Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: How to...sri
    Verified VCDS User victor35ma's Avatar
    Nov 2014
    Los Angeles CA.
    Hello Here I am again with SRI question. I learned how to do a SRI now, but today I got a 2013 VW Touraeg TDi 3.0T sorry i can give the auto scan at this time, I am from home right now. I will tomorrow from the shop.... service interval is oil change reset. and I did it successfully thanks for that ( 07 instrument/) as you can see in the following pic. but Which option should I need to pick besides SRI interval to reset service inspection Highlighted "B" in red circle in my pci.... I know but that's my B. also to take the most of VCDS which other option(s) should I execute on car like this on daily maintenance ??? diesel, with DPF and DEF @ 40K miles
    pic 2
    I am new to VCDS but... I will master it.
  2. #12
    I think this will be a UDS cluster, and without knowing which ASAM dataset it uses, it's going to be difficult to say for sure, but... If it's similar to a 2015 I have data for, there will be an Adaptation Channel in [17-Instruments] named "ESI: distance driven from inspection". If you'd performed the the distance-based inspection items, make that channel 0 km.
    Edit: It could also be "FIX: Distance covered since last mileage-dependent inspection".
    The best thing to do would be to make an Adaptation Channel Map from the cluster so we can see all the channels. The way these channels interact is sometimes a whole lot clearer when we can see what's in all of them.
  3. #13
    Nov 2014
    Los Angeles CA.
    Uwe-
    thank and good Morning...how can I get dataset info?
    ok, I did the maps yesterday and I sent the hold car maps to vcds support.
  4. #14
    Nov 2014
    Los Angeles CA.
    Thursday,16,April,2015,13:13:05:33623
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
    VIN: WVGEP9BP2DD006473   License Plate:
    Mileage: 63901km-39706mi   Repair Order: tuareg tdi30t
    Chassis Type: BP (7P6)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
              69 6C 6D 72
    VIN: WVGEP9BP2DD006473   Mileage: 63901km-39706miles
    Address 01: Engine (J623-CNRA)       Labels: None
       Part No SW: 7P0 907 401 K    HW: 7P0 907 401 K
       Component: 3.0TDI EDC17  H19 0003
       Revision: 56H19---
       Coding: 292A4012233600050000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0117P0907401K 001004
       ROD: EV_ECM30TDI0117P0907401K.rod
       VCID: 377D176B8ECED3999F5-8062
    8854 - Idle Control System RPM
              P0507 00 [096] - Higher than Expected.
                        Mileage: 61635 km
                        Date: 2015.02.28
                        Time: 12:25:09
    5568 - Sensor for Ambient Air Temperature (G17)
              P0073 00 [032] - Signal too High
    10065 - Mass Air Flow Sensor (G70)
              P0104 00 [032] - Intermittent
    8787 - ROD - Unknown Error Code
              - 00 [104]
                        Mileage: 36869 km
                        Date: 2014.03.10
                        Time: 13:38:15
    12288 - Charge Air Cooler
              P026A 00 [096] - Efficiency Below Threshold
    Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
       Part No SW: 0C8 927 750 AK    HW: 0C8 927 750 AK
       Component: AL1000 AISIN  001 2269
       Coding: 001368
       ASAM Dataset: EV_TCMAL991031 002114
       ROD: EV_TCMAL991031_VW52.rod
       VCID: 75E1DD63D44261894D9-8020
    Address 03: ABS Brakes (J104)       Labels: 7P0-907-379.clb
       Part No SW: 7P0 907 379 M    HW: 7P0 907 379 A
       Component: MK25A         H36 0436
       Revision: --------    Serial number: 423120010EC815
       Coding: 5B7613C349242559DAF8C89A92D5A4407300
       ROD: EV_ESPMK25A00800.rod
       VCID: 479D67ABFE2EA319EF5-8012
       Slave 1:
    Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.CLB
       Part No SW: 4H0 907 064 CK    HW: 4H0 907 064 CK
       Component: BCM2 2.0      H32 0421
       Coding: 09860010000000000000
       VCID: 74E7E067D73878817A7-8021
       Subsystem 1 - Part No SW: 7P6 959 754 AD    HW: 7P6 959 754 AD
       Component: FBSTOUAREGIDG  H04 0051
       Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
    Address 08: Auto HVAC (J255)       Labels: 7P6-907-040.clb
       Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
       Component: Klima 2 Zonen H20 1305
       Coding: B606200A80
       VCID: 7EF3C24FE17422D11C3-802B
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.CLB
       Part No SW: 4H0 907 063 BL    HW: 4H0 907 063 D
       Component: BCM1 2.0      H12 0111
       Revision: 15012002    Serial number: 00000001594314
       Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
       VCID: 73E5E37BD2367FB963D-8026
       Component: WWS    120820  31  0020
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
       Component: RLFS  H09 0011
       Coding: 025223
       Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
       Component: E1 - LDS  H04 0031
       Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0020
       Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
       Component: VW10Airbag025 H05 0025
       Revision: --------    Serial number: 003L0004KY40
       Coding: 000000000000000000000000000000003235
       ROD: EV_AirbaVW10BPAVW526.rod
       VCID: 418979B3D00A9D29211-8014
       Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
       Component: BF-Gewichtss.  003 0005
       Serial number: 5850000R12601093FT
       Serial number: 3575LRB404T1G7FG68KX
       Serial number: 3585LRB405L1G7FCC089
       Serial number: 3515RRB40691GLOO98PB
       Serial number: 3525RRB40691GLOOJGKP
       Serial number: 3555NRB405R1GCDMMOQ-
       Serial number: 3565NRB405R1GCDMEPNR
    Address 16: Steering wheel (J527)       Labels: 4H0-953-568.CLB
       Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
       Revision: --------    Serial number: 90815LHR0001J
       Coding: 000015
       VCID: 36631A6F81C42A91843-8063
       Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
       Component: E221__MFL-TAS  H03 0027
    Address 17: Instruments (J285)       Labels: 7P6-920-xxx-17.clb
       Part No SW: 7P6 920 981 F    HW: 7P6 920 981 F
       Component: Kombi         H13 0318
       Revision: 13240077    Serial number: 658220812592019
       Coding: 8B7733022B00CF05020004
       ASAM Dataset: EV_KombiUDSRBVW526 001017
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 408F7CB7DB0094212EF-8015
       Part No SW: 7P6 907 530 F    HW: 7P6 907 530 F
       Component: GW-CAN-L-MOST H11 6028
       Revision: --------    Serial number: 00000000656045
       Coding: 0001037500
       ROD: EV_GatewUDS_VW52.rod
       VCID: 3B750B5BB2E6F7F97BD-806E
       Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
       Component: Batt_Sensor  H07 0140
       Serial number: 00000000005650041674
              U140B 00 [008] - -
                        Reset counter: 143
                        Mileage: 62199 km
                        Date: 2015.03.07
                        Time: 13:13:21
    Address 36: Seat Mem. Drvr (J136)       Labels: NONE
       Revision: AA000000    Serial number: 00000037431534
       Coding: 0058130000004001000001010101202020202121202020
       VCID: 3467206797B83881BA7-8061
    Address 42: Door Elect, Driver (J386)       Labels: NONE
       Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
       Component: TSG FA        H07 0166
       Revision: --------    Serial number: 0000129998882
       Coding: 011D07205E00453005080000
       VCID: 448770A7C71888010A7-8011
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.CLB
       Revision: 00002001    Serial number: 0182129872
       Coding: 0186123A28B9509480A00620210000000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
       Component: GTO BT  H19 0059
       Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
       Component: J245 PS30.055  H01 0008
       Coding: 191100
       Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
       Component: J394 PS30.055  H01 0008
       Coding: 191100
    Address 52: Door Elect, Pass. (J387)       Labels: NONE
       Component: TSG BF        H07 0166
       Revision: --------    Serial number: 0000130015577
       VCID: 3B750B5BBAE6F7F97BD-806E
    Address 53: Parking Brake (J540-)       Labels: 7P0-907-801.clb
       Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: C1282000972
       Coding: 01040200
       ROD: EV_ParkbA7.rod
       VCID: 36631A6F89C42A91843-8063
       Slave 3:
    12656790 - Databus
                        Fault Frequency: 127
                        Reset counter: 0
                        Mileage: 6656 km
                        Date: 2105.02.19
                        Time: 01:61:02
       Coding: 010A00010F000400
       VCID: 7CF7C847F76830C1327-8029
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329
       Component: LeiMo links  H01 0002
       Coding: 130000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329
       Component: LeiMo rechts  H01 0002
       Coding: 130000
    Address 56: Radio (R)       Labels: REDIR FAIL!
       Part No SW: 4G0 035 082 D    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0112
       Revision: AB001007    Serial number: 156H00C7625672
       Coding: 020007020100000001
       VCID: 2149D933384ABD29411-8074
    Address 5F: Information Electr. (J794)       Labels: 4E0-035-6XX-5F.CLB
       Part No SW: 7P6 035 664 C    HW: 7P6 035 664
       Component: H-BN-NA       H45 0544
       Revision: --------    Serial number: 445HS0C7540220
       Coding: 010200050040E1EE41022B0C00000003F0000100
       VCID: 387F14578BD0DCE196F-806D
       Subsystem 1 - Part No: 8R0 060 884 AM
       Component: NAR 2012  0605
       Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: DU8 SV Touch  H26 0045
       Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: CD-Database  1886
                000 -  -
                        Reset counter: 16
                        Mileage: 446 km
                        Date: 2013.03.17
                        Time: 16:03:48
                        Bin. Bits: 00000000 00000000
                        Bin. Bits: 00000000 00010000
    Address 62: Door, Rear Left (J388)       Labels: NONE
       Component: TSG HL        H09 0167
       Revision: --------    Serial number: 0000129941366
       Coding: 011C07200000253005080000
       VCID: 3A7B0E5FB5DCCEF160B-806F
       Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
       Component: RDKBERU25     H09 0008
       Serial number: 10000000091248
       ROD: EV_RDKBERU25_VW52.rod
       VCID: 3F8D7F4BA6FEEBD9575-806A
    Address 69: Trailer (J345)       Labels: NONE
       Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
       Component: Anhaenger     H09 0110
       Revision: 5A001001    Serial number: 00000181794436
       Coding: 020D000000000000
    Address 6C: Back-up Cam.        Labels: 4L0-910-441.CLB
       Part No SW: 7P6 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0020
       Revision: 00H06000    Serial number: 525 PA8J272294
       Coding: 0110001
       VCID: 377D176B46CED3999F5-8062
    Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
       Part No SW: 7P6 959 107 A    HW: 7P6 959 107
       Component: HDSG-Modul    H10 0620
       Revision: 22010001    Serial number: 227200134
       Coding: 0533314003
       ASAM Dataset: EV_HeckkTouar 202137
       ROD: EV_HeckkTouar.rod
       VCID: 3D710543ACF2F9C9459-8068
    Address 72: Door, Rear Right (J389)       Labels: NONE
       Component: TSG HR        H09 0167
       Revision: --------    Serial number: 0000129884593
    End---------------------(Elapsed Time: 20:52, Deb=2)-----------------------
  5. #15
    Nov 2014
    Los Angeles CA.
    17 Instrument cluster Map
    ;SW:7P6-920-981-F   HW:7P6-920-981-F ---  Instruments
    ;Component:Kombi         H13 0318	 Coding:8B7733022B00CF05020004
    ;EV_KombiUDSRBVW526	1017	EV_KombiUDSRBVW526.rod
    ;Friday	17	April	2015	09:35:43:33623
    ;VCDS Version: Release 14.10.2 (x64)  Data version: 20150311
    ;VCID: 408F7CB7DB0094212EF-8015
    Automatic door locking	No display
    (1)-Configuration of driver information system-Drive time	active
    (2)-Configuration of driver information system-Current consumption	active
    (3)-Configuration of driver information system-Average consumption	active
    (4)-Configuration of driver information system-Average speed	active
    (5)-Configuration of driver information system-Daily distance driven	active
    (6)-Configuration of driver information system-Range	active
    (7)-Configuration of driver information system-Oil temperature	not active
    Counter of sporadic MOST-ring disruptions	0
    Day	17
    Day counter	777 Days
    Deactivate seat belt warning	No
    Display correction of consumptions and operating range	100%
    Distance	63907 km
    Driving profiled for range remaining	9.2
    ESI: distance driven from inspection	0 km
    ESI: maximum value km-driving distance/inspection	16100 km
    ESI: maximum value of time between inspections	365 Days
    ESI: minimum value km-driving distance/inspection	16100 km
    ESI: minimum value of time between inspections	365 Days
    ESI: oil quality	poor oil quality
    ESI: Resetting ESI	no warning
    ESI: soot entry	0 km
    ESI: thermal load	0 km
    ESI: time from inspection	1 Days
    FIX: Distance covered since last mileage-dependent inspection	72400 km
    Fix: Max. distance until next mileage-related inspection	64400 km
    FIX: Maximum time until next time-dependent inspection	1460 Days
    FIX: Time since last time-dependent inspection	777 Days
    Hour	9 H
    Language version	US English
    Minute	32 min
    Month	4
    MOST light performance	Decrease 0 dB
    (1)-Offset for tank calibration values-Offset sensor 1	-12.8 l
    (2)-Offset for tank calibration values-Offset sensor 2	-12.8 l
    (3)-Offset for tank calibration values-Offset sensor 3	12.7 l
    (4)-Offset for tank calibration values-Offset sensor 4	12.7 l
    (5)-Offset for tank calibration values-Complete tank calibration	-12.8 l
    SIA: maximum value of distance to service	16100 km
    SIA: maximum value of time to service	365 Days
    Source for synchronization of time	internal clock
    (1)-Speed warning-	not active
    (2)-Speed warning-Unit	Miles per hour
    (3)-Speed warning-Speed	20
    Timer of sporadic MOST-ring disruptions	15000 ms
    (1)-Units adjusted-Temperature	°F
    (2)-Units adjusted-Distance	miles
    (3)-Units adjusted-Speed	Miles per hour
    (4)-Units adjusted-Pressure	psi
    (5)-Units adjusted-Volume	gallons (US)
    (6)-Units adjusted-Time	12h AM_PM
    (7)-Units adjusted-Date	mm_dd_yy
    (8)-Units adjusted-Consumption	Miles per gallon (US)
    (9)-Units adjusted-Average consumption; electric drive	kWh per 100 km
    Year	2015
    (1)-animation_speeds-p_t_fade_out_time_content	100 ms
    (2)-animation_speeds-p_t_reiteranim_sandstill	200 ms
    (3)-animation_speeds-BC_p_t_bc_scroll	480 ms
    (4)-animation_speeds-p_t_fade_in_time_content	200 ms
    (5)-animation_speeds-p_t_small_bc_scroll	250 ms
    (6)-animation_speeds-WARN_p_t_small_bc_scroll	250 ms
    (7)-animation_speeds-p_t_MOST_fadeout_time	100 ms
    (8)-animation_speeds-p_kopplung_reiter_contentfading	0 ms
    (9)-animation_speeds-p_t_fast_caroutline_fading	150 ms
    (10)-animation_speeds-p_t_listcursor	100 ms
    (11)-animation_speeds-p_t_pageflip	350 ms
    (12)-animation_speeds-p_t_cursor_fade	75 ms
    (13)-animation_speeds-p_t_tpafade	300 ms
    (14)-animation_speeds-p_t_load_icon_rotate	2000 ms
    (15)-animation_speeds-p_pt1_compass_T	1500 ms
    (16)-animation_speeds-p_dssa_fadeout_time	100 ms
    (17)-animation_speeds-p_cursor_change_speed	100 ms
    (18)-animation_speeds-p_NV_	300 ms
    (19)-animation_speeds-p_t_RGI_fade	250 ms
    (20)-animation_speeds-p_t_MOST_fadein_time	300 ms
    (21)-animation_speeds-WURM_p_t_reiteranim_duration	100 ms
    (1)-animation_speeds_engine_maps_1-p_t_reiteranim_duration_X1	0%
    (2)-animation_speeds_engine_maps_1-p_t_reiteranim_duration_X2	20%
    (3)-animation_speeds_engine_maps_1-p_t_reiteranim_duration_X3	40%
    (4)-animation_speeds_engine_maps_1-p_t_reiteranim_duration_X4	60%
    (5)-animation_speeds_engine_maps_1-p_t_reiteranim_duration_X5	90%
    (6)-animation_speeds_engine_maps_1-p_t_reiteranim_duration_X6	100%
    (7)-animation_speeds_engine_maps_1-p_t_reiteranim_duration_Y1	0%
    (8)-animation_speeds_engine_maps_1-p_t_reiteranim_duration_Y2	10%
    (9)-animation_speeds_engine_maps_1-p_t_reiteranim_duration_Y3	35%
    (10)-animation_speeds_engine_maps_1-p_t_reiteranim_duration_Y4	70%
    (11)-animation_speeds_engine_maps_1-p_t_reiteranim_duration_Y5	85%
    (12)-animation_speeds_engine_maps_1-p_t_reiteranim_duration_Y6	100%
    (13)-animation_speeds_engine_maps_1-p_t_small_bc_scroll_X1	0%
    (14)-animation_speeds_engine_maps_1-p_t_small_bc_scroll_X2	20%
    (15)-animation_speeds_engine_maps_1-p_t_small_bc_scroll_X3	40%
    (16)-animation_speeds_engine_maps_1-p_t_small_bc_scroll_X4	60%
    (17)-animation_speeds_engine_maps_1-p_t_small_bc_scroll_X5	90%
    (18)-animation_speeds_engine_maps_1-p_t_small_bc_scroll_X6	100%
    (19)-animation_speeds_engine_maps_1-p_t_small_bc_scroll_Y1	0%
    (20)-animation_speeds_engine_maps_1-p_t_small_bc_scroll_Y2	10%
    (21)-animation_speeds_engine_maps_1-p_t_small_bc_scroll_Y3	35%
    (22)-animation_speeds_engine_maps_1-p_t_small_bc_scroll_Y4	70%
    (23)-animation_speeds_engine_maps_1-p_t_small_bc_scroll_Y5	85%
    (24)-animation_speeds_engine_maps_1-p_t_small_bc_scroll_Y6	100%
    (25)-animation_speeds_engine_maps_1-p_t_bc_scroll_X1	0%
    (26)-animation_speeds_engine_maps_1-p_t_bc_scroll_X2	20%
    (27)-animation_speeds_engine_maps_1-p_t_bc_scroll_X3	40%
    (28)-animation_speeds_engine_maps_1-p_t_bc_scroll_X4	60%
    (29)-animation_speeds_engine_maps_1-p_t_bc_scroll_X5	90%
    (30)-animation_speeds_engine_maps_1-p_t_bc_scroll_X6	100%
    (31)-animation_speeds_engine_maps_1-p_t_bc_scroll_Y1	0%
    (32)-animation_speeds_engine_maps_1-p_t_bc_scroll_Y2	10%
    (33)-animation_speeds_engine_maps_1-p_t_bc_scroll_Y3	35%
    (34)-animation_speeds_engine_maps_1-p_t_bc_scroll_Y4	70%
    (35)-animation_speeds_engine_maps_1-p_t_bc_scroll_Y5	85%
    (36)-animation_speeds_engine_maps_1-p_t_bc_scroll_Y6	100%
    (1)-animation_speeds_engine_maps_2-p_t_listcursor_X1	0%
    (2)-animation_speeds_engine_maps_2-p_t_listcursor_X2	20%
    (3)-animation_speeds_engine_maps_2-p_t_listcursor_X3	40%
    (4)-animation_speeds_engine_maps_2-p_t_listcursor_X4	60%
    (5)-animation_speeds_engine_maps_2-p_t_listcursor_X5	90%
    (6)-animation_speeds_engine_maps_2-p_t_listcursor_X6	100%
    (7)-animation_speeds_engine_maps_2-p_t_listcursor_Y1	0%
    (8)-animation_speeds_engine_maps_2-p_t_listcursor_Y2	10%
    (9)-animation_speeds_engine_maps_2-p_t_listcursor_Y3	35%
    (10)-animation_speeds_engine_maps_2-p_t_listcursor_Y4	70%
    (11)-animation_speeds_engine_maps_2-p_t_listcursor_Y5	85%
    (12)-animation_speeds_engine_maps_2-p_t_listcursor_Y6	100%
    (13)-animation_speeds_engine_maps_2-p_t_pageflip_X1	0%
    (14)-animation_speeds_engine_maps_2-p_t_pageflip_X2	20%
    (15)-animation_speeds_engine_maps_2-p_t_pageflip_X3	40%
    (16)-animation_speeds_engine_maps_2-p_t_pageflip_X4	60%
    (17)-animation_speeds_engine_maps_2-p_t_pageflip_X5	90%
    (18)-animation_speeds_engine_maps_2-p_t_pageflip_X6	100%
    (19)-animation_speeds_engine_maps_2-p_t_pageflip_Y1	0%
    (20)-animation_speeds_engine_maps_2-p_t_pageflip_Y2	10%
    (21)-animation_speeds_engine_maps_2-p_t_pageflip_Y3	35%
    (22)-animation_speeds_engine_maps_2-p_t_pageflip_Y4	70%
    (23)-animation_speeds_engine_maps_2-p_t_pageflip_Y5	85%
    (24)-animation_speeds_engine_maps_2-p_t_pageflip_Y6	100%
    (1)-Development_Mode_Message-Block 1	OFF
    (2)-Development_Mode_Message-send messages	active
    (3)-Development_Mode_Message-Block 2	OFF
    (4)-Development_Mode_Message-Block 3	OFF
    (5)-Development_Mode_Message-Block 4	OFF
    (6)-Development_Mode_Message-Block 5	OFF
    (7)-Development_Mode_Message-Block 6	OFF
    (8)-Development_Mode_Message-Block 7	OFF
    (9)-Development_Mode_Message-Block 8	OFF
    (10)-Development_Mode_Message-Block 9	OFF
    (11)-Development_Mode_Message-Block 10	OFF
    (12)-Development_Mode_Message-Block 11	OFF
    (13)-Development_Mode_Message-Block 12	OFF
    (14)-Development_Mode_Message-Block 13	OFF
    (15)-Development_Mode_Message-Block 14	OFF
    (16)-Development_Mode_Message-Block 15	OFF
    (17)-Development_Mode_Message-Block 16	OFF
    (18)-Development_Mode_Message-Block 17	OFF
    (19)-Development_Mode_Message-Block 18	OFF
    (20)-Development_Mode_Message-Block 19	OFF
    (1)-dimming_characteristic_curve_adjustment_clock_dial_day-X1	0
    (2)-dimming_characteristic_curve_adjustment_clock_dial_day-Y1	0
    (3)-dimming_characteristic_curve_adjustment_clock_dial_day-X2	160
    (4)-dimming_characteristic_curve_adjustment_clock_dial_day-Y2	0
    (5)-dimming_characteristic_curve_adjustment_clock_dial_day-X3	200
    (6)-dimming_characteristic_curve_adjustment_clock_dial_day-Y3	400
    (7)-dimming_characteristic_curve_adjustment_clock_dial_day-X4	220
    (8)-dimming_characteristic_curve_adjustment_clock_dial_day-Y4	700
    (9)-dimming_characteristic_curve_adjustment_clock_dial_day-X5	253
    (10)-dimming_characteristic_curve_adjustment_clock_dial_day-Y5	1000
    (1)-dimming_characteristic_curve_adjustment_clock_dial_night-X1	0
    (2)-dimming_characteristic_curve_adjustment_clock_dial_night-Y1	0
    (3)-dimming_characteristic_curve_adjustment_clock_dial_night-X2	76
    (4)-dimming_characteristic_curve_adjustment_clock_dial_night-Y2	30
    (5)-dimming_characteristic_curve_adjustment_clock_dial_night-X3	127
    (6)-dimming_characteristic_curve_adjustment_clock_dial_night-Y3	280
    (7)-dimming_characteristic_curve_adjustment_clock_dial_night-X4	147
    (8)-dimming_characteristic_curve_adjustment_clock_dial_night-Y4	400
    (9)-dimming_characteristic_curve_adjustment_clock_dial_night-X5	253
    (10)-dimming_characteristic_curve_adjustment_clock_dial_night-Y5	1000
    (1)-dimming_characteristic_curve_adjustment_extra_field-X1	0
    (2)-dimming_characteristic_curve_adjustment_extra_field-Y1	0
    (3)-dimming_characteristic_curve_adjustment_extra_field-X2	76
    (4)-dimming_characteristic_curve_adjustment_extra_field-Y2	30
    (5)-dimming_characteristic_curve_adjustment_extra_field-X3	127
    (6)-dimming_characteristic_curve_adjustment_extra_field-Y3	350
    (7)-dimming_characteristic_curve_adjustment_extra_field-X4	147
    (8)-dimming_characteristic_curve_adjustment_extra_field-Y4	500
    (9)-dimming_characteristic_curve_adjustment_extra_field-X5	253
    (10)-dimming_characteristic_curve_adjustment_extra_field-Y5	1000
    (1)-dimming_characteristic_curve_adjustment_gauge-X1	0
    (2)-dimming_characteristic_curve_adjustment_gauge-Y1	0
    (3)-dimming_characteristic_curve_adjustment_gauge-X2	25
    (4)-dimming_characteristic_curve_adjustment_gauge-Y2	200
    (5)-dimming_characteristic_curve_adjustment_gauge-X3	50
    (6)-dimming_characteristic_curve_adjustment_gauge-Y3	450
    (7)-dimming_characteristic_curve_adjustment_gauge-X4	75
    (8)-dimming_characteristic_curve_adjustment_gauge-Y4	700
    (9)-dimming_characteristic_curve_adjustment_gauge-X5	100
    (10)-dimming_characteristic_curve_adjustment_gauge-Y5	1000
    (1)-dimming_characteristic_curve_adjustment_indicator_lights-X1	0
    (2)-dimming_characteristic_curve_adjustment_indicator_lights-Y1	0
    (3)-dimming_characteristic_curve_adjustment_indicator_lights-X2	76
    (4)-dimming_characteristic_curve_adjustment_indicator_lights-Y2	50
    (5)-dimming_characteristic_curve_adjustment_indicator_lights-X3	127
    (6)-dimming_characteristic_curve_adjustment_indicator_lights-Y3	210
    (7)-dimming_characteristic_curve_adjustment_indicator_lights-X4	147
    (8)-dimming_characteristic_curve_adjustment_indicator_lights-Y4	300
    (9)-dimming_characteristic_curve_adjustment_indicator_lights-X5	253
    (10)-dimming_characteristic_curve_adjustment_indicator_lights-Y5	1000
    (1)-dimming_characteristic_curve_adjustment_middle_display_main_field-X1	0
    (2)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1	0
    (3)-dimming_characteristic_curve_adjustment_middle_display_main_field-X2	76
    (4)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2	9
    (5)-dimming_characteristic_curve_adjustment_middle_display_main_field-X3	127
    (6)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3	161
    (7)-dimming_characteristic_curve_adjustment_middle_display_main_field-X4	147
    (8)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4	200
    (9)-dimming_characteristic_curve_adjustment_middle_display_main_field-X5	253
    (10)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5	1000
    (1)-outside_temperature-p_engine_on_detection	500
    (2)-outside_temperature-p_time_constant_pt1	40
    (3)-outside_temperature-p_time_constant_slow_damping	2
    (4)-outside_temperature-P_speed_threshold	20
    (5)-outside_temperature-p_tendency_threshold	1
    (6)-outside_temperature-p_kmt_at_delta	25
    (7)-outside_temperature-p_kmt_threshold	80
    (8)-outside_temperature-p_kmt_switch	active
    (9)-outside_temperature-p_blocking_time_status	0
    (10)-outside_temperature-p_blocking_time_after_v_bigger_0	15
    (11)-outside_temperature-p_storage_time_display_off	10
    (12)-outside_temperature-p_storage_time_engine_off	360
    (13)-outside_temperature-p_mileage_after_v_bigger_0	5
    (16)-outside_temperature-p_tendency_damping	15
    tank_validation	validation_deactivated
    (1)-time_parameter_display-tDDWUP	1.0 s
    (2)-time_parameter_display-tDD15_on	1.0 s
    (3)-time_parameter_display-tDD15_off	0.25
  6. Likes Dana liked this post
  7. #16
    United States
    This VW Touareg (7P) Instrument Cluster page will apply. The oil change is ESI: Resetting ESI but you need to reset both of these to 0:
    FIX: Distance covered since last mileage-dependent inspection 72400 km > to 0
    FIX: Time since last time-dependent inspection 777 Days > to 0
  8. Likes Uwe, victor35ma, roth liked this post
  9. #17
    Nov 2014
    Los Angeles CA.
    perfect it works.... thank you guys
  10. Likes Uwe, Dana liked this post
  11. #18
    United States
    I just spoke to a shop with P026A in a 2014 2.0L TDI NMS (NMS = NAR 2012+ Passat which is not a B8 like the RoW market) and found this thread. I'm not entirely sure if any of my recommendations will help with that car but I did locate a 2013 NAR Touareg flash update for a grocery list of DTCs including that one:
    P0299, P0403, P20EE, P2100, P0045, P2008, P24AF, P026A and last but not least P050E. This 2013 Touareg CNRB flash update applies specifically to 7P0-907-401-K and flashes the EDC to SWL 0004 or higher. See TSB # 01-13-12 if anyone ends up here with those codes stored.
  12. Likes Uwe liked this post
