Results 1 to 1 of 1
Thread: 2004 r32 3.2l BJS
    HQ
    2004 r32 3.2l BJS
    Thursday,19,March,2015,19:16:26:47536
    VCDS Version: 14.10.2.0
    Data version: 20150311
    VIN: WVWSR61J84W047451   License Plate:
    Mileage: 155340km-96523mi   Repair Order:
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
              76
    VIN: WVWSR61J84W047451   Mileage: 155340km-96523miles
    Address 01: Engine        Labels: 022-906-032-BJS.lbl
       Part No SW: 022 906 032 EG    HW: 14. 4.0 3
       Component: MOTRONIC ME7.1.1G   5626
       Coding: 0000132
       Shop #: WSC 31414 000 00000
       VCID: D4EB7F1D76427F811A7-5184
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-A.lbl
       Part No: 1C0 907 379 P
       Component: ESP ALLRAD MK60     0101
       Coding: 0023049
       VCID: B7312891C7F4B4991F5-5184
    Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
       Part No: 3B1 907 044 C
       Component: CLIMATRONIC     C 2.0.0
       Coding: 11200
       Shop #: WSC 31414
       VCID: A105E6C92970DA29C11-51CE
       Part No: 1C0 909 605 F
       Component: 17 AIRBAG VW61 0108 0003
       Coding: 12599
       Shop #: WSC 31414
       VCID: A711F8D1475424198F5-5160
       Part No: 1J0 920 927 A
       Component: KOMBI+WEGFAHRSP VDO V03
       Coding: 15230
       VCID: A915FEE951401269991-5160
       WVWSR61J84W047451     VWZ7Z0C7769815
    01176 - Key
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 31414
       VCID: F0A3D38DB21A23A11EF-5160
    Address 22: AWD        Labels: 02D-900-554.lbl
       Part No: 02D 900 554 D
       Component: HALDEX LSC  ECC     0011
       VCID: A105E6C92970DA29C11-4B3C
    End-------------------------(Elapsed Time: 06:53)--------------------------
    Cold, engine off
    ;SW:022-906-032-EG   HW:14.-4.0-3 ---  Engine
    ;Component:MOTRONIC ME7.1.1G   5626, Coding:0000132
    ;Thursday,19,March,2015,19:05:43:47536
    ;VCDS Version: Release 14.10.2  Data version: 20150311
    ;VCID: D4EB7F1D76427F811A7-5184
    1,0,Basic Functions,
    1,1,Engine Speed,,
    ;0 /min,RPM,
    1,2,Coolant,Temperature,Specification: 80.0...110.0 C
    ;7.0C,Temperature,
    1,3,Lambda Control,Bank 1,
    ;0.0 %,Lambda,
    1,4,Lambda Control,Bank 2,
    ;0.0 %,Lambda,
    2,0,Basic Functions (Mass Air Flow),
    2,1,Engine Speed,,
    ;0 /min,RPM,
    2,2,Engine Load,,
    ;100.0 %,Load,
    2,3,Injection Timing,,
    ;0.00 ms,Inj. On Time,
    2,4,Mass Air Flow,,
    ;0.00 g/s,Mass Flow,
    3,0,Basic Functions (Mass Air Flow),
    3,1,Engine Speed,,
    ;0 /min,RPM,
    3,2,Mass Air Flow,,
    3,3,Throttle Position,Sensor (G187),
    ;6.7 %,Load,
    3,4,Ignition,Timing Angle,
    ;0.0 BTDC,Ign. Timing,
    4,0,Basic Functions,
    4,1,Engine Speed,,
    ;0 /min,RPM,
    4,2,Supply Voltage,,Specification: 12.0...15.0 V
    ;11.270 V,Voltage,
    4,3,Coolant,Temperature,Specification: 80.0...110.0 C
    ;7.0C,Temperature,
    4,4,Intake Air,Temperature,
    ;9.0C,Temperature,
    5,0,Basic Functions,
    5,1,Engine Speed,,
    ;0 /min,RPM,
    5,2,Engine Load,,
    ;100.0 %,Load,
    5,3,Vehicle Speed,,
    ;0.0 km/h,Speed,
    5,4,Load Status,,Display Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
    ;Idle, ,
    6,0,Basic Functions,
    6,1,Engine Speed,,
    ;0 /min,RPM,
    6,2,Engine Load,,
    ;100.0 %,Load,
    6,3,Intake Air,Temperature,
    ;9.0C,Temperature,
    6,4,Altitude,Correction Factor,
    ;-4.7 %,Lambda,
    8,0,Basic Functions,
    8,1,Brake Condition,,Display Range: Operated/Not Oper.
    ;Not Oper., ,
    8,2,Vacuum Pump,Condition,Display Range: Pump ON/Pump OFF
    ;11.270 V,Voltage,
    8,3,Brake Booster,Pressure,
    ;970.0 mbar,Absolute Pres.,
    8,4,,,
    9,0,,
    9,1,,,
    9,2,,,
    9,3,,,
    ;800.0,(no units),
    9,4,,,
    10,0,Ignition,
    10,1,Engine Speed,,
    ;0 /min,RPM,
    10,2,Engine Load,,
    ;100.0 %,Load,
    10,3,Throttle Position,Sensor (G187),
    ;6.7 %,Load,
    10,4,Ignition,Timing Angle,
    11,0,Ignition,
    11,1,Engine Speed,,
    ;0 /min,RPM,
    11,2,Coolant,Temperature,Specification: 80.0...110.0 C
    ;7.0C,Temperature,
    11,3,Intake Air,Temperature,
    ;9.0C,Temperature,
    11,4,Ignition,Timing Angle,
    14,0,Ignition (Misfire Recognition - Total),
    14,1,Engine Speed,,
    ;0 /min,RPM,
    14,2,Engine Load,,
    ;100.0 %,Load,
    14,3,Misfire,(total),Specification: 0
    ;0,Count,
    14,4,Misfire,Recognition,Display Range: Disabled/Enabled
    ;Disabled, ,
    15,0,Ignition (Misfire Recognition - Cylinder 1-3),
    15,1,Misfire Counter,Cylinder 1,
    ;0,Count,
    15,2,Misfire Counter,Cylinder 2,
    ;0,Count,
    15,3,Misfire Counter,Cylinder 3,
    ;0,Count,
    15,4,Misfire,Recognition,Display Range: Disabled/Enabled
    ;Disabled, ,
    16,0,Ignition (Misfire Recognition - Cylinder 4-6),
    16,1,Misfire Counter,Cylinder 4,
    ;0,Count,
    16,2,Misfire Counter,Cylinder 5,
    ;0,Count,
    16,3,Misfire Counter,Cylinder 6,
    ;0,Count,
    16,4,Misfire,Recognition,Display Range: Disabled/Enabled
    ;Disabled, ,
    18,0,RPM/Load Barriers,
    18,1,Lower,RPM Barrier,
    ;0 /min,RPM,
    18,2,Upper,RPM Barrier,
    ;0 /min,RPM,
    18,3,Lower,Load Barrier,
    ;0.0 %,Load,
    18,4,Upper,Load Barrier,
    ;0.0 %,Load,
    20,0,Ignition (Timing Retardation Cylinder 1-4),
    20,1,Timing Retardation,Cylinder 1,
    ;0.0KW,Idle Stabilization,
    20,2,Timing Retardation,Cylinder 2,
    20,3,Timing Retardation,Cylinder 3,
    20,4,Timing Retardation,Cylinder 4,
    21,0,Ignition (Timing Retardation Cylinder 5-8),
    21,1,Timing Retardation,Cylinder 5,
    21,2,Timing Retardation,Cylinder 6,
    21,3,,,
    21,4,,,
    22,0,Ignition (Timing Retardation Cylinder 1 && 2),
    22,1,Engine Speed,,
    ;0 /min,RPM,
    22,2,Engine Load,,
    ;100.0 %,Load,
    22,3,Timing Retardation,Cylinder 1,
    22,4,Timing Retardation,Cylinder 2,
    23,0,Ignition (Timing Retardation Cylinder 3 && 4),
    23,1,Engine Speed,,
    ;0 /min,RPM,
    23,2,Engine Load,,
    ;100.0 %,Load,
    23,3,Timing Retardation,Cylinder 3,
    23,4,Timing Retardation,Cylinder 4,
    24,0,Ignition (Timing Retardation Cylinder 5 && 6),
    24,1,Engine Speed,,
    ;0 /min,RPM,
    24,2,Engine Load,,
    ;100.0 %,Load,
    24,3,Timing Retardation,Cylinder 5,
    24,4,Timing Retardation,Cylinder 6,
    26,0,Ignition (Knock Control Cylinder 1-4),
    26,1,Voltage,Cylinder 1,
    ;3.510 V,Voltage,
    26,2,Voltage,Cylinder 2,
    ;3.510 V,Voltage,
    26,3,Voltage,Cylinder 3,
    ;3.510 V,Voltage,
    26,4,Voltage,Cylinder 4,
    ;3.510 V,Voltage,
    27,0,Ignition (Knock Control Cylinder 5-8),
    27,1,Voltage,Cylinder 5,
    ;3.510 V,Voltage,
    27,2,Voltage,Cylinder 6,
    ;3.510 V,Voltage,
    27,3,,,
    27,4,,,
    28,0,Ignition (Knock Sensor Test - Short Trip),
    28,1,Engine Speed,,
    ;0 /min,RPM,
    28,2,Engine Load,,
    ;100.0 %,Load,
    28,3,Coolant,Temperature,Specification: 80.0...110.0 C
    ;7.0C,Temperature,
    28,4,Result,,Display Range: Test ON/Test OFF/Sys. OK/Sys. not OK
    Specification: Sys. OK
    ;Test OFF, ,
    30,0,Lambda Control (Sensor Status),
    30,1,Bank 1,Sensor 1,
    ;   00000,Bin. Bits,
    30,2,Bank 1,Sensor 2,
    ;    0000,Bin. Bits,
    30,3,Bank 2,Sensor 1,
    ;   00000,Bin. Bits,
    30,4,Bank 2,Sensor 2,
    ;    0000,Bin. Bits,
    31,0,Lambda Control (Lambda Sensor Voltages),
    31,1,Lambda Sensor,B1-S1 (actual),
    ;1.000,Lambda Factor,
    31,2,Lambda Sensor,B1-S1 (specified),
    ;0.797,Lambda Factor,
    31,3,Lambda Sensor,B2-S1 (actual),
    31,4,Lambda Sensor,B2-S1 (specified),
    32,0,Lambda Control (Mixture Adaptation),
    32,1,Adaptation (Idle),Bank 1 Sensor 1,
    ;0.8 %,Lambda,
    32,2,Adaptation (Partial),Bank 1 Sensor 1,
    ;-0.8 %,Lambda,
    32,3,Adaptation (Idle),Bank 2 Sensor 1,
    ;0.8 %,Lambda,
    32,4,Adaptation (Partial),Bank 2 Sensor 1,
    ;-3.1 %,Lambda,
    33,0,Lambda Control,
    33,1,Lambda Control,Bank 1 Sensor 1,
    ;0.0 %,Lambda,
    33,2,Sensor Voltage,Bank 1 Sensor 1,
    ;1.540 V,Voltage,
    33,3,Lambda Control,Bank 2 Sensor 1,
    ;0.0 %,Lambda,
    33,4,Sensor Voltage,Bank 2 Sensor 1,
    ;1.540 V,Voltage,
    34,0,Lambda Control (Aging Check Bank 1),
    34,1,Engine Speed,,
    ;0 /min,RPM,
    34,2,Catalytic Converter,Temperature,
    ;55.0C,Temperature,
    34,3,Dynamic Factor,Bank 1 Sensor 1,
    ;2.06,(no units),
    34,4,Result,Lambda Aging,Display Range: Test ON/Test OFF/B1-S1 not OK/B1-S1 OK
    Specification: B1-S1 OK
    ;Test OFF, ,
    35,0,Lambda Control (Aging Check Bank 2),
    35,1,Engine Speed,,
    ;0 /min,RPM,
    35,2,Catalytic Converter,Temperature,
    ;55.0C,Temperature,
    35,3,Dynamic Factor,Bank 2 Sensor 1,
    ;2.06,(no units),
    35,4,Result,Lambda Aging,Display Range: Test ON/Test OFF/B2-S1 not OK/B2-S1 OK
    Specification: B2-S1 OK
    ;Test OFF, ,
    36,0,Lambda Control (Sensor Readiness - After Catalyst),
    36,1,Sensor Voltage,Bank 1 Sensor 2,
    ;0.435 V,Voltage,
    36,2,Result,Lambda Availability,Display Range: Test ON/Test OFF/B1-S2 not OK/B1-S2 OK
    Specification: B1-S2 OK
    ;Test OFF, ,
    36,3,Sensor Voltage,Bank 2 Sensor 2,
    ;0.440 V,Voltage,
    36,4,Result,Lambda Availability,Display Range: Test ON/Test OFF/B2-S2 not OK/B2-S2 OK
    Specification: B2-S2 OK
    ;Test OFF, ,
    37,0,Lambda Control (Delta Lambda Bank 1),
    37,1,Engine Load,,
    ;100.0 %,Load,
    37,2,Sensor Voltage,Bank 1 Sensor 2,
    ;0.435 V,Voltage,
    37,3,Delta Lambda,Bank 1 Sensor 2,
    ;0.000,Difference,
    37,4,Result,,Specification: Test ON/Test OFF/B1-S1 OK/B1-S1 n.OK
    ;Test OFF, ,
    38,0,Lambda Control (Delta Lambda Bank 2),
    38,1,Engine Load,,
    ;100.0 %,Load,
    38,2,Sensor Voltage,Bank 2 Sensor 2,
    ;0.440 V,Voltage,
    38,3,Delta Lambda,Bank 2 Sensor 2,
    ;0.000,Difference,
    38,4,Result,,Specification: Test ON/Test OFF/B2-S1 OK/B2-S1 n.OK
    ;Test OFF, ,
    39,0,Lambda Control (Sensor Exchange),
    39,1,Mass Air Flow,,
    39,2,Sensor Voltage,Bank 1 Sensor 2,
    ;0.435 V,Voltage,
    39,3,Sensor Voltage,Bank 2 Sensor 2,
    ;0.440 V,Voltage,
    39,4,Result,Sensor Exchange,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK
    Specification: Syst. OK
    ;00000000,Bin. Bits,
    41,0,Lambda Sensor Heating Bank 1,
    41,1,Resistance,Bank 1 Sensor 1,
    ;502 ohms,Resistance,
    41,2,Heater Condition,,Display Range: Htg. S1 OFF/Htg. S1 ON
    ;Htg. S1 OFF, ,
    41,3,,,
    41,4,Heater Condition,,Display Range: Htg. S2 OFF/Htg. S2 ON
    ;Htg. S2 OFF, ,
    42,0,Lambda Sensor Heating Bank 2,
    42,1,Resistance,Bank 2 Sensor 1,
    42,2,Heater Condition,,Display Range: Htg. S1 OFF/Htg. S1 ON
    ;Htg. S1 OFF, ,
    42,3,,,
    42,4,Heater Condition,,Display Range: Htg. S2 OFF/Htg. S2 ON
    ;Htg. S2 OFF, ,
    43,0,Lambda Sensor Aging Bank 1,
    43,1,Engine Speed,,
    ;0 /min,RPM,
    43,2,Catalytic Converter,Temperature,
    ;55.0C,Temperature,
    43,3,Lambda Voltage,Bank 1 Sensor 2,
    ;0.435 V,Voltage,
    43,4,Result,Aging,Display Range: Test ON/Test OFF/B1-S2 OK/B1-S2 n.OK
    ;Test OFF, ,
    44,0,Lambda Sensor Aging Bank 2,
    44,1,Engine Speed,,
    ;0 /min,RPM,
    44,2,Catalytic Converter,Temperature,
    ;55.0C,Temperature,
    44,3,Lambda Voltage,Bank 2 Sensor 1,
    ;0.435 V,Voltage,
    44,4,Result,Aging,Display Range: Test ON/Test OFF/B2-S2 OK/B2-S2 n.OK
    ;Test OFF, ,
    46,0,Catalytic Conversion Test Bank 1,
    46,1,Engine Speed,,
    ;0 /min,RPM,
    46,2,Catalytic Converter,Temperature,
    ;55.0C,Temperature,
    46,3,Catalytic,Conversion,
    ;0.00,(no units),
    46,4,Result,Cat. Conversion,Display Range: Test ON/Test OFF/CatB1 OK/CatB1 n.OK
    Specification: CatB1 OK
    ;Test OFF, ,
    47,0,Catalytic Conversion Test Bank 2,
    47,1,Engine Speed,,
    ;0 /min,RPM,
    47,2,Catalytic Converter,Temperature,
    ;55.0C,Temperature,
    47,3,Catalytic,Conversion,
    ;0.00,(no units),
    47,4,Result,Cat. Conversion,Display Range: Test ON/Test OFF/CatB2 OK/CatB2 n.OK
    Specification: CatB2 OK
    ;Test OFF, ,
    50,0,Engine Speed Increase,
    50,1,Engine Speed,(actual),
    ;0 /min,RPM,
    50,2,Engine Speed,(specified),
    ;800 /min,RPM,
    50,3,A/C Readiness,,Display Range: A/C-Low / A/C-High
    ;A/C-Low, ,
    50,4,A/C Compressor,,Display Range: Compr.OFF/Compr.ON
    ;Compr.OFF, ,
    51,0,Engine Speed Increase (Gear shifts),
    51,1,Engine Speed,(actual),
    ;0 /min,RPM,
    51,2,Engine Speed,(specified),
    ;800 /min,RPM,
    51,3,Selected Gear,,Display Range: P or N = 0/Gear = 1 - 6/R = 7
    ;0,Count,
    51,4,Supply Voltage,,Specification: 12.0...15.0 V
    ;11.270 V,Voltage,
    52,0,Engine Speed Increase,
    52,1,Engine Speed,(actual),Specification (Idle): 640...740 RPM
    Specification (Load): 3000...3500 RPM
    Display Range: 640...6800 RPM
    ;0 /min,RPM,
    52,2,Engine Speed,(specified),
    ;800 /min,RPM,
    52,3,A/C Readiness,,Display Range: A/C-Low / A/C-High
    ;A/C-Low, ,
    52,4,,,
    53,0,Engine Speed Increase (Generator Load),
    53,1,Engine Speed,(actual),
    ;0 /min,RPM,
    53,2,Engine Speed,(specified),
    ;800 /min,RPM,
    53,3,Supply Voltage,,Specification: 12.0...15.0 V
    ;11.270 V,Voltage,
    53,4,,,
    54,0,Idle Speed Stabilization,
    54,1,Engine Speed,,
    ;0 /min,RPM,
    54,2,Load Status,,Display Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
    ;Idle, ,
    54,3,Throttle Position,Sensor (G79),
    ;0.0 %,Load,
    54,4,Throttle Position,Sensor (G187),
    ;6.7 %,Load,
    55,0,Idle Speed Stabilization,
    55,1,Engine Speed,,
    ;0 /min,RPM,
    55,2,Idle Regulator,,
    ;0.0 %,Lambda,
    55,3,Idle Stabilization,Self-Adaptation,
    ;0.6 %,Lambda,
    55,4,Operating,Condition,00xxx1 = A/C Compressor ON
    00xx1x = Gear engaged
    00x1xx = A/C Readiness ON
    001xxx = Rear Window Heater ON
    ;  000000,Bin. Bits,
    56,0,Idle Speed Stabilization,
    56,1,Engine Speed,(actual),
    ;0 /min,RPM,
    56,2,Engine Speed,(specified),
    ;800 /min,RPM,
    56,3,Idle Regulator,,
    ;0.0 %,Lambda,
    56,4,Operating,Condition,00xxx1 = A/C Compressor ON
    ;  000000,Bin. Bits,
    57,0,Idle Speed Stabilization (Air Condition),
    57,1,Engine Speed,(actual),
    ;0 /min,RPM,
    57,2,Engine Speed,(specified),
    ;800 /min,RPM,
    57,3,A/C Compressor,,Display Range: Compr.OFF/Compr.ON
    ;Compr.OFF, ,
    57,4,A/C Compressor,Pressure,
    58,0,Engine Mounting,
    58,1,Engine Speed,,
    ;0 /min,RPM,
    58,2,Engine Load,,
    ;100.0 %,Load,
    58,3,,,
    58,4,,,
    60,0,Electronic Throttle Adaptation,
    60,1,Throttle Position,Sensor (G187),
    ;15.6 %,Duty Cycle,
    60,2,Throttle Position,Sensor (G188),
    ;84.4 %,Duty Cycle,
    60,3,Adaptation,Steps Counter,Specification: 0
    ;0,Count,
    60,4,Result,Throttle Valve Adp.,Display Range: ADP RUN/ADP OK/ADP ERROR
    Specification: ADP OK
    ;ADP. O.K., ,
    61,0,Electronic Throttle,
    61,1,Engine Speed,,
    ;0 /min,RPM,
    61,2,Supply Voltage,,Specification: 12.0...15.0 V
    ;11.270 V,Voltage,
    61,3,Throttle Position,Sensor (G187),
    ;6.7 %,Load,
    61,4,Operating,Condition,00xxx1 = A/C Compressor ON
    ;  000000,Bin. Bits,
    62,0,Electronic Throttle,
    62,1,Throttle Position,Sensor (G187),
    ;15.6 %,Duty Cycle,
    62,2,Throttle Position,Sensor (G188),
    ;84.4 %,Duty Cycle,
    62,3,Throttle Position,Sensor (G79),
    ;14.5 %,Duty Cycle,
    62,4,Accelerator Pedal,Position  (G185),
    ;7.0 %,Duty Cycle,
    63,0,Electronic Throttle (Kick-Down Adaptation),
    63,1,Throttle Position,Sensor (G79),
    ;14.5 %,Duty Cycle,
    63,2,Kick-Down,Adaptation Value,
    63,3,Kick-Down,Switch,Display Range: Kick Down
    63,4,Kick-Down,Adaptation,Display Range: ADP RUN/ADP OK/ADP ERROR
    64,0,Throttle Valve Potentiometer Adaption Values,
    64,1,Potentiometer 1,Lower Adaptation,
    ;0.520 V,Voltage,
    64,2,Potentiometer 2,Lower Adaptation,
    ;4.580 V,Voltage,
    64,3,Emergency Air Gap,Potentiometer 1,
    ;0.800 V,Voltage,
    64,4,Emergency Air Gap,Potentiometer 2,
    ;4.320 V,Voltage,
    66,0,Cruise Control System,
    66,1,Vehicle Speed,(current),
    ;0.0 km/h,Speed,
    66,2,Pedal Settings,,
    ;00001000,Bin. Bits,
    66,3,Vehicle Speed,(specified),
    ;0.0 km/h,Speed,
    66,4,Switch Settings,,
    ;00000011,Bin. Bits,
    70,0,Emission Reduction (TEV - Basic Setting),
    70,1,Evap. Emissions,Sol. Valve (Open),Specification: 0...100 %
    ;0.0 %,Load,
    70,2,Lambda Control,,
    ;0.0 %,Lambda,
    70,3,Evap. Emissions,Sol. Valve (Flow),
    70,4,Result,,Display Range: Test ON/Test OFF/TEV OK/TEV not OK
    ;Test OFF, ,
    71,0,Exhaust Reduction (Basic Setting: Leak Diagnostic System),
    71,1,Reed Contact,Condition,Display Range: Reed Open/Reed Closed
    ;Reed Open, ,
    71,2,Malfunction Display,,Display Range: minor leak/significant leak/Open circuit
    ;Abort, ,
    71,3,Diagnostic Status,,Display Range: System test/Measurement end
    71,4,Result,Leak Test,Display Range: Test ON/Test OFF/Syst. OK/Syst. not OK
    ;Test OFF, ,
    72,0,,
    72,1,Reed Contact,Condition,
    ;Reed Open, ,
    72,2,Malfunction,Message,
    ;Abort, ,
    72,3,,,
    72,4,Result,,
    ;Test OFF, ,
    73,0,,
    73,1,Opening angle,of TVV,
    ;0.0 %,Load,
    73,2,Flush rate,,
    ;0.0 %,Load,
    73,3,Load factor,,
    ;0.0 %,Lambda,
    73,4,TE-Fuel portion,,
    ;0.0 %,Lambda,
    77,0,Emission Reduction (Bank 1),
    77,1,Engine Speed,,
    ;0 /min,RPM,
    77,2,Mass Air Flow,,
    77,3,Air Mass from,Sec. Air Inj. Bank 1,
    ;0.0 %,Lambda,
    77,4,Result,,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK
    ;Test OFF, ,
    78,0,Emission Reduction (Bank 2),
    78,1,Engine Speed,,
    ;0 /min,RPM,
    78,2,Mass Air Flow,,
    78,3,Air Mass from,Sec. Air Inj. Bank 2,
    ;0.0 %,Lambda,
    78,4,Result,,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK
    ;Test OFF, ,
    79,0,,
    79,1,Engine Speed,,
    ;0 /min,RPM,
    79,2,Engine Load,,
    ;100.0 %,Load,
    79,3,Flap Bank 1,,
    ;OFF, ,
    79,4,Flap Bank 2,,
    80,0,Advanced Control Module Identification I,
    80,1,,,
    ;   <>   09.01.04    <>     <>  0245,RPM,
    81,0,Advanced Control Module Identification II,
    81,1,VIN & IMMO-ID,,
    ;WVWSR61J84W047451 VWZ7Z0C7769815   <>   ,VIN & IMMO-ID,
    82,0,Advanced Control Module Identification III,
    82,1,,,
    ;0000000000000    <>    000 00 <>  <>,VIN & IMMO-ID,
    86,0,Readiness Code I,
    86,1,Readiness Bits,,
    86,2,Cycle Flags,,
    ;11111111,Bin. Bits,
    86,3,Cycle Flags,,
    ;01101011,Bin. Bits,
    86,4,Cycle Flags,,
    ;00001011,Bin. Bits,
    87,0,Readiness Code II,
    87,1,Readiness Bits,,
    87,2,Error Flags,,
    87,3,Error Flags,,
    87,4,Error Flags,,
    88,0,Readiness Code III,
    88,1,Cycle Flags,,
    ;11111010,Bin. Bits,
    88,2,Cycle Flags,,
    ;11101111,Bin. Bits,
    88,3,Cycle Flags,,
    ;11001100,Bin. Bits,
    88,4,,,
    89,0,,
    89,1,Distance Driven,with MIL on,
    ;0,Count,
    89,2,Tank Condition,,Display Range: OK/too low
    ;OK, ,
    89,3,,,
    89,4,,,
    90,0,Continuous Camshaft Adjustment (Bank 1 - Exhaust),
    90,1,Engine Speed,,
    ;0 /min,RPM,
    90,2,Duty Cycle,,
    ;20.0 %,Load,
    90,3,Adjustment Bank 1,(specified),
    90,4,Adjustment Bank 1,(actual),
    91,0,Continuous Camshaft Adjustment (Bank 1 - Intake),
    91,1,Engine Speed,,
    ;0 /min,RPM,
    91,2,Duty Cycle,,
    ;14.9 %,Load,
    91,3,Adjustment Bank 1,(specified),
    91,4,Adjustment Bank 1,(actual),
    93,0,Continuous Camshaft Adjustment (Bank 2 - Intake),
    93,1,Engine Speed,,
    ;0 /min,RPM,
    93,2,Duty Cycle,,
    ;100.0 %,Load,
    93,3,Adjustment,(specified),
    ;-2.0KW,Idle Stabilization,
    93,4,Adjustment,(actual),
    ;-3.0KW,Idle Stabilization,
    94,0,Continuous Camshaft Adjustment (Intake),
    94,1,Adjustment,Bank 1,
    94,2,Adjustment,Bank 2,
    94,3,Result Bank 1,,Display Range: Test OFF/Test ON/System OK/System Not OK
    ;Test OFF, ,
    94,4,Result Bank 2,,Display Range: Test OFF/Test ON/System OK/System Not OK
    95,0,Performance Increase (Intake Manifold Change Over),
    95,1,Engine Speed,,Specification: 650...6500 RPM
    ;0 /min,RPM,
    95,2,Engine Load,,Specification: 0...100 %
    ;100.0 %,Load,
    95,3,Coolant,Temperature,Specification: 80.0...110.0 C
    ;7.0C,Temperature,
    95,4,Switch-Over,Staus,Display Range: IMC-V ON/IMC-V OFF
    ;IMC-V OFF, ,
    96,0,Continuous Camshaft Adjustment (Exhaust),
    96,1,Adjustment,Bank 1,
    96,2,Adjustment,Bank 2,
    96,3,Result Bank 1,,Display Range: Test ON/Test OFF/System OK/System Not OK
    Specification: System OK
    ;Test OFF, ,
    96,4,Result Bank 2,,Display Range: Test ON/Test OFF/System OK/System Not OK
    98,0,Continuous Camshaft Adjustment (Exhaust - Bank 2),
    98,1,Engine Speed,,
    ;0 /min,RPM,
    98,2,Engine Load,,
    ;20.0 %,Load,
    98,3,Adjustment,(specified),
    98,4,Adjustment,(actual),
    99,0,Lambda Control Shut-Off (Basic Setting),
    99,1,Engine Speed,,
    ;0 /min,RPM,
    99,2,Lambda Control,Bank 1,
    99,3,Lambda Control,Bank 2,
    99,4,Lambda Control,Status,Display Range: O2-Reg.OFF/O2-Reg.ON
    ;O2-Reg.OFF, ,
    100,0,Readiness Code,
    100,1,Readiness Bits,,see labelfile
    100,2,Coolant,Temperature,Specification: 80.0...110.0 C
    ;7.0C,Temperature,
    100,3,Time since,Engine Start,
    ;0.00 s,Time,
    100,4,OBD-Status,,see labelfile
    ;10000000,Bin. Bits,
    101,0,Fuel Injection,
    101,1,Engine Speed,,
    ;0 /min,RPM,
    101,2,Engine Load,,
    ;100.0 %,Load,
    101,3,Injection Timing,,
    101,4,Mass Air Flow,,
    102,0,Fuel Injection,
    102,1,Engine Speed,,
    ;0 /min,RPM,
    102,2,Coolant,Temperature,Specification: 80.0...110.0 C
    ;7.0C,Temperature,
    102,3,Intake Air,Temperature,
    ;9.0C,Temperature,
    102,4,Injection Timing,,
    104,0,Start Adaption Values,
    104,1,Start Engine,Temperature,
    ;7.0C,Temperature,
    104,2,Temperature,Adaptation Factor 1,
    ;28.9 %,Lambda,
    104,3,Temperature,Adaptation Factor 2,
    ;28.9 %,Lambda,
    104,4,Temperature,Adaptation Factor 3,
    ;28.9 %,Lambda,
    105,0,Cylinder Shut-Off,
    105,1,Engine Speed,,
    ;0 /min,RPM,
    105,2,Engine Load,,
    ;100.0 %,Load,
    105,3,Coolant,Temperature,Specification: 80.0...110.0 C
    ;7.0C,Temperature,
    105,4,Status,Cylinder Shut-Off,Display Range: ON/OFF
    ;OFF, ,
    107,0,Lambda Control,
    107,1,Engine Speed,,
    ;0 /min,RPM,
    107,2,Lambda Control,Bank 1 (average),
    ;0.0 %,Lambda,
    107,3,Lambda Control,Bank 2 (average),
    ;0.0 %,Lambda,
    107,4,Result,Lambda Control,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK
    ;Test OFF, ,
    110,0,Load/Full Throttle Enrichment,
    110,1,Engine Speed,,
    ;0 /min,RPM,
    110,2,Coolant,Temperature,Specification: 80.0...110.0 C
    ;7.0C,Temperature,
    110,3,Injection Timing,,
    110,4,Throttle Position,Sensor (G187),
    ;6.7 %,Load,
    112,0,Exhaust Gas Temperature,
    112,1,Exhaust Gas,Temperature Bank 1,
    ;55.0C,Temperature,
    112,2,,,
    112,3,Exhaust Gas,Temperature Bank 2,
    ;55.0C,Temperature,
    112,4,,,
    113,0,Load/Full Throttle Enrichment,
    113,1,Engine Speed,,
    ;0 /min,RPM,
    113,2,Engine Load,,
    ;100.0 %,Load,
    113,3,Throttle Position,Sensor (G187),
    ;6.7 %,Load,
    113,4,Athmospheric,Pressure,
    120,0,Traction Control (ASR),
    120,1,Engine Speed,,
    ;0 /min,RPM,
    120,2,Engine Load,(specified),
    ;408.0 Nm,Torque,
    120,3,Engine Load,(actual),
    ;246.0 Nm,Torque,
    120,4,Status,,Specification: ASR OFF/ASR ON
    ;ASR OFF, ,
    122,0,Transmission,
    122,1,Engine Speed,,
    ;0 /min,RPM,
    122,2,Engine Load,(specified),
    ;408.0 Nm,Torque,
    122,3,Engine Load,(actual),
    ;246.0 Nm,Torque,
    122,4,Status,,Display Range: Engine interv./No engine interv.
    ;No Torq Red, ,
    125,0,CAN-Databus Powertrain (Communication),
    125,1,Transmission,,Display Range: Transm. 1/Transm. 0
    125,2,Brake Electronics,,Specification: ABS 1
    Display Range: ABS 1/ABS 0
    ;ABS 1, ,
    125,3,Instrument Cluster,,Specification: Instruments 1
    Display Range: Instruments 1/Instruments 0
    ;Instruments 1, ,
    125,4,,,
    126,0,CAN-Databus Powertrain (Communication),
    126,1,,,
    126,2,,,
    126,3,Airbag,,Specification: Airbag 1
    Display Range: Airbag 1/Airbag 0
    ;Airbag 1, ,
    126,4,,,
    130,0,Map Cooling,
    130,1,Engine Outlet,Temperature,
    ;7.0C,Temperature,
    130,2,,,
    130,3,,,
    130,4,,,
    131,0,Map Cooling,
    131,1,Engine Outlet,Temperature,
    ;7.0C,Temperature,
    131,2,,,
    131,3,,,
    131,4,,,
    134,0,Temperatures,
    134,1,Oil Temperature,,
    ;-60.0C,Temperature,
    134,2,Ambient,Temperature,
    ;7.0C,Temperature,
    134,3,Intake Air,Temperature,
    ;9.0C,Temperature,
    134,4,Engine Outlet,Temperature,
    ;7.0C,Temperature,
    137,0,Air Condition Requirements,
    137,1,A/C Readiness,,Display Range: A/C-Low / A/C-High
    ;A/C-Low, ,
    137,2,A/C Compressor,,Display Range: Compr.OFF/Compr.ON
    ;Compr.OFF, ,
    137,3,,,
    137,4,,,
    138,0,,
    138,1,,,
    ;7.0C,Temperature,
    138,2,,,
    ;113.33 g/s,Mass Flow,
    138,3,,,
    ;224.4 km/h,Speed,
    138,4,,,
    ;Test OFF, ,
    139,0,,
    139,1,,,
    ;7.0C,Temperature,
    139,2,,,
    ;0.0 kg,Mass/Weight,
    139,3,,,
    ;8.4 kg,Mass/Weight,
    139,4,,,
    ;Test OFF, ,
    201,0,,
    201,1,,,
    ;0.0 %,Lambda,
    201,2,,,
    ;0.0 %,Lambda,
    201,3,,,
    201,4,,,
    202,0,,
    202,1,,,
    ;0.00 s,Time,
    202,2,,,
    ;0.00 s,Time,
    202,3,,,
    ;Abort, ,
    202,4,,,
    203,0,,
    203,1,,,
    ;0 /min,RPM,
    203,2,,,
    ;100.0 %,Load,
    203,3,,,
    ;7.0C,Temperature,
    203,4,,,
    204,0,,
    204,1,,,
    ;0 /min,RPM,
    204,2,,,
    ;0.0 km/h,Speed,
    204,3,,,
    ;55.0C,Temperature,
    204,4,,,
    205,0,,
    205,1,,,
    205,2,,,
    ;0.0 %,Load,
    205,3,,,
    ;-1.0,(no units),
    205,4,,,
    206,0,,
    206,1,,,
    206,2,,,
    ;0.0 %,Load,
    206,3,,,
    ;-2.0,(no units),
    206,4,,,
    207,0,,
    207,1,,,
    ;0.00 s,Time,
    207,2,,,
    ;0.00 s,Time,
    207,3,,,
    ;0,Count,
    207,4,,,
    208,0,,
    208,1,,,
    ;0 /min,RPM,
    208,2,,,
    ;123,Count,
    208,3,,,
    208,4,,,
    ;00100000,Bin. Bits,
    209,0,,
    209,1,,,
    ;0 /min,RPM,
    209,2,,,
    ;123,Count,
    209,3,,,
    209,4,,,
    210,0,,
    210,1,,,
    210,2,,,
    210,3,,,
    ;1,Count,
    210,4,,,
    211,0,,
    211,1,,,
    211,2,,,
    211,3,,,
    ;1,Count,
    211,4,,,
    212,0,,
    212,1,,,
    ;0.000,Difference,
    212,2,,,
    ;0,Count,
    212,3,,,
    ;2.06,(no units),
    212,4,,,
    213,0,,
    213,1,,,
    ;0.000,Difference,
    213,2,,,
    ;0,Count,
    213,3,,,
    ;2.06,(no units),
    213,4,,,
    215,0,,
    215,1,,,
    215,2,,,
    215,3,,,
    215,4,,,
    216,0,,
    216,1,,,
    ;1.016,Lambda Factor,
    216,2,,,
    ;0.992,Lambda Factor,
    216,3,,,
    ;0.8 %,Lambda,
    216,4,,,
    ;01100000,Bin. Bits,
    217,0,,
    217,1,,,
    217,2,,,
    ;0.969,Lambda Factor,
    217,3,,,
    ;0.8 %,Lambda,
    217,4,,,
    218,0,,
    218,1,,,
    ;-0.020,Difference,
    218,2,,,
    ;1.00,(no units),
    218,3,,,
    ;0.94,(no units),
    218,4,,,
    220,0,,
    220,1,,,
    ;25.50 kOhm,Resistance,
    220,2,,,
    220,3,,,
    ;54.0C,Temperature,
    220,4,,,
    221,0,,
    221,1,,,
    221,2,,,
    221,3,,,
    ;54.0C,Temperature,
    221,4,,,
    222,0,,
    222,1,,,
    ;0.435 V,Voltage,
    222,2,,,
    222,3,,,
    ;55.0C,Temperature,
    222,4,,,
    223,0,,
    223,1,,,
    ;0.440 V,Voltage,
    223,2,,,
    223,3,,,
    ;55.0C,Temperature,
    223,4,,,
    224,0,,
    224,1,,,
    ;0.435 V,Voltage,
    224,2,,,
    ;0.440 V,Voltage,
    224,3,,,
    ;0.00 s,Time,
    224,4,,,
    225,0,,
    225,1,,,
    ;0.435 V,Voltage,
    225,2,,,
    225,3,,,
    ;0.00 s,Time,
    225,4,,,
    226,0,,
    226,1,,,
    ;0.440 V,Voltage,
    226,2,,,
    226,3,,,
    ;0.00 s,Time,
    226,4,,,
    227,0,,
    227,1,,,
    ;0.00,(no units),
    227,2,,,
    ;55.0C,Temperature,
    227,3,,,
    ;1.00 s,Time,
    227,4,,,
    ;01110000,Bin. Bits,
    228,0,,
    228,1,,,
    ;0.00,(no units),
    228,2,,,
    ;55.0C,Temperature,
    228,3,,,
    ;1.00 s,Time,
    228,4,,,
    229,0,,
    229,1,,,
    ;0.0 %,Load,
    229,2,,,
    ;0.0 %,Lambda,
    229,3,,,
    ;0.0 %,Load,
    229,4,,,
    231,0,,
    231,1,,,
    ;0.0 %,Lambda,
    231,2,,,
    231,3,,,
    ;0.000,Difference,
    231,4,,,
    232,0,,
    232,1,,,
    ;0.0 %,Lambda,
    232,2,,,
    232,3,,,
    ;0.000,Difference,
    232,4,,,
    233,0,,
    233,1,,,
    ;0.0 %,Lambda,
    233,2,,,
    233,3,,,
    ;0.8 %,Lambda,
    233,4,,,
    234,0,,
    234,1,,,
    ;0.0 %,Lambda,
    234,2,,,
    234,3,,,
    ;0.8 %,Lambda,
    234,4,,,
    237,0,,
    237,1,,,
    ;2543,Count,
    237,2,,,
    ;1539,Count,
    237,3,,,
    ;4123,Count,
    237,4,,,
    238,0,,
    238,1,,,
    ;1527,Count,
    238,2,,,
    ;1607,Count,
    238,3,,,
    ;637,Count,
    238,4,,,
    239,0,,
    239,1,,,
    ;00111111,Bin. Bits,
    239,2,,,
    ;01111111,Bin. Bits,
    239,3,,,
    239,4,,,
    ;0,Count,
    240,0,,
    240,1,,,
    240,2,,,
    240,3,,,
    ;4,Count,
    240,4,,,
    241,0,,
    241,1,,,
    ;6.0C,Temperature,
    241,2,,,
    ;7.0C,Temperature,
    241,3,,,
    ;27.0C,Temperature,
    241,4,,,
    ;9.0C,Temperature,
    242,0,,
    242,1,,,
    ;0,Count,
    242,2,,,
    ;0,Count,
    242,3,,,
    ;9.0C,Temperature,
    242,4,,,
    ;00010000,Bin. Bits,
    243,0,,
    243,1,,,
    ;9.0C,Temperature,
    243,2,,,
    ;22.0C,Temperature,
    243,3,,,
    ;0,Count,
    243,4,,,
    ;9.0C,Temperature,
    244,0,,
    244,1,,,
    ;1.5KW,Idle Stabilization,
    244,2,,,
    244,3,,,
    244,4,,,
    ;0.8KW,Idle Stabilization,
    245,0,,
    245,1,,,
    245,2,,,
    245,3,,,
    ;100.0 %,Load,
    245,4,,,
    ;First Map, ,
    246,0,,
    246,1,,,
    ;1.05,(no units),
    246,2,,,
    ;1.11,(no units),
    246,3,,,
    ;1.08,(no units),
    246,4,,,
    ;0.80,(no units),
    247,0,,
    247,1,,,
    ;0.6 %,Lambda,
    247,2,,,
    ;0.0 %,Lambda,
    247,3,,,
    ;7.0C,Temperature,
    247,4,,,
    248,0,,
    248,1,,,
    ;0.6 %,Lambda,
    248,2,,,
    ;-1.6 %,Lambda,
    248,3,,,
    ;0.0 %,Lambda,
    248,4,,,
    ;0.0 %,Lambda,
    249,0,,
    249,1,,,
    ;1.00,(no units),
    249,2,,,
    ;0.94,(no units),
    249,3,,,
    ;0.56 g/s,Mass Flow,
    249,4,,,
    250,0,,
    250,1,,,
    250,2,,,
    250,3,,,
    ;83.33 g/s,Mass Flow,
    250,4,,,
    251,0,,
    251,1,,,
    251,2,,,
    251,3,,,
    251,4,,,
    252,0,,
    252,1,,,
    ;0.0,Steering Angle,
    252,2,,,
    252,3,,,
    252,4,,,
    253,0,,
    253,1,,,
    ;100.0 %,Load,
    253,2,,,
    ;IMC-V OFF, ,
    253,3,,,
    253,4,,,
    code, engine at idle
    ;Thursday,19,March,2015,19:07:47:47536
    1,1,Engine Speed,,
    ;1160 /min,RPM,
    ;9.0C,Temperature,
    ;-25.0 %,Lambda,
    ;-23.4 %,Lambda,
    2,1,Engine Speed,,
    ;1160 /min,RPM,
    2,2,Engine Load,,
    ;32.3 %,Load,
    ;4.16 ms,Inj. On Time,
    2,4,Mass Air Flow,,
    ;12.78 g/s,Mass Flow,
    3,1,Engine Speed,,
    ;1160 /min,RPM,
    3,2,Mass Air Flow,,
    ;12.58 g/s,Mass Flow,
    ;6.7 %,Load,
    ;5.3 ATDC,Ign. Timing,
    4,1,Engine Speed,,
    ;1160 /min,RPM,
    ;14.070 V,Voltage,
    ;9.0C,Temperature,
    ;10.0C,Temperature,
    5,1,Engine Speed,,
    ;1160 /min,RPM,
    5,2,Engine Load,,
    ;30.8 %,Load,
    5,3,Vehicle Speed,,
    ;0.0 km/h,Speed,
    ;Idle, ,
    6,1,Engine Speed,,
    ;1120 /min,RPM,
    6,2,Engine Load,,
    ;30.8 %,Load,
    ;11.0C,Temperature,
    ;-4.7 %,Lambda,
    ;Not Oper., ,
    ;14.210 V,Voltage,
    ;460.0 mbar,Absolute Pres.,
    8,4,,,
    ;410.0 mbar,Absolute Pres.,
    9,0,,
    9,1,,,
    9,2,,,
    9,3,,,
    ;800.0,(no units),
    9,4,,,
    10,0,Ignition,
    10,1,Engine Speed,,
    ;1160 /min,RPM,
    10,2,Engine Load,,
    ;30.1 %,Load,
    ;6.3 %,Load,
    ;3.8 ATDC,Ign. Timing,
    11,0,Ignition,
    11,1,Engine Speed,,
    ;1160 /min,RPM,
    ;9.0C,Temperature,
    ;11.0C,Temperature,
    ;2.3 ATDC,Ign. Timing,
    14,1,Engine Speed,,
    ;1160 /min,RPM,
    14,2,Engine Load,,
    ;28.6 %,Load,
    ;0,Count,
    ;Enabled, ,
    ;0,Count,
    ;0,Count,
    ;0,Count,
    ;Enabled, ,
    ;0,Count,
    ;0,Count,
    ;0,Count,
    ;Enabled, ,
    ;0 /min,RPM,
    ;0 /min,RPM,
    ;0.0 %,Load,
    ;0.0 %,Load,
    21,3,,,
    21,4,,,
    22,1,Engine Speed,,
    ;1160 /min,RPM,
    22,2,Engine Load,,
    ;26.3 %,Load,
    23,1,Engine Speed,,
    ;1160 /min,RPM,
    23,2,Engine Load,,
    ;26.3 %,Load,
    24,1,Engine Speed,,
    ;1160 /min,RPM,
    24,2,Engine Load,,
    ;25.6 %,Load,
    ;1.989 V,Voltage,
    ;2.106 V,Voltage,
    ;1.872 V,Voltage,
    ;2.808 V,Voltage,
    ;3.276 V,Voltage,
    ;2.925 V,Voltage,
    27,3,,,
    27,4,,,
    28,1,Engine Speed,,
    ;1160 /min,RPM,
    28,2,Engine Load,,
    ;24.8 %,Load,
    ;10.0C,Temperature,
    ;Test OFF, ,
    ;   00111,Bin. Bits,
    ;    0000,Bin. Bits,
    ;   00111,Bin. Bits,
    ;    0000,Bin. Bits,
    ;1.601,Lambda Factor,
    ;1.671,Lambda Factor,
    ;1.632,Lambda Factor,
    ;0.8 %,Lambda,
    ;-0.8 %,Lambda,
    ;0.8 %,Lambda,
    ;-3.1 %,Lambda,
    ;-25.0 %,Lambda,
    ;2.480 V,Voltage,
    ;-25.0 %,Lambda,
    ;2.540 V,Voltage,
    34,1,Engine Speed,,
    ;1160 /min,RPM,
    ;330.0C,Temperature,
    ;2.06,(no units),
    ;Test OFF, ,
    35,1,Engine Speed,,
    ;1160 /min,RPM,
    ;320.0C,Temperature,
    ;2.06,(no units),
    ;Test OFF, ,
    ;0.440 V,Voltage,
    ;Test OFF, ,
    ;0.440 V,Voltage,
    ;Test OFF, ,
    37,1,Engine Load,,
    ;24.1 %,Load,
    ;0.440 V,Voltage,
    ;0.000,Difference,
    ;Test OFF, ,
    38,1,Engine Load,,
    ;23.3 %,Load,
    ;0.445 V,Voltage,
    ;0.000,Difference,
    ;Test OFF, ,
    ;9.56 g/s,Mass Flow,
    ;0.415 V,Voltage,
    ;0.430 V,Voltage,
    ;79 ohms,Resistance,
    ;Htg. S1 ON, ,
    41,3,,,
    ;Htg. S2 OFF, ,
    ;77 ohms,Resistance,
    ;Htg. S1 OFF, ,
    42,3,,,
    ;Htg. S2 OFF, ,
    43,1,Engine Speed,,
    ;1160 /min,RPM,
    ;315.0C,Temperature,
    ;0.445 V,Voltage,
    ;Test OFF, ,
    44,1,Engine Speed,,
    ;1160 /min,RPM,
    ;305.0C,Temperature,
    ;0.450 V,Voltage,
    ;Test OFF, ,
    46,1,Engine Speed,,
    ;1160 /min,RPM,
    ;5.0C,Temperature,
    ;0.00,(no units),
    ;Test OFF, ,
    47,1,Engine Speed,,
    ;1160 /min,RPM,
    ;5.0C,Temperature,
    ;0.00,(no units),
    ;Test OFF, ,
    ;1180 /min,RPM,
    ;1180 /min,RPM,
    ;A/C-Low, ,
    ;Compr.OFF, ,
    ;1180 /min,RPM,
    ;1180 /min,RPM,
    ;0,Count,
    ;14.210 V,Voltage,
    ;1180 /min,RPM,
    ;1180 /min,RPM,
    ;A/C-Low, ,
    52,4,,,
    ;1180 /min,RPM,
    ;1180 /min,RPM,
    ;14.280 V,Voltage,
    53,4,,,
    54,1,Engine Speed,,
    ;1160 /min,RPM,
    ;Idle, ,
    ;0.0 %,Load,
    ;4.3 %,Load,
    55,1,Engine Speed,,
    ;1170 /min,RPM,
    ;-1.8 %,Lambda,
    ;0.6 %,Lambda,
    ;  000000,Bin. Bits,
    ;1170 /min,RPM,
    ;1180 /min,RPM,
    ;-1.8 %,Lambda,
    ;  000000,Bin. Bits,
    ;1170 /min,RPM,
    ;1180 /min,RPM,
    ;Compr.OFF, ,
    58,1,Engine Speed,,
    ;1160 /min,RPM,
    58,2,Engine Load,,
    ;19.5 %,Load,
    58,3,,,
    58,4,,,
    ;13.7 %,Duty Cycle,
    ;86.3 %,Duty Cycle,
    ;0,Count,
    ;ADP. O.K., ,
    61,1,Engine Speed,,
    ;1120 /min,RPM,
    ;14.140 V,Voltage,
    ;4.3 %,Load,
    ;  000000,Bin. Bits,
    ;13.7 %,Duty Cycle,
    ;85.9 %,Duty Cycle,
    ;14.5 %,Duty Cycle,
    ;7.4 %,Duty Cycle,
    ;14.5 %,Duty Cycle,
    ;0.520 V,Voltage,
    ;4.580 V,Voltage,
    ;0.800 V,Voltage,
    ;4.320 V,Voltage,
    ;0.0 km/h,Speed,
    ;0.0 km/h,Speed,
    ;0.0 %,Load,
    ;-21.9 %,Lambda,
    ;Test OFF, ,
    ;Reed Closed, ,
    ;Abort, ,
    ;Test OFF, ,
    72,0,,
    ;Reed Closed, ,
    ;Abort, ,
    72,3,,,
    72,4,Result,,
    ;Test OFF, ,
    73,0,,
    ;0.0 %,Load,
    73,2,Flush rate,,
    ;0.0 %,Load,
    73,3,Load factor,,
    ;0.0 %,Lambda,
    ;0.0 %,Lambda,
    77,1,Engine Speed,,
    ;1120 /min,RPM,
    ;7.69 g/s,Mass Flow,
    ;0.0 %,Lambda,
    ;Test OFF, ,
    78,1,Engine Speed,,
    ;1120 /min,RPM,
    ;7.61 g/s,Mass Flow,
    ;0.0 %,Lambda,
    ;Test OFF, ,
    79,0,,
    79,1,Engine Speed,,
    ;1080 /min,RPM,
    79,2,Engine Load,,
    ;18.8 %,Load,
    79,3,Flap Bank 1,,
    ;ON, ,
    79,4,Flap Bank 2,,
    80,1,,,
    82,1,,,
    86,2,Cycle Flags,,
    86,3,Cycle Flags,,
    86,4,Cycle Flags,,
    87,2,Error Flags,,
    87,3,Error Flags,,
    87,4,Error Flags,,
    88,1,Cycle Flags,,
    88,2,Cycle Flags,,
    ;10101111,Bin. Bits,
    88,3,Cycle Flags,,
    88,4,,,
    89,0,,
    ;0,Count,
    ;OK, ,
    89,3,,,
    89,4,,,
    90,1,Engine Speed,,
    ;920 /min,RPM,
    90,2,Duty Cycle,,
    ;29.4 %,Load,
    ;22.0KW,Idle Stabilization,
    91,1,Engine Speed,,
    ;920 /min,RPM,
    91,2,Duty Cycle,,
    ;30.2 %,Load,
    ;3.0KW,Idle Stabilization,
    93,1,Engine Speed,,
    ;920 /min,RPM,
    93,2,Duty Cycle,,
    ;18.8 %,Load,
    ;2.0KW,Idle Stabilization,
    ;Test OFF, ,
    ;880 /min,RPM,
    ;18.8 %,Load,
    ;15.0C,Temperature,
    ;IMC-V OFF, ,
    ;21.5KW,Idle Stabilization,
    ;Test OFF, ,
    98,1,Engine Speed,,
    ;840 /min,RPM,
    98,2,Engine Load,,
    ;31.0 %,Load,
    99,1,Engine Speed,,
    ;840 /min,RPM,
    ;O2-Reg.ON, ,
    ;15.0C,Temperature,
    ;48.46 s,Time,
    ;01000000,Bin. Bits,
    ;800 /min,RPM,
    101,2,Engine Load,,
    ;18.0 %,Load,
    ;2.08 ms,Inj. On Time,
    ;5.11 g/s,Mass Flow,
    ;800 /min,RPM,
    ;15.0C,Temperature,
    ;11.0C,Temperature,
    ;7.0C,Temperature,
    ;28.9 %,Lambda,
    ;28.9 %,Lambda,
    ;28.9 %,Lambda,
    ;760 /min,RPM,
    105,2,Engine Load,,
    ;18.0 %,Load,
    ;16.0C,Temperature,
    ;OFF, ,
    ;760 /min,RPM,
    ;-19.5 %,Lambda,
    ;-18.0 %,Lambda,
    ;Test OFF, ,
    ;760 /min,RPM,
    ;16.0C,Temperature,
    ;2.60 ms,Inj. On Time,
    ;2.7 %,Load,
    ;230.0C,Temperature,
    112,2,,,
    ;225.0C,Temperature,
    112,4,,,
    ;760 /min,RPM,
    113,2,Engine Load,,
    ;18.8 %,Load,
    ;3.1 %,Load,
    ;760 /min,RPM,
    ;408.0 Nm,Torque,
    ;0.0 Nm,Torque,
    ;ASR OFF, ,
    122,0,Transmission,
    ;760 /min,RPM,
    ;408.0 Nm,Torque,
    ;0.0 Nm,Torque,
    ;No Torq Red, ,
    ;ABS 1, ,
    ;Instruments 1, ,
    125,4,,,
    126,1,,,
    126,2,,,
    ;Airbag 1, ,
    126,4,,,
    130,0,Map Cooling,
    ;18.0C,Temperature,
    130,2,,,
    130,3,,,
    130,4,,,
    131,0,Map Cooling,
    ;18.0C,Temperature,
    131,2,,,
    131,3,,,
    131,4,,,
    134,0,Temperatures,
    ;7.0C,Temperature,
    ;11.0C,Temperature,
    ;18.0C,Temperature,
    ;A/C-Low, ,
    ;Compr.OFF, ,
    137,3,,,
    137,4,,,
    138,0,,
    138,1,,,
    ;7.0C,Temperature,
    138,2,,,
    138,3,,,
    ;224.4 km/h,Speed,
    138,4,,,
    ;Test OFF, ,
    139,0,,
    139,1,,,
    ;18.0C,Temperature,
    139,2,,,
    139,3,,,
    139,4,,,
    ;Test OFF, ,
    201,0,,
    201,1,,,
    ;-12.5 %,Lambda,
    201,2,,,
    ;-10.2 %,Lambda,
    201,3,,,
    201,4,,,
    ;01111100,Bin. Bits,
    202,0,,
    202,1,,,
    ;0.00 s,Time,
    202,2,,,
    ;0.00 s,Time,
    202,3,,,
    ;Abort, ,
    202,4,,,
    ;01010000,Bin. Bits,
    203,0,,
    203,1,,,
    ;720 /min,RPM,
    203,2,,,
    ;18.0 %,Load,
    203,3,,,
    ;21.0C,Temperature,
    203,4,,,
    204,0,,
    204,1,,,
    ;720 /min,RPM,
    204,2,,,
    ;0.0 km/h,Speed,
    204,3,,,
    ;5.0C,Temperature,
    204,4,,,
    205,0,,
    205,1,,,
    ;78 ohms,Resistance,
    205,2,,,
    ;40.6 %,Load,
    205,3,,,
    ;0.0,(no units),
    205,4,,,
    206,0,,
    206,1,,,
    206,2,,,
    ;46.1 %,Load,
    206,3,,,
    ;-1.0,(no units),
    206,4,,,
    207,0,,
    207,1,,,
    ;0.00 s,Time,
    207,2,,,
    ;0.00 s,Time,
    207,3,,,
    ;0,Count,
    207,4,,,
    208,0,,
    208,1,,,
    ;720 /min,RPM,
    208,2,,,
    ;123,Count,
    208,3,,,
    208,4,,,
    209,0,,
    209,1,,,
    ;720 /min,RPM,
    209,2,,,
    ;123,Count,
    209,3,,,
    209,4,,,
    210,0,,
    210,1,,,
    210,2,,,
    ;3.5KW,Idle Stabilization,
    210,3,,,
    ;1,Count,
    210,4,,,
    211,0,,
    211,1,,,
    211,2,,,
    211,3,,,
    ;1,Count,
    211,4,,,
    212,0,,
    212,1,,,
    ;0.000,Difference,
    212,2,,,
    ;0,Count,
    212,3,,,
    ;2.06,(no units),
    212,4,,,
    213,0,,
    213,1,,,
    ;0.000,Difference,
    213,2,,,
    ;0,Count,
    213,3,,,
    ;2.06,(no units),
    213,4,,,
    215,0,,
    215,1,,,
    215,2,,,
    215,3,,,
    215,4,,,
    ;11000000,Bin. Bits,
    216,0,,
    216,1,,,
    216,2,,,
    216,3,,,
    ;0.8 %,Lambda,
    216,4,,,
    217,0,,
    217,1,,,
    217,2,,,
    217,3,,,
    ;0.8 %,Lambda,
    217,4,,,
    218,0,,
    218,1,,,
    ;-0.020,Difference,
    218,2,,,
    ;0.97,(no units),
    218,3,,,
    ;0.94,(no units),
    218,4,,,
    220,0,,
    220,1,,,
    220,2,,,
    220,3,,,
    ;0.0C,Temperature,
    220,4,,,
    221,0,,
    221,1,,,
    221,2,,,
    221,3,,,
    ;0.0C,Temperature,
    221,4,,,
    222,0,,
    222,1,,,
    ;0.460 V,Voltage,
    222,2,,,
    222,3,,,
    ;5.0C,Temperature,
    222,4,,,
    223,0,,
    223,1,,,
    ;0.450 V,Voltage,
    223,2,,,
    223,3,,,
    ;5.0C,Temperature,
    223,4,,,
    224,0,,
    224,1,,,
    ;0.480 V,Voltage,
    224,2,,,
    ;0.455 V,Voltage,
    224,3,,,
    ;0.00 s,Time,
    224,4,,,
    225,0,,
    225,1,,,
    ;0.460 V,Voltage,
    225,2,,,
    225,3,,,
    ;0.00 s,Time,
    225,4,,,
    226,0,,
    226,1,,,
    ;0.445 V,Voltage,
    226,2,,,
    226,3,,,
    ;0.00 s,Time,
    226,4,,,
    227,0,,
    227,1,,,
    ;0.00,(no units),
    227,2,,,
    ;5.0C,Temperature,
    227,3,,,
    ;1.00 s,Time,
    227,4,,,
    228,0,,
    228,1,,,
    ;0.00,(no units),
    228,2,,,
    ;5.0C,Temperature,
    228,3,,,
    ;1.00 s,Time,
    228,4,,,
    229,0,,
    229,1,,,
    ;0.0 %,Load,
    229,2,,,
    ;0.0 %,Lambda,
    229,3,,,
    ;0.0 %,Load,
    229,4,,,
    231,0,,
    231,1,,,
    ;0.0 %,Lambda,
    231,2,,,
    231,3,,,
    ;0.000,Difference,
    231,4,,,
    232,0,,
    232,1,,,
    ;0.0 %,Lambda,
    232,2,,,
    232,3,,,
    ;0.000,Difference,
    232,4,,,
    233,0,,
    233,1,,,
    ;-11.7 %,Lambda,
    233,2,,,
    233,3,,,
    ;0.8 %,Lambda,
    233,4,,,
    234,0,,
    234,1,,,
    ;-10.2 %,Lambda,
    234,2,,,
    234,3,,,
    ;0.8 %,Lambda,
    234,4,,,
    237,0,,
    237,1,,,
    ;2543,Count,
    237,2,,,
    ;1539,Count,
    237,3,,,
    ;4123,Count,
    237,4,,,
    238,0,,
    238,1,,,
    ;1527,Count,
    238,2,,,
    ;1607,Count,
    238,3,,,
    ;637,Count,
    238,4,,,
    239,0,,
    239,1,,,
    239,2,,,
    239,3,,,
    239,4,,,
    ;0,Count,
    240,0,,
    240,1,,,
    240,2,,,
    240,3,,,
    ;4,Count,
    240,4,,,
    241,0,,
    241,1,,,
    ;12.0C,Temperature,
    241,2,,,
    ;22.0C,Temperature,
    241,3,,,
    ;15.0C,Temperature,
    241,4,,,
    ;11.0C,Temperature,
    242,0,,
    242,1,,,
    ;0,Count,
    242,2,,,
    ;0,Count,
    242,3,,,
    ;11.0C,Temperature,
    242,4,,,
    243,0,,
    243,1,,,
    ;9.0C,Temperature,
    243,2,,,
    ;22.0C,Temperature,
    243,3,,,
    ;0,Count,
    243,4,,,
    ;11.0C,Temperature,
    244,0,,
    244,1,,,
    244,2,,,
    244,3,,,
    244,4,,,
    245,0,,
    245,1,,,
    245,2,,,
    245,3,,,
    ;17.3 %,Load,
    245,4,,,
    ;First Map, ,
    246,0,,
    246,1,,,
    ;1.05,(no units),
    246,2,,,
    ;1.11,(no units),
    246,3,,,
    ;1.08,(no units),
    246,4,,,
    ;0.80,(no units),
    247,0,,
    247,1,,,
    ;0.6 %,Lambda,
    247,2,,,
    ;0.4 %,Lambda,
    247,3,,,
    ;23.0C,Temperature,
    247,4,,,
    248,0,,
    248,1,,,
    ;0.6 %,Lambda,
    248,2,,,
    ;-1.6 %,Lambda,
    248,3,,,
    ;0.0 %,Lambda,
    248,4,,,
    ;0.0 %,Lambda,
    249,0,,
    249,1,,,
    ;0.97,(no units),
    249,2,,,
    ;0.94,(no units),
    249,3,,,
    249,4,,,
    250,0,,
    250,1,,,
    ;4.64 g/s,Mass Flow,
    250,2,,,
    ;1.72 g/s,Mass Flow,
    250,3,,,
    ;14.06 g/s,Mass Flow,
    250,4,,,
    251,0,,
    251,1,,,
    251,2,,,
    ;2.5KW,Idle Stabilization,
    251,3,,,
    251,4,,,
    ;20.5KW,Idle Stabilization,
    252,0,,
    252,1,,,
    ;255.0,Steering Angle,
    252,2,,,
    252,3,,,
    252,4,,,
    ;21.0KW,Idle Stabilization,
    253,0,,
    253,1,,,
    ;17.3 %,Load,
    253,2,,,
    ;IMC-V OFF, ,
    253,3,,,
    253,4,,,
    Jef
  2. Likes Uwe, R32 liked this post
