512 = Roof Blinds via Remote Control
      +1024 = Roof Blinds via Door Locks
      +8192 = Front Sliding Roof to Tilt Position
    3. 062 (Comfort Operation: Closing) breaks down to:
      48059
      +8 = Power Windows via KESSY
      +16 = Front Sliding Roof via Remote Control
      +32 = Front Sliding Roof via Door Locks
      +128 = Front Sliding Roof via KESSY
      +256 = Rear Sliding Roof via Remote Control
      +512 = Rear Sliding Roof via Door Locks
      +2048 = Rear Sliding Roof via KESSY
      +4096 = Roof Blinds via Remote Control
      +8192 = Roof Blinds via Door Locks
      +32768 = Roof Blinds via KESSY
    In conclusion I believe tweaks to channels 001 and 002 will get the comfort windows operating via remote.
