Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
Thread: 2012 VW Passat Adblue reset
    Mar 2014
    Posting this up, hoping someone can help out, i have a 2012 passat the low adblue indicator is on and will not go off despite filling tank to the top.
    The first thing that i was informed to try was to leave the key on for 30 sec to a min in the on position without starting, then turn to the off position for the same time period. Then start the car to see if the light goes off. As of yet no luck.
    Other things i have tried with the vagcom is to go to engine, basic settings, reset the scr lock and Resetting of SCR tank level detection? The first time i have done this it works without error, but the light remains, the next time i try it again without logging completely out, i get the error of "Service not supported in active session". So i log all the way out of vcds and am able to run again with the same results, ie successful, "Finished Correctly End system ok", but the light remains, 20 miles till no engine start.
    I also tried the output tests on pump for reducing agents, the message i get is "Aborted for safety reasons"
    Anyone have any ideas on how to get the light to go away or to reset the no restart portion, car was run low with adblue then sitting for winter. Do i need to prime the system somehow, disconnect the battery or ?
    Thanks in advance
    Are there any fault codes?
    Please post up an Auto-Scan.
  3. Likes roth liked this post
    Mar 2014
    codes
    does this one have anything to do with it? i have other codes that are not related ie tpms, bulbs out etc, this is all im seeing that may be something?
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    00484 - Vehicle Position Recognition Control Module (J603)
    Reset counter: 153
    Mileage: 45989 km
    Date: 2015.01.27
    Time: 21:21:28
    Near Philadelphia, PA, USA
    Quote Originally Posted by iltdi View Post
    Hard to say... you have not posted the Autoscan requested. Please do so. If you do not know how, please read the thread linked in Uwe's message. An Autoscan gives us details about the car which we can not divine through the ether of the interwebs without your help.
  6. Likes Uwe, jyoung8607, roth liked this post
    Mar 2014
    Chassis Type: A3 (7N0)
    Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
    VIN: 1VWBN7A37CCxxxxxx   Mileage: 46000km-28583miles
    03-ABS Brakes -- Status: Malfunction 0010 tpms as i have aftermarket wheels need to disable
    09-Cent. Elect. -- Status: Malfunction 0010 bulbs ie recall and led lights?
    15-Airbags -- Status: Malfunction 0010 aware of this
    1C-Position Sensing -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CKRA)       Labels: 03L-906-012-CKR.clb
       Part No SW: 03L 906 012     HW: 03L 907 309 S
       Component: R4 2,0L EDC   H21 2157
       Revision: 71H21---    Serial number:
       Coding: 00190012042400000000
       Shop #: WSC 09003 957 00200
       ASAM Dataset: EV_ECM20TDI01103L906012 004009
       ROD: EV_ECM20TDI01103L906012.rod
       VCID: 61C9722070FB4429011-8034
       Revision: 00H31001
       Coding: C54BC0F549290003A31303E5921A0042A71000
       VCID: 7DF12E50E44380C9059-8028
                        Reset counter: 196
                        Mileage: 45989 km
                        Date: 2015.01.27
                        Time: 21:21:23
                        Count: 2
                        Count: 2
                        Count: 20480
                        Count: 16390
                        Count: 43264
                        Count: 512
    02214 - Tire Pressure Warning
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 154
                        Mileage: 45989 km
                        Date: 2015.01.29
                        Time: 19:31:49
                        Count: 4608
                        Count: 16401
                        Count: 51200
                        Count: 12056
                        Count: 2053
       Part No SW: 561 907 044 H    HW: 561 907 044 H
       Component: Climatronic   043 0202
       Revision: 00001001
       Coding: 0010001002
       ROD: EV_ACClimaBHBVW411_VW41.rod
       VCID: 1C3703D4171929C1927-8049
       Part No SW: 5K0 937 085 S    HW: 5K0 937 085 S
       Component: BCM PQ35 B+   021 0064
       Revision: BH021001
       Coding: 6F200EB8902908D408880001160004480071008650A00560648040000C70
       VCID: 438598A8C227363933D-8016
       Component: RLS 210312 05  54  0403
       Coding: 22300A
                        Reset counter: 196
                        Mileage: 46007 km
                        Date: 2015.02.16
                        Time: 00:11:21
                            Term 15 Off
                        Voltage: 8.50 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 153
                        Mileage: 45989 km
                        Date: 2015.01.27
                        Time: 23:42:21
                        Voltage: 13.80 V
                        Reset counter: 153
                        Mileage: 45989 km
                        Date: 2015.01.27
                        Time: 23:42:21
                        Voltage: 13.95 V
                        Reset counter: 153
                        Mileage: 45989 km
                        Date: 2015.01.27
                        Time: 23:42:25
                        Voltage: 14.20 V
    01339 - Door Warning Light
                        Reset counter: 153
                        Mileage: 45989 km
                        Date: 2015.01.27
                        Time: 21:21:26
                        Voltage: 12.10 V
       Part No SW: 5C0 959 655     HW: 5C0 959 655
       Component: AirbagVW10G   013 0809
       Serial number: 003ENM024E0$
       Coding: 00003548
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
       VCID: 6FED0418B62FE259875-803A
       Serial number: 3572MSME05356369ZZZU
       Serial number: 3582MSME6227106AZZZS
       Serial number: 3516KSME57562D17ZZZZ
       Serial number: 3526KSME6019271AZZZQ
       Subsystem 5 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
       Serial number: 3556LSME421F2515ZZZT
       Serial number: 3566LSME0A012515ZZZJ
              B1007 1B [137] - Resistance Too High
                        Mileage: 45989 km
                        Date: 2015.01.27
                        Time: 21:21:24
    9442331 - Passenger's Belt Force Limiter Igniter
              B1014 1B [137] - Resistance Too High
                        Mileage: 45989 km
                        Date: 2015.01.27
                        Time: 21:21:25
    9441051 - Front passenger's safety belt tensioner igniter 2
              B100F 1B [137] - Resistance Too High
                        Mileage: 45989 km
                        Date: 2015.01.27
                        Time: 21:21:25
    9445937 - Seat occupied recognition control module
              B1022 31 [137] - No Signal
                        Reset counter: 153
                        Mileage: 45989 km
                        Date: 2015.01.27
                        Time: 21:21:26
       Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
       Revision: FF010040    Serial number: 20120127101640
       Coding: 008A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 76E3317CC975D391443-8023
       Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
       Component: E221__MFL-YVJ  H06 0022
       Coding: E20000
       Part No SW: 561 920 970 C    HW: 561 920 970 C
       Component: KOMBI         H07 0507
       Coding: 231C00
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
       VCID: 1A3B05CC1D2D57F180B-804F
       Part No SW: 7N0 907 530 P    HW: 1K0 907 951
       Component: J533  Gateway H40 1623
       Revision:   H40       Serial number: 31031201290081
       Coding: 461000
       VCID: 3D71EE50A4C340C9459-8068
                        Reset counter: 153
                        Mileage: 45989 km
                        Date: 2015.01.27
                        Time: 21:21:28
    Address 1C: Position Sensing
       Component: IMMO          H07 0507
       VCID: 6ADB150C8DCD0771D0B-803F
       Component: TUER-SG FT    002 0525
       Revision: 13110009    Serial number: 0004093713
       Coding: 0404F5
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 5BB540C852976EF95BD-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  004 4472
       Coding: 800000
    67584 - Warning Light for Front Door
              B11F5 01 [009] - Electrical Failure
                        Fault Frequency: 12
                        Reset counter: 156
                        Mileage: 45989 km
                        Date: 2015.01.27
                        Time: 21:21:22
    131584 - Motor for Rear Window Regulator
              B11EE 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 153
                        Mileage: 45989 km
                        Date: 2015.01.27
                        Time: 21:21:22
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 290    3305
       Revision: 00H22000
       VCID: 377DFC7846FF6A999F5-8062
       Component: EZE_2         H40 1623
       Coding: 00000008
       VCID: 6FED0418BE2FE259875-803A
       Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0004
       Component: TUER-SG BT    002 0525
       Revision: 15110009    Serial number: 0004255251
       Coding: 0404F4
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 5CB743D4579969C1527-8009
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  004 4472
       Coding: 800000
                        Reset counter: 154
                        Reset counter: 153
                        Mileage: 45989 km
                        Date: 2015.01.27
                        Time: 21:21:22
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
       Component: Radio Prem-8  H02 0016
       Revision: -----16S    Serial number: VWZ4Z7M3274251
       Coding: 0500040004000B
       VCID: 63C5782862E7563913D-8036
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007661964617
       Coding: 0A10040000010110
       ASAM Dataset: EV_UHVNA A01719
       ROD: EV_UHVNA.rod
       VCID: 275D2C385E5FFA190F5-8072
    End-------------------------(Elapsed Time: 02:36)--------------------------
  8. Likes roth liked this post
  9. #6
    That's just the Gateway Installation List, not a complete Auto-Scan.
  10. #7
    Verified VCDS User roth's Avatar
    Feb 2015
    My friend,
    Watch this
    BR, Andy
  11. #8
    OK, he fixed it. I need to poke around in what we know about this engine this afternoon.
  12. #9
    Feb 2015
    It supposed to reset itself. Light comes on, add AdBlue, light supposed go out by itself after a short time.
    Andy
  13. #10
    Quote Originally Posted by roth View Post
    Yes, I agree. That's why I was adamant about seeing an Auto-Scan, to see if there were any fault codes related to the reductant system. We had a guy with a ~2009 Touareg not that long ago who thought VCDS didn't work right because it couldn't reset his AdBlue light and mileage counter. Of course, there were actual problems with his AdBlue injection system. Unfortunately, this car doesn't seem to have any such fault codes. So the next thing to do is to start poking around the measuring values. After lunch, I plan to do some digging to see what values might be useful to look at. I will also have access to a 2013 NMS TDI next week.
  14. Likes Jack@European_Parts liked this post
