Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Rns315 version d with 9w7 Bluetooth issues
    United States
    Dana, Steeldrivinman,
    Thanks for the replies. I tried the coding, and rebooted the system the other day, and still no luck.
    I decided to just remove the Bluetooth module, and use the internal Bluetooth on the radio. And it is working as it should! No more disconnecting! It displays the Song info, and I am able to skip tracks now! I had to rewire the microphone though. I purchased a repair wire (http://www.ebay.com/itm/400659060362) Cut the wire in half, and I wired pin 11 and 12 from the Bluetooth harness to pins 1 and 2 on the back of the Headunit, and the microphone works perfect!
    I guess the 7P6 035 730 C module isnt fully compatible with the RNS-315 unit. The internal Bluetooth works so much better than the external module.
    I hope this post helps someone in the future.
  2. Likes steeldrivinman, Dana liked this post
  3. #12
    I just retrofit the bluetooth module to my Yeti.
    I also cant skip tracks from spotify...
    And no song information on mfa.
    Microphone sound quality is poor. Is there some kind of tricks for coding?
    I changed the sensitivy adaptation to 4db.
    What are "audio parameter sets" in byte 2?
    Thanks from Finland !
    Sunday,02,July,2017,13:45:33:64262VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 17.1.3.0
    VIN: TMBLD95L7B6050077   License Plate: YETI4
    Mileage: 168020km-104402mi   Repair Order:
    Chassis Type: 5L (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 18 19 22 25 42 44 46 52 55 56 62
              69 72 77
    VIN: TMBLD95L7B6050077   Mileage: 168020km-104402miles
    Address 01: Engine (J623-CFHC)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 DB    HW: 03L 906 018 BR
       Component: R4 2,0L EDC   H23 7098
       Revision: 42H23---    Serial number:
       Coding: 001D001A043600080000
       ASAM Dataset: EV_ECM20TDI01103L906018DB 003004
       ROD: EV_ECM20TDI01103L906018DB.rod
       VCID: 6DDA3F44BC6AF82932-8038
       Part No SW: 02E 300 013 L    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2601
       Revision: 05351112    Serial number: 00001102231030
       Shop #: WSC 33361 790 00999
       VCID: 1A302498D564BF9107-804E
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       Coding: 913F400E092701FA890B02EB9020804A350000
       VCID: 76E81028C13C3BF1C3-8022
       Part No SW: 3T0 907 044 BG    HW: 3T0 907 044 BG
       Component: Climatronic   H16 0402
       Revision: 00006001
       Coding: 0000000002
       VCID: 78F41E10C3284D81D1-802C
       Part No SW: 1K0 937 086 H    HW: 1K0 937 086 H
       Component: BCM PQ35  M   103 0615
       Revision: 00103 AD
       Coding: 40000AB8E01328C040080080100089E4477C00AE722DA5605C8560200040
       VCID: 356AD7249CBA70E90A-8060
       Subsystem 1 - Part No: 5L1 955 119 A  Labels: 1KX-955-119.CLB
       Component: SK356  26  0604
       Coding: 00F795
       Component: RLS 100311 05  54  0403
       Coding: 0714ED
    Address 10: Park/Steer Assist (J446)       Labels: 5J0-919-475.clb
       Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
       Component: PARKHILFE 4K  H11 0005
       Revision: --H11---    Serial number: 32901106900226
       Coding: 110113
       ASAM Dataset: EV_EPHVA14SKxxx0000 001001
       ROD: EV_EPHVA14SKxxx0000.rod
       VCID: 336EE93C9ACE6ED924-8066
       Part No SW: 5C0 959 655 D    HW: 5C0 959 655 D
       Component: AirbagVW10G   013 0613
       Serial number: 003G7RA00V6E
       Coding: 00005431
       ROD: EV_AirbaVW10SMEVW360.rod
       Serial number: 3572MSME2D72335DZZZ+
       Serial number: 3582MSME5E08345DZZZ3
       Serial number: 3512QSME7434072BZZZT
       Serial number: 3522QSME6818072BZZZZ
       Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
       Revision: FF010040    Serial number: 20110309300751
       Coding: 188A140000
       ROD: EV_SMLSNGVOLWSXS.rod
       VCID: 7EF80808E10C73B19B-802A
       Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
       Component: E221__MFL-URO  H07 0012
       Coding: 800000
       Part No SW: 5L0 920 840 H    HW: 5L0 920 840 H
       Component: KOMBI         H21 0420
       Coding: 120E01
       VCID: 3064E6306BD855C159-8064
    Address 18: Aux. Heat        Labels: 1K0-815-007.clb
       Part No: 7N0 963 272 A
       Component: Standheizer     043 4730
       Revision: 00043000    Serial number: 09022127000000
       Coding: 0030012
       VCID: 336EE93C52CE6ED924-8066
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 120311F2000551
       Coding: 356302
       VCID: 3064E63063D855C159-8064
       Part No SW: 0BR 907 554 B    HW: 0BR 907 554 B
       Component: Haldex 4Motion      3017
       Coding: 0000005
       VCID: 448CBAE00760D9618D-8010
       Component: IMMO          H21 0420
       VCID: 6AD034588D84EF1157-803E
    Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
       Part No SW: 7N0 959 793 E    HW: 7N0 959 793 A
       Component: TSG FA        H04 0400
       Revision:             Serial number: 0000012258695
       Coding: 011502208000231003
       VCID: 448CBAE0C760D9618D-8010
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 71     3201
       Revision: 00H20000
       VCID: 346CEA2057C069E13D-8060
    Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
       Part No SW: 7N0 959 792 E    HW: 7N0 959 792 A
       Component: TSG BF        H04 0400
       Revision:             Serial number: 0000012357207
       Coding: 011500208000231003
       VCID: 438EB9FCC26EDE59B4-8016
       Coding: 3703835
       Subsystem 1 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    0008
       Coding: 00000056
       Subsystem 2 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul r    0008
       Coding: 00000056
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1Z0 035 161 N    HW: 1Z0 035 161 N
       Component: Radio-SWING   012 0036
       Revision: -----16S    Serial number: SKZ4Z2L1168315
       Coding: 0D0004030003
       VCID: 3972DB14B0A29489EE-806C
    Address 62: Door, Rear Left (J388)       Labels: 7N0-959-795.clb
       Part No SW: 7N0 959 795 D    HW: 7N0 959 795
       Component: TSG HL        H03 0400
       Revision:             Serial number: 0000012383762
       Coding: 010000200000531003
       VCID: 458AA7E4CC5AE0699A-8010
    Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
       Revision: 3A001001    Serial number: 00000144335952
       Coding: 410D000100000000
    Address 72: Door, Rear Right (J389)       Labels: 7N0-959-795.clb
       Component: TSG HR        H03 0400
       Revision:             Serial number: 0000012365379
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
       Component: TELEFON       H16 4217
       Revision: 1B001001    Serial number: 00007666972907
       Coding: 0201030000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3C7CC200B790A1A1F5-8068
    End-------------------------(Elapsed Time: 03:37)--------------------------
  4. #13
    Question
    The reason for why I cant skip tracks is the radio Swing (vw rcd310).
    I will need rns510/rcd510.
    But I still need help for coding telephone...
    Because the microphone sound is bad (driving noise etc)
    Quote Originally Posted by tos View Post
  5. #14
    United States
    In my opinion the road noise through a factory installed Mk6 chassis microphone and telephone system is terrible. We had a 2010 GTI (with sunroof) and still have a 2012 Tiggy (with the large pana roof) and both of those vehicles are terrible to be on the landline side of when speaking to my husband while he's driving. It sounds like he's operating aircraft rather than a 2.0T VW Golf based car!
    I haven't messed much with Audio parameters but I recall some of those coding attempts being rejected by the module. You can certainly experiment to see if any changes are accepted but the only TPI I found when searching for Audio parameter was one specific to MIB Audi systems. That TPI that mentioned High-frequency or Buzzing noises when phoning - not microphone concerns.
    Hopefully someone else has additional parameter info but I don't see anything wrong with the coding of 77.
    This was the factory condition module in my 2012 Tiguan
    Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
    Component: TELEFON H09 2902
    Revision: 1B001001 Serial number: 00007660091672
    Coding: 0A11040000010100
    Shop #: WSC 25807 444 28888
    ASAM Dataset: EV_UHVNA A01719
    ROD: EV_UHVNA_VW36.rod
    Factory condition Adp map from a very old version:
    ;SW:7P6-035-730-F   HW:7P6-035-730-F ---  Telephone
    ;Component:TELEFON       H09 2902	 Coding:0A11040000010100
    ;EV_UHVNA	A01719	EV_UHVNA_VW36.rod
    ;Tuesday	28	August	2012	08:41:56:03064
    ;VCDS Version: Release 11.11.4  Data version: Unknown
    ;VCID: 356A218D944A8EB0C23
    Developer mode	not activated
    Bluetooth acknowledgement signal	OFF
    Base volume of speech output	7.15256e-007 dB
    Base volume of telephone	0 dB
    Microphone sensitivity	0 dB
    Emergency telephone number	00 00 00 00 00 00 00
    Reference channel delay	0 ms
    Delay of audio output	0.0 s
    (1)-Masking of Languages-Mask Byte 0/Bit0 Language - German	valid
    (2)-Masking of Languages-Mask Byte 0/Bit1 Language - English	valid
    (3)-Masking of Languages-Mask Byte 0/Bit2 Language - French	invalid
    (4)-Masking of Languages-Mask Byte 0/Bit3 Language - Italian	valid
    (5)-Masking of Languages-Mask Byte 0/Bit4 Language - Spanish	invalid
    (6)-Masking of Languages-Mask Byte 0/Bit5 Language - Portuguese	valid
    (7)-Masking of Languages-Mask Byte 0/Bit6 Language - Czech	valid
    (8)-Masking of Languages-Mask Byte 0/Bit7 Language - Russian	valid
    (9)-Masking of Languages-Mask Byte 1/Bit0 Language - US-English	valid
    (10)-Masking of Languages-Mask Byte 1/Bit1 Language - French-Canadian	valid
    (11)-Masking of Languages-Mask Byte 1/Bit2 Language - US-Spanish	valid
    (12)-Masking of Languages-Mask Byte 1/Bit3 Language - Dutch	valid
    (13)-Masking of Languages-Mask Byte 1/Bit4 Language - Swedish	valid
    (14)-Masking of Languages-Mask Byte 1/Bit5 Language - Polish	valid
    (15)-Masking of Languages-Mask Byte 1/Bit6 Language - Norwegian	valid
    (16)-Masking of Languages-Mask Byte 1/Bit7 Language - Turkish	valid
    Name of universal cell phone package (UHV)	VW PHON
    User profiles	not erased
    Setting Bluetooth PIN	00 00
    Media playback volume	0 dB
    CDMA Detection	activated
    Number 1 for Info call	00 00 00 00 00 00 00
    Number 1 for roadside assistance	00 00 00 00 00 00 00
    Number 2 for Info call	00 00 00 00 00 00 00
    Number 2 for roadside assistance	00 00 00 00 00 00 00
  6. Likes Uwe liked this post
  7. #15
    Thank You Dana!
    Here comes my adaptation map:
    It will not show all... german things missing.
    ;SW:7P6-035-730-M   HW:7P6-035-730-M ---  Telephone;Component:TELEFON       H16 4217, Coding:0201030000010110
    ;EV_UHVNA,002720,EV_UHVNA_002.rod
    ;Thursday,13,July,2017,19:32:18:64262
    ;VCDS Version: Release 17.1.3  Data version: 20170320 DS267.7
    ;VCID: 3C7CC200B790A1A1F5-8068
    IDE00689-Name of universal cell phone package (UHV),YETI PHONE
    IDE00758-Base volume of telephone,0 dB
    IDE00759-Base volume of speech output,7.15256e-007 dB
    IDE00760-Microphone sensitivity,4 dB
    IDE00762-Setting Bluetooth PIN,00 00
    IDE00764-User profiles,not erased
    IDE00765-Delay of audio output,0.0 s
    IDE00766-Reference channel delay,0 ms
    IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00
    IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00
    IDE00771-Media playback volume,0 dB
    IDE02122-Developer mode,not activated
    IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00
    IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00
    IDE02504-Bluetooth acknowledgement signal,OFF
    IDE03481-Emergency telephone number,00 00 00 00 00 00 00 00 00
    ENG113809-CDMA Detection,not activated
    ENG107578-ENG103154-Masking of Languages-Mask Byte 0/Bit0 Language - German,valid
    ENG107578-ENG100316-Masking of Languages-Mask Byte 0/Bit1 Language - English,valid
    ENG107578-ENG103726-Masking of Languages-Mask Byte 0/Bit2 Language - French,valid
    ENG107578-ENG103477-Masking of Languages-Mask Byte 0/Bit3 Language - Italian,valid
    ENG107578-ENG102676-Masking of Languages-Mask Byte 0/Bit4 Language - Spanish,valid
    ENG107578-ENG100258-Masking of Languages-Mask Byte 0/Bit5 Language - Portuguese,valid
    ENG107578-ENG99657-Masking of Languages-Mask Byte 0/Bit6 Language - Czech,valid
    ENG107578-ENG100762-Masking of Languages-Mask Byte 0/Bit7 Language - Russian,valid
    ENG107578-ENG103078-Masking of Languages-Mask Byte 1/Bit0 Language - US-English,valid
    ENG107578-ENG99208-Masking of Languages-Mask Byte 1/Bit1 Language - French-Canadian,invalid
    ENG107578-ENG99771-Masking of Languages-Mask Byte 1/Bit2 Language - US-Spanish,invalid
    ENG107578-ENG99829-Masking of Languages-Mask Byte 1/Bit3 Language - Dutch,valid
    ENG107578-ENG111964-Masking of Languages-Mask Byte 1/Bit4 Language - Swedish,valid
    ENG107578-ENG111965-Masking of Languages-Mask Byte 1/Bit5 Language - Polish,valid
    ENG107578-ENG111966-Masking of Languages-Mask Byte 1/Bit6 Language - Norwegian,valid
    ENG107578-ENG111967-Masking of Languages-Mask Byte 1/Bit7 Language - Turkish,valid
    Elapsed Time: 00:08
