2007 Passat (3C) ABS Module coding
colly
N Ireland
C?ID=30555
Hi guys,
I’ve scanned a 2007 Passat (3C), where I believe the ABS module coding has gotten reset to 0010000 as in the following post.
http://forums.ross-tech.com/showthread.php?1980-2007-Passat-ABS-module-coding
I’ve attached an autoscan and was wondering if you would be able to let me know the correct coding?
Thanks,
Colm
I've sent this to the support email as well..apologies if I'm doubling up.
VCDS Version: Release 14.10.1 (x64)
Data version: 20150130
Wednesday,11,March,2015,11:12:36:25238
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ7E121336   Mileage: 195310km-121360miles
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 AS    HW: 03G 906 018 AS
   Component: R4 2.0l PPD1.2 G    9971
   Revision: --H32---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 00688 210 89628
   VCID: 76E8656001A5AB9144C-8023
005714 - Please check DTC Memory of Transmission Controller
               P1652 - 008 -  - Intermittent
                    Fault Frequency: 17
                    Reset counter: 40
                    Mileage: 195308 km
                    Time: 13:33:32
                    RPM: 800 /min
                    Torque: 64.0 Nm
                        0.00 %
                    Voltage: 12.20 V
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
               P1653 - 008 -
                    Fault Status: 11101000
                    Reset counter: 40
                    Mileage: 195308 km
                    Time: 13:33:32
                    RPM: 800 /min
                    Torque: 64.0 Nm
                        0.00 %
                    Voltage: 13.67 V
                    Bin. Bits: 00000100
                    Torque: 168.0 Nm
012295 - Camshaft Position Sensor (G40)
               P3007 - 006 - No Signal - Intermittent
                    Fault Status: 00100001
                    Reset counter: 40
                    Mileage: 195309 km
                    Time: 00:19:00
                    RPM: 800 /min
                    Torque: 48.0 Nm
                    Speed: 60.0 km/h
                    Bin. Bits: 11111111
                    (no units): 8.0
                    (no units): 92.0
                    Time: 0.01 s
000833 - Camshaft Position Sensor (G40)
               P0341 - 006 - Implausible Signal - Intermittent
                    Reset counter: 38
                    Mileage: 195309 km
                    Time: 01:34:18
                    RPM: 416 /min
                    Torque: 112.0 Nm
                    (no units): 0.0
                    Steering Angle: 0.00*
                    Angle: 0.0 *
                    (no units): 1.0
Readiness: N/A
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 043 S    HW: 02E 927 770 AD
   Component: GSG DSG         082 1302
   Revision: 04808020    Serial number: 00000812050147
   Shop #: WSC 00581 210 83422
   VCID: 244C6F28E7B969012A8-8071
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 109 A    HW: 3C0 614 109 A
   Component: ESP 440 C4     H018 0001
   Revision:  H018       Serial number: 0668105311
   Coding: 0010000
   Shop #: WSC 05311 000 00000
   VCID: 1C3C57C8DFC951C1928-8049
            000 -  -
                    Reset counter: 124
                    Mileage: 195318 km
                    Time: 11:05:36
                    Reset counter: 124
                    Mileage: 195318 km
                    Time: 11:05:36
                    Reset counter: 124
                    Mileage: 195318 km
                    Time: 11:05:36
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AH    HW: 3C0 907 044 AH
   Component: ClimatronicPQ46 050 0505
   Revision: 00050005    Serial number: 00000000000000
   VCID: 67D63824560F4219CFA-8032
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Revision: 00H52000    Serial number: 00000006328295
   Coding: A1898F211004100000120C000000000000087F075C0000
   Shop #: WSC 00908 210 178902
   VCID: 6CDC47084FE96141A28-8039
   Subsystem 1 - Part No: 3C2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00063445
   Shop #: WSC 00908
00834 - Signal for Activation of Heated Rear Window
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 125
                    Mileage: 195318 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.30 V
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 0C AIRBAG VW8   031 2522
   Revision: 11031000    Serial number: 003B1PMHRU29
   Coding: 0012355
   VCID: 30649378A341C5A1DE0-8065
   Subsystem 1 - Serial number: 6332MSME1321631C
   Subsystem 2 - Serial number: 6342MSME14194D4C
   Subsystem 3 - Serial number: 6351HTS66HBG4Q27
   Subsystem 4 - Serial number: 6361HTS66HB8LMT6
   Part No SW: 3C0 953 549 J    HW: 3C0 953 549 J
   Component: Lenksäulenmodul 006 0010
   Revision: 00006000    Serial number: 3C9953507AC
   Coding: 0001014
   VCID: 336E9C745257FEB9A32-8066
   Part No SW: 3C0 920 960 K    HW: 3C0 920 960 K
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: X0006000    Serial number: 00000000000000
   Coding: 0007405
   Shop #: WSC 65536 645 369769
   VCID: 2B5E84148A67A679EB2-807E
   Coding: 0007405
Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
   Revision: 00007000    Serial number: 0700C06A26051F
   Coding: 3FFD0C04C22003
   VCID: 2142663CF8AB7C2941E-8074
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Shop #: WSC 00688 210 83442
   VCID: 3972AE5C703B04E969E-806C
   Component: J386  TUER-SG FT    1124
   Revision: 32008001    Serial number: 00000017469017
   Coding: 0000693
   VCID: 3B7EB4547A0736F97B2-806E
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.136 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 356AA26C5C23E0898D6-8060
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 042 0472
   Coding: 0191020051030E763004941570085FCE1078A0
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Part No: 3C0 951 171 A
   Component: Neigungssensor  002 0508
   Subsystem 3 - Part No: 3C0 951 171 A
   Component: Innenraumueberw.002 0508
01134 - Alarm Horn (H12)
                    Reset counter: 125
                    Mileage: 195318 km
                    Time: 11:10:18
   Component: J387  TUER-SG BT    1124
   Revision: 32008001    Serial number: 00000118769015
   Coding: 0000692
   VCID: 3C7CB7487F0931C1728-8069
   Part No SW: 3C0 907 801 G    HW: 3C0 907 801 G
   Component: EPB  VD8HC005   013 0005
   Revision:   013
   Coding: 0010000
   Shop #: WSC 00688 210 87565
   VCID: 2648752091859B1134C-8073
01316 - ABS Control Module
                    Fault Status: 11101101
                    Reset counter: 125
                    Mileage: 195304 km
                    Time: 11:55:02
                    Voltage: 10.56 V
                    Count: 236
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 15
                    Reset counter: 121
                    Voltage: 11.18 V
                    Count: 171
            000 -  -  - MIL ON
                    Fault Frequency: 15
                    Reset counter: 121
                    Voltage: 11.18 V
                    Count: 170
   Part No: 1K0 035 186 T
   Component: Radio GR0       020 0023
   Revision: 0002006S    Serial number: VWZ2Z2F1104258
   Coding: 0040402
   VCID: 3776A864462F12999FA-8062
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1114
   Revision: 11005001    Serial number: 00000000807938
   Coding: 0000144
   VCID: 3D7ABA4C641338C9456-8068
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1114
   Revision: 11005001    Serial number: 00000000826885
   Coding: 0000144
   VCID: 3E78BD40691523D15CC-806B
End-------------------------(Elapsed Time: 01:46)--------------------------
This is a different car than in the last thread, right? The VINs are certainly different..
Edit: Yeah, different person too. It's early. I need more coffee. :facepalm:
Jef
HQ
Please try 0013629 for the ABS coding.
colly
N Ireland
C?ID=30555
Thanks guys. I'll give that a try tomorrow and will let you know - I'm away for the weekend.
colly
N Ireland
C?ID=30555
Tried that and am getting the results below. Perhaps it's the right coding and I need to perform something else.
Sunday,15,March,2015,15:24:27:25238
VIN: WVWZZZ3CZ7E121336   Mileage: 195370km-121397miles
   Coding: 0000078
               P1652 - 008 -
                    Fault Status: 01101000
                    Fault Frequency: 66
                    Reset counter: 40
                    Mileage: 195318 km
                    Time: 11:17:24
                    RPM: 800 /min
                    Torque: 40.0 Nm
                        0.00 %
                    Voltage: 13.79 V
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
               P1653 - 008 -
                    Reset counter: 40
                    Mileage: 195318 km
                    Time: 11:17:24
                    RPM: 800 /min
                    Torque: 40.0 Nm
                        0.00 %
                    Voltage: 14.13 V
                    Bin. Bits: 00000100
                    Torque: 168.0 Nm
                    Fault Frequency: 8
                    Reset counter: 40
                    Mileage: 195318 km
                    Time: 11:17:25
                    RPM: 800 /min
                    Torque: 40.0 Nm
                    Bin. Bits: 11111111
                    (no units): 8.0
                    (no units): 45.0
                    Time: 0.00 s
                    Fault Frequency: 27
                    Reset counter: 39
                    Mileage: 195318 km
                    Time: 14:08:02
                    RPM: 416 /min
                    Torque: 104.0 Nm
                    (no units): 0.0
                    Angle: 0.0 *
                    (no units): 1.0
Readiness: N/A
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -
                    Fault Frequency: 255
                    Reset counter: 1
                    Mileage: 195379 km
   Coding: 0013629
   Coding: E0898F211004100000120C000000000000087F075C0000
   Coding: 00063445
   Shop #: WSC 00908
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     261006 014  1201
   Coding: 00208933
   Shop #: WSC 00908
                    Reset counter: 138
                    Mileage: 195379 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.80 V
   Coding: 0012355
   Coding: 0001014
   Coding: 0007405
   Coding: 0007405
   Coding: 0000693
                    Reset counter: 138
                    Mileage: 195379 km
                    Time: 15:23:38
   Coding: 0000692
   Revision:   013
   Coding: 0000012
                    Reset counter: 138
                    Mileage: 195304 km
                    Time: 11:55:02
                    Voltage: 10.56 V
                    Count: 236
   Coding: 0040402
00857 - CD Changer Unit (R41)
   Coding: 0000144
   Coding: 0000144
Do the adaption of the sensor here.......
http://wiki.ross-tech.com/wiki/index.php/VW_Passat_(3C)_Brake_Electronics#Basic_Setting
Brake Pressure Sensor 1 (G201)
Prerequisites:
## System voltage at least 12.0 V.
[Select]
[03 - Brake Electronics]
[Measuring Blocks - 08]
Group 005
[Go!]
Check field 1, the value has to be between -8.0 and +8.0 bar.
[Done, Go Back]
[Security Access - 16]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 066
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 2 should say "OK".
[Done, Go Back]
To make sure the basic setting was succesful, check the sensor again.
Group 005
[Go!]
Check field 1, the value has to be between -3.8 and +3.8 bar.
[Done, Go Back]
[Close Controller, Go Back - 06]
