Hi guys
Well today turned out better, checked steering assist module and found no power getting to module, so I started checking fuses again (with a multimeter this time) and found a blown 1, couldnt see it with the naked eye... it was a 5a fuse which powered:
traction control switch
tcs esp button
Brake light switch
Brake light relay
control unit
Power steering control unit
left/right headlight range control motor
headlight control regulator
Thought a 5a fuse was a little small for all these?
I also changed byte 18 in 09 back to factory 00, from the 74 that kufatec told me to put in. what exactly does byte 18 do in 09 central electrics? not sure weather its made any difference at all..
And the nasty rattle coming from the engine was the "chip express" unit blown a fuse, removed the unit and all is good
I do have a couple off coding queries if anybody can help please..
when the lights are on sidelights just the DRL LED's are on, nothing else, is there sidelights in the bixenon? I have a bulb error light on the dash but says its licence plate bulbs, which are error free LED bulbs, do I need some other licence plate light bulbs now? also when I turn a corner the headlights follow round the bend but there is another light that also comes on, shining a light further round the bend, is this a function of the lights or can it be turned off?
Thank You guys for all your help and advice with the bixenons retrofit, I could have not completed it without you guys
I'll hopfully sleep better tonight...
Wayne, todays autoscan
Thursday,02,April,2015,20:34:09:28228
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: WV1ZZZ2KZCX031974 License Plate: RY10 MAK
Mileage: 29150km-18112mi Repair Order:
Chassis Type: 2K (7N0)
Scan: 01 03 09 15 16 17 19 25 37 42 44 46 52 55 56 77
VIN: WV1ZZZ2KZCX031974 Mileage: 29150km-18112miles
77-Telephone -- Status: Not registered 0011
Address 01: Engine (J623-CFHC) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 NF HW: 03L 907 309 R
Component: R4 2,0L EDC H25 0660
Revision: 42H25--- Serial number: 00000000000000
Coding: 00190010042500080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM20TDI01103L906018NF 003001
ROD: EV_ECM20TDI01103L906018NF.rod
VCID: 7BF5D657F28B24F93BD-802E
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BH HW: 1K0 907 379 BH
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 433C400D092503FBC21402EB901DC082300000
Shop #: WSC 35110 377 08192
VCID: 79F9CC5FF0B716E9291-802C
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AC HW: 5K0 937 087 AC
Component: BCM PQ35 H+ 122 0174
Revision: BF122001
Coding: 411A0A3AC025186A08400080950010E80374000852210160E48000000048
Shop #: WSC 18752 008 00032
VCID: 76E3C763C1A97991443-8023
Subsystem 1 - Part No: 1T2 955 119 A
Component: Wischer 19071 26 0512
Coding: 009795
Component: RLS 201211 05 54 0403
Coding: 0730ED
Fault Status: 00101010
Reset counter: 11
Mileage: 29155 km
Date: 2015.04.02
Time: 08:54:56
Voltage: 13.75 V
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag00U H06 0013
Revision: -------- Serial number: 003HL006USR3
Coding: 000000000000000000000000000000003055
ROD: EV_AirbaVW10BPAVN750_SK12.rod
VCID: 3561006F942F32898D9-8060
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422LEI000OH
Coding: 1082140000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 72EBFB73A5C165B168B-8027
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0090713
Coding: 820000
Part No SW: 1T0 920 985 C HW: 1T0 920 985 C
Component: KOMBI H05 0505
Coding: 780800
Shop #: WSC 01342 020 12345
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 39790C5FB837D6E9691-806C
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 220711F1000133
Coding: 357401
VCID: 3561006F9C2F32898D9-8060
Fault Frequency: 28
Mileage: 29155 km
Date: 2015.04.02
Time: 07:53:11
Component: IMMO H05 0505
VCID: 6ADBE3138D11AD71D0B-803F
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 686 D HW: 1T0 035 686 D
Component: RNS-MID H10 5270
Revision: AB001001 Serial number: VWZ6Z7N5262015
Coding: 06000242040000A10000
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V11 8117
00857 - CD Changer Unit (R41)
Fault Frequency: 16
Reset counter: 226
Mileage: 29152 km
Fault Frequency: 10
Reset counter: 226
Mileage: 29152 km
Fault Frequency: 10
Reset counter: 226
Mileage: 29152 km
00856 - Radio Antenna
Fault Frequency: 13
Reset counter: 226
Mileage: 29152 km
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0000626
VCID: 489F799B3BDDBF61E6F-801D
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 140 3201
Revision: 00H20000
VCID: 34673D6B57552B81BA7-8061
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000626
VCID: 479D7AA736C3B019EF5-8012
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 090200000F000200
ROD: EV_HeadlRegulVWAFSPt_SE36.rod
VCID: 377D0A678E23C0999F5-8062
Subsystem 1 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A
Component: LeiMo links H06 0007
Coding: 320000
Subsystem 2 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A
Component: LeiMo rechts H06 0007
Coding: 320000
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Fault Frequency: 17
Reset counter: 226
Mileage: 29152 km
Fault Frequency: 10
Reset counter: 226
Mileage: 29152 km
Fault Frequency: 10
Reset counter: 226
Mileage: 29152 km
Fault Frequency: 13
Reset counter: 226
Mileage: 29152 km
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663383815
Coding: 0A10000100010101
Shop #: WSC 00028 028 00022
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
9457171 - Right audio channel for speech/telephone
B104E 13 [009] - Short to GND
Reset counter: 226
Mileage: 29155 km
Date: 2015.04.02
Time: 07:51:36
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Reset counter: 226
Mileage: 29155 km
Date: 2015.04.02
Time: 07:51:36
End-------------------------(Elapsed Time: 02:25)--------------------------
