VW Touareg (2006) level calibration question
N867LC
Texas
C?ID=199170
After some long and drawn out work. I'm trying to recalibrate the level control system on my Egg. I did this after I rebuilt the front end, but after a battery replace, and a few other system gremlins being chased out, the calibration has been lost.
I've followed the process, scanned the car, cleared the codes, found a few fuses put in the wrong places. Yet when I get to the save page in VCDS the vehicle gives me an error.
The vehicle goes through the motions of up and down. I'm sitting outside the vehicle so no open doors. The only code being thrown for the level control system is not calibrated.
Is there a hard reset, that needs to be done prior to going into the calibration mode?
Here is the scan if that helps.
Monday,30,March,2015,18:25:10:14552
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WVGPT77L06D054863   License Plate:
Mileage: 208880km-129792mi   Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGPT77L06D054863   Mileage: 208880km-129792miles
   Part No SW: 070 906 016 CQ    HW: 028 101 196 2
   Component: V10 5,0L EDCG000AGMª8472
   Revision: --H02---    Serial number: VWZ3Z0E6402710
   Coding: 0060575
   Shop #: WSC 31414 000 00000
   VCID: 61C95F86BB717229011-5140
   Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
   Component: AL 750 6A           0856
   Revision: 00H51000    Serial number:
   Coding: 0000008
   VCID: 7F0DF9FE2DC5A4D9175-5140
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0022786
   VCID: 3D71C3F6674976C9459-5140
            000 -  -  - Intermittent
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 137     HW: 5WK 484 92
   Component: G2 Kessy            6700
   Revision: 67005614    Serial number: VWZ3Z0E6402710
   Coding: 0131304
   VCID: 70EF2AC2609BCBA19EF-515E
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
00955 - Key 1
            002 - Lower Limit Exceeded
00956 - Key 2
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77FD11DE05F59C995F5-5140
Address 08: Auto HVAC        Labels: 7L6-907-044.clb
   Part No: 7L6 907 044 T
   Component: CLIMAtronic 2+2     4222
   Coding: 0020030
   VCID: 4581AB160F993E091D9-5140
   Subsystem 1 - Part No: 7L6 907 049 E
   Component: CLIMAtronic FOND    0400
02379 - Positioning Motor for Left Side Vent (V299)
02600 - Rear Right Temperature Flap Motor (V314)
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 N
   Component:                     3001
   Coding: 0111836
   VCID: 479DA11E35952C19EF5-5140
00070 - Starting Battery Voltage
Address 11: Engine II        Labels: Redir Fail!
   Component: V10 5,0L EDCG000AGSª8472
   Coding: 0060575
   VCID: 61C95F86BB717229011-515E
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 000 -  - Intermittent
                    Mileage: 208878 km
                    RPM: 672 /min
                    Voltage: 11.55 V
                    Bin. Bits: 00001011
                    Bin. Bits: 00000000
                    (no units): 0.0
005782 - Powertrain Data Bus
               P1696 - 000 - Implausible Message from Steering Column Controller - Intermittent
                    Mileage: 208878 km
                    RPM: 672 /min
                    Voltage: 11.55 V
                    Bin. Bits: 00001011
                    Bin. Bits: 00000000
                    (no units): 0.0
012547 - Motor for Intake Manifold Flap (V157)
               P3103 - 000 - Malfunction - Intermittent
                    Mileage: 208882 km
                    RPM: 588 /min
                    Voltage: 13.38 V
                    Bin. Bits: 00001000
                    Torque: 331.8 Nm
                    Torque: 0.0 Nm
   Part No: 3D0 909 601 H
   Component: 05 Airbag 8.4E++H02 0562
   Revision: BB38727     Serial number: 0010170?
   Coding: 0012341
   Shop #: WSC 25053 444 59338
   VCID: 285F02A298CBC36106F-5140
   Subsystem 1 - Part No: 7L0 959 339 E
   Component: BF-Gewichtsens. 007 0009
   Part No: 7L6 953 549 H
   Component: Lenksäulenmodul     3401
   Coding: 0010032
   VCID: 4487B61204A307010A7-515E
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 981 R
   Component: KOMBIINSTRUMENT RB8 3211
   Coding: 0005231
   VCID: 489FA222388B2361E6F-5140
02053 - Control Module for Transfer Case (J646)
01517 - Control Module for Trailer/Towing Sensor (J345)
00464 - Control Module with Display for Radio and Navigation (J503)
Address 18: Aux. Heat        Labels: 7L6-819-008.lbl
   Part No: 7L6 815 071 D
   Component: Standheizung E1MAC
   Coding: 0000100
   VCID: 3365E5CE510DB0B9A3D-5140
02251 - Heater Unit Locked
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70EF2AC2609BCBA19EF-5140
6 Faults Found:
00484 - Vehicle Position Recognition Control Module (J603)
01308 - Control Module for Roof Electronics (J528)
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879 A
   Component: JCI PathPoint       2200
02519 - Display Module for Roof (J702)
   Part No: 0AD 927 755 BG
   Component: TRANSFERCASE        0126
   VCID: 01097F065B31D229611-5140
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000003
   VCID: 66C34C9A525F1511F43-5140
00492 - Body Pitch Angle from Level Control Module
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   VCID: 3663DCDA427FA591843-5140
01437 - Control Position not Learned
02332 - Position Sensor for Backrest Adjustment (G440)
01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
01915 - Lumbar Support Height Adjustment Sensor (G374)
   Part No: 3D0 909 158
   Coding: 0000003
   VCID: 67DD419E55550C19CF5-5140
   Part No: 7L0 959 933 J
   Component:    HSG              5115
   Coding: 0000085
   VCID: 4385B50E01AD003933D-4B1A
   Subsystem 1 - Part No: 7L0 959 701 H
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 H
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 D
   Subsystem 4 - Part No: 7L0 959 704 D
12 Faults Found:
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
00576 - Terminal 15
00329 - Control Circuit for Unlocking Rear Lid
00901 - Back-Up Lamps
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 K
   Component: Front Wiper         4027
   Coding: 0000341
   Shop #: WSC 31414 000 376832
   VCID: 3C77CEF27C537FC1727-515E
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 N    HW: 7L0 907 383 N
   Component: J345  Anhaenger     0080
   Revision: 4A009001    Serial number: 00000193524428
   Coding: 0016385
   VCID: 3F8DB9FE6D4564D9575-5140
                    Reset counter: 40
   Part No SW: 7L6 907 441     HW: 7L6 907 441
   Component: J772__Rearview      0051
   Revision: 00H07000    Serial number:    PA8 J670048
   Coding: 0000101
   Shop #: WSC 25053 444 85538
   VCID: 72EB20CA6E97F9B168B-5140
03006 - Back-up Camera System not calibrated
                    Reset counter: 118
                        Invalid
                        Invalid
                        Invalid
03008 - Supply Voltage for Back-Up Camera
                    Fault Frequency: 62
                    Reset counter: 50
                        Reverse OFF
                    Count: 3
02203 - Audio / Video Input 1
                    Reset counter: 10
                        Reverse OFF
                    Count: 3
                    Reset counter: 10
                        Reverse OFF
                    Count: 3
Address 6E: Ctrl Head Roof        Labels: 7L6-919-044.lbl
   Part No: 7L6 919 044 T
   Component: DACHDISPLAY         0539
   Revision: 00900539    Serial number: 2009289.07
   VCID: 489FA222388B2361E6F-515E
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   VCID: 3979D7E673614AE9691-5140
00431 - Rear Parking Aid Display (Y15)
End-------------------------(Elapsed Time: 07:54)--------------------------
roth
C?ID=242642
You mentioned, you did some work on the front end. I've seen the level sensors installed incorrectly many times. You might want to double check that. Maybe read relevamt MVBs and post it here.
BTW post between code tags to save space.
Andy
At which "Save" page are you getting an error? You're supposed to put actual measured heights as new values into Adaptation Channels 01 to 04, and then an 01 as the new value into channel 05. How far are you getting with this? What are the measured values you're putting into channels 01 - 04?
I agree with Andy. Let's see the measuring values. Easiest way is to run a map.
[Applications]
[Controller Channel Map]
Controller Address = 34
Login or security code: Leave blank
Function: Measuring blocks
Output: CSV file
[Go]
The best thing to do with the resulting file is to upload it to a Google spreadsheet and link it here, although you could paste it into the body of a message (using CODE tags please) as well.
N867LC
Texas
C?ID=199170
Andy,
I know the level sensors are installed correctly. As I did them prior to the front end rebuild, I was able to calibrate the ride height system after the rebuild. It was after I started into a gremlin chasing exercise that I replaced the batteries and a few other modules in the rear of the vehicle and lost the ride calibration during this process. You can see I still need to set the steering angle sensor, just haven't got to that just yet.
Uwe,
I get the error on channel 05, where I am to change the setting to a "1" and save. All the values from channel 01 to 04 are input, tested, and saved before going to the next channel (in order). The vehicle goes into the calibration mode, and the values at the corners are FL-496, FR-496, RL-496, RR-498.
I will run the diagnostic above shortly and post here.
I apologize, but I don't recall how to input the data between the code tags...
DrPeter
16.4905° S, 151.7375° W
- If you have entered the above values and the controller refuses or gives an error on the last adaptation, ch.05, this typically means one of the ride height values is just out of spec.
Based on the VIN number and the PR-code [1BK] the specified ride height values should be:
1BK:
Front = [497mm +/-3mm] - (494mm to 500mm)
Rear = [502mm +/- 3mm] - (499mm to 505mm)
Try to enter the values again, this time stay within 3mm of the of the specified ride height values and then see if adaptation ch.05 saves correctly.
Hope this helps,
drpeter
N867LC
Texas
C?ID=199170
roth
C?ID=242642
Each time you try basic settings, turn the ignition off for 15 seconds. Peter means to enter values that are within the range. Front is OK but rear enter 500. Then you will repeat the adaptation again. One more thing, set both switches on the center console to AUTO.
BR, Andy
N867LC
Texas
C?ID=199170
In this last process, I let VCDS sit on each channel a while, I saw that channel 01 (front left) would indicate a valid entry (new value and test), but then occasionally flash invalid (in green and very quickly) then back to valid. All other channels 02-04 do not do this. This makes me think a bad or marginal sensor.
roth
C?ID=242642
Possible, plug might be corroded, how about unplugging it / plugging it back a couple of times. Maybe spray some WD-40 to remove moisture?
Andy
N867LC
Texas
C?ID=199170
The system allowed me to calibrate it and accept the values added. 497 fronts and 500 rears. The only real change was that I put BOTH level switches on the console in AUTO.
The only thing different was the console switches both set to AUTO. I did nothing different in my procedures. So this may want to be noted in the wiki.
Thanks all!
roth
C?ID=242642
Yeah, the da book saz put both of them on AUTO and you put 500 like Peter said. Glad U got it.:D Now drive it for a day or two and try to adopt again putting the real values in.
BR, Andy
N867LC
Texas
C?ID=199170
Crap! I didn't see that in the wiki. I really love this "little" truck but I swear, troubleshooting it is like a monkey getting serious with a football!
