Thursday,16,April,2015,13:13:05:33623
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WVGEP9BP2DD006473 License Plate:
Mileage: 63901km-39706mi Repair Order: tuareg tdi30t
Chassis Type: BP (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
69 6C 6D 72
VIN: WVGEP9BP2DD006473 Mileage: 63901km-39706miles
Address 01: Engine (J623-CNRA) Labels: None
Part No SW: 7P0 907 401 K HW: 7P0 907 401 K
Component: 3.0TDI EDC17 H19 0003
Revision: 56H19---
Coding: 292A4012233600050000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0117P0907401K 001004
ROD: EV_ECM30TDI0117P0907401K.rod
VCID: 377D176B8ECED3999F5-8062
8854 - Idle Control System RPM
P0507 00 [096] - Higher than Expected.
Mileage: 61635 km
Date: 2015.02.28
Time: 12:25:09
5568 - Sensor for Ambient Air Temperature (G17)
P0073 00 [032] - Signal too High
10065 - Mass Air Flow Sensor (G70)
P0104 00 [032] - Intermittent
8787 - ROD - Unknown Error Code
- 00 [104]
Mileage: 36869 km
Date: 2014.03.10
Time: 13:38:15
12288 - Charge Air Cooler
P026A 00 [096] - Efficiency Below Threshold
Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 AK HW: 0C8 927 750 AK
Component: AL1000 AISIN 001 2269
Coding: 001368
ASAM Dataset: EV_TCMAL991031 002114
ROD: EV_TCMAL991031_VW52.rod
VCID: 75E1DD63D44261894D9-8020
Address 03: ABS Brakes (J104) Labels: 7P0-907-379.clb
Part No SW: 7P0 907 379 M HW: 7P0 907 379 A
Component: MK25A H36 0436
Revision: -------- Serial number: 423120010EC815
Coding: 5B7613C349242559DAF8C89A92D5A4407300
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: 479D67ABFE2EA319EF5-8012
Slave 1:
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.CLB
Part No SW: 4H0 907 064 CK HW: 4H0 907 064 CK
Component: BCM2 2.0 H32 0421
Coding: 09860010000000000000
VCID: 74E7E067D73878817A7-8021
Subsystem 1 - Part No SW: 7P6 959 754 AD HW: 7P6 959 754 AD
Component: FBSTOUAREGIDG H04 0051
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Address 08: Auto HVAC (J255) Labels: 7P6-907-040.clb
Part No SW: 7P6 907 040 BK HW: 7P6 907 040 BK
Component: Klima 2 Zonen H20 1305
Coding: B606200A80
VCID: 7EF3C24FE17422D11C3-802B
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.CLB
Part No SW: 4H0 907 063 BL HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0111
Revision: 15012002 Serial number: 00000001594314
Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
VCID: 73E5E37BD2367FB963D-8026
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 120820 31 0020
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Part No SW: 7P0 959 655 C HW: 7P0 959 655 C
Component: VW10Airbag025 H05 0025
Revision: -------- Serial number: 003L0004KY40
Coding: 000000000000000000000000000000003235
ROD: EV_AirbaVW10BPAVW526.rod
VCID: 418979B3D00A9D29211-8014
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R12601093FT
Serial number: 3575LRB404T1G7FG68KX
Serial number: 3585LRB405L1G7FCC089
Serial number: 3515RRB40691GLOO98PB
Serial number: 3525RRB40691GLOOJGKP
Serial number: 3555NRB405R1GCDMMOQ-
Serial number: 3565NRB405R1GCDMEPNR
Address 16: Steering wheel (J527) Labels: 4H0-953-568.CLB
Part No SW: 4H0 953 568 F HW: 7P6 953 507 L
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815LHR0001J
Coding: 000015
VCID: 36631A6F81C42A91843-8063
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Address 17: Instruments (J285) Labels: 7P6-920-xxx-17.clb
Part No SW: 7P6 920 981 F HW: 7P6 920 981 F
Component: Kombi H13 0318
Revision: 13240077 Serial number: 658220812592019
Coding: 8B7733022B00CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001017
ROD: EV_KombiUDSRBVW526.rod
VCID: 408F7CB7DB0094212EF-8015
Part No SW: 7P6 907 530 F HW: 7P6 907 530 F
Component: GW-CAN-L-MOST H11 6028
Revision: -------- Serial number: 00000000656045
Coding: 0001037500
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 3B750B5BB2E6F7F97BD-806E
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650041674
U140B 00 [008] - -
Reset counter: 143
Mileage: 62199 km
Date: 2015.03.07
Time: 13:13:21
Address 36: Seat Mem. Drvr (J136) Labels: NONE
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000037431534
Coding: 0058130000004001000001010101202020202121202020
VCID: 3467206797B83881BA7-8061
Address 42: Door Elect, Driver (J386) Labels: NONE
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000129998882
Coding: 011D07205E00453005080000
VCID: 448770A7C71888010A7-8011
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.CLB
Revision: 00002001 Serial number: 0182129872
Coding: 0186123A28B9509480A00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Coding: 191100
Address 52: Door Elect, Pass. (J387) Labels: NONE
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000130015577
VCID: 3B750B5BBAE6F7F97BD-806E
Address 53: Parking Brake (J540-) Labels: 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1282000972
Coding: 01040200
ROD: EV_ParkbA7.rod
VCID: 36631A6F89C42A91843-8063
Slave 3:
12656790 - Databus
Fault Frequency: 127
Reset counter: 0
Mileage: 6656 km
Date: 2105.02.19
Time: 01:61:02
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 010A00010F000400
VCID: 7CF7C847F76830C1327-8029
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329
Component: LeiMo links H01 0002
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329
Component: LeiMo rechts H01 0002
Coding: 130000
Address 56: Radio (R) Labels: REDIR FAIL!
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 156H00C7625672
Coding: 020007020100000001
VCID: 2149D933384ABD29411-8074
Address 5F: Information Electr. (J794) Labels: 4E0-035-6XX-5F.CLB
Part No SW: 7P6 035 664 C HW: 7P6 035 664
Component: H-BN-NA H45 0544
Revision: -------- Serial number: 445HS0C7540220
Coding: 010200050040E1EE41022B0C00000003F0000100
VCID: 387F14578BD0DCE196F-806D
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H26 0045
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: CD-Database 1886
Reset counter: 16
Mileage: 446 km
Date: 2013.03.17
Time: 16:03:48
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00010000
Address 62: Door, Rear Left (J388) Labels: NONE
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0167
Revision: -------- Serial number: 0000129941366
Coding: 011C07200000253005080000
VCID: 3A7B0E5FB5DCCEF160B-806F
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000091248
ROD: EV_RDKBERU25_VW52.rod
VCID: 3F8D7F4BA6FEEBD9575-806A
Address 69: Trailer (J345) Labels: NONE
Part No SW: 7P0 907 383 F HW: 7P0 907 383 B
Component: Anhaenger H09 0110
Revision: 5A001001 Serial number: 00000181794436
Coding: 020D000000000000
Address 6C: Back-up Cam. Labels: 4L0-910-441.CLB
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H06000 Serial number: 525 PA8J272294
Coding: 0110001
VCID: 377D176B46CED3999F5-8062
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 7P6 959 107 A HW: 7P6 959 107
Component: HDSG-Modul H10 0620
Revision: 22010001 Serial number: 227200134
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202137
ROD: EV_HeckkTouar.rod
VCID: 3D710543ACF2F9C9459-8068
Address 72: Door, Rear Right (J389) Labels: NONE
Component: TSG HR H09 0167
Revision: -------- Serial number: 0000129884593
End---------------------(Elapsed Time: 20:52, Deb=2)-----------------------
