- Mar 6, 2014
- 16
- 2
- C?ID=192198
Posting this up, hoping someone can help out, i have a 2012 passat the low adblue indicator is on and will not go off despite filling tank to the top.
The first thing that i was informed to try was to leave the key on for 30 sec to a min in the on position without starting, then turn to the off position for the same time period. Then start the car to see if the light goes off. As of yet no luck.
Other things i have tried with the vagcom is to go to engine, basic settings, reset the scr lock and Resetting of SCR tank level detection? The first time i have done this it works without error, but the light remains, the next time i try it again without logging completely out, i get the error of "Service not supported in active session". So i log all the way out of vcds and am able to run again with the same results, ie successful, "Finished Correctly End system ok", but the light remains, 20 miles till no engine start.
I also tried the output tests on pump for reducing agents, the message i get is "Aborted for safety reasons"
Anyone have any ideas on how to get the light to go away or to reset the no restart portion, car was run low with adblue then sitting for winter. Do i need to prime the system somehow, disconnect the battery or ?
Thanks in advance
Thanks in advance
