AUDI a3 8v Cruise Control Retrofit (big problem)
azet
Poland
C?ID=123840
Hi, I'm from Poland, and i'm sory if my english is sometimes hard to understand :D
I'm new here, so i'm not verified yet and i'm not allowed to post in this tread :
http://forums.ross-tech.com/showthr...se-Control-retrofit&highlight=cruise+retrofit
But i've the same problem. I can tell that I put correct login in every modul that should be coded with CCS coding (Engine, Steering wheel , and Instrument Cluster is adapted to cruise control). The problem is that I bought second hand Stalk and Audi dealer says they can do SVM configuration only if I buy a new OEM part from them.
It's frustrating because I was sure that retrofitting a CCS will be easy and quick.... I had another a3 in my garage for a while, and I took an autoscan of it - I can't find any differences in coding, parts number nor software version. the second A3 has a few modules more so there are some differences in coding, but everything is clear and it's easy to understand the Coding. I wonder only if the ABS module have to be re coded too - i didn't find any information about this coding.
Im pretty sure that there are some differences in adaptation in engine module or Can Gataway, but i can not find them...
similar situation in Golf 7, Skoda Octavia 3, and the new seat leon , so its not only Audi issue...
Can You help with any sugestion ...
there are autoscans :
ONE from car that with retrofited CCS :
Wednesday,25,March,2015,18:40:30:29512
VCDS Version: 15.3.0.0
Data version: 20150314
VIN: WAUZZZ8V3FA067600   License Plate: MIRKA SKAN KONCOWY
Mileage: 7km-4mi   Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V3FA067600   Mileage: 7km-4miles
Address 01: Engine (J623-CZCA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 DA    HW: 04E 907 309 AC
   Component: 1.4l R4 TSI   H21 7989
   Revision: R7H21---
   Coding: 02250032232405082000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM14TFS01104E906027DA 001009
   ROD: EV_ECM14TFS01104E906027DA_AU37.rod
   VCID: 66C94E49991485085D-8033
21472 - Databus
          U1122 00 [039] - Implausible Message
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 17:36:45
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 17:36:46
17923 - Databus
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 17:36:44
Readiness: 1110 0001
   Part No SW: 0CW 300 047 S    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5201
   Revision: 00043014    Serial number: CU501409175862
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_AU37.rod
   VCID: 4B9F9FFDE2B6586062-801E
   Revision: 00000000    Serial number: 62644000002877
   Coding: 12F16AA224261273037D060041C32948562448C0608294F3002100788608
   ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
   VCID: 458BA9C5C4D2AE10B4-8010
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [008] - -
                    Reset counter: 42
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 18:47:15
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Revision: 20026000    Serial number: 00000000447017
   Coding: 03000004000000001000000000001000
   VCID: 3261E219655C29A801-8067
459023 - Databus
                    Reset counter: 42
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 16:42:02
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011426305863
   Coding: 04041A42C24122F503844004B31C07080000000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 000578D19B704B38C7-8055
   Slave 1:
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119
   Component: WWS370 140819  042 0580
   Serial number:         140912133641
   Coding: 0A47F7
   Slave 2:
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Serial number: 23240920
   Coding: 00006C
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 K    HW: 8V0 941 531 K
   Serial number: 09 06 2014  00000023
   Serial number: 000000000ZY142372FJ7
   Serial number: 00000000000060618040
541973 - Databus
                    Reset counter: 42
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 16:42:04
542229 - Databus
                    Reset counter: 42
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 16:42:04
542485 - Databus
                    Reset counter: 42
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 16:42:11
555541 - Databus
                    Reset counter: 42
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 16:42:04
559125 - Databus
                    Reset counter: 42
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 16:42:11
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39331427306029
   Coding: 0010050011
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 4281B2D9D5FC992891-8017
13637426 - Databus
                    Reset counter: 42
                    Mileage: 7 km
                    Date: 2015.03.24
                    Time: 19:50:49
   Serial number: 003M2R08KANT
   Coding: 98CCC0000C0000005C5400CA004800000065
   Subsystem 1 - Part No SW: -----------    HW: 480 002 509 14
   Serial number: 35767000000B5798511W
   Subsystem 2 - Part No SW: -----------    HW: 480 002 509 14
   Serial number: 358670000007F698511
   Subsystem 3 - Part No SW: -----------    HW: 480 401 709 14
   Serial number: 351650299176A6B4A23E
   Subsystem 4 - Part No SW: -----------    HW: 480 401 709 14
   Serial number: 352650299176A6B390EM
   Subsystem 5 - Part No SW: -----------    HW: 480 402 208 14
   Serial number: 35565029D16C6CE4425S
   Pedestrian protection crash sensor; driver side:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 809 14
   Serial number: 2286502C7175A8E3C18R
   Pedestrian protection crash sensor; front passenger side:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 908 14
   Serial number: 2296502C3175A8E0C33I
   Center pedestrian protection crash sensor:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 809 14
   Serial number: 2306502C3175A8D372DG
          B1000 1B [136] - Resistance Too High
                    Mileage: 7 km
                    Date: 2015.03.24
                    Time: 20:26:06
   Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 27091404400052
   Coding: A418
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 06096EC9B9546508FD-8053
   Part No SW: 8V0 920 871     HW: 8V0 920 871
   Component: KOMBI         H02 4291
   Coding: 07A509082B8000080700A8001000000000000000
   VCID: 79F31535F8AA1AF080-802C
16776971 - Databus
                    Reset counter: 42
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 16:42:02
16776988 - Databus
                    Reset counter: 42
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 16:42:02
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002497644
   Coding: 030100042F0857005B000248180B00000001010000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_AU37.rod
   Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
   Serial number: 17 09 2014  B0047376
   Serial number: 1069034603
   Serial number: 01091401100339
   Coding: 001C8E204000040000001002
   VCID: 4085B8D1DBF08B3887-8015
458803 - Databus
                    Reset counter: 42
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 16:42:03
   Coding: 0103
   ROD: EV_SteerAssisMQB.rod
   VCID: 4183BDD5D0FA823088-8014
   Serial number: 13091403111262
   Coding: 001C86204000040000001002
   VCID: 3F87BB2DA60EF4C0FE-806A
458803 - Databus
                    Reset counter: 42
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 16:42:03
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 019A000001000000
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   VCID: 75EB1905D4B27E90E4-8020
13705475 - Databus
                    Reset counter: 42
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 16:42:05
   Part No SW: 8V0 035 864 B    HW: 8V0 035 864 B
   Component: MU-S-N-ER     041 0420
   Serial number: A3F02609140887
   Coding: 01730301FF0A000021110001000A00002F0001440100010006
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE_AU37.rod
   VCID: 3A71CA39BD2CD1E8C9-806F
   Seat Adjustment Driver Side:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0013
   Serial number: AUZ8Z9EY306DT9
   Sound System:
   Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Serial number: C1000016091400020105
6708 - Databus
                    Reset counter: 42
                    Mileage: 7 km
                    Date: 2015.03.25
                    Time: 16:42:08
End-------------------------(Elapsed Time: 04:13)--------------------------
and the second a3 with CCS as standard equipment..
Wednesday,25,March,2015,17:28:01:29512
VIN: WAUZZZ8V7FA041842   License Plate: TESTOWKA A3 GROBEL
Mileage: 8389km-5212mi   Repair Order:
Scan: 01 02 03 08 09 10 15 16 17 19 20 42 44 52 55 5F
VIN: WAUZZZ8V7FA041842   Mileage: 8389km-5212miles
Address 01: Engine (J623-CZEA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BL    HW: 04E 907 309 AB
   Component: 1.4l R4 TSI   H21 8139
   Revision: R6H21---
   Coding: 02250032232401082000
   ASAM Dataset: EV_ECM14TFS01104E906027BL 001006
   ROD: EV_ECM14TFS01104E906027BL.rod
   VCID: 6FE72B6DB6EE44402E-803A
4509 - Internal Control Module
          P1640 00 [101] - EEPROM Error
                    Mileage: 1399 km
                    Time: 00:00:00
   Part No SW: 0CW 300 047 T    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5202
   Revision: 00043014    Serial number: CU501407235645
   VCID: 4C9D9CE1E7B85F586B-8019
   Revision: 00000000    Serial number: 62014000006647
   Coding: 12F16AA22424126D037F060441C52948562448C0608294F3022100788608
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 103
                    Mileage: 7575 km
                    Date: 2015.03.17
                    Time: 15:46:07
   Revision: 20026000    Serial number: 00000000388527
   Coding: 03000004000000011000000000001100
   VCID: 336FE71D9A4620A00A-8066
   Serial number: 01011420304128
   Coding: 04041B46C24122FD03844004B31C07A80000000000000000000000000000
   Slave 1:
   Component: WWS370 140714  042 0580
   Serial number:         140719165958
   Coding: 0A47F7
   Slave 2:
   Serial number: 22959974
   Coding: 00006C
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
   Serial number: 17 05 2014  00000230
   Serial number: 000000000ZY1416347NP
   Serial number: 00000000000060190488
   Revision: --------    Serial number: 39331420902945
   Coding: 0030050011
   Serial number: 003M2R07U7V0
   Subsystem 1 - Part No SW: -----------    HW: 480 002 807 14
   Serial number: 35767000000D3A70801R
   Subsystem 2 - Part No SW: -----------    HW: 480 002 807 14
   Serial number: 358670000007B970801T
   Subsystem 3 - Part No SW: -----------    HW: 480 402 507 14
   Serial number: 3516502B31656B965267
   Subsystem 4 - Part No SW: -----------    HW: 480 402 507 14
   Serial number: 3526502B91656B905178
   Subsystem 5 - Part No SW: -----------    HW: 480 401 706 14
   Serial number: 35565029B169752090ED
   Subsystem 6 - Part No SW: -----------    HW: 480 402 207 14
   Serial number: 2286502A31656B93E12A
   Subsystem 7 - Part No SW: -----------    HW: 480 402 207 14
   Serial number: 2296502AB1656B9621FN
   Subsystem 8 - Part No SW: -----------    HW: 480 402 207 14
   Serial number: 2306502C915F3C33B33C
   Part No SW: 8V0 953 521 BP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 28071404220282
   Coding: A418
   VCID: 091365F5A84A0A7090-805C
   Coding: 07A409082B8000080700E8001000000000000000
   Revision: --------    Serial number: 0002292641
   Coding: 030100042F0857005B0002481C0B00000001010000000000000000000000
   Serial number: 08 07 2014  E0020996
   Serial number: 9130264003
   Part No SW: 8V0 857 511     HW: 8V0 857 511
   Component: FLA           H03 0002
   Revision: AA001001
   Coding: 02018764747464545425363E00
   Serial number: 14071403110033
   Coding: 001C8E205C00040000001002
   Coding: 8103
   Serial number: 11071402091629
   Coding: 001C86205E00040000001002
   Part No SW: 8V0 035 035 B    HW: 8V0 035 035 B
   Component: MU-H-LN-EU    H43 0356
   Serial number: A301G0EB002352
   Coding: 01730301FF0A000021110001000A00132F00010501000100DE
   ROD: EV_MUHig6C3HBAS_AU37.rod
   VCID: 3065E8116B501BB877-8065
   Engine Control Module 2:
   Subsystem 1 - Part No SW: V03 959 800 PS    HW: -----------
   Component: ECE 2014/2015  --- 0086
   Component: DU High  H49 0013
   Serial number: AUZ8Z9EY201FBK
   Sound System:
   Subsystem 3 - Part No SW: 8V0 919 614 K    HW: 8V0 919 614 K
   Component: ControlUnit_H  H81 0816
   Serial number: C1000015051400030310
   Door Electronics Rear Left:
   Component: Gracenote  --- 1010
3072 - Cellular Antenna
          B1053 11 [008] - Short to Ground
                    Reset counter: 124
                    Mileage: 2094 km
                    Date: 2015.01.09
                    Time: 23:18:54
3083 - GSM Antenna 2
          B1533 11 [008] - Short to Ground
                    Reset counter: 124
                    Mileage: 2094 km
                    Date: 2015.01.09
                    Time: 23:18:54
End-------------------------(Elapsed Time: 04:26)--------------------------
Thank You for any advice...
Welcome aboard. Nice first post; good info, Auto-Scans wrapped in CODE tags. I like you already. :)
I've updated your user status.
I don't have the answer to your coding questions, but I don't mind moving this to the Retrofits section.
azet
Poland
C?ID=123840
I lost a lot of time trying to code everything in a proper way, but no success...
I had another a3 for cruise control retrofit so I made some test, I hope it will be helpful for You to find solution. I bought new stalk with CCS in local audi dealer, i Did auto-scan and scan of adaption channel before i let them code the car with SVM procedure... of course i did another scan after the car came back from dealer and CCS works and no errors.
I found every change that the SVM did in coding of the car. I re coded the first car exactly same way . . . But still have errors of wrong coding... i'm realy frustrated.
Here is the autoscan of the second A3 8v before CCS retrofiting:
Thursday,02,April,2015,17:05:29:29512
VIN: WAUZZZ8V1Fxxxxx98   License Plate: DRUGI MIRKA
VIN: WAUZZZ8V1Fxxxxx98   Mileage: 7km-4miles
Address 01: Engine (J623-CZCA)       Labels: User\04E-907-309-V1.lbl
   Revision: R7H21---
   Coding: 02250032230401082000
   Revision: 00043014    Serial number: CU501409067217
   Revision: 00000000    Serial number: 62554000004855
   Coding: 12F16AA224251274037D060941CB2948562448C0608294F3002100788608
   Revision: 20026000    Serial number: 00000000431905
   Serial number: 01011425503597
   Slave 1:
   Component: WWS370 140823  042 0580
   Serial number:         140902231942
   Coding: 0A47F7
   Slave 2:
   Serial number: 23178886
   Coding: 00006C
   Slave 3:
   Serial number: 11 06 2014  00001429
   Serial number: 000000000ZY1421703WU
   Serial number: 00000000000060465907
   Revision: --------    Serial number: 39331426000957
   Coding: 0010050011
   Serial number: 003M2R08AUM
   Subsystem 1 - Part No SW: -----------    HW: 480 001 109 14
   Serial number: 3576700000013729F01N
   Subsystem 2 - Part No SW: -----------    HW: 480 001 109 14
   Serial number: 358670000004B629F01Y
   Subsystem 3 - Part No SW: -----------    HW: 480 400 509 14
   Serial number: 3516502BF176A6C393BU
   Subsystem 4 - Part No SW: -----------    HW: 480 400 509 14
   Serial number: 3526502C7176A6C222CG
   Subsystem 5 - Part No SW: -----------    HW: 480 401 007 14
   Serial number: 3556502B916569056187
   Subsystem 6 - Part No SW: -----------    HW: 480 402 908 14
   Serial number: 2286502AF16C6CE2819Z
   Serial number: 2296502C1175A8E521CI
   Subsystem 8 - Part No SW: -----------    HW: 480 402 908 14
   Serial number: 2306502AF17750B4E0CI
   Revision: --------    Serial number: 12091404221057
   Coding: 8418
   Coding: 078409082B8000080700A8001000000000000000
   Revision: --------    Serial number: 0002392442
   Serial number: 26 08 2014  A0060700
   Serial number: 1707744403
   Serial number: 30081401100814
   Coding: 0103
   Serial number: 04091406070469
   Serial number: A3F01209141828
   Serial number: AUZ8Z9EY30667P
   Sound System:
   Serial number: C1000027081400030228
End-------------------------(Elapsed Time: 04:17)--------------------------
the same car after SVM configuration (I found coding change in Engine , Instruments, Steering wheel - those are good labeled in VCDS - an theres is "2" instead of "0" in ABS coding - i tried this coding earlier but i wasn't sure if it was correct. now I am.
Auto scan after CCS retrofited by dealer
Friday,03,April,2015,12:09:06:29512
VIN: WAUZZZ8V1FA058698   License Plate: DRUGA PO KODOWANIU
VIN: WAUZZZ8V1FA058698   Mileage: 7km-4miles
   Revision: R7H21---
   Shop #: WSC 30209 001 1048576
   Coding: 12F16AA224251274037D060941CB2948562448C0608294F3022100788608
   Slave 1:
   Coding: 0A47F7
   Slave 2:
   Coding: 00006C
   Slave 3:
   Coding: 0010050011
   Coding: A418
   Coding: 07A409082B8000080700A8001000000000000000
   Coding: 0103
   Sound System:
End-------------------------(Elapsed Time: 04:20)--------------------------
This is autoscan of the car from first post after coding the same way as dealer did
Saturday,04,April,2015,00:46:17:29512
VIN: WAUZZZ8V3FA067600   License Plate: PO ZMIANACH PIERWSZA
   Revision: R7H21---
21472 - Databus
                    Mileage: 7 km
                    Date: 2015.04.04
                    Time: 00:37:38
          P1647 00 [167] - -
                    Mileage: 7 km
                    Date: 2015.04.04
                    Time: 00:37:40
17923 - Databus
                    Mileage: 7 km
                    Date: 2015.04.04
                    Time: 00:37:38
   Coding: 12F16AA224261273037D060041C32948562448C0608294F3022100788608
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [009] - -
                    Reset counter: 5
                    Mileage: 7 km
                    Date: 2015.04.04
                    Time: 00:37:41
   Slave 1:
   Coding: 0A47F7
   Slave 2:
   Coding: 00006C
   Slave 3:
   Coding: 0010050011
   Coding: A418
   Shop #: WSC 00070 000 00000
   Coding: 0103
   Sound System:
End-------------------------(Elapsed Time: 04:14)--------------------------
I did scan of adaption channels of can gataway - i Was sure that problem is somewhere there but now I don't know.
CAN before
;SW:5Q0-907-530-T   HW:5Q0-907-530-F ---  CAN Gateway
;Component:GW MQB High   128 1188, Coding:030100042F0857005B000248180B00000001010000000000000000000000
;EV_GatewLear,011016,EV_GatewLear_AU37.rod
;Thursday,02,April,2015,17:21:05:29512
;VCDS Version: Beta 15.3.0  Data version: 20150314
;VCID: 4281B2D9D5FC992891-8017
Activating and deactivating all development messages,not active
(1)-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active
(2)-Auxiliary heater activation restriction request-Set_point_target_time,--
(1)-Battery adaptation-Rated battery capacity,69 Ah
(2)-Battery adaptation-Battery technology,EFB
(3)-Battery adaptation-Battery manufacturer,MLA
(4)-Battery adaptation-Battery Serial Number,140916GPHB
Battery terminal recognition,connected
Component protection showroom mode,not active
Counter for inconsistent states,0
Cyclization limitation request battery service,0
Deactivate production mode,0
Deactivation of start-stop function,Mode not active
Distance left for deactivation of static current measuring mode,2
Distance left for deactivation of transport mode,50
(1)-Efficiency program display-Live tip air resistance: close window/sunroof,activated
(2)-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated
(3)-Efficiency program display-Live tip do not operate gas pedal during engine start,activated
(4)-Efficiency program display-Live tip adhere to switch display (only manual switch),activated
(5)-Efficiency program display-Live tip use start-stop-system,activated
(6)-Efficiency program display-Live tip switch on start-stop-system,activated
(7)-Efficiency program display-Live tip air conditioning: close window/sunroof,activated
(8)-Efficiency program display-Live tip use gearshift position D,not activated
(9)-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated
(10)-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),not activated
(11)-Efficiency program display-Live tip avoid engine warm-up at standstill,activated
(12)-Efficiency program display-Dash Board,activated
(13)-Efficiency program display-Comfort use A/C,activated
(14)-Efficiency program display-Comfort use parking heater,activated
(15)-Efficiency program display-Comfort use rear window heater,activated
(16)-Efficiency program display-Comfort use front seat heater,activated
(17)-Efficiency program display-Comfort use front seat ventilation,activated
(18)-Efficiency program display-Comfort use rear heater,activated
(19)-Efficiency program display-Comfort use fog light,not activated
(20)-Efficiency program display-Comfort use rear fog light,activated
(21)-Efficiency program display-Comfort use parking heater consumption emission,activated
(22)-Efficiency program display-Comfort use windshield heater,activated
(23)-Efficiency program display-Comfort use steering wheel heater,not activated
(24)-Efficiency program display-Comfort use mirror heater,activated
(25)-Efficiency program display-Comfort use rear seat heater,not activated
(26)-Efficiency program display-Comfort use rear seat ventilation,not activated
Energy management deactivation stage,Mode not active
Energy management heat output control status,Mode not active
Generator specified voltage value variable,10.6 V
(1)-Hysteresis voltage-Voltage_lowering,12.1 V
(2)-Hysteresis voltage-Voltage_elevation,12.1 V
Increase idle speed request,Mode not active
(1)-Installation list; specified installations-Gateway,coded
(2)-Installation list; specified installations-Node_0x01,Not coded
(3)-Installation list; specified installations-Node_0x02,Not coded
(4)-Installation list; specified installations-Node_0x03,Not coded
(5)-Installation list; specified installations-Node_0x04,Not coded
(6)-Installation list; specified installations-Node_0x05,Not coded
(7)-Installation list; specified installations-Node_0x06,Not coded
(8)-Installation list; specified installations-Node_0x07,Not coded
(9)-Installation list; specified installations-Node_0x08,Not coded
(10)-Installation list; specified installations-Node_0x09,Not coded
(11)-Installation list; specified installations-Parking Assistance,coded
(12)-Installation list; specified installations-Tire Pressure Monitoring 1,Not coded
(13)-Installation list; specified installations-Steering Column Electronics,coded
(14)-Installation list; specified installations-Node_0x0D,Not coded
(15)-Installation list; specified installations-Central Electrics,coded
(16)-Installation list; specified installations-All-wheel electronics,Not coded
(17)-Installation list; specified installations-Node_0x11,Not coded
(18)-Installation list; specified installations-Steering Assistance,coded
(19)-Installation list; specified installations-Brakes 1,coded
(20)-Installation list; specified installations-Dash Board,coded
(21)-Installation list; specified installations-Airbag,coded
(22)-Installation list; specified installations-Node_0x16,Not coded
(23)-Installation list; specified installations-Node_0x17,Not coded
(24)-Installation list; specified installations-Radio,Not coded
(25)-Installation list; specified installations-Air Conditioning Compressor,Not coded
(26)-Installation list; specified installations-Node_0x1A,Not coded
(27)-Installation list; specified installations-Node_0x1B,Not coded
(28)-Installation list; specified installations-Actuator For Structure-borne Sound,Not coded
(29)-Installation list; specified installations-Node_0x1D,Not coded
(30)-Installation list; specified installations-Lock Electronics,Not coded
(31)-Installation list; specified installations-Node_0x1F,Not coded
(32)-Installation list; specified installations-Node_0x20,Not coded
(33)-Installation list; specified installations-Node_0x21,Not coded
(34)-Installation list; specified installations-Node_0x22,Not coded
(35)-Installation list; specified installations-Deck Lid Control Unit,Not coded
(36)-Installation list; specified installations-Node_0x24,Not coded
(37)-Installation list; specified installations-Node_0x25,Not coded
(38)-Installation list; specified installations-Node_0x26,Not coded
(39)-Installation list; specified installations-Node_0x27,Not coded
(40)-Installation list; specified installations-Node_0x28,Not coded
(41)-Installation list; specified installations-Node_0x29,Not coded
(42)-Installation list; specified installations-Node_0x2A,Not coded
(43)-Installation list; specified installations-Special Function 2,Not coded
(44)-Installation list; specified installations-Special Function,Not coded
(45)-Installation list; specified installations-Electronic Roof Control,Not coded
(46)-Installation list; specified installations-Node_0x2E,Not coded
(47)-Installation list; specified installations-Node_0x2F,Not coded
(48)-Installation list; specified installations-High Beam Assistance,Not coded
(49)-Installation list; specified installations-Steering Column Locking,Not coded
(50)-Installation list; specified installations-Access Startsystem Interface,Not coded
(51)-Installation list; specified installations-Sliding Door Rear Left,Not coded
(52)-Installation list; specified installations-Sliding Door Rear Right,Not coded
(53)-Installation list; specified installations-Node_0x35,Not coded
(54)-Installation list; specified installations-Node_0x36,Not coded
(55)-Installation list; specified installations-Node_0x37,Not coded
(56)-Installation list; specified installations-Node_0x38,Not coded
(57)-Installation list; specified installations-Node_0x39,Not coded
(58)-Installation list; specified installations-Node_0x3A,Not coded
(59)-Installation list; specified installations-Brake booster,Not coded
(60)-Installation list; specified installations-Node_0x3C,Not coded
(61)-Installation list; specified installations-Node_0x3D,Not coded
(62)-Installation list; specified installations-Door Electronics Rear Driver Side,Not coded
(63)-Installation list; specified installations-Door Electronics Rear Passenger Side,Not coded
(64)-Installation list; specified installations-Node_0x40,Not coded
(65)-Installation list; specified installations-Node_0x41,Not coded
(66)-Installation list; specified installations-Thermal management,Not coded
(67)-Installation list; specified installations-Node_0x43,Not coded
(68)-Installation list; specified installations-Battery Charger Control Module,Not coded
(69)-Installation list; specified installations-Node_0x45,Not coded
(70)-Installation list; specified installations-Air Conditioning,coded
(71)-Installation list; specified installations-Trailer Function,Not coded
(72)-Installation list; specified installations-Node_0x48,Not coded
(73)-Installation list; specified installations-Node_0x49,Not coded
(74)-Installation list; specified installations-Door Electronics Driver Side,coded
(75)-Installation list; specified installations-Door Electronics Passenger Side,coded
(76)-Installation list; specified installations-Seat Adjustment Driver Side,Not coded
(77)-Installation list; specified installations-Seat Adjustment Passenger Side,Not coded
(78)-Installation list; specified installations-Lane change assistance,Not coded
(79)-Installation list; specified installations-Frontsensorik für Fahrerassistenzsysteme,Not coded
(80)-Installation list; specified installations-Vehicle Position Detection,Not coded
(81)-Installation list; specified installations-Node_0x51,Not coded
(82)-Installation list; specified installations-Node_0x52,Not coded
(83)-Installation list; specified installations-Node_0x53,Not coded
(84)-Installation list; specified installations-Headlight Regulation,coded
(85)-Installation list; specified installations-Node_0x55,Not coded
(86)-Installation list; specified installations-Node_0x56,Not coded
(87)-Installation list; specified installations-Adaptive Cruise Control,Not coded
(88)-Installation list; specified installations-Node_0x58,Not coded
(89)-Installation list; specified installations-Node_0x59,Not coded
(90)-Installation list; specified installations-Node_0x5A,Not coded
(91)-Installation list; specified installations-Node_0x5B,Not coded
(92)-Installation list; specified installations-Node_0x5C,Not coded
(93)-Installation list; specified installations-Node_0x5D,Not coded
(94)-Installation list; specified installations-Node_0x5E,Not coded
(95)-Installation list; specified installations-Node_0x5F,Not coded
(96)-Installation list; specified installations-Node_0x60,Not coded
(97)-Installation list; specified installations-Node_0x61,Not coded
(98)-Installation list; specified installations-Node_0x62,Not coded
(99)-Installation list; specified installations-Microphone Control Unit,Not coded
(100)-Installation list; specified installations-Actuator For Exterior Noise,Not coded
(101)-Installation list; specified installations-High Voltage Battery Charge Management,Not coded
(102)-Installation list; specified installations-Node_0x66,Not coded
(103)-Installation list; specified installations-Telematics Communication Unit,Not coded
(104)-Installation list; specified installations-Node_0x68,Not coded
(105)-Installation list; specified installations-Camera System Rear View,Not coded
(106)-Installation list; specified installations-Auxiliary Parking Heater,Not coded
(107)-Installation list; specified installations-Node_0x6B,Not coded
(108)-Installation list; specified installations-Node_0x6C,Not coded
(109)-Installation list; specified installations-TV Tuner,Not coded
(110)-Installation list; specified installations-Node_0x6E,Not coded
(111)-Installation list; specified installations-Sound System,Not coded
(112)-Installation list; specified installations-Media Player Position 1,Not coded
(113)-Installation list; specified installations-Trip recorder,Not coded
(114)-Installation list; specified installations-Wheel Dampening Electronics,Not coded
(115)-Installation list; specified installations-Information Control Unit 1,coded
(116)-Installation list; specified installations-Node_0x74,Not coded
(117)-Installation list; specified installations-Node_0x75,Not coded
(118)-Installation list; specified installations-Engine Control Module 1,coded
(119)-Installation list; specified installations-Transmission Control Module,coded
(120)-Installation list; specified installations-Node_0x78,Not coded
(121)-Installation list; specified installations-Node_0x79,Not coded
(122)-Installation list; specified installations-Node_0x7A,Not coded
(123)-Installation list; specified installations-Battery Energy Control Module,Not coded
(124)-Installation list; specified installations-Drive Motor Control Module,Not coded
(125)-Installation list; specified installations-Node_0x7D,Not coded
(126)-Installation list; specified installations-Node_0x7E,Not coded
(127)-Installation list; specified installations-Node_0x7F,Not coded
(128)-Installation list; specified installations-Node_0x80,Not coded
(129)-Installation list; specified installations-Node_0x81,Not coded
(130)-Installation list; specified installations-Node_0x82,Not coded
(131)-Installation list; specified installations-Node_0x83,Not coded
(132)-Installation list; specified installations-Control module for sunroof,Not coded
(133)-Installation list; specified installations-Node_0x85,Not coded
(134)-Installation list; specified installations-Node_0x86,Not coded
(135)-Installation list; specified installations-Node_0x87,Not coded
(136)-Installation list; specified installations-Node_0x88,Not coded
(137)-Installation list; specified installations-Node_0x89,Not coded
(138)-Installation list; specified installations-Lane Change Assistant 2,Not coded
(139)-Installation list; specified installations-Node_0x8B,Not coded
(140)-Installation list; specified installations-Node_0x8C,Not coded
(141)-Installation list; specified installations-Node_0x8D,Not coded
(142)-Installation list; specified installations-Node_0x8E,Not coded
(143)-Installation list; specified installations-Node_0x8F,Not coded
(144)-Installation list; specified installations-Node_0x90,Not coded
(145)-Installation list; specified installations-Node_0x91,Not coded
(146)-Installation list; specified installations-Node_0x92,Not coded
(147)-Installation list; specified installations-Node_0x93,Not coded
(148)-Installation list; specified installations-Node_0x94,Not coded
(149)-Installation list; specified installations-Node_0x95,Not coded
(150)-Installation list; specified installations-Node_0x96,Not coded
(151)-Installation list; specified installations-Node_0x97,Not coded
(152)-Installation list; specified installations-Node_0x98,Not coded
(153)-Installation list; specified installations-Node_0x99,Not coded
(154)-Installation list; specified installations-Node_0x9A,Not coded
(155)-Installation list; specified installations-Node_0x9B,Not coded
(156)-Installation list; specified installations-Node_0x9C,Not coded
(157)-Installation list; specified installations-Node_0x9D,Not coded
(158)-Installation list; specified installations-Node_0x9E,Not coded
(159)-Installation list; specified installations-Node_0x9F,Not coded
(160)-Installation list; specified installations-Node_0xA0,Not coded
(161)-Installation list; specified installations-Node_0xA1,Not coded
(162)-Installation list; specified installations-Node_0xA2,Not coded
(163)-Installation list; specified installations-Node_0xA3,Not coded
(164)-Installation list; specified installations-Node_0xA4,Not coded
(165)-Installation list; specified installations-Node_0xA5,Not coded
(166)-Installation list; specified installations-Node_0xA6,Not coded
(167)-Installation list; specified installations-Node_0xA7,Not coded
(168)-Installation list; specified installations-Node_0xA8,Not coded
(169)-Installation list; specified installations-Node_0xA9,Not coded
(170)-Installation list; specified installations-Node_0xAA,Not coded
(171)-Installation list; specified installations-Node_0xAB,Not coded
(172)-Installation list; specified installations-Node_0xAC,Not coded
(173)-Installation list; specified installations-Node_0xAD,Not coded
(174)-Installation list; specified installations-Node_0xAE,Not coded
(175)-Installation list; specified installations-Node_0xAF,Not coded
(176)-Installation list; specified installations-Node_0xB0,Not coded
(177)-Installation list; specified installations-Node_0xB1,Not coded
(178)-Installation list; specified installations-Node_0xB2,Not coded
(179)-Installation list; specified installations-Node_0xB3,Not coded
(180)-Installation list; specified installations-Node_0xB4,Not coded
(181)-Installation list; specified installations-Node_0xB5,Not coded
(182)-Installation list; specified installations-Node_0xB6,Not coded
(183)-Installation list; specified installations-Node_0xB7,Not coded
(184)-Installation list; specified installations-Node_0xB8,Not coded
(185)-Installation list; specified installations-Node_0xB9,Not coded
(186)-Installation list; specified installations-Node_0xBA,Not coded
(187)-Installation list; specified installations-Node_0xBB,Not coded
(188)-Installation list; specified installations-Node_0xBC,Not coded
(189)-Installation list; specified installations-Node_0xBD,Not coded
(190)-Installation list; specified installations-Node_0xBE,Not coded
(191)-Installation list; specified installations-Node_0xBF,Not coded
(192)-Installation list; specified installations-Node_0xC0,Not coded
(193)-Installation list; specified installations-Node_0xC1,Not coded
(194)-Installation list; specified installations-Node_0xC2,Not coded
(195)-Installation list; specified installations-Node_0xC3,Not coded
(196)-Installation list; specified installations-Node_0xC4,Not coded
(197)-Installation list; specified installations-Node_0xC5,Not coded
(198)-Installation list; specified installations-Node_0xC6,Not coded
(199)-Installation list; specified installations-Node_0xC7,Not coded
(200)-Installation list; specified installations-Node_0xC8,Not coded
(201)-Installation list; specified installations-Node_0xC9,Not coded
(202)-Installation list; specified installations-Node_0xCA,Not coded
(203)-Installation list; specified installations-Node_0xCB,Not coded
(204)-Installation list; specified installations-Node_0xCC,Not coded
(205)-Installation list; specified installations-Node_0xCD,Not coded
(206)-Installation list; specified installations-Node_0xCE,Not coded
(207)-Installation list; specified installations-Node_0xCF,Not coded
(208)-Installation list; specified installations-Node_0xD0,Not coded
(209)-Installation list; specified installations-Node_0xD1,Not coded
(210)-Installation list; specified installations-Node_0xD2,Not coded
(211)-Installation list; specified installations-Node_0xD3,Not coded
(212)-Installation list; specified installations-Node_0xD4,Not coded
(213)-Installation list; specified installations-Node_0xD5,Not coded
(214)-Installation list; specified installations-Node_0xD6,Not coded
(215)-Installation list; specified installations-Node_0xD7,Not coded
(216)-Installation list; specified installations-Node_0xD8,Not coded
(217)-Installation list; specified installations-Node_0xD9,Not coded
(218)-Installation list; specified installations-Node_0xDA,Not coded
(219)-Installation list; specified installations-Node_0xDB,Not coded
(220)-Installation list; specified installations-Node_0xDC,Not coded
(221)-Installation list; specified installations-Node_0xDD,Not coded
(222)-Installation list; specified installations-Node_0xDE,Not coded
(223)-Installation list; specified installations-Node_0xDF,Not coded
(224)-Installation list; specified installations-Node_0xE0,Not coded
(225)-Installation list; specified installations-Node_0xE1,Not coded
(226)-Installation list; specified installations-Node_0xE2,Not coded
(227)-Installation list; specified installations-Node_0xE3,Not coded
(228)-Installation list; specified installations-Node_0xE4,Not coded
(229)-Installation list; specified installations-Node_0xE5,Not coded
(230)-Installation list; specified installations-Node_0xE6,Not coded
(231)-Installation list; specified installations-Node_0xE7,Not coded
(232)-Installation list; specified installations-Node_0xE8,Not coded
(233)-Installation list; specified installations-Node_0xE9,Not coded
(234)-Installation list; specified installations-Node_0xEA,Not coded
(235)-Installation list; specified installations-Node_0xEB,Not coded
(236)-Installation list; specified installations-Node_0xEC,Not coded
(237)-Installation list; specified installations-Node_0xED,Not coded
(238)-Installation list; specified installations-Node_0xEE,Not coded
(239)-Installation list; specified installations-Node_0xEF,Not coded
(240)-Installation list; specified installations-Node_0xF0,Not coded
(241)-Installation list; specified installations-Node_0xF1,Not coded
(242)-Installation list; specified installations-Node_0xF2,Not coded
(243)-Installation list; specified installations-Node_0xF3,Not coded
(244)-Installation list; specified installations-Node_0xF4,Not coded
(245)-Installation list; specified installations-Node_0xF5,Not coded
(246)-Installation list; specified installations-Node_0xF6,Not coded
(247)-Installation list; specified installations-Node_0xF7,Not coded
(248)-Installation list; specified installations-Node_0xF8,Not coded
(249)-Installation list; specified installations-Node_0xF9,Not coded
(250)-Installation list; specified installations-Node_0xFA,Not coded
(251)-Installation list; specified installations-Node_0xFB,Not coded
(252)-Installation list; specified installations-Node_0xFC,Not coded
(253)-Installation list; specified installations-Node_0xFD,Not coded
(254)-Installation list; specified installations-Node_0xFE,Not coded
(255)-Installation list; specified installations-Node_0xFF,Not coded
MKE Check box,activated
(1)-Production mode-p_mode_deactivate_mfl_keys,Deactivating
(2)-Production mode-p_mode_deactivate_recuperation,Deactivating
Production process data 1,FA AA
(1)-Range gain-Range gain AC system,not activated
(2)-Range gain-Range gain auxiliary heater,not activated
(3)-Range gain-Range gain window defogger,not activated
(4)-Range gain-Range gain seat heater front,not activated
(5)-Range gain-Range gain front set ventilation,not activated
(6)-Range gain-Range gain rear heater,not activated
(7)-Range gain-Range gain fog light,not activated
(8)-Range gain-Range gain rear fog light,not activated
(9)-Range gain-Range gain windshield heating,not activated
(10)-Range gain-Range gain steering wheel heater,not activated
(11)-Range gain-Range gain mirror heater,not activated
(12)-Range gain-Range gain rear seat heater,not activated
(13)-Range gain-Range gain rear seat heater,not activated
(14)-Range gain-Catalogue range display,not activated
(15)-Range gain-Loading condition catalogue range display,not activated
(16)-Range gain-Windshield heater consumption in AC system,not activated
(17)-Range gain-Windshield heater range gain in AC system,not activated
(18)-Range gain-PTC(low voltage) consumption,activated
(19)-Range gain-PTC(low voltage) range gain,activated
(20)-Range gain-List at engine still stand,not activated
(1)-Roller test bench mode; functional-Activation stages,not activated
(2)-Roller test bench mode; functional-Malfunction states,no error
Selection of release codes for a SWaP function,FF FF FF FF
Start/stop start voltage limit,7.6 V
Static current measuring mode,not activated
Transfer of release code for a SWaP function,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B6DD1122 138228 50F098 50F098 50F098 50F098 50F098 50F098 50F098 50F098 507 1390C8 00 138A28 00 50F098 B6DD11BE 138A28 00 00 662759D 07 02 180 FFFFFFFF 6E7BD18 7381568 416AB0 1386EC 4CF2A2 05 1386F8 408D4F 1382AC 01 281 138A28 138AA0 50F098 14D 24 13830C 75F91060 2BF98DAF FFFFFFFE 13831C 75F4A365 340356 0F 00 00 52BCF04 01 5E1E80C3 3B 777EDDC0 00 1384AC 75F91060 340356 00 01 1382E0 A0FE4 13835C 75F91060 2BF9A00F FFFFFFFE 13834C 75F4A98F 52BCEF0 0F 00 75F4A9A1 00 00 01 00 00 5E1E8093 13840C 777DCAA6 138368 18 1384AC 777DCA50 138380 52BCEF0 0F 00 00 49F421 777EDDC0 75F4D6DA 72FBB266 340356 37328C 00 105 01 72F56BC0 72F56CB2 00 14D 01 340356 01 01 01 01 5E1E80AB FA0114B8 138420 75F4A0EB 0A 01 72F56BC0 777A957C 72F56BC0 777A957C 00 777A9650 00 777A9650 20 FA0114B8 58EA96E2 01 138438 75F48C50 340356 14E 14D 00 72F56BC0 DCBAABCD 00 01 72F56BC0 1384BC 75F48E21 72F56BC0 5F9BC2D9 1384BC 75F48EAB 75F48E35 5E1E8763 14E 52BCEF0 75F48E65 510CC8 24 01 00 00 70 FFFFFFFF FFFFFFFF 75F48D9A 75F48EAB 00 75F48EAB 01 72F56BC0 14D 5E1E8763 14C 5E1E871B 138584 75F91060 2BF98DAF FFFFFFFE 1384EC 75F6F751 340356 14E 14D 00 00 00 29F7E0 75F6F75D 510E70 5E1E8733 13850C 49CF7F 72F56BC0 340356 14E 14D 00 138AA0 138528 49D099 14E 14D 00 138AA0 14D 138590 49F3C8 14E 14D 49F41E B6DD16A2 01 340356 00 1F108E 113 05 00 00 00 00 4A31DB 4A3100 4A3723 49ECAA 01 49F421 777A957C 138650 4CCFBA 00 49F41E 49F457 00 340356 14E 14D 14D 49F421 1385DC 75F48C50 340356 14E 14D 00 49F421 DCBAABCD 00 01 49F421 138660 75F48E21 5F9BC4B9 340356 138660 75F48EAB 75F48E35 5E1E85BF
Transport mode,not active
(1)-AGW_Calibration-AGW_Time_Fade_In,0 ms
(2)-AGW_Calibration-AGW_Time_Fade_Out,0 ms
(3)-AGW_Calibration-AGW_Time_Fade_In_Start,0 ms
(4)-AGW_Calibration-AGW_Time_Fade_Out_Start,0 ms
(5)-AGW_Calibration-AGW_Time_Start_Sequence,0 ms
(6)-AGW_Calibration-AGW_Time_Start_Delay,0 ms
(7)-AGW_Calibration-AGW_Brightness_Start_Sequence,100 %
(8)-AGW_Calibration-AGW_fade_in_deactivation_threshold,100
(1)-AGW_Function_Releases-AGW_Enabling_Brightness,active
(2)-AGW_Function_Releases-AGW_Enabling_Flash_Frequency,active
(3)-AGW_Function_Releases-AGW_Enabling_Supression_Symbol,active
(1)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms
(2)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,3000 ms
(3)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms
(4)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms
(5)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,500 ms
(6)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms
(7)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms
(8)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,120
(9)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms
(10)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active
(1)-Enable_CAN_Timeout_DTC-Gateway,Enabled
(2)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled
(3)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled
(4)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled
(5)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled
(6)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled
(7)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled
(8)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled
(9)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled
(10)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09,Enabled
(11)-Enable_CAN_Timeout_DTC-Parking Assistance,Enabled
(12)-Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled
(13)-Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled
(14)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled
(15)-Enable_CAN_Timeout_DTC-Central Electrics,Enabled
(16)-Enable_CAN_Timeout_DTC-All-wheel electronics,Enabled
(17)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled
(18)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled
(19)-Enable_CAN_Timeout_DTC-Steering Assistance,Enabled
(20)-Enable_CAN_Timeout_DTC-Brakes 1,not enabled
(21)-Enable_CAN_Timeout_DTC-Dash Board,Enabled
(22)-Enable_CAN_Timeout_DTC-Airbag,not enabled
(23)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled
(24)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled
(25)-Enable_CAN_Timeout_DTC-Radio,Enabled
(26)-Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled
(27)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled
(28)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1B,Enabled
(29)-Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled
(30)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled
(31)-Enable_CAN_Timeout_DTC-Lock Electronics,Enabled
(32)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled
(33)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled
(34)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled
(35)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled
(36)-Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled
(37)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled
(38)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled
(39)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled
(40)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled
(41)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled
(42)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled
(43)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled
(44)-Enable_CAN_Timeout_DTC-Special Function 2,Enabled
(45)-Enable_CAN_Timeout_DTC-Special Function,Enabled
(46)-Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled
(47)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled
(48)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled
(49)-Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled
(50)-Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled
(51)-Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled
(52)-Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled
(53)-Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled
(54)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled
(55)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled
(56)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled
(57)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled
(58)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled
(59)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled
(60)-Enable_CAN_Timeout_DTC-Brake booster,Enabled
(61)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled
(62)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled
(63)-Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled
(64)-Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled
(65)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled
(66)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled
(67)-Enable_CAN_Timeout_DTC-Thermal management,Enabled
(68)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled
(69)-Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled
(70)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled
(71)-Enable_CAN_Timeout_DTC-Air Conditioning,Enabled
(72)-Enable_CAN_Timeout_DTC-Trailer Function,Enabled
(73)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled
(74)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled
(75)-Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled
(76)-Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled
(77)-Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled
(78)-Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled
(79)-Enable_CAN_Timeout_DTC-Lane change assistance,Enabled
(80)-Enable_CAN_Timeout_DTC-Frontsensorik für Fahrerassistenzsysteme,Enabled
(81)-Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled
(82)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled
(83)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled
(84)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled
(85)-Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled
(86)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled
(87)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled
(88)-Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled
(89)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled
(90)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled
(91)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled
(92)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled
(93)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled
(94)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled
(95)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled
(96)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled
(97)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled
(98)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled
(99)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled
(100)-Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled
(101)-Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled
(102)-Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled
(103)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled
(104)-Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled
(105)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled
(106)-Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled
(107)-Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled
(108)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled
(109)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled
(110)-Enable_CAN_Timeout_DTC-TV Tuner,Enabled
(111)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled
(112)-Enable_CAN_Timeout_DTC-Sound System,Enabled
(113)-Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled
(114)-Enable_CAN_Timeout_DTC-Trip recorder,Enabled
(115)-Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled
(116)-Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled
(117)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled
(118)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled
(119)-Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled
(120)-Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled
(121)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled
(122)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled
(123)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled
(124)-Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled
(125)-Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled
(126)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled
(127)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled
(128)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled
(129)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled
(130)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled
(131)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled
(132)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled
(133)-Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled
(134)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85,Enabled
(135)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled
(136)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled
(137)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled
(138)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled
(139)-Enable_CAN_Timeout_DTC-Lane Change Assistant 2,Enabled
(140)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled
(141)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled
(142)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled
(143)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled
(144)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled
(145)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled
(146)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled
(147)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled
(148)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled
(149)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled
(150)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled
(151)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled
(152)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled
(153)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled
(154)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled
(155)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled
(156)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled
(157)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C,Enabled
(158)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled
(159)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled
(160)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled
(161)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled
(162)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled
(163)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled
(164)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled
(165)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA4,Enabled
(166)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled
(167)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled
(168)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled
(169)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled
(170)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA9,Enabled
(171)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled
(172)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled
(173)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled
(174)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled
(175)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAE,Enabled
(176)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled
(177)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled
(178)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled
(179)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled
(180)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled
(181)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled
(182)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled
(183)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled
(184)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled
(185)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled
(186)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled
(187)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled
(188)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled
(189)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled
(190)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled
(191)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled
(192)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled
(193)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled
(194)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled
(195)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled
(196)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled
(197)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled
(198)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled
(199)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled
(200)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled
(201)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled
(202)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled
(203)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled
(204)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled
(205)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled
(206)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled
(207)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled
(208)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled
(209)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled
(210)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled
(211)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled
(212)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled
(213)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled
(214)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled
(215)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled
(216)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled
(217)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled
(218)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled
(219)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled
(220)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled
(221)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled
(222)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled
(223)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled
(224)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled
(225)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled
(226)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled
(227)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled
(228)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled
(229)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled
(230)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled
(231)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled
(232)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled
(233)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled
(234)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled
(235)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled
(236)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled
(237)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled
(238)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled
(239)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled
(240)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled
(241)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled
(242)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled
(243)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled
(244)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled
(245)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled
(246)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled
(247)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled
(248)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled
(249)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled
(250)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled
(251)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled
(252)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled
(253)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled
(254)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled
(255)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled
(256)-Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled
(1)-Energiemanagement Warnanzeigen-Generatormeldungen,Mode not active
(2)-Energiemanagement Warnanzeigen-Batteriemeldungen,Mode not active
(3)-Energiemanagement Warnanzeigen-MMI Vorwarnungen,Mode not active
(4)-Energiemanagement Warnanzeigen-Charge level,Mode not active
(1)-mirror_mode-mirror_mode_typ,not active
(2)-mirror_mode-mirror_mode_bus,Databus drivetrain
routing_0,00 00 00 00 00 00 00 00 00 00 00 00
routing_1,00 00 00 00 00 00 00 00 00 00 00 00
routing_2,00 00 00 00 00 00 00 00 00 00 00 00
routing_3,00 00 00 00 00 00 00 00 00 00 00 00
routing_4,00 00 00 00 00 00 00 00 00 00 00 00
routing_5,00 00 00 00 00 00 00 00 00 00 00 00
routing_6,00 00 00 00 00 00 00 00 00 00 00 00
routing_7,00 00 00 00 00 00 00 00 00 00 00 00
routing_8,00 00 00 00 00 00 00 00 00 00 00 00
routing_9,00 00 00 00 00 00 00 00 00 00 00 00
Sollspannungsbegrenzung Abblendlicht,12.1 V
(1)-Start/Stopp Außentemperaturvorgabe-Minimaltemperatur,-50.0 °C
(2)-Start/Stopp Außentemperaturvorgabe-Maximaltemperatur,-50.0 °C
Vorgabe Reduktion Innengebläse,Mode not active
Vorgabe Zykluszeit Spannungsmessung,0 s
WakeUpMonitor_Activation,activated
(1)-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s
(2)-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100
(3)-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s
and after :
;Friday,03,April,2015,12:30:00:29512
Transfer of release code for a SWaP function,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 876DF153 1382D8 50F098 50F098 50F098 50F098 50F098 50F098 50F098 50F098 507 139178 00 138AD8 00 50F098 876DF0AF 138AD8 00 00 65B7592 07 02 180 FFFFFFFF 6DABB98 8684AC0 416AB0 13879C 4CF2A2 05 1387A8 408D4F 13835C 01 281 138AD8 138B50 50F098 14D 24 1383BC 75F91060 B0F95E4C FFFFFFFE 1383CC 75F4A365 2C11D2 0F 00 00 5380CB4 01 C51E53F0 3B 777EDDC0 00 13855C 75F91060 2C11D2 00 01 138390 570298 13840C 75F91060 B0F973EC FFFFFFFE 1383FC 75F4A98F 5380CA0 0F 00 75F4A9A1 00 00 01 00 00 C51E53C0 1384BC 777DCAA6 138418 18 13855C 777DCA50 138430 5380CA0 0F 00 00 49F421 777EDDC0 75F4D6DA 72FBB266 2C11D2 71E3C94 00 105 01 72F56BC0 72F56CB2 00 14D 01 2C11D2 01 01 01 01 C51E5418 44010FB6 1384D0 75F4A0EB 0A 01 72F56BC0 777A957C 72F56BC0 777A957C 00 777A9650 00 777A9650 100020 44010FB6 C3173CAF 01 1384E8 75F48C50 2C11D2 14E 14D 00 72F56BC0 DCBAABCD 00 01 72F56BC0 13856C 75F48E21 72F56BC0 C760B351 13856C 75F48EAB 75F48E35 C51E5550 14E 5380CA0 75F48E65 510CC8 24 01 00 00 70 FFFFFFFF FFFFFFFF 75F48D9A 75F48EAB 00 75F48EAB 01 72F56BC0 14D C51E5550 14C C51E5548 138634 75F91060 B0F95E4C FFFFFFFE 13859C 75F6F751 2C11D2 14E 14D 00 00 00 51CF7E0 75F6F75D 510E70 C51E55A0 1385BC 49CF7F 72F56BC0 2C11D2 14E 14D 00 138B50 1385D8 49D099 14E 14D 00 138B50 14D 138640 49F3C8 14E 14D 49F41E 876DF5D3 01 2C11D2 00 620310 113 05 00 00 00 00 4A31DB 4A3100 4A3723 49ECAA 01 49F421 777A957C 138700 4CCFBA 00 49F41E 49F457 00 2C11D2 14E 14D 14D 49F421 13868C 75F48C50 2C11D2 14E 14D 00 49F421 DCBAABCD 00 01 49F421 138710 75F48E21 C760B1F1 2C11D2 138710 75F48EAB 75F48E35 C51E572C
I believe there is solution to retrofit CCS without using SVM (general problem is that You can use it only if You have new stalk form dealer - there are SVM codes in the box). I hope somebody can find solution, or maybe there is somebody that can tell for 100% that it is impossible.. HELP:D
NEtech
C?ID=56995
My guess is, that it is Swap code change in Adaptation in [19-CAN Gateway].
It is + 0xB0 and and ...... calculations ;-)
As you can see it done on-line, then also the PR code for the car VIN is changed.
azet
Poland
C?ID=123840
SVM is changing PR codes that clear for me, and I think this is the main reason why it is coded on-line.
e.g. If the wiper stalk will be broken in the future You can order a new one from dealer , and You always use VIN to order part. If the CCS was coded by dealer You will order proper stal (with CCS), if the CCS will be coded manualy (with VCDS or other of-line system) You will get wrong stalk (without CCS). this is how i understand the procedure. but i can not understand why dealer is not able (or don't want) to code "second hand" stalk...
norfolk-boy
C?ID=201631
Has there been any update on this issue as I have stumbled across the same thing. I would like to use VCDS to code it, if at all possible, rather than the dealer. I do however have a code to allow the dealer to code it!
DV52
C?ID=194404
(I believe there is solution to retrofit CCS without using SVM (general problem is that You can use it only if You have new stalk form dealer - there are SVM codes in the box). I hope somebody can find solution, or maybe there is somebody that can tell for 100% that it is impossible.. HELP:D
azet: Hello - First I must say that I admire your tenacity and your eye-for-detail! I was suspicious at first that perhaps you had missed a setting in the new control module. But I have checked your work ( see HERE) and I take my hat off to you - the settings for all 635 x adaptation channels for the "before" and "after" modules are exactly the same - respect!!
Are you certain that the problem is a coding/adaptation channel problem? I'm not familiar with the A3, but I do know that there are subtle wiring differences in the Mk7 (same MQB platform) between those models that have CCS and those that don't (apart from the obvious difference of the switches) The picture below is an example (see note *2)
Cheers
I assume that the added wire shown in the picture is the reason why the upper nibble of byte 5, (i.e. Bits 5-8) in the Engine module is set to hex20 -see below
norfolk-boy
C?ID=201631
I previously bought an Audi A1 kit and installed that in my A1 and it had an extra wire in it I had to install. This is the official kit and no wire or anything in the instructions to install one. I have booked it in to Audi now. Looks like VCDS can't do it :-(
LN-TAL
Norway
C?ID=13729
I also bought the official kit for my Audi A3 2004 (8P), and the wire and instructions was NOT included, still the wire from steering control coloumn elec. and the ECU was NOT installed, and I needed to install it.
norfolk-boy
C?ID=201631
Hi All well looking in to the kit it seems Audi now have a new system with retrofit kits for the A3 8V they include a function activation to go with the stalk assembly and it has an Activation code, activation Number and PIN code. Reading it it says it is a one time only code and cannot be transferred from car to car. Hence not allowing Azet activation of his secondhand assembly. I take it this is a new concept or is the community aware of this practice now? Will this become more widespread on newer cars? Is this another way for them to charge through the nose for dealer services? Thoughts appreciated by the Forum members.
norfolk-boy
C?ID=201631
Just re-read Azets post again and he pointed this practice out previously, sorry about repeating it. However would be good to see if Ross Tech are working on this at all as it could damage the VCDS product if it cannot crack this latest practice by VAG?
norfolk-boy
C?ID=201631
Gave up as well and paid Audi to online code it.
azet
Poland
C?ID=123840
Cheers
I'm sory for so long time without answer but I gave up with this CCS. I know the wiring differences and it was the first thing that I checked. The wire from Your diagram was allready in the car.
I preety sure tha the problem is somewhere in CAN Gataway - there must be some data about car's equipment, and if You change the coding You need to change something in the CANGataway. But i didn't find it....
Timonator
Belgium
C?ID=264441
Hey, did you turn off start/stop before coding the engine module with CCS? Otherwise you will indeed get some engine faults.
Usman786
C?ID=276001
How much did Audi charge for online coding?
What was the total cost of part and fitting?
