Post Thanks / Like - 1 Likes
Uwe liked this post
Pirate
have you got a rear-photo of your cd player please?
New User
Originally Posted by
Xander409
Unfortunately I don't have any pictures from the actual assembly job.
Rooster
Just a teaser
Moar details! Is that Apple Carplay?
New User
m_bolc
More details! Is that Apple Carplay?
No it's not the Carplay.
This is Apple TV 3 connected into AMI. Internet connection is gained via iPhone's Personal hotspot.
audi music interface harness
where comes the loose red and black cables?
Rooster
Happy to be part of this community. My case is following:
I have successfully retrofitted the Audi Music Interface (AMI) to my A3 sedan (8V0). Original AUX interface has been replaced with the AMI/USB combination and required wire harness has been installed and connected to the MMI Radio as well.
Retrofit kit what I have used is this:
http://www.carsystems.pl/audi-a3-8v-...fit,id961.html
There is a note saying:
VAS programming is required after installation
The problem is that MMI still thinks that original AUX is present not the AMI and thus the MMI should be re-coded. I have tried to figure it out with
VCDS but unfortunately even the latest beta software doesn't support labels for module 5F - Information Electronics. Are there any ideas how I could proceed or do I just have to wait for the next
VCDS release where the support for my car is present?
I have already sent the Auto-scan and Controller Channel Maps for you by mail (those where taken by version 14.10.2.0 but Auto-scan with the latest beta 15.3.0 gave the same result set though).
Thanks and regards,
Rooster
Wednesday,25,March,2015,15:38:54:43720
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WAUZZZ8V7F1043297 License Plate:
Mileage: 7108km-4416mi Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V7F1043297 Mileage: 7108km-4416miles
Address 01: Engine (J623-CZEA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 BL HW: 04E 907 309 AB
Component: 1.4l R4 TSI H21 8139
Revision: R6H21---
Coding: 02250032242401082000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM14TFS01104E906027BL 001006
ROD: EV_ECM14TFS01104E906027BL.rod
VCID: 6FED1358B637C459875-803A
Part No SW: 0CW 300 047 T HW: 0AM 927 769 K
Component: GSG DQ200-MQB H43 5202
Revision: 00043014 Serial number: CU501406226128
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021_AU37.rod
VCID: 4C97A4D4E761DF41C27-8019
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 61924000001910
Coding: 13F16AA22424126F0179060941CA29C856244880608294F2022100788608
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 458191F0C40B2E091D9-8010
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000380730
Coding: 03000014000000011000000000001100
VCID: 3365DF289A9FA0B9A3D-8066
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011416702002
Coding: 04141A46C24122FD43C04004001807A80000000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 000F40E49BA9CB216EF-8055
Slave 1:
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A
Component: WWS371 140711 042 0585
Serial number: 140715225852
Coding: 0A47F7
Slave 2:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Serial number: 22867854
Coding: 00006C
Slave 3:
Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
Serial number: 30 03 2014 00000637
Subsystem 4 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO3006111T
Coding: 901E00
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 E HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0051
Revision: -------- Serial number: 39231418901291
Coding: 0000050011
ASAM Dataset: EV_EPHVA14AU3700000 002022
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: 3B75F708B2CF68F97BD-806E
Part No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB
Component: AirbagVW20 014 0385
Serial number: 003MMR01N4V4
Coding: 98CCC0000C0000005C5400CA004800000065
Subsystem 1 - Part No SW: ----------- HW: 480 000 707 14
Serial number: 35767000000413BC001H
Subsystem 2 - Part No SW: ----------- HW: 480 000 707 14
Serial number: 35867000000D6875101R
Subsystem 3 - Part No SW: ----------- HW: 480 400 807 14
Serial number: 3516502AD1656B84928J
Subsystem 4 - Part No SW: ----------- HW: 480 400 807 14
Serial number: 3526502C31697523C186
Subsystem 5 - Part No SW: ----------- HW: 480 400 207 14
Serial number: 3556502C7156E9E1D0BX
Pedestrian protection crash sensor; driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 401 207 14
Component: PedP_Sensor_D 001 6149
Serial number: 2286502BF165690461DG
Pedestrian protection crash sensor; front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 401 207 14
Component: PedP_Sensor_P 001 6149
Serial number: 2296502B51656905C189
Subsystem 8 - Part No SW: ----------- HW: 480 001 704 14
Component: PedPSensor_D2 001 0887
Serial number: I0M800000009938D6F0P
Subsystem 9 - Part No SW: ----------- HW: 480 001 704 14
Component: PedPSensor_P2 001 0887
Serial number: I0N80000000A938D6F0R
Part No SW: 8V0 953 521 CB HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 14071404220163
Coding: A018
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 7CF73414F741AFC1327-8029
Part No SW: 8V0 920 871 HW: 8V0 920 871
Component: KOMBI H02 4291
Coding: 07A519082B8000080100A8001000000000000000
VCID: 79F92D00F8739AE9291-802C
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 07071410801857
Coding: 030100042F0857005B0002481C0B00000001010000000000000000000000
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_AU37.rod
VCID: 428B8AECD525193138B-8017
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Serial number: 02 07 2014 E0001942
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 0222073903
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 01071403110396
Coding: 001C8F204000040000001002
VCID: 408F80E4DB290B212EF-8015
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 8103
ROD: EV_SteerAssisMQB.rod
VCID: 418985E0D0230229211-8014
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 11071403111530
Coding: 001C87204C00040000001002
VCID: 3F8D8318A6D774D9575-806A
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Component: LWR-ECU 005 0080
Coding: 019A000001000000
ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
VCID: 75E12130D46BFE894D9-8020
Part No SW: 8V0 035 840 B HW: 8V0 035 840 B
Component: MU-S--ER 041 0420
Serial number: A3E01107142410
Coding: 01730100FF00000011110001000A00002F0001040100010002
ASAM Dataset: EV_MUStd6C3PASE 002010
ROD: EV_MUStd6C3PASE_AU37.rod
VCID: 3467DC349F91A781BA7-8061
Seat Adjustment Driver Side:
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0013
Serial number: AUZ8Z9EY304XMC
Sound System:
Subsystem 2 - Part No SW: 8V0 919 614 P HW: 8V0 919 614 P
Component: ControlUnit_B H41 0054
Serial number: C1000003071400020201
End---------------------(Elapsed Time: 03:45, Deb=2)-----------------------
hi guys, i also have installed this retrofit kit but i dont know where to connect the red and black cables.
i connected that cables to the 12v power but the usb won't charge my phone....
rive872
What phone do you have?
I seem to remember (I retrofitted AMI to my previous car, a 2006 Audi RS4) that not all iPhones could be charged using the AMI lead, and that may apply to other phones too.
I have iPhone 6s but I don't know where to connect the spare red and black cables of the AMI
rive872
If you mean the power cables for the AMI then when I retrofitted AMI I connected them to the power going to the RNS-E in my B7 RS4.
