Results 11 to 20 of 30
Thread: Audi A3 8V retrofitting Audi Music Interface (AMI)
    Verified VCDS User lala30's Avatar
    Mar 2015
    Croatia
    hello
    this is code without AUX only AMI ( MDI)
    01730100FF00000020110001000A00002F0001040100010002
  2. #12
    New User Rooster's Avatar
    Apr 2015
    Quote Originally Posted by lala30 View Post
    hello
    Just tried your coding but still the same Open circuit error in VCDS and MMI says "No device is connected to the system."
    USB is getting power though and Lightning adapter is charging my phone as well.
  3. #13
    Apr 2015
    Finally I was able to get rid of that 'Open circuit' error in 5F module, meaning there is no single error in my auto-scan anymore.
    But still the AMI adapter is not recognized in MMI Radio.
    Measurement data in VCDS is showing the following when AMI Lightning adapter is connected:
    Address 5F: Information Electr. (8V0 035 840 B)
    175 External multimedia device interface-Adapter lead Adapter line for iPod (multimedia)
    176 External multimedia device interface-Adapter voltage 328
    So it seems AMI is correctly recognized but for some reason it cannot be chosen in MMI Radio; MMI prompts:
    "No device is connected to the system." when selecting AMI as audio source.
  4. Likes Uwe liked this post
  5. #14
    Apr 2015
    And here is the latest auto-scan taken with version 15.5.0
    Still no labels for module 5F but hopefully in the next release.
    Tuesday,19,May,2015,22:03:29:43720
    VCDS Version: 15.5.0.0 (x64)
    Data version: 20150510
    VIN:    License Plate:
    Mileage: 9252km-5748mi   Repair Order:
    Chassis Type: 8V (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
    VIN:   Mileage: 9252km-5748miles
    Address 01: Engine (J623-CZEA)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 027 BL    HW: 04E 907 309 AB
       Component: 1.4l R4 TSI   H21 8139
       Revision: R6H21---
       Coding: 02250032242401082000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM14TFS01104E906027BL 001006
       ROD: EV_ECM14TFS01104E906027BL.rod
       VCID: 6FED1358B637C44766-803A
    Address 02: Auto Trans (J743)       Labels: None
       Part No SW: 0CW 300 047 T    HW: 0AM 927 769 K
       Component: GSG DQ200-MQB H43 5202
       Revision: 00043014    Serial number: CU501406226128
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021_AU37.rod
       VCID: 4C97A4D4E761DF5F23-8019
       Revision: 00000000    Serial number: 61924000001910
       Coding: 13F16AA22424126F0179060941CA29C856244880608294F2022100788608
       ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
       VCID: 458191F0C40B2E17FC-8010
    Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
       Revision: 20026000    Serial number: 00000000380730
       Coding: 03000014000000011000000000001100
       VCID: 3365DF289A9FA0A742-8066
       Component: BCM MQBAB H   H18 0134
       Serial number: 01011416702002
       Coding: 04141A46C24122FD43C04004001807A80000000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 000F40E49BA9CB3F8F-8055
       Slave 1:
       Subsystem 1 - Part No SW: 8V1 955 119 C    HW: 8V1 955 119 A
       Component: WWS371 140711  042 0585
       Serial number:         140715225852
       Coding: 0A47F7
       Slave 2:
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
       Serial number: 22867854
       Coding: 00006C
       Slave 3:
       Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
       Serial number: 30 03 2014  00000637
       Subsystem 4 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.014  H02 0007
       Serial number:     WOO3006111T
       Coding: 901E00
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0051
       Revision: --------    Serial number: 39231418901291
       Coding: 0000050011
       ROD: EV_EPHVA14AU3700000_AU37.rod
       VCID: 3B75F708B2CF68E79A-806E
       Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
       Component: AirbagVW20    014 0385
       Serial number: 003MMR01N4V4
       Coding: 98CCC0000C0000005C5400CA004800000065
       Subsystem 1 - Part No SW: -----------    HW: 480 000 707 14
       Serial number: 35767000000413BC001H
       Subsystem 2 - Part No SW: -----------    HW: 480 000 707 14
       Serial number: 35867000000D6875101R
       Subsystem 3 - Part No SW: -----------    HW: 480 400 807 14
       Serial number: 3516502AD1656B84928J
       Subsystem 4 - Part No SW: -----------    HW: 480 400 807 14
       Serial number: 3526502C31697523C186
       Subsystem 5 - Part No SW: -----------    HW: 480 400 207 14
       Serial number: 3556502C7156E9E1D0BX
       Pedestrian protection crash sensor; driver side:
       Subsystem 6 - Part No SW: -----------    HW: 480 401 207 14
       Serial number: 2286502BF165690461DG
       Pedestrian protection crash sensor; front passenger side:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 207 14
       Serial number: 2296502B51656905C189
       Subsystem 8 - Part No SW: -----------    HW: 480 001 704 14
       Serial number: I0M800000009938D6F0P
       Subsystem 9 - Part No SW: -----------    HW: 480 001 704 14
       Serial number: I0N80000000A938D6F0R
       Part No SW: 8V0 953 521 CB    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 14071404220163
       Coding: A018
       ROD: EV_SMLSKLOMQB_AU37.rod
       VCID: 7CF73414F741AFDFD3-8029
       Part No SW: 8V0 920 871     HW: 8V0 920 871
       Component: KOMBI         H02 4291
       Coding: 07A519082B8000080100AA001000000000000000
       VCID: 79F92D00F8739AF7C8-802C
    Address 19: CAN Gateway (J533)       Labels: Redir Fail!
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2186
       Revision: --------    Serial number: 07071410801857
       Coding: 030100042F0857005B0002481C0B00000001010000000000000000000000
       ROD: EV_GatewConti_AU37.rod
       VCID: 428B8AECD525192FD9-8017
       Serial number: 02 07 2014  E0001942
       Serial number: 0222073903
       Serial number: 01071403110396
       Coding: 001C8F204000040000001002
       VCID: 408F80E4DB290B3FCF-8015
       Component: EPS_MQB_ZFLS  123 1043
       Coding: 8103
       ROD: EV_SteerAssisMQB.rod
       VCID: 418985E0D0230237C0-8014
       Serial number: 11071403111530
       Coding: 001C87204C00040000001002
       VCID: 3F8D8318A6D774C7B6-806A
    Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
       Coding: 019A000001000000
       ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
       VCID: 75E12130D46BFE97AC-8020
       Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
       Component: MU-S--ER      041 0420
       Serial number: A3E01107142410
       Coding: 01730100FF00000021110001000A00002F0001040100010002
       ASAM Dataset: EV_MUStd6C3PASE 002010
       ROD: EV_MUStd6C3PASE_AU37.rod
       VCID: 3467DC349F91A79F5B-8061
       Seat Adjustment Driver Side:
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0013
       Serial number: AUZ8Z9EY304XMC
       Sound System:
       Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
       Serial number: C1000003071400020201
    End-------------------------(Elapsed Time: 03:48)--------------------------
  6. Likes Uwe liked this post
  7. #15
    New User
    Jul 2015
    I have the exact same issue with my golf mk7. (A3 an Golf7 MQB)
    Cable-Adapters are visible in the adaption channels.
    But it is not possible to switch to mdi (VW) / AMI (Audi).
    I think this feature is protected as SWaP (Software as a Product)?!
  8. #16
    Pirate Xander409's Avatar
    Jul 2015
    Italy
    Hi all,
    Any news about that?
    I have a mmi radio with default aux port, and i'd like to have AMI or connectivity kit. Do you think it will be possible?
    Thanks in advance
  9. #17
    Apr 2015
    Finally got this sorted out!
    For my car's setup the correct software coding for 5F module was the following:
    01730100FF00000031110001000A00002F0001040100010002
    It took almost half a year but now I have fully working AMI with USB port retrofitted in my A3 sedan.
    Over and out!
  10. Likes Uwe liked this post
  11. #18
    Jul 2015
    Italy
    Quote Originally Posted by Rooster View Post
    Over and out!
    this code is associated only to the ami, or not?
    if i need to code the ami, i can use this, or it will be different for each car?
  12. #19
    Over and out!
    Rooster: Hi. I also have an interest in this matter but I desperately need your help in trying to understand your solution (I've been reading this thread, but it's messin'-with-my-membrane!).
    From what I have understood, the Coding values for address 5F are as shown below for:
    1. your original posting (post #1 autoscan),
    2. Sebatian's preliminary advice (post #2)
    3. Your advice regarding the fix (post # 17)
    If my understanding (and my hex-to-binary conversion) is correct, it seems to me that the only change that you made was to set Bit 4 and Bit 5 of Byte 08 to "1". Is this the fix for enabling AMI/USB - what have I missed?
    Cheers
  13. Likes Bruce, Uwe liked this post
  14. #20
    Apr 2015
    Xander: Coding is for overall 5F module, which contains everything regarding information electronics (and yes, it depends on your car's features); thus it is not just for AMI. But the actual code change what I did corresponds with AMI, though.
    Don: Exactly! Bits 4 and 5 of Byte 08 was changed to 1. After the code change I made a soft reset and when MMI was up and running again, I had the AMI as a selectable Media source.
  15. Likes DV52 liked this post
