Page 7 of 7 FirstFirst ... 567
Results 61 to 63 of 63
Thread: Audi a3 retrofit halogen-full led
  1. #61
    Jan 2019
    France
    Quote Originally Posted by langers2k View Post
    Everything you need should be in https://erwin.audi.com/erwin/showHome.do regarding wiring...
    I have ready download all wiring diagrams but I don't find the diagram for full LED
    I have changed the wiring for 8IT and I seen that it's for bixénon not for full LED
    For that I asked her
    I have 2745 pages of wiring diagrams
    I have do my best for search the full LED but nothing found
  2. #62
    Feb 2016
    Czech Republic
    Hello, i made retrofit from A6 C7 facelift Xenon to LED (not Matrix)
    I have the similar 2 errors, did you find solution for eliminate the errors ?
       Coding: 04DA06102A630200
       VCID: 3430ED87FEB5D8F71DF-8060
       Coding: E01E00
       Coding: E01F00
              U1014 00 [137] - -
              [Steuergeraet falsch codiert]
                    Reset counter: 54
                    Mileage: 230167 km
                    Date: 2019.10.30
                    Time: 16:36:12
    5275220 - Headlight
                    Reset counter: 54
                    Mileage: 230167 km
                    Date: 2019.10.30
                    Time: 16:36:13
    5544945 - Output Stage for LED Headlamp; Right
              B149B F1 [137] - Incorrectly Coded
                    Fault Priority: 2VCDS
                    Reset counter: 54
                    Mileage: 230167 km
                    Date: 2019.10.31
                    Time: 07:42:39
    5335297 - Fan 2 for Right Headlamp
              C1169 01 [137] - Electrical Failure
                    Reset counter: 54
                    Mileage: 230167 km
                    Date: 2019.10.30
                    Time: 16:36:14
    THX
  3. #63
    Feb 2016
    Czech Republic
    So like i wrote in my other thread - i used:
    09 - Central El. - VCP (vag can pro ) - parametrisation of my configuration
    55 - Head. range - basic setting (also with VCP but can work also with VCDS)
    All is without errors now...
    All is working great!
