Rns315 version d with 9w7 Bluetooth issues
MikeLyons27
United States
C?ID=104983
I have a 2011 vw gti, and I purchased a rns315 model number 1k0035274d. From my research it is the latest model. And my car came with a 9w7 Bluetooth module.
I am having issues with streaming music to my unit. I am not sure if it's a coding issue. The issues I am having are:
after a song is done playing and there is a slight gap in between the songs, it cuts off the Bluetooth, and goes to fm radio. But when I look at my phone the song is still playing. I have to press the media button to go back to the music. It is extremely annoying.
I cannot get Bluetooth to display track info. It just says "Bluetooth audio" also I cannot skip songs.
I've read that the radio supposed to detect the Bluetooth phone and automatically start playing music. It doesn't do that.
I am using and iphone 5 with iOS 7. The only info I found out about was for ios6 and older versions of the head unit.
I've tried tinkering around with the settings in the vagcom but with no luck... Anyone out there that can help?
MikeLyons27
United States
C?ID=104983
Ok, I've done a little more looking around. I found this here on ross-techs site http://wiki.ross-tech.com/wiki/index.php/Telephone_Retrofitting
I took a look at the bluetooth module, and I have the 7P6 035 730 C module. There isnt much info listed about the module...
Does the "C" version support track control from the radio, and other features?
Do I need to upgrade to the "F" version?
Since I have the rns315 1k0035274d, can I remove the Bluetooth module all together and use the internal Bluetooth? Do I have to rewire the mic?
Or is there a simple coding change i need to do in-order to get the Bluetooth to work correctly?
Any help would be appreciated...
steeldrivinman
Switzerland
C?ID=208345
Hey Mike, I finally got mine to work today. RNS-315 and the RW7 BT module although I have the K version. I was convinced that it would just say Bluetooth Audio on the screen and that's it. The only things I did was: erased the DTCs that were in there. (I hooked up the module without the microphone and it threw a few errors) and turned off BT audio and then turned it back on under Module 77 Telephone. Maybe turn off the the ignition between deactivating and reactivating it. I was quite surprised when today mine "woke up"
Give it a try
Cheers
Paul
MikeLyons27
United States
C?ID=104983
Ok I will try when I get home later today!
MikeLyons27
United States
C?ID=104983
Sorry it took so long for an update.
But I tried resetting the errors through the vag-com. I still keep getting a Satellite radio not active error, I guess that's normal?
I turned off the Bluetooth module under module 77, and disconnected the battery, then reactivated the Bluetooth, and no luck... it still wont display track info, and it constantly disconnects after every song that plays through Bluetooth.
Should I try disconnect the Bluetooth module all together, and try activating the internal one in the radio? does anyone know the vag-com settings for doing that? do i have to rewire the microphone?
any help would be appreciated!
Dana
Western PA, USA
Mike,
Post the Auto-Scan from this vehicle prior to retrofitting (preferably the one with completely stock/factory settings) in addition to a current scan.
-Dana
P.S. I retrofitted that 7P6 035 730 C BT module to a 2010 Gti in addition to a RNS-510 and it was limited compared to my current 2012 Tiguan SEL with factory 7P6 035 730 F and a much newer RNS-510.
MikeLyons27
United States
C?ID=104983
Dana, thanks for the reply. I was going to post the autoscan last night, and my Laptop power supply crapped out! I cant get my laptop to turn on...I odered anew power supply, and hopefully it will be here in a couple of days. Ill post it then.
Thanks in advance!
steeldrivinman
Switzerland
C?ID=208345
Hey Mike, still no love huh?
The software code on mine is 0A01000000000110 just for a quick compare and tryout
MikeLyons27
United States
C?ID=104983
Dana, I finally got my laptop up and running again. Below is the post install scan. I accidentally wrote over the pre-scan when I went to save this scan :-/
I noticed a few errors like the ignition starter and Terminal 15? Are they anything i should be concerned with? I cleared just them....
Also, It looks like my rear driver side speaker is acting up, it shows and error as well, and no sound is coming out of it...but that's another issue i'll have to look into.
Do you have any suggestions on the coding for the Bluetooth issues?
Friday,02,May,2014,00:56:07:34944
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WVWGV7AJ6BW123687   License Plate:
Chassis Type: AJ (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AP    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0030
   Revision: AAH18---    Serial number:
   Coding: 0403010A18070160
   VCID: 74C910381733AFBE8FF-8021
   Part No SW: 1K0 907 379 BG    HW: 1K0 907 379 BG
   Component: ESP MK60EC1   H31 0106
   Revision: 00H31001
   Coding: 114B600C492400FD881106EC92200041B70800
   VCID: 78D12408CB5BCBDEA37-802D
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000001002
   ROD: EV_ClimaBasis_SE36.rod
   VCID: 75CF2D3CD449B6B6B81-8020
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4R014Z11
   Coding: 00003031
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3957E10CB8D112D69C9-806C
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--0005FCK400
   Serial number: 3572MSME036D2058ZZZU
   Serial number: 3582MSME70284358ZZZV
   Serial number: 3512QSME2C56711EZZZ$
   Serial number: 3522QSME321C6417ZZZS
   Serial number: 35527SME5F234C23ZZZM
   Crash sensor for front airbag; passenger side:
   Serial number: 35627SME4A176723ZZZH
   Part No SW: 5K0 953 507 BA    HW: 5K0 953 549 C
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90422JJ5000E1
   Coding: 5080140000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 70C11C28AB2B939E6B7-8025
147462 - Terminal 15
          B1148 12 [008] - Short to Plus
                    Fault Frequency: 171
                    Reset counter: 81
                    Mileage: 59010 km
                    Date: 2039.14.23
                    Time: 12:27:45
226057 - Ignition Starter Switch; Terminal S
          B1147 F1 [008] - Open or Short to GND
                    Fault Frequency: 52
                    Reset counter: 80
                    Mileage: 57687 km
                    Date: 2039.14.05
                    Time: 17:27:43
   Part No SW: 5K6 920 971 C    HW: 5K6 920 971 C
   Component: KOMBI         H20 0420
   Coding: 270F01
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 354FED3C94C9F6B6781-8060
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 091010F1002062
   Coding: E9807F0640061200000002
   VCID: EDFF855CF419FE76C01-80B8
   Component: IMMO          H20 0420
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EAF58E400DF7E94EA53-80BF
   Revision: A1001003    Serial number: 7668751036
   VCID: 2773377456659426FAD-8072
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H58 0319
   Serial number: VWZAZ2M0027834
   Coding: 04010021010006000000000A
   Shop #: WSC 01383 790 50316
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 256F3D7C24698636C81-8070
1048615 - Rear Left Audio Signal Output
          B1108 13 [009] - Open Circuit
                    Fault Frequency: 24
                    Reset counter: 40
                    Mileage: 57659 km
                    Date: 2039.14.05
                    Time: 08:13:50
          B11CF 53 [009] - Deactivated
                    Reset counter: 214
                    Mileage: 57659 km
                    Date: 2039.14.04
                    Time: 14:42:46
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2151
   Coding: 0001268
   VCID: 334BD32452BDE886565-8066
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   VCID: 3147D92CA8A1DA96249-8064
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Coding: 0001268
   VCID: 3449D03857B3EFBE4FF-8061
   Coding: 0001232
   Shop #: WSC 01357 011 1012551
   VCID: 354FED3C5CC9F6B6781-8060
   Coding: 0001232
   VCID: 364DEA3041CFFDAE71B-8063
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668719714
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 3245D62065A7E18E5D3-8067
Address 16: DTCs cleared
Dana
Western PA, USA
Hi Mike,
You may have this sorted already but the vehicle does not have a diagnostic capable 47-Sound System module installed so I would tweak those coding position and something is different when compared to the NAR Golf R so I tweaked Byte 05 and 10 which resulted in: 04000421040500000000100A
That would leave the internal BT functions off but I like the idea of unplugging the external (7P6 035 730 C) #77 module and using the internal system as a test. If the above coding doesn't help please try that and go with this coding instead: 04000401040500000000100A
Keep in mind that you may need to reboot the RNS and/or lock the car doors for a short period of time so the CAN Gateway refreshes to rule out false conflicts.​
I wouldn't be concerned about that Tuner for Satellite Radio fault but the ignition switch faults may be something if those aren't the end result of address 16 coding modifications or this retrofit. Did you tweak the coding in that #16 module at any point in time?
MikeLyons27
United States
C?ID=104983
Dana, Steeldrivinman,
Thanks for the replies. I tried the coding, and rebooted the system the other day, and still no luck.
I decided to just remove the Bluetooth module, and use the internal Bluetooth on the radio. And it is working as it should! No more disconnecting! It displays the Song info, and I am able to skip tracks now! I had to rewire the microphone though. I purchased a repair wire (http://www.ebay.com/itm/400659060362) Cut the wire in half, and I wired pin 11 and 12 from the Bluetooth harness to pins 1 and 2 on the back of the Headunit, and the microphone works perfect!
I guess the 7P6 035 730 C module isnt fully compatible with the RNS-315 unit. The internal Bluetooth works so much better than the external module.
I hope this post helps someone in the future.
tos
C?ID=89390
I just retrofit the bluetooth module to my Yeti.
I also cant skip tracks from spotify...
And no song information on mfa.
Microphone sound quality is poor. Is there some kind of tricks for coding?
I changed the sensitivy adaptation to 4db.
What are "audio parameter sets" in byte 2?
index.php
Thanks from Finland !
Sunday,02,July,2017,13:45:33:64262VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.1.3.0
VIN: TMBLD95L7B6050077   License Plate: YETI4
Mileage: 168020km-104402mi   Repair Order:
Chassis Type: 5L (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 22 25 42 44 46 52 55 56 62
          69 72 77
VIN: TMBLD95L7B6050077   Mileage: 168020km-104402miles
Address 01: Engine (J623-CFHC)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 DB    HW: 03L 906 018 BR
   Component: R4 2,0L EDC   H23 7098
   Revision: 42H23---    Serial number:
   Coding: 001D001A043600080000
   ASAM Dataset: EV_ECM20TDI01103L906018DB 003004
   ROD: EV_ECM20TDI01103L906018DB.rod
   VCID: 6DDA3F44BC6AF82932-8038
   Part No SW: 02E 300 013 L    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2601
   Revision: 05351112    Serial number: 00001102231030
   Shop #: WSC 33361 790 00999
   VCID: 1A302498D564BF9107-804E
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 913F400E092701FA890B02EB9020804A350000
   VCID: 76E81028C13C3BF1C3-8022
   Part No SW: 3T0 907 044 BG    HW: 3T0 907 044 BG
   Component: Climatronic   H16 0402
   Revision: 00006001
   Coding: 0000000002
   VCID: 78F41E10C3284D81D1-802C
   Part No SW: 1K0 937 086 H    HW: 1K0 937 086 H
   Component: BCM PQ35  M   103 0615
   Revision: 00103 AD
   Coding: 40000AB8E01328C040080080100089E4477C00AE722DA5605C8560200040
   VCID: 356AD7249CBA70E90A-8060
   Subsystem 1 - Part No: 5L1 955 119 A  Labels: 1KX-955-119.CLB
   Component: SK356  26  0604
   Coding: 00F795
   Component: RLS 100311 05  54  0403
   Coding: 0714ED
Address 10: Park/Steer Assist (J446)       Labels: 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32901106900226
   Coding: 110113
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000.rod
   VCID: 336EE93C9ACE6ED924-8066
   Part No SW: 5C0 959 655 D    HW: 5C0 959 655 D
   Component: AirbagVW10G   013 0613
   Serial number: 003G7RA00V6E
   Coding: 00005431
   Serial number: 3572MSME2D72335DZZZ+
   Serial number: 3582MSME5E08345DZZZ3
   Serial number: 3512QSME7434072BZZZT
   Serial number: 3522QSME6818072BZZZZ
   Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
   Revision: FF010040    Serial number: 20110309300751
   Coding: 188A140000
   ROD: EV_SMLSNGVOLWSXS.rod
   VCID: 7EF80808E10C73B19B-802A
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 800000
   Part No SW: 5L0 920 840 H    HW: 5L0 920 840 H
   Component: KOMBI         H21 0420
   Coding: 120E01
   VCID: 3064E6306BD855C159-8064
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 A
   Component: Standheizer     043 4730
   Revision: 00043000    Serial number: 09022127000000
   Coding: 0030012
   VCID: 336EE93C52CE6ED924-8066
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 120311F2000551
   Coding: 356302
   VCID: 3064E63063D855C159-8064
   Part No SW: 0BR 907 554 B    HW: 0BR 907 554 B
   Component: Haldex 4Motion      3017
   Coding: 0000005
   VCID: 448CBAE00760D9618D-8010
   Component: IMMO          H21 0420
   VCID: 6AD034588D84EF1157-803E
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
   Part No SW: 7N0 959 793 E    HW: 7N0 959 793 A
   Component: TSG FA        H04 0400
   Revision:             Serial number: 0000012258695
   Coding: 011502208000231003
   VCID: 448CBAE0C760D9618D-8010
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 71     3201
   Revision: 00H20000
   VCID: 346CEA2057C069E13D-8060
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
   Part No SW: 7N0 959 792 E    HW: 7N0 959 792 A
   Component: TSG BF        H04 0400
   Revision:             Serial number: 0000012357207
   Coding: 011500208000231003
   VCID: 438EB9FCC26EDE59B4-8016
   Coding: 3703835
   Subsystem 1 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0008
   Coding: 00000056
   Subsystem 2 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0008
   Coding: 00000056
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 161 N    HW: 1Z0 035 161 N
   Component: Radio-SWING   012 0036
   Revision: -----16S    Serial number: SKZ4Z2L1168315
   Coding: 0D0004030003
   VCID: 3972DB14B0A29489EE-806C
Address 62: Door, Rear Left (J388)       Labels: 7N0-959-795.clb
   Part No SW: 7N0 959 795 D    HW: 7N0 959 795
   Component: TSG HL        H03 0400
   Revision:             Serial number: 0000012383762
   Coding: 010000200000531003
   VCID: 458AA7E4CC5AE0699A-8010
Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
   Revision: 3A001001    Serial number: 00000144335952
   Coding: 410D000100000000
Address 72: Door, Rear Right (J389)       Labels: 7N0-959-795.clb
   Component: TSG HR        H03 0400
   Revision:             Serial number: 0000012365379
   Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
   Component: TELEFON       H16 4217
   Revision: 1B001001    Serial number: 00007666972907
   Coding: 0201030000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3C7CC200B790A1A1F5-8068
End-------------------------(Elapsed Time: 03:37)--------------------------
tos
C?ID=89390
The reason for why I cant skip tracks is the radio Swing (vw rcd310).
I will need rns510/rcd510.
But I still need help for coding telephone...
Because the microphone sound is bad (driving noise etc)
index.php
Dana
Western PA, USA
In my opinion the road noise through a factory installed Mk6 chassis microphone and telephone system is terrible. We had a 2010 GTI (with sunroof) and still have a 2012 Tiggy (with the large pana roof) and both of those vehicles are terrible to be on the landline side of when speaking to my husband while he's driving. It sounds like he's operating aircraft rather than a 2.0T VW Golf based car!
I haven't messed much with Audio parameters but I recall some of those coding attempts being rejected by the module. You can certainly experiment to see if any changes are accepted but the only TPI I found when searching for Audio parameter was one specific to MIB Audi systems. That TPI that mentioned High-frequency or Buzzing noises when phoning - not microphone concerns.
Hopefully someone else has additional parameter info but I don't see anything wrong with the coding of 77.
This was the factory condition module in my 2012 Tiguan
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660091672
Coding: 0A11040000010100
Shop #: WSC 25807 444 28888
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA_VW36.rod
Factory condition Adp map from a very old version:
;SW:7P6-035-730-F   HW:7P6-035-730-F ---  Telephone
;Component:TELEFON       H09 2902	 Coding:0A11040000010100
;EV_UHVNA	A01719	EV_UHVNA_VW36.rod
;Tuesday	28	August	2012	08:41:56:03064
;VCDS Version: Release 11.11.4  Data version: Unknown
;VCID: 356A218D944A8EB0C23
Developer mode	not activated
Bluetooth acknowledgement signal	OFF
Base volume of speech output	7.15256e-007 dB
Base volume of telephone	0 dB
Microphone sensitivity	0 dB
Emergency telephone number	00 00 00 00 00 00 00
Reference channel delay	0 ms
Delay of audio output	0.0 s
(1)-Masking of Languages-Mask Byte 0/Bit0 Language - German	valid
(2)-Masking of Languages-Mask Byte 0/Bit1 Language - English	valid
(3)-Masking of Languages-Mask Byte 0/Bit2 Language - French	invalid
(4)-Masking of Languages-Mask Byte 0/Bit3 Language - Italian	valid
(5)-Masking of Languages-Mask Byte 0/Bit4 Language - Spanish	invalid
(6)-Masking of Languages-Mask Byte 0/Bit5 Language - Portuguese	valid
(7)-Masking of Languages-Mask Byte 0/Bit6 Language - Czech	valid
(8)-Masking of Languages-Mask Byte 0/Bit7 Language - Russian	valid
(9)-Masking of Languages-Mask Byte 1/Bit0 Language - US-English	valid
(10)-Masking of Languages-Mask Byte 1/Bit1 Language - French-Canadian	valid
(11)-Masking of Languages-Mask Byte 1/Bit2 Language - US-Spanish	valid
(12)-Masking of Languages-Mask Byte 1/Bit3 Language - Dutch	valid
(13)-Masking of Languages-Mask Byte 1/Bit4 Language - Swedish	valid
(14)-Masking of Languages-Mask Byte 1/Bit5 Language - Polish	valid
(15)-Masking of Languages-Mask Byte 1/Bit6 Language - Norwegian	valid
(16)-Masking of Languages-Mask Byte 1/Bit7 Language - Turkish	valid
Name of universal cell phone package (UHV)	VW PHON
User profiles	not erased
Setting Bluetooth PIN	00 00
Media playback volume	0 dB
CDMA Detection	activated
Number 1 for Info call	00 00 00 00 00 00 00
Number 1 for roadside assistance	00 00 00 00 00 00 00
Number 2 for Info call	00 00 00 00 00 00 00
Number 2 for roadside assistance	00 00 00 00 00 00 00
tos
C?ID=89390
Thank You Dana!
Here comes my adaptation map:
It will not show all... german things missing.
;SW:7P6-035-730-M   HW:7P6-035-730-M ---  Telephone;Component:TELEFON       H16 4217, Coding:0201030000010110
;EV_UHVNA,002720,EV_UHVNA_002.rod
;Thursday,13,July,2017,19:32:18:64262
;VCDS Version: Release 17.1.3  Data version: 20170320 DS267.7
;VCID: 3C7CC200B790A1A1F5-8068
IDE00689-Name of universal cell phone package (UHV),YETI PHONE
IDE00758-Base volume of telephone,0 dB
IDE00759-Base volume of speech output,7.15256e-007 dB
IDE00760-Microphone sensitivity,4 dB
IDE00762-Setting Bluetooth PIN,00 00
IDE00764-User profiles,not erased
IDE00765-Delay of audio output,0.0 s
IDE00766-Reference channel delay,0 ms
IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00
IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00
IDE00771-Media playback volume,0 dB
IDE02122-Developer mode,not activated
IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00
IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00
IDE02504-Bluetooth acknowledgement signal,OFF
IDE03481-Emergency telephone number,00 00 00 00 00 00 00 00 00
ENG113809-CDMA Detection,not activated
ENG107578-ENG103154-Masking of Languages-Mask Byte 0/Bit0 Language - German,valid
ENG107578-ENG100316-Masking of Languages-Mask Byte 0/Bit1 Language - English,valid
ENG107578-ENG103726-Masking of Languages-Mask Byte 0/Bit2 Language - French,valid
ENG107578-ENG103477-Masking of Languages-Mask Byte 0/Bit3 Language - Italian,valid
ENG107578-ENG102676-Masking of Languages-Mask Byte 0/Bit4 Language - Spanish,valid
ENG107578-ENG100258-Masking of Languages-Mask Byte 0/Bit5 Language - Portuguese,valid
ENG107578-ENG99657-Masking of Languages-Mask Byte 0/Bit6 Language - Czech,valid
ENG107578-ENG100762-Masking of Languages-Mask Byte 0/Bit7 Language - Russian,valid
ENG107578-ENG103078-Masking of Languages-Mask Byte 1/Bit0 Language - US-English,valid
ENG107578-ENG99208-Masking of Languages-Mask Byte 1/Bit1 Language - French-Canadian,invalid
ENG107578-ENG99771-Masking of Languages-Mask Byte 1/Bit2 Language - US-Spanish,invalid
ENG107578-ENG99829-Masking of Languages-Mask Byte 1/Bit3 Language - Dutch,valid
ENG107578-ENG111964-Masking of Languages-Mask Byte 1/Bit4 Language - Swedish,valid
ENG107578-ENG111965-Masking of Languages-Mask Byte 1/Bit5 Language - Polish,valid
ENG107578-ENG111966-Masking of Languages-Mask Byte 1/Bit6 Language - Norwegian,valid
ENG107578-ENG111967-Masking of Languages-Mask Byte 1/Bit7 Language - Turkish,valid
Elapsed Time: 00:08
