Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Audi A3 8V retrofitting Audi Music Interface (AMI)
  1. #21
    New User Rooster's Avatar
    Apr 2015
    Just a teaser
  2. Likes Uwe liked this post
  3. #22
    Pirate Xander409's Avatar
    Jul 2015
    Italy
    have you got a rear-photo of your cd player please?
  4. #23
    Apr 2015
    Quote Originally Posted by Xander409 View Post
    Unfortunately I don't have any pictures from the actual assembly job.
  5. #24
    Nov 2014
    San José, Costa Rica
    Quote Originally Posted by Rooster View Post
    Just a teaser
    Moar details! Is that Apple Carplay?
  6. #25
    Apr 2015
    Quote Originally Posted by m_bolc View Post
    More details! Is that Apple Carplay?
    No it's not the Carplay.
    This is Apple TV 3 connected into AMI. Internet connection is gained via iPhone's Personal hotspot.
  7. #26
    New User
    Apr 2016
    audi music interface harness
    where comes the loose red and black cables?
    Happy to be part of this community. My case is following:
    I have successfully retrofitted the Audi Music Interface (AMI) to my A3 sedan (8V0). Original AUX interface has been replaced with the AMI/USB combination and required wire harness has been installed and connected to the MMI Radio as well.
    Retrofit kit what I have used is this:
    http://www.carsystems.pl/audi-a3-8v-...fit,id961.html
    There is a note saying: VAS programming is required after installation
    The problem is that MMI still thinks that original AUX is present not the AMI and thus the MMI should be re-coded. I have tried to figure it out with VCDS but unfortunately even the latest beta software doesn't support labels for module 5F - Information Electronics. Are there any ideas how I could proceed or do I just have to wait for the next VCDS release where the support for my car is present?
    I have already sent the Auto-scan and Controller Channel Maps for you by mail (those where taken by version 14.10.2.0 but Auto-scan with the latest beta 15.3.0 gave the same result set though).
    Thanks and regards,
    Rooster
    Wednesday,25,March,2015,15:38:54:43720
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
    VIN: WAUZZZ8V7F1043297   License Plate:
    Mileage: 7108km-4416mi   Repair Order:
    Chassis Type: 8V (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
    VIN: WAUZZZ8V7F1043297   Mileage: 7108km-4416miles
    Address 01: Engine (J623-CZEA)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 027 BL    HW: 04E 907 309 AB
       Component: 1.4l R4 TSI   H21 8139
       Revision: R6H21---
       Coding: 02250032242401082000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM14TFS01104E906027BL 001006
       ROD: EV_ECM14TFS01104E906027BL.rod
       VCID: 6FED1358B637C459875-803A
       Part No SW: 0CW 300 047 T    HW: 0AM 927 769 K
       Component: GSG DQ200-MQB H43 5202
       Revision: 00043014    Serial number: CU501406226128
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021_AU37.rod
       VCID: 4C97A4D4E761DF41C27-8019
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
       Part No SW: 5Q0 907 379 L    HW: 5Q0 907 379 G
       Component: ESC           H31 0471
       Revision: 00000000    Serial number: 61924000001910
       Coding: 13F16AA22424126F0179060941CA29C856244880608294F2022100788608
       ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
       VCID: 458191F0C40B2E091D9-8010
    Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
       Component: AC Automat    H13 0052
       Revision: 20026000    Serial number: 00000000380730
       Coding: 03000014000000011000000000001100
       VCID: 3365DF289A9FA0B9A3D-8066
       Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
       Component: BCM MQBAB H   H18 0134
       Serial number: 01011416702002
       Coding: 04141A46C24122FD43C04004001807A80000000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 000F40E49BA9CB216EF-8055
       Slave 1:
       Subsystem 1 - Part No SW: 8V1 955 119 C    HW: 8V1 955 119 A
       Component: WWS371 140711  042 0585
       Serial number:         140715225852
       Coding: 0A47F7
       Slave 2:
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
       Serial number: 22867854
       Coding: 00006C
       Slave 3:
       Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
       Serial number: 30 03 2014  00000637
       Subsystem 4 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.014  H02 0007
       Serial number:     WOO3006111T
       Coding: 901E00
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0051
       Revision: --------    Serial number: 39231418901291
       Coding: 0000050011
       ASAM Dataset: EV_EPHVA14AU3700000 002022
       ROD: EV_EPHVA14AU3700000_AU37.rod
       VCID: 3B75F708B2CF68F97BD-806E
       Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
       Component: AirbagVW20    014 0385
       Serial number: 003MMR01N4V4
       Coding: 98CCC0000C0000005C5400CA004800000065
       Subsystem 1 - Part No SW: -----------    HW: 480 000 707 14
       Serial number: 35767000000413BC001H
       Subsystem 2 - Part No SW: -----------    HW: 480 000 707 14
       Serial number: 35867000000D6875101R
       Subsystem 3 - Part No SW: -----------    HW: 480 400 807 14
       Serial number: 3516502AD1656B84928J
       Subsystem 4 - Part No SW: -----------    HW: 480 400 807 14
       Serial number: 3526502C31697523C186
       Subsystem 5 - Part No SW: -----------    HW: 480 400 207 14
       Serial number: 3556502C7156E9E1D0BX
       Pedestrian protection crash sensor; driver side:
       Subsystem 6 - Part No SW: -----------    HW: 480 401 207 14
       Component: PedP_Sensor_D  001 6149
       Serial number: 2286502BF165690461DG
       Pedestrian protection crash sensor; front passenger side:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 207 14
       Component: PedP_Sensor_P  001 6149
       Serial number: 2296502B51656905C189
       Subsystem 8 - Part No SW: -----------    HW: 480 001 704 14
       Serial number: I0M800000009938D6F0P
       Subsystem 9 - Part No SW: -----------    HW: 480 001 704 14
       Serial number: I0N80000000A938D6F0R
       Part No SW: 8V0 953 521 CB    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 14071404220163
       Coding: A018
       ROD: EV_SMLSKLOMQB_AU37.rod
       VCID: 7CF73414F741AFC1327-8029
       Part No SW: 8V0 920 871     HW: 8V0 920 871
       Coding: 07A519082B8000080100A8001000000000000000
       VCID: 79F92D00F8739AE9291-802C
    Address 19: CAN Gateway (J533)       Labels: Redir Fail!
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2186
       Revision: --------    Serial number: 07071410801857
       Coding: 030100042F0857005B0002481C0B00000001010000000000000000000000
       ASAM Dataset: EV_GatewConti 011017
       ROD: EV_GatewConti_AU37.rod
       VCID: 428B8AECD525193138B-8017
       Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
       Serial number: 02 07 2014  E0001942
       Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
       Component: J367-BDMHella  H03 8043
       Serial number: 0222073903
       Serial number: 01071403110396
       Coding: 001C8F204000040000001002
       VCID: 408F80E4DB290B212EF-8015
       Component: EPS_MQB_ZFLS  123 1043
       Coding: 8103
       ROD: EV_SteerAssisMQB.rod
       VCID: 418985E0D0230229211-8014
       Serial number: 11071403111530
       Coding: 001C87204C00040000001002
       VCID: 3F8D8318A6D774D9575-806A
    Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
       Coding: 019A000001000000
       ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
       VCID: 75E12130D46BFE894D9-8020
       Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
       Component: MU-S--ER      041 0420
       Serial number: A3E01107142410
       Coding: 01730100FF00000011110001000A00002F0001040100010002
       ASAM Dataset: EV_MUStd6C3PASE 002010
       ROD: EV_MUStd6C3PASE_AU37.rod
       VCID: 3467DC349F91A781BA7-8061
       Seat Adjustment Driver Side:
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0013
       Serial number: AUZ8Z9EY304XMC
       Sound System:
       Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
       Component: ControlUnit_B  H41 0054
       Serial number: C1000003071400020201
    End---------------------(Elapsed Time: 03:45, Deb=2)-----------------------
  8. #27
    New User
    Dec 2016
    Italy
    hi guys, i also have installed this retrofit kit but i dont know where to connect the red and black cables.
    i connected that cables to the 12v power but the usb won't charge my phone....
  9. #28
    Quote Originally Posted by rive872 View Post
    What phone do you have?
    I seem to remember (I retrofitted AMI to my previous car, a 2006 Audi RS4) that not all iPhones could be charged using the AMI lead, and that may apply to other phones too.
  10. #29
    New User
    Dec 2016
    Italy
    I have iPhone 6s but I don't know where to connect the spare red and black cables of the AMI
  11. #30
    If you mean the power cables for the AMI then when I retrofitted AMI I connected them to the power going to the RNS-E in my B7 RS4.
