Results 1 to 1 of 1
Thread: 2009 A4 B8 Quattro Saloon, 2.0T CDNC
    Jun 2014
    Newcastle, England
    2009 A4 B8 Quattro Saloon, 2.0TFSi CDNC
    If you are able to get engine channel maps, please create and post one (or more) of the following:
    • Cold engine, engine off.
    • Cold eninge, engine at idle.
    • Engine +80*C, engine off.
    • Engine +80*C, engine at idle
    Unfortunately not able to grab anything as the Channel Mapping doesn't seem to be supported for ASAM controllers.
    Here's an Auto-Scan:
    Saturday,04,April,2015,10:50:40:26758
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
    VIN: WAUZZZ8K69AXXXXXX   License Plate:
    Mileage: 56990km-35411mi   Repair Order:
    Chassis Type: 8K (8T0)
    Scan: 01 03 05 07 08 09 0E 0F 10 13 15 16 17 19 1E 36 37 42 46 47
              52 53 55 56 57 62 69 6C 72 77
    VIN: WAUZZZ8K69AXXXXXX   Mileage: 56990km-35411miles
    Address 01: Engine (-----CDNC)       Labels: 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 A    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H12 0002
       Revision: E1H12---
       Coding: 0104000C180F0A60
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM20TFS8K2907115A A01003
       ROD: EV_ECM20TFS8K2907115A.rod
       VCID: 2D5B729C7C79B849F59-8078
    Readiness: 1110 0101
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
       Part No SW: 8K0 907 379 AD    HW: 8K0 907 379 AD
       Component: ESP8 quattro  H04 0060
       Coding: 07CD00
       VCID: 7BFF8CC4FA8DE6F93BD-802E
       Part No SW: 8K0 907 064 AE    HW: 8K0 907 064 AE
       Component: BCM2 1.1      H71 0134
       Coding: 071100
       VCID: 73EFA4E4D2DDAEB963D-8026
       Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Component: ELVAUDIB8  H36 0041
    Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
       Part No SW: 8T0 035 730     HW: 4E0 035 729 A
       Component: Interfacebox    H43 5570
       Revision: 00000000    Serial number: 331GW087527386
       VCID: 6ED9B59079FF83518C3-803B
       Subsystem 1 - Part No: 8T0 919 609 C
       Component: E0380 BedienteilH08 0100
       Subsystem 2 - Serial number: 00000000122047
       Subsystem 3 - Serial number: 0125.07.080000000100010252ˇ
       Subsystem 4 - Serial number: 010252ˇ
       Part No SW: 8T2 820 043 T    HW: 8T2 820 043 T
       Component: KLIMA 3 ZONEN H06 0140
       Revision: D1000000    Serial number: 0112.07.080038
       Coding: 64040000
       VCID: 438F3424C2FD5E3933D-8016
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H22 0253
       Revision: 05022001    Serial number: 00000000197362
       Coding: 260050914034AF010001000300001D0D4F1D230800010141000000
       Shop #: WSC 01130 210 66681
       VCID: 30656BE8634BD5A1DEF-8065
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 150708  H05 0070
       Coding: 00FD11
       Component: RLS  H04 0003
       Coding: 024B2D
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Part No SW: 8T2 035 110 C    HW: 8T2 035 110 C
       Component: MP3-Changer     H44 0390
       Revision: 00044003    Serial number: AUZ5ZBH8521457
       VCID: 2B5F7C848A6DB679EBD-807E
    Address 0F: Digital Radio        Labels: None
       Part No SW: 4E0 910 563 C    HW: 4E0 035 563
       Component: DAB-Tuner       H41 0830
       Revision: 00000001    Serial number: KE1276W7300525
       VCID: 244D97B8E7B379012A7-8071
    Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
       Part No SW: 8K0 919 475 E    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0020
       Revision: 11001001    Serial number: 52830821004243
       Coding: 310003
       VCID: 3B7F4CC4BA0D26F97BD-806E
    Address 13: Auto Dist. Reg (J428)       Labels: None
       Part No SW: 8K0 907 561     HW: 8K0 907 561
       Component: ACC2          H07 0080
       Coding: 00C7CF
       VCID: 6FE7A894BEF58A59875-803A
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
       Component: AirbagVW-AU10 H26 0410
       Serial number: 0038JD182SKG
       Coding: 30363434363030303030554A3052384B3053
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 3C7D4FD8B70321C1727-8069
       Serial number: 6334MSME3E12552BG
       Serial number: 6344MSME3F43723AL
       Serial number: 6352QSME7C522E43Q
       Serial number: 6362QSME7F3A3927Y
       Serial number: 63732SME2D024606W
       Serial number: 63832SME45002800J
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Component: Lenks.Modul   H12 0013
       Revision: --------    Serial number: 90304HG3000BA
       Coding: 00001E
       VCID: 3E7945D0A91F33D15C3-806B
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 980 E    HW: 8K0 920 980 E
       Component: KOMBIINSTR.   H12 0216
       Revision: 00400000    Serial number: 6Y912F1A7
       Coding: 2F0D09000F002600010400
       Shop #: WSC 00783 210 90835
       VCID: 346D67F89753E981BA7-8061
       Part No SW: 8T0 907 468 L    HW: 8T0 907 468 L
       Component: GW-BEM 5CAN-M H10 0092
       Revision: FB402044    Serial number: 4400F087218051
       Coding: 000303
       VCID: 4A911900E5D78F71F0B-801F
       Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H04 0150
    Address 1E: Media Player 2 (R199)       Labels: 4E0-035-785.lbl
       Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
       Component: SG ext.Player H15 0850
       Revision: 00000000
       VCID: 2B5F7C844A6DB679EBD-807E
    Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
       Part No SW: 8K0 959 760     HW: 8K0 959 760
       Component: MEM-FS        H05 0043
       Revision: AA000000    Serial number: 00001001111410
       Coding: 00781B00000000000000
       VCID: 77F790F4C6A5C2995F5-8022
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
       Component: MNS ECE         H51 1060
       Revision: 00000000    Serial number: 333G%087599178
       Shop #: WSC 00762 210 97024
       VCID: 3B7F4CC47A0D26F97BD-806E
       Part No SW: 8K0 959 793 B    HW: 8K0 959 793
       Component: TSG FA        H10 0170
       Revision:             Serial number: 0000007541200
       Coding: 011C12205E01410001
       VCID: 3F8738D4AE153AD9575-806A
       Revision: 00002001    Serial number: 0113463471
       Coding: 011B0E22003905C5003001
       Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J245 PS034  H06 0037
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
       Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
       Component: DSP Prem      H14 0400
       Revision: 00H14003    Serial number: 34814002277201
       Coding: 020101
       Shop #: WSC 12336 024 394758
    00003 - Control Module
                014 - Defective
                        Fault Status: 01101110
                        Date: 2064.00.00
                        Time: 00:00:10
                        Voltage: 11.30 V
                        Temperature: 251.0∞C
                        Temperature: 253.0∞C
                        Bin. Bits: 00000100
                        Bin. Bits: 00000100
                        Bin. Bits: 00000000
       Part No SW: 8K0 959 792 B    HW: 8K0 959 792
       Component: TSG BF        H10 0170
       Revision:             Serial number: 0000007516848
       Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
       Component: EPB Audi B8   H05 0060
       Revision: 00000003    Serial number: 10000000072910
       VCID: 31636EEC6841DCA9D11-8064
    Address 55: Headlight Range        Labels: 8T0-907-357.clb
       Part No SW: 8H0 907 357 A    HW: 8H0 907 357
       Coding: 0000019
       Shop #: WSC 06324 000 00000
       VCID: 30656BE8A34BD5A1DEF-8065
       Subsystem 1 - Part No: 8K0 941 329
       Component: AFS-Modul links H01 S001
       Subsystem 2 - Part No: 8K0 941 329
       Component: AFS-Modul rechtsH01 S001
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 L
       Revision: 00000000    Serial number: 336H+087584845
       VCID: 31636EECA841DCA9D11-8064
    Address 57: TV Tuner        Labels: None
       Part No SW: 4E0 910 148 E    HW: 4E0 919 148
       Component: R78 TVHybridDVB     0470
       Revision: R0H06000    Serial number: 76300801710102
       Coding: 0000103
       VCID: 254B8ABCEC8980093D9-8070
       Part No SW: 8K0 959 795     HW: 8K0 959 795
       Component: TSG HL        H06 0170
       Revision:             Serial number: 0000007490460
       Coding: 010C12204001210001
       VCID: 7F0778D4EE95FAD9175-802A
    Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Revision: 1A001001    Serial number: 00008200250331
       Coding: 0100000000000000
       VCID: 36695DF0812FFB91843-8063
       Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
       Component: J772__Rearview      0070
       Revision: --H12---    Serial number: 525PA8-J87910O
       Coding: 1032006
       VCID: 377750F4462502999F5-8062
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
       Part No SW: 8K0 959 794     HW: 8K0 959 795
       Component: TSG HR        H06 0170
       Revision:             Serial number: 0000007559497
       VCID: 7EF985D0E99FF3D11C3-802B
    Address 77: Telephone        Labels: 4F1-910-336.lbl
       Part No SW: 4F1 910 336 D    HW: 4F1 862 335
       Component: BTA             H11 1120
       Revision: 00H11000    Serial number: 00000007586811
       Coding: 1010021
       Shop #: WSC 00783 210 84012
    End-------------------------(Elapsed Time: 03:56)--------------------------
